This page contains the description of the following commands
\S,
\samepage,
\@sanitize,
\savebox,
\savekeys,
\SaveVerb,
\savingdiscards,
\savinghyphcodes,
\sb,
\sbox,
\sc,
\scalebox,
\scaleput,
\scantokens,
\@scanupdown,
\scriptfont,
\scriptscriptdont,
\scriptscriptstyle,
\scriptsize,
\scriptspace,
\scriptstyle,
\scrollmode,
\scshape,
\searrow,
\sec,
\@secondoftwo,
\section,
\sectionmark,
\segment,
\selectfont,
\seriesdefault,
\setboolean,
\setbox,
\setcounter,
\@setfontsize,
\setkeys,
\setlength,
\setlanguage,
\SetMathAlphabet,
\setmathchar,
\setminus,
\@setmode,
\setrmkeys,
\@setsize,
\SetSymbolFont,
\sf,
\sfcode,
\sffamily,
\shapedefault,
\sharp,
\shipout,
\shortdownarrow,
\shortleftarrow,
\shortrightarrow,
\shortuparrow,
\shoveleft,
\shoveright,
\show,
\showbox,
\showboxbreadth,
\showboxdepth,
\showgroups,
\showhyphens,
\showifs,
\showlists,
\showoutput,
\showoverfull,
\showthe,
\showtokens,
\sideset,
\sigma,
\Sigma,
\sim,
\simeq,
\sin,
\sinh,
\sixt@@n,
\skewchar,
\skip,
\skip@,
\skipdef,
\sl,
\slash,
\sloppy,
\slshape,
\small,
\smallbreak,
\smallint,
\smallsetminus,
\smallskip,
\smallskipamount,
\smash,
\smile,
\so,
\sortnoop,
\sp,
\space,
\@spaces,
\spacefactor,
\spaceskip,
\spadesuit,
\span,
\special,
\sphericalangle,
\splitbotmark,
\splitbotmarks,
\splitdiscards,
\splitfirstmark,
\splitfirstmarks,
\splitmaxdepth,
\splittopskip,
\sqcap,
\sqcup,
\sqrt,
\sqsubset,
\sqsubseteq,
\sqsupset,
\sqsupseteq,
\square,
\SS,
\ss,
\sslash,
\st,
\stackrel,
\star,
\startdocument,
\stepcounter,
\stop,
\@stpelt,
\stretch,
\strikeout,
\string,
\strip@prefix,
\strip@pt,
\strut,
\subfigure,
\subitem,
\subparagraph,
\subparagraphmark,
\subsection,
\subsectionmark,
\subset,
\Subset,
\subseteq,
\subseteqq,
\subsetneq,
\subsetneqq,
\subsubsection,
\subsubsectionmark,
\succ,
\succapprox,
\succcurlyeq,
\succeq,
\succnapprox,
\succneqq,
\succnsim,
\succsim,
\sum,
\sup,
\supset,
\Supset,
\supseteq,
\supseteqq,
\supsetneq,
\supsetneqq,
\surd,
\swarrow,
\symbol,
\syntaxonly,
and environments
subequations,
split,
sloppypar.
The \S command translates to a section sign, §, Unicode U+A7. It is equivalent to \textsection. See description of the latin supplement characters.
Translation of \samepage is <samepage/>.
The two commands \sbox and \savebox read a box number and a box content, and fill the box. The \savebox command takes some optional arguments.
\setlength{\unitlength}{1pt} \sbox0{1A\bf b} \savebox1{2A\bf b} \savebox2(3,4){3A\bf b} \savebox3(3,4)[c]{4A\bf b} \savebox4[40pt]{5A\bf b} \savebox{5}[40pt][c]{6A\bf b} \newsavebox\Nsbox \savebox\Nsbox[40pt][c]{7A\bf b} \box0\box1\box2\box3\box4\box5\usebox\Nsbox
Translation, where bold face font is shown as BF.
<mbox>1A<BF>b</BF></mbox> <mbox>2A<BF>b</BF></mbox> <pic-framebox width='3' height='4'>3A<BF>b</BF></pic-framebox> <pic-framebox width='3' height='4' position='c'>4A<BF>b</BF></pic-framebox> <mbox width='40.0pt'>5A<BF>b</BF></mbox> <mbox width='40.0pt' position='c'>6A<BF>b</BF></mbox> <mbox width='40.0pt' position='c'>7A<BF>b</BF></mbox>
There are cases where verbatim material is forbidden. The solution consists
in reading the verbatim material and putting it in a command, then use it
later. The \SaveVerb command takes as argument a name (a sequence
of letters), and reads the verbatim material, delimited by a character of
category code 16 (defined by \DefineShortVerb). This material is
saved, and can be used by the \UseVerb command.
For an example, see catcode section
When TeX's page builder transfers material from the `recent contribution' to the `page so far', it discards discardable items preceding the first box or rule on the page. When ε-TeX's parameter \savingdiscards is positive, these discarded items are stored in a special list; the command \pagediscards reinserts these items (and clears the list). The same holds for \vsplit, the command is then \splitdiscards. Not used in Tralics.
The integer quantity \savinghyphcodes, when positive, tells ε-TeX to store the current \lccode table together with the hyphenation table of the current language. See ε-TeX documentation for why it is useful to store such a table; not used in Tralics.
The \sb command is a shorthand for an underscore character of
category code 8.
See an example \sp.
The \sc command is equivalent to
\normalfont\scshape. In other words, it selects a font of normal
(Roman) family, medium series and small-caps shape.
For an example of fonts, see \rm.
The \scalebox command takes three arguments, the first
produces the attribute scale, the second is optional, it produces the
attribute vscale, and the third argument
is a box content (a priori paragraphs are not allowed).
The comand \reflectbox takes a single argument, the box content,
the scale is -1 and the yscale is 1.
For an example, see \fbox.
Note: \scalebox{.33}{\includegraphics{xx}} adds
scale='.33' to the image and
produces no box.
The \scaleput command is defined by the curves package.
See \arc.
Sometimes, an integer value is read by Tralics. The value is a signed 32bit integer number. When a number is read, tokens are expanded, in order to see if it is a space, a digit, or whatever. An integer is formed by an optional sign, followed by an unsigned number.
In the example that follows, \count@ is a command that reads a number (preceded by an optional equals sign). Commands on the first line yield the number two, commands on the second line yield the number minus two. The translation of the two lines is XX.
X\count@=2 \count@=+2 \count@= + + 2 \count@ = + + + 2 \count@=-2 \count@=+-2 \count@= -+ + 2 \count@ = + - + + 2 \count@=---2 X
A number can be obtained by converting a dimension (in this case, the dimension is expressed in scaled point units), or by converting a glue (in this case, only the fixed part of the glue is considered). In the example that follows, the number assigned to \count@ is respectively -16384 and 8192.
\dimen0=.25pt \count@=-\dimen0 \skip0=-.125pt plus 4fill \count@=+-+\skip0
A number can be an internal integer. This is the result of applying a command that produces an integer. For instance, the first line of the following example shows how to change the sign of \count@. Note that \inputlineno refers to the current input line number, this is a value that cannot be changed by the user. Note the last line. In the case where the year is 2004, this will put 2004 into \count@. After that, characters zero, comma, and space are translated. Then 20040 will be put into \count@, because the scanner sees the token list returned by \the, and merges it with the tokens that follow.
\count@=-\count@ \count@=-\count255 \count@=\catcode`\A \count@=\escapechar \count@=\inputlineno \count@=\year0, \count@\the\year0
Finally, a number can be a constant. In this case it can be followed by one optional space. Constants are expressed in base ten, unless preceded by a single quote (base eight) or a double quote (base sixteen). It is also possible to use a backquote followed by a character (or a one-character command). In the following example, one thousand in put in \count@ on the first line, while the values are 65, 65 and 126 on the second line. The translation is XX.
X\count@=1000 \count@='1750 \count@="3E8 %" \count@=`A \count@=`\A \count@ =`\~ X
Note some special cases: the quotes in the example above should be of catcode 12, as well the plus or minus signs. Base ten digits should also be of catcode 12, while additional digits (A to F) must be upper case, of catcode 11 or 12. Example (lines marked `Error' provoke a missing number error)
{\catcode`8=11 \count@=78}%counter holds 7 {\catcode `A=12\catcode`B=11 \count@="AB }%counter holds 171 % Error{\catcode `'=11 \count@='12} % Error{\catcode ``=11 \count@=`12} % Error{\catcode `"=11 \count@="12} %" % Error{\catcode `+=11 \count@=+12} % Error{\catcode `-=11 \count@=-12}
You have to remember that conditionals can be expanded. In the example that follows, \ifodd is called before the second assignment is done, the value is true and 21 is put in \count@.
\count@=3 \count@=2\ifodd\count@ 1 \else 2\fi
The following commands scan a 32bit number: \addtocounter, \alph (via \@alph), \Alph (via \@Alph), \ding, \penalty, \setlanguage, \romannumeral, \ifodd, \isodd, etc.
The following commands scan a 27 bit number: \accent, \char, \radical, \delimiter, etc.
The following commands scan a 15 bit number: \mathaccent, \mathchar, etc.
There are lots of tables indexed by a register code number (between 0 and 255 in TeX, 0 and 1023 in Tralics). The following commands use scanint to get the value: \box, \copy, \unhbox, \unvbox, \unhcopy, \unvcopy, \showbox, \toks, \toksdef, \count, \dimen, \skip, \muskip.
These commands read a character code, which is also a number between 0 and 255 in TeX (and 65535 in Tralics): \endlinechar, \catcode, \lccode, \uccode, \sfcode.
There are 16 input channels, numbered between 0 and 15. The following commands use scanint to get the value: \openin, \ifeof, \closein, \read. \openout, \closeout, \write.
There are all the integer parameters (same order as the TeXbook): \pretolerance, \tolerance, \hbadness, \vbadness, \linepenalty, \hyphenpenalty, \exhyhenpenalty, \binoppenalty, \relpenalty, \clubpenalty, \widowpenalty, \displaywidowpenalty, \brokenpenalty, \predisplaypenalty, \postdisplaypenalty, \interlinepenalty, \floatingpenalty, \outputpenalty, \doublehyphendemerits, \finalhyphendemerits, \adjdemerits, \looseness, \pausing, \holdinginserts, \tracingonline, \tracingmacros, \tracingstats, \tracingparagraphs, \tracingpages, \tracingoutput, \tracinglostchars, \tracingcommands, \tracingrestores, \language, \uchyph, \lefthyphenmin, \righthyphenmin, \globaldefs, \defaulthyphenchar, \defaultskewchar, \escapechar, \endlinechar, \newlinechar, \maxdeadcycles, \hangafter, \fam, \mag, \delimiterfactor, \time, \day, \month, \year, \showboxbreadth, \showboxdepth, \errorcontextlines.
In Tralics, there are quantities called dimensions. A dimension is an integral multiple of a scaled point; there are 65536 scaled points in a point. Hence a dimension is at most 16000pt in absolute value (this is over five meters). When you say \parindent2\parindent the \parindent command calls a routine that reads a dimension, which is 2\parindent, this replaces the current value of \parindent by twice its value. You can say \parindent= 2\parindent, the result is exactly the same.
A dimension is an unsigned dimension preceded by an optional sign. We begin with a short example, it is like the example for integers, but \count@ is replaced by \dimen@ and 2 by 2pt. The translation of the example is XX.
X\dimen@=2pt \dimen@=+2pt \dimen@= + + 2pt \dimen@ = + + + 2pt \dimen@=-2pt \dimen@=+-2 Pt \dimen@= -+ + 2pT \dimen@ = + - + + 2PT \dimen@=---2 pt X
A dimension can be obtained from glue by skipping the variable part (the stretch and shrink part). Example
\skip0=2ptplus2fill \parskip=2pt minus 3pt \dimen@=\skip0 \dimen@=\parskip
A dimension can be the result of a command that returns a dimension. Here are some examples.
\dimen@=-\dimen@ \dimen@=-\dimen0 \dimen@=\hsize \dimen@=\fontdimen0 \font
In all other cases, a dimension is factor followed by unit-of-measure. A factor is either an integer or a real number. Here, an integer is as described in the comments for the scanint routine above, except that it cannot be a dimension or a glue coerced into an integer. A real number is formed of digits (in base ten) before and after a point or comma. The value is 0 if no digit is given. In the example below, we use `pt' as unit of measure.
\dimen@=.10pt \dimen@=10.pt \dimen@=1.2pt \dimen@=.pt \dimen@=,10pt \dimen@=10,pt \dimen@=1,2pt \dimen@=,pt \dimen@=2pt \count@=5 \dimen@=\count@ pt \dimen@=\year pt \dimen@=\the\year,\the\month pt
A unit of measure can be a physical unit (see the \setlength command for a list of them), preceded by the optional keyword true, followed by an optional space. Note that a keyword is case insensitive, it can be preceded by any number of spaces. In Tralics, magnification is ignored, so that the true keyword has no effect. The following example translates into XX; the value of \dimen@ will be 2pt. The meaning of the second line is left as an exercise.
X\dimen@=2truept \dimen@=2 TRUE PT \dimen@=2.0 True PtX
\dimen@="Ccc \dimen@=-,sp % TeXbook Exercise 10.3
A unit of measure can also be optional spaces followed by an internal quantity like integer, dimension or glue (in fact, a command that returns such thing, coerced to a dimension), or the keywords em or ex followed by one optional space. In the current implementation of Tralics, one em is 10pt and one ex is 4.25pt.
Example. In the case \ifdim\ifnum, the quantity \skip0 is converted into a dimension, by removing the stretch part. In the last line of the example, we have inserted a \the whose effect is to convert the value into a list of tokens. The stretch part had to be removed by hand. The result is 12cm.
\dimen0=2pt \count@=196608 \skip0=4pt plus 3fill
\dimen@=2\dimen0 \dimen@=2\count@ \dimen@=2\skip0
\dimen@=.2 \dimen0 \dimen@=.2 \count@ \dimen@= .2 \skip0
\ifdim \ifnum0=1 \count0 pt\else \skip 0\fi >1cm \errmessage{bad}\fi
\skip0 =1\skip0 % TeXbook Exercise 24.3
\dimen@ = 12c\ifdim \the\ifnum0=1 \count0 pt\else \skip 0\fi <1cmm\else c\fi
Here are the commands that read a dimension: \hfuzz, \vfuzz, \overfullrule, \emergencystretch, \hsize, \vsize, \maxdepth, \splitmaxdepth, \boxmaxdepth, \lineskiplimit, \delimitershortfall, \nulldelimiterspace, \scriptspace, \mathsurround, \predisplaysize, \displaywidth, \displayindent, \parindent, \hangindent, \hoffset, \voffset.
A mudimen is like a dimen, but the unit must be a math-unit. You say \mkern2mu instead of \kern2pt (there are 18 mu to an em, where the em is taken from family 2). Note that, if you say \def\xx{\mkern18mu }, then $a\xx_{b\xx_{c\xx d}}$, you will get three different values (for instance, with standard latex, 10, 8.2 and 7.4 pt, but 10pt for Tralics).
A glue is like a dimension, but it has two additional (optional) parts: a stretch part and a shrink part. You should read the description of scanint and scandimen above. Then the following example should not be a surprise.
\skip0=2pt \skip0=-\skip0 \skip0=\parskip
The stretch part of a glue specification is introduced by the plus keyword, the shrink part by the minus keyword. This can be a dimension (or glue coerced to a dimension) or a factor (see definition above) times fill. Hence the following (it translates to XX).
X\skip0 = 1pt plus 2 pt minus 3pt \skip0 = 1pt PLUS -2 pt MINUS -3pt \skip0 = 1pt \skip0=.33\skip0 plus \count0fill minus \parskip \skip0 = 1pt minus 2pt \skip0 = 1ptplus 3Filll minus 4fil X
Here are the commands that read/write glue: \baselineskip, \lineskip, \parskip, \abovedisplayskip \abovedisplayshortskip, \belowdisplayskip, \belowdissplayshortskip, \leftskip, \rightskip, \topskip, \splittopskip, \tabskip, \spaceskip, \xspaceskip, \parfillskip.
A command like \mskip reads a mu skip (the unit is mu instead of em, units like pt or mm are forbidden). In an assignment like \thinmuskip=3mu a mu skip is expected after the equals sign and stored in the register.
Together with \thinmuskip, there is \medmuskip, \thickmuskip, and \muskip NNN, where NNN is a register number (between 0 and 255). In math mode, \lastskip can return a mu glue. The only other commands that return mu glue are those made equivalent to one of these (\muskipdef\foo15 makes \foo equivalent to \muskip15).
There are some commands that read a token list. For instance, an assignment of a token variable, like \everypar, has the following form: after the variable there is an <equals>, then <general text> or <filler><token variable>. By definition <general text> is <filler>{<balanced text><right brace>.
Said otherwise, after the variable there is an <equals>, a <filler> and either a <token variable> or a {<balanced text><right brace>.
When the object is scanned, tokens are expanded, until either the token variable is found, the opening brace is seen, or an error is signaled because of an unexpected token. A <equals> is a list (possibly empty) of spaces, followed by an optional equals sign (of \catcode 12). A <filler> is a list (possibly empty) of space or \relax tokens.
Note that a space is either a character of \catcode 10, or a token make equivalent to such a character. In the example below, we use the fact that the equals sign after a \let is followed by one optional space so that the space after \: will be assigned to \sptoken. After that we show that, in the assignment of \everymath, the equals sign can be preceded by \space or \sptoken, it can be followed by \space, \relax, or \sptoken. We show also a case without equals sign.
{\def\:{\global\let\sptoken= } \: % this makes \sptoken a space token \gdef\space{ } } \everymath \space \space \sptoken= \relax \space\relax\sptoken{foo} \everydisplay\relax\sptoken\everymath
The syntax of {<balanced text><right brace> is a bit special: a <left brace> is any character (not a command) whose \catcode is 1, while a <right brace> is any character whose \catcode is 2. A <balanced text> is a token list that has as many <left brace>s as <right brace>s, and such that every initial sublist of it has at least as many <left brace>s as <right brace;>s. Assume \let\bgroup={ and \let\egroup=} has been executed. Then $\egroup{\egroup}$ is balanced. Note that the expression above will provoke an error at evaluation. On the other hand, the opening brace in <general text> can be \bgroup or an explicit brace, so that \relax\bgroup$\egroup{\egroup}} is valid as general text <general text>.
The following commands use the syntax above for assignment: \everycr, \errhelp, \output, \everyhbox, \everyjob, \everypar, \everyvbox, \everyxbox, \everymath, \everydisplay.
The following commands read their argument as general text: \uppercase, \lowercase, \write. There are command like \insert that scan a <filler> before a brace.
The command \scantokens absorbs a list of unexpanded tokens, converts it into a character string, that is treated as if it were an external file and starts to read from this pseudo file. Every newline character (The ε-TeX document says: current newline character) is interpreted as the start of a new line.
This command takes four arguments, for instance \@scanupdown\foo{aa}{bb}{^x_y}. The last argument should consist in an optional exponent and index (arguments two and three give default values). The first command is applied to the exponent and index. For instance, the previous expression expands to \foo{x}{y}. If no x is given, then aa is used instead, if no y is given then bb is used instead. The order of exponent/index is irrelevant. A prime sign is allowed as exponent.
When you say \scriptfont2=\sevensy, you say
which font to use for math symbol indices.
See
\textfont for details.
When you say \scriptscriptfont2=\sevensy, you say
which font to use for math symbol sub-indices.
See
The \scriptscriptstyle command is valid only in math mode.
It changes the current style to scriptscriptstyle, the style used for
indices inside indices, it uses the smallest possible size.
The result is something like
<mstyle displaystyle="false" scriptlevel="2">...</mstyle>
and one problem is to find the argument of the MathML element.
See \displaystyle.
The \scriptsize command is a command that selects a small font.
When you say \scriptspace=5pt,
then TeX will add 5pt before every superscript or subscript
(See TEXbook, appendix G, rule 18).
It is ignored by Tralics.
(See scandimen for details of argument scanning).
The \scriptstyle command is valid only in math mode.
It changes the current style to scriptstyle, the style used for indices.
<mstyle displaystyle="false" scriptlevel="1">...</mstyle>
See \displaystyle.
You can prefix the command \scrollmode with \global. Nothing happens, since batch-mode is the only interaction mode.
The \scshape command changes the shape of the current font to
a small-caps shape.
The \searrow command is valid only in math mode. It generates an arrow that points South-East: <mo>↘</mo> (Unicode U+2198,↘).
The \sec command is valid only in math mode. Its translation is
a math operator of the same name:
<mo form='prefix'>sec</mo>.
For an example see the
\log command.
The \@secondoftwo command takes two arguments. The expansion is the second argument. Hence, the expansion of \@secondoftwo{{\it foo}} {{\it bar}} is {\it bar} (one level of braces removed).
The \section command is used to divide a text in smaller parts.
There is a counter named section, that is updated by the
command.
See the description of the \part command.
The \sectionmark command takes one argument and does
nothing. It is called by \section for constructing
page marks.
See \chaptermark
for an explanation of page marks. We show here how this command is redefined
in standard classes (in the one-side case, marks do not depend on sections).
% report.cls \if@twoside \renewcommand\sectionmark[1]{% \markright {\MakeUppercase{% \ifnum \c@secnumdepth >\z@ \thesection. \ % \fi #1}}} % article.cls \if@twoside \def\sectionmark#1{% \markboth {\MakeUppercase{% \ifnum \c@secnumdepth >\z@ \thesection\quad \fi #1}}{}}%
In LaTeX, \selectfont looks at parameters saved
by \fontencoding, \fontfamily,
\fontseries, \fontshape, and \fontsize,
and creates a command like \OT1/cmr/m/n/10, that becomes the
current font. In Tralics, the encoding and size is ignored.
For an example see \fontfamily.
This variable contains the default font series; its value is m in Tralics, but not used.
You can say \setboolean{foo}{true}. This sets the boolean value
of foo to true. You can also set it to false. The effect is the same as
if you had said \footrue or \foofalse.
The control sequence \footrue
is created by \csname, nasty errors
may occur! More precisely, something similar to \csname is
used to gather the letters (after expansion) in the second argument, and
converted to lower case. If the result is neither true nor false, an
error is signaled. Otherwise the same is done with the first argument
(without change of case), but the second argument (processed as explained
above) is added to the first. An error is signaled in case the result
is an undefined command.
See
\newboolean for an example.
When you say, \setbox12=\xbox{foo}{ok},
the effect is to put in the box register number 12, the box defined by
the commands following the optional equals sign.
In Tralics, a box is an XML element, produced by
\hbox, \vbox, \xbox, or one of the 256
box registers. You can prefix the command with \global,
in this case, the box is globally changed.
(see
scanint for how the number 12 is read).
You say \setcounter{foo}{200}, when you want to put 200 in the counter named foo. If the calc package is loaded, operations are performed on the argument before assignment is done. For more info see the calc package. We show here the expansion of \setcounter.
> \newcounter{foo} > \toks0=\expandafter{\setcounter{foo}{25}} > \showthe\toks0 \show: \global \c@foo 25\relax
The same code, in LateX, would give \@ifundefined {c@foo}{\@nocounterr {foo}}{\global \csname c@foo\endcsname 25\relax }. You can notice that the \c@foo token is constructed twice (once in \@ifundefined, and once for the assignment. On the other hand, Tralics constructs it only once (the expansion fails if the counter is undefined).
This command reads a integer (see scanint for details), The value is used as a language number of the hyphenation algorithm. Since Tralics does not do hyphenation it is unused.
These commands are provided by the keyval package.
If you say \setlength\foo{2cm}
it is as if you has said \foo2cm\relax.
calc package.
Assume that \foo wants a dimension (read by scandimen) the purpose of the \relax is just to avoid scanning for a space after the dimension. In the case of a glue (see scanglue) it avoids scanning a plus or minus keyword.
TeX units are converted to points according to the following table
unit | in | pc | cm | mm | bp | dd | cc |
numerator | 7227 | 12 | 7227 | 7227 | 7227 | 1238 | 14856 |
denominator | 100 | 1 | 254 | 2540 | 7200 | 1157 | 1157 |
The following piece of code shows how many pt are in one X, where X is a valid TeX unit.
{\catcode `\p=12\catcode`\t=12\gdef\ZPT{0.0pt}}%0.0pt with the right catcodes %This needs the calc package %\xtesteq checks that both arguments are the same \Bc=1in \setlength\Bc{\the\Bc-72.26999pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT \Bc=1pc \setlength\Bc{\the\Bc-12pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT \Bc=1cm \setlength\Bc{\the\Bc-28.45274pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT \Bc=1mm \setlength\Bc{\the\Bc-2.84526pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT \Bc=1bp \setlength\Bc{\the\Bc-1.00374pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT \Bc=1dd \setlength\Bc{\the\Bc-1.07pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT \Bc=1cc \setlength\Bc{\the\Bc-12.8401pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT \Bc=1sp \setlength\Bc{\the\Bc-0.00002pt} \edef\foo{\the\Bc}\xtesteq\foo\ZPT
If you say \setmathchar5 6 7, you change the behaviour of character 6 in font 5 to 7. See \mathfontproperty for an example. (See scanint for details of integer scanning). Instead of the integer 5, you can give a fontname, for instance \mml@font@fraktur, or \mathbf. Instead of the integer 6, you can give a character like `\x; note that any integer between 0 and 127 is accepted, but the value is used only if it represents a letter (upper case, or lower case). After the second integer, there is an optional equals sign, followed by a value, that Tralics translates and converts and stores in a table (assignment is global). If you say \the\setmathchar5 6, you will get the value sorted in this table, as a sequence of characters (of category code 12, as usual).
The \setminus command is valid only in math mode. It generates
a binary operator
<mo>∖</mo> (Unicode U+2216, ∖).
\pm command.
The command \@setmode 16 sets the current mode to some mode. The argument is scanned as an integer (see scanint), values outside the range 0-6 are replaced by 0. Other values correspond to argument mode (0), or horizontal mode (1), or vertical mode(2), no mode (3), bibliographic mode (4), array mode (5), mathmode (6). Do not use this command if you do not understand the consequences. In a case like 1\@setmode 2 \space3 4 5\par, there is no space between 1 and 3, because we are vertical mode, horizontal mode is entered when the the digit 3 is seen. In a case like 1\@setmode 4 \space3 4 5\par there is no space at all since they are ignored in bib mode. The \par command is ignored as well, so you had better to add \@setmode 1 or enclose everything in group.
The \sf command is equivalent to
\normalfont\sffamily. In other words, it selects a font of
sans-serif family, medium series and upright shape.
When you say \sfcode13 12, you change the spacefactor code of the character number 13 to the value 12. See scanint for details of how numbers are read. The first integer must be a valid character code (between 0 and 255 in TeX, 65535 in Tralics), and the second must be between 0 and 32767. See \spacefactor. When TeX inserts a character in an horizontal list, it modifies the spacefactor as follows: If f is the current spacefactor, and g the \sfcode of the character, then the spacefactor is set to g unless either g is 0 (spacefactor is unchanged) or f is less than 1000, and g greater than 1000 (spacefactor is set to 1000). The spacefactor can be changed via \spacefactor. In Tralics, this is useless, and the \sfcode table is empty.
The \sffamily command changes the family of the current
font to a sans-serif family.
This variable contains the default font shape; its value is n in Tralics, but not used.
The \sharp command is valid in math mode and text mode.
It generates a miscellaneous symbol:
<mo>♯</mo>
or ♯ (Unicode U+266F, ♯).
\qquad and
\ldots commands.
You may say \shipout\vbox{vertical material}, and TeX is assumed to put the content of the box into the dvi file. This command is normally called via \output when a page is full. The behavior of Tralics is different: the whole XML tree is put in memory until the end of the job, and \shipout signals an error as `\shipout is undefined'. As a result every \write is immediate,
The \shortdownarrow command is an alias for \downarrow.
The \shortleftarrow command is an alias for \leftarrow.
The \shortrightarrow command is an alias for \rightarrow.
The \shortuparrow command is an alias for \uparrow.
This command can be used to push an equation to the left in a multline environment. It is defined as \multicolumn{1}{l}. See description of the multline command.
This command can be used to push an equation to the right in a multline environment. It is defined as \multicolumn{1}{r}. See description of the multline command.
The \show command reads a token and prints its meaning on the terminal and the transcript file. Example
\def\Bar#1#{#1} \show\Bar \long\def\Barl#1#{#1} \show\Barl \long\outer\def\Barol#1#{#1} \show\Barol \outer\def\Baro#1#{#1} \show\Baro \let\foo\par \show\foo \renewcommand\foo[2][toto]{#1#2} \show\foo \let\foo=1 \show\foo \let\foo=\undef \show\foo \show\bgroup
This is what Tralics prints.
\Bar=macro: #1#->#1. \Barl=\long macro: #1#->#1. \Barol=\long\outer macro: #1#->#1. \Baro=\outer macro: #1#->#1. \foo=\par. \foo=opt \long macro: toto#2->#1#2. \foo=the character 1. \foo=undefined. \bgroup=begin-group character {.
In the case of \Bar, TeX would print a second opening brace. In the case of a user defined command, TeX prints a newline character instead of a space after macro:. Notice also that Tralics understands commands with an (initial) optional argument, so that no command named \\foo is generated.
The \show command can also be used with a non-command.
\catcode `\A=1 \show A \catcode `\A=2 \show A \catcode `\A=3 \show A \catcode `\A=4 \show A \catcode `\A=6 \show A \catcode `\A=7 \show A \catcode `\A=8 \show A \expandafter \show \space \catcode `\A=11 \show A \catcode `\A=12 \show A \catcode `\A=13 \show A \def A{foo} \show A
Valid catcodes are between 0 and 15, but the \show command cannot see characters of catcode 0, 9, 14, and 15. It is a bit tricky to show a space character. Note that, in the case of a command or an active character, the output has the form `name=value', otherwise, it has the form `type value'.
begin-group character A. end-group character A. math shift character A. alignment tab character A. macro parameter character A. superscript character A. subscript character A. blank space . the letter A. the character A. A=undefined. A=macro: ->foo.
The \showbox command reads a box number (see scanint for details), and prints the content of the box. Example.
\def\foo{123} \afterassignment\foo\setbox0=\hbox{4} \showbox0
This is what TeX prints in the transcript file:
> \box0= \hbox(6.4151+0.0)x19.99512 .\T1/cmr/m/n/10 1 .\T1/cmr/m/n/10 2 .\T1/cmr/m/n/10 3 .\T1/cmr/m/n/10 4
This is what Tralics prints: 1234. The box (the XML element) contains no font information, and no size.
When you say \showboxbreadth=907, TeX
will show only the 907 first elements in a box
(others are indicated by etc.). Set to -1
by LaTeX, ignored by Tralics (that prints
always the full content of an XML element).
(See scanint for details of argument scanning).
When you say \showboxdepth=908, TeX
will show only the 908 first levels in a box
(after that the content of the box is shown as []).
Set to -1
The command \showgroups is an ε-TeX extension. It
shows the current grouping structure.
The read-only integer \currentgrouplevel returns the current save
group level, and \currentgrouptype returns a number representing
the type of the
current group. This gives a number between 0 and 16, see the ε-TeX
documentation. The values used by Tralics are: 0 is bottom level (no
group), 1 is simple group, 9 is math group, 14 is semi simple group,
18 is environment, 19 is a cell in a table, 20 is a local group (corresponds
to 4 and 5 in ε-TeX), 21 is a title-page group, 17 is impossible.
Example. If we have a file with
\begin{foo} \begingroup { \begin{tabular}{c} \showgroups! \end{tabular} \the\currentgrouplevel \the\currentgrouptype } \endgroup \end{foo}
The following is printed by ε-TeX
### simple group (level 10) entered at line 13 ({) ### align group (level 9) entered at line 12 (align entry) ### align group (level 8) entered at line 12 (\halign{) ### vcenter group (level 7) entered at line 12 (\vcenter{) ### math shift group (level 6) entered at line 12 ($) ### hbox group (level 5) entered at line 12 (\hbox{) ### semi simple group (level 4) entered at line 12 (\begingroup) ### simple group (level 3) entered at line 11 ({) ### semi simple group (level 2) entered at line 10 (\begingroup) ### semi simple group (level 1) entered at line 9 (\begingroup) ### bottom level
or by Tralics
### cell group (level 5) entered at line 13 ### environment group (level 4) entered at line 12 ### brace group (level 3) entered at line 11 ### semi simple group (level 2) entered at line 10 ### environment group (level 1) entered at line 9 ### bottom level
You may wonder why ε-TeX uses twice as many stack levels as Tralics. This is because tables are implemented in a different way. For instance, using math mode for tables is very strange; one might wonder what the current mode is, when \tracinggroups is seen; the answer is restricted horizontal mode, but why? If we insert a \showlists command, we see
### restricted horizontal mode entered at line 13 [] spacefactor 3000 ### restricted horizontal mode entered at line 13 [] spacefactor 0 ### internal vertical mode entered at line 12 prevdepth ignored ### internal vertical mode entered at line 12 prevdepth ignored ### math mode entered at line 12 ### restricted horizontal mode entered at line 12 spacefactor 1000 ### horizontal mode entered at line 12 [] spacefactor 1000 ### vertical mode entered at line 0 ### current page: []
In the same situation, you will see the following lines in the Tralics transcript file. Here, the level is an index in the XML stack, and you can see that the current mode is `a' (for array).
level 0 entered at line 0, type document, mode_v: <std> <table rend='inline'><row><cell/></row></table></std> level 1 entered at line 12, type tabular, mode_v: <table rend='inline'><row><cell/></row></table> level 2 entered at line 13, type row, mode_a: <row><cell/></row> level 3 entered at line 13, type cell, mode_a: <cell/>
If you translate the following line in verbose mode
{\the\currentgrouplevel}
you will see the following in the transcript file. The current level outside the group is one, so that you see it increase to 2; but ε-TeX shows it as zero, so that the \the inside the group expands to one. The reason for this strange behaviour is that a quantity defined at level zero is never defined; the level is never zero, so that the \the never returns a negative value.
[9] {\the\currentgrouplevel} {begin-group character} +stack: level + 2 for brace entered on line 9 {\the} {\the \currentgrouplevel} \the->1. {end-group character} +stack: level - 2 for brace from line 9
If you call this command in LaTeX, you will see a two-line warning message, where the first line is Underfull \hbox (badness 10000) detected at line 10. Quote from the TeXbook: The \showhyphens macro creates an hbox that is intentionally underfull, so you should ignore the warning about `badness 10000'; this spurious message comes out because TeX displays hyphens in compact form only when it is displaying the contents of anomalous hboxes. The second line could be [] \OT1/cmr/m/n/10 ex-er-cise. Another quote: TeX wizards may enjoy studying the way \showhyphens is defined in Appendix B. The LaTeX definition is similar, but a bit more complicated (guess why). You can see the name of the default font, preceded by a space, and an empty box (then brackets, it corresponds to the paragraph indentation). For each hyphenation point, you will see the value of the \hyphenchar, normally a hyphen. Note that hyphenation depends on the language. Since hyphenation is not implemented in Tralics, this command just ignores its argument.
This command is introduced in ε-TeX; it should you the conditional stack on the transcript file. Example
$ \iftrue\unless\iffalse \ifmmode \ifnum1=2 \else \ifdim\parskip=3pt \else \showifs\fi\fi\fi\fi\fi$
What you will see is the following:
### level 4 serial 6: \ifdim\else entered on line 13 ### level 3 serial 5: \ifnum\else entered on line 12 ### level 2 serial 4: \ifmmode entered on line 12 ### level 1 serial 3: \unless\iffalse entered on line 12 ### level 0 serial 2: \iftrue entered on line 12
The \showlists commands prints on the transcript file that status of the engine. Consider a file with the following lines
... \def\foo{123} \afterassignment\foo\setbox0=\hbox{4} \showbox0 \write-1{HEY}\write17{hey}${\showlists}$
### math mode entered at line 27 ### math mode entered at line 27 \mathord ### horizontal mode entered at line 27 \hbox(0.0+0.0)x15.0 spacefactor 1000 ### vertical mode entered at line 0 ### current page: \write-{} \write-{HEY} \write*{hey} prevdepth 0.0 ! OK. l.27 \write-1{HEY}\write17{hey}${\showlists }$
You may wonder: what is the meaning of the first \write-{} ? It is because the current class calls \onecolumn that calls \clearpage that calls \newpage then \write with the comment: Part of hack to make sure no \write's get lost.
In Tralics, the \showlists above does not print anything useful. Thus assume that line 29 contains this:
\chapter{A}a\part{B}b\section{C}c\subsection{D}d\paragraph{E}e\showlists
Then \showlists will produce the following output (we removed all newline characters, and each line was truncated to 80 characters). It happens that the mode is always vertical mode: the current mode is horizontal mode (but this information is not printed) because a new paragraph was entered when the character `e' was translated. This character is not yet in the XML tree (it is in a temporary buffer).
level 0 entered at line 0, type document, mode_v <rr part='true'><p><formula type='inline'><math xmlns='http://www.w3.org/1... level 1 entered at line 29, type div0, mode_v <div0 id='uid2'><head>B</head><p>b</p><div2 id='uid3'><head>C</head><p>c</p>... level 2 entered at line 29, type div2, mode_v <div2 id='uid3'><head>C</head><p>c</p><div3 id='uid4'><head>D</head><p>d</p>... level 3 entered at line 29, type div3, mode_v <div3 id='uid4'><head>D</head><p>d</p><div5 id='uid5'><head>E</head><p></p>... level 4 entered at line 29, type div5, mode_v <div5 id='uid5'><head>E</head><p></p></div5> level 5 entered at line 29, type p, mode_v <p></p>
This command is ignored by Tralics; in LaTeX it is like \loggingoutput, but information is also printed to the terminal. You should say \tracingall in Tralics.
In LaTeX \showoverfull shows overfull boxes by setting \tracingonline to one. Ignored by Tralics.
There are lots of internal quantities, some of them are read-only, some of them can be modified by the user. In Tralics, quantities like \badness are neither modified by the user nor the program. If \foo is an internal quantity, you say \foo=\bar if you want to modify \foo, and the value of \foo is used otherwise (for instance in \bar\=foo). If \foo is a count register, you can use its value for computations. If you want to typeset the number, you say \number\foo.
The \the command is part of the expand routine. It takes a token (unexpanded), and the expansion is the meaning of this token, provided that the token refers to an internal quantity. For instance \the\catcode`\A is 11, this is a list of two tokens. All tokens produced by \the are of catcode 12 (except space, of catcode 10). There are two exceptions \the\font returns a font identifier, and \the\toks0 returns a copy of the token list.
The command \showthe\foo prints on the terminal and the transcript file all the tokens produced by \the\foo.
In the example below, the \relax is important: without it, the assignment to \leftskip will expand the \Show command (because it could start with an l, and produce `filll'), hence the \the, and the typeset value would be the value before the assignment).
\def\Show#1{\relax\the#1\showthe#1} %1) \the parameter \widowpenalty=3 \Show\widowpenalty \parindent1.5pt \Show\parindent \leftskip = 1pt plus 2fil minus 4fill \Show\leftskip \thinmuskip = 3mu plus -2fil minus 4fill \Show\thinmuskip %2) \the register \count0=17 \Show{\count0} \dimen0=17pt \Show{\dimen0} \skip0=17pt plus 1 pt minus 2pt \Show{\skip0} \muskip0=17mu plus 1 mu minus 2mu \Show{\muskip0} %3) \the codename 8bit-number \Show{\catcode`\A} \Show{\lccode`\B} %4) \the special register \Show\inputlineno %5) \the\fontdimen number font \font\xa=cmr10 at 11truept \fontdimen6\xa = 11pt \hyphenchar\xa=`\- \Show{\fontdimen6\xa} %6) \the\hyphenchar ... \Show{\hyphenchar\xa} %7) \the\lastpenalty... %8)\the defined character \chardef\foo25 \Show\foo %9) \the font \Show\xa %10) \the token variable \toks0={\foo = \foo} \def\foo{foo} \Show{\toks0}
This is printed on the terminal and the transcript file
\show: 3 \show: 1.5pt \show: 1.0pt plus 2.0fil minus 4.0fill \show: 3.0mu plus -2.0fil minus 4.0fill \show: 17 \show: 17.0pt \show: 17.0pt plus 1.0pt minus 2.0pt \show: 17.0mu plus 1.0mu minus 2.0mu \show: 11 \show: 98 \show: 20 \show: 11.0pt \show: 45 \show: 25 \show: cmr10 \show: \foo = \foo
And this is the translation:
3 1.5pt 1.0pt plus 2.0fil minus 4.0fill 3.0mu plus -2.0fil minus 4.0fill 1717.0pt17.0pt plus 1.0pt minus 2.0pt17.0mu plus 1.0mu minus 2.0mu119821 11.0pt 45 25 cmr10 foo= foo
he command \showtokens reads a token list, and print it on the terminal, and transcript file. As the example below shows, the start of the token list is obtained by expanding tokens and ignoring \relax until a brace (implicit or explicit) is found. The last list should print something like \tralicsversion 2.10.
\showtokens \relax \expandafter{\jobname} \showtokens \expandafter{\expandafter\tralicsversion\tralicsversion }
The \sideset command takes three arguments, L, R, and S. Each quantity L and R defines a superscript and a subscript, they will be put on the left and right of the operator S. The quantity S should be an operator, it can have superscript and subscripts (placed above and below). In the first example below, L is empty, and R contains a superscript (remember that a prime sign is the same as ^{\prime}). The result is a sum sign, with the letter i below it, and a prime accent on the upper right. In the second example, we have a superscript and a subscript in L, R and S.
$\sideset{}{'}\sum_i x_i$ $\sideset{^{a}_b}{_{D}^c}\sum_x^yw$
Translation
<formula type='inline'> <math xmlns='http://www.w3.org/1998/Math/MathML'> <mrow> <munder> <mmultiscripts><mo>∑</mo><none/><mo>'</mo></mmultiscripts> <mi>i</mi> </munder> <msub><mi>x</mi> <mi>i</mi> </msub> </mrow> </math> </formula> <formula type='inline'> <math xmlns='http://www.w3.org/1998/Math/MathML'> <mrow> <munderover> <mmultiscripts> <mo>∑</mo><mi>D</mi><mi>c</mi> <mprescripts/><mi>b</mi><mi>a</mi> </mmultiscripts> <mi>x</mi> <mi>y</mi> </munderover> <mi>w</mi> </mrow> </math> </formula>
The \sigma command is valid only in math mode. It generates a Greek letter: <mi>σ</mi> (Unicode U+3C3, σ). See description of the \alpha command.
The \Sigma command is valid only in math mode. It generates an uppercase Greek letter: <mi>Σ</mi> (Unicode U+3A3, Σ). See description of the \alpha command.
The \sim command is valid only in math mode. It generates a relation symbol: <mo>∼</mo> (Unicode U+223C, ∼). See description of the \le command.
The \simeq command is valid only in math mode. It generates a relation symbol: <mo>≃</mo> (Unicode U+2243, ≃). See description of the \le command.
The \sin command is valid only in math mode. Its translation is
<mo form='prefix'>sin</mo>.
\log command.
The \sinh command is valid only in math mode. Its translation is
<mo form='prefix'>sinh</mo>.
\log command.
The \sixt@@n command is defined to be the integer 16. Use it only when TeX expects a number, for instance, the piece of code below uses \tw@ (two), \z@ (zero) and \sixt@@n (sixteen). It computes in count0 and count2 the quotient and remainder of count) by 16.
\count\tw@\count\z@ \divide\count\z@\sixt@@n \count@\count\z@ \multiply\count@\sixt@@n \advance\count\tw@-\count@
If you say \the\skewchar\foo, you will get the skewchar of the font \foo. This is an integer. If you say \skewchar\foo=444, you set this to 444. This is explained in the TeXbook, appendix G, rule 12. Not used by Tralics.
When you say \skip13 12pt, you change the value of the glue
register number 13 to the value 12pt.
integers are read, and scanglue
for glue. The integer must be a valid register number
(between 0 and 255). After \skip13 there comes an optional
equals sign and a glue. For instance skip1=\skip2 makes
a copy of register number 2 into register number 1.
The command \skip@ is a short-hand for \skip0.
When you say \skipdef\foo=13, you make \foo
an alias for \skip13.
the number 13 is read; it has to be a valid register number
(between 0 and 255). The two commands
\newskip and
\newlength use \countdef
for defining the command associated to the counter.
You can put the prefix \global before \skipdef.
The \sl command is equivalent to
\normalfont\slshape. In other words, it selects a font of
Roman family, medium series and slanted shape.
LaTeX contains the following definition \def\slash{/\penalty\exhyphenpenalty}. But Tralics ignores penalties, so that \slash produces a simple slash.
In LaTeX, the \sloppy command modifies some internal quantities, like \tolerance, \emergencystretch, \hfuzz and \vfuzz, all quantities that Tralics ignores. Hence \sloppy is implemented as a no-op.
The equivalent of \newenvironment{sloppypar} {\par\sloppy} {\par} is executed by the latex kernel.
The \slshape command changes the shape of the current
font to a slanted shape.
The \small command is a command that selects a small font.
In Tralics, the \smallbreak command is the same as \par. In LaTeX, it makes also sure that the space between the two paragraphs is at least \smallskipamount, by calling \smallskip if necessary; not implemented in Tralics.
The \smallint command should give a small integral sign. It gives a normal one. Here are some randomly chosen math symbols
$\smallint \int \land \wedge \lor \owns \ni \notin \neg \lnot \gets \leftarrow \to \rightarrow \gtrless \geqslant \leqslant \iff \backslash$
The XML result is
<formula type='inline'><math xmlns='http://www.w3.org/1998/Math/MathML'> <mrow><mo>∫</mo><mo>∫</mo><mo>∧</mo><mo>∧</mo><mo>∨</mo> <mo>∋</mo><mo>∋</mo><mo>∉</mo><mo>¬</mo><mo>¬</mo> <mo>←</mo><mo>←</mo><mo>→</mo><mo>→</mo> <mo>≷</mo><mo>⩾</mo><mo>⩽</mo><mo>⟺</mo> <mo>\</mo></mrow></math></formula>
If you do not like entity names, you can use the -noentnames switch, and you get
<formula type='inline'> <math xmlns='http://www.w3.org/1998/Math/MathML'> <mrow><mo>∫</mo><mo>∫</mo><mo>∧</mo><mo>∧</mo> <mo>∨</mo><mo>∋</mo><mo>∋</mo><mo>∉</mo> <mo>¬</mo><mo>¬</mo><mo>←</mo><mo>←</mo> <mo>→</mo><mo>→</mo><mo>≷</mo> <mo>⩾</mo><mo>⩽</mo><mo>⟺</mo><mo>\</mo> </mrow></math> </formula>
Preview .
The command \smallsetminus is an alias for \setminus. It is valid only in math mode, generates <mo>∖</mo> (Unicode U+2216, ∖).
In LaTeX, we have the following definitions:
\newskip\smallskipamount \smallskipamount=3pt plus 1pt minus 1pt \newskip\medskipamount \medskipamount =6pt plus 2pt minus 2pt \newskip\bigskipamount \bigskipamount =12pt plus 4pt minus 4pt \def\smallskip{\vspace\smallskipamount} \def\medskip{\vspace\medskipamount} \def\bigskip{\vspace\bigskipamount}
In plain TeX, definitions are similar, with \vskip instead of\vspace. In Tralics, the three glue registers are defined as above, but unsed; the three commands use a fixed dimension (3, 6 and 12 pt), and the \vskip by a change of paragraph, (see description of the \vskip command) so that \smallskip is like \\[3pt] (except that the new paragraph is indented). Example.
text A \bigskip text B \smallskip text C \medskip text D \begin{center} short line \bigskip a longer line \smallskip a still longer line \medskip a very long line of text \end{center}
<p>text A </p> <p spacebefore='12.0pt'>text B </p> <p spacebefore='3.0pt'>text C </p> <p spacebefore='6.0pt'>text D</p> <p rend='center'>short line </p> <p spacebefore='12.0pt' rend='center'>a longer line </p> <p spacebefore='3.0pt' rend='center'>a still longer line </p> <p spacebefore='6.0pt' rend='center'>a very long line of text</p>
Preview .
See \smallskip
The \smash command takes an argument, and modifies its height and depth to be zero. It takes an optional argument: h, d or w, case where the height, depth or width is set to zero. Example:
$\smash{x} \smash[t]{x} \smash[b]{x} \smash[w]{x}$
Translation
<formula type='inline'> <math xmlns='http://www.w3.org/1998/Math/MathML'> <mrow> <mpadded height='0pt' depth='0pt'><mi>x</mi></mpadded> <mpadded height='0pt'><mi>x</mi></mpadded> <mpadded depth='0pt'><mi>x</mi></mpadded> <mpadded width='0pt'><mi>x</mi></mpadded> </mrow> </math> </formula.
The \smile command is valid only in math mode. It generates a relation symbol: <mo>⌣</mo> (Unicode U+2323, ⌣). See description of the \le command.
Command from the soul package, that takes an argument and behaves like \textit. For an example, see \ul.
The \sp command is a shorthand for a hat character of catcode 7. The following two lines are equivalent
$a^c_b$ $a\sb b\sp c$
The XML result is
<formula type='inline'><math xmlns='http://www.w3.org/1998/Math/MathML'> <msubsup><mi>a</mi> <mi>b</mi> <mi>c</mi> </msubsup></math></formula> <formula type='inline'><math xmlns='http://www.w3.org/1998/Math/MathML'> <msubsup><mi>a</mi> <mi>b</mi> <mi>c</mi> </msubsup></math></formula>
The expansion of the \space command is a space. Note that \space{ } \space produces four spaces. Note that spaces are ignored in math mode (use command like \mkern, \quad, ~, \,, and so on).
Expansion of this command is \space\space\space\space.
TeX uses the value of \spacefactor for computing spaces between characters. In general, the spacefactor is obtained via the \sfcode of the current character, using some complicated rules. You can change the space factor, like any other integer, for instance \spacefactor=1234, however the value must be between 1 and 32767.
In Tralics, you can say \spacefactor-12345, and nothing happens. As a consequence, \showthe\spacefactor will always print 0.
You can say \spaceskip=10pt plus 2pt minus 3pt. This explains to TeX that it should put 10pt (maybe up to 2pt more, maybe up to 3pt less) of glue between words. Unused by Tralics. (See scanglue for details of argument scanning). In fact, if the spacefactor f is at least 2000, and \xspaceskip is not zero, then this quantity is used. Otherwise, if \spaceskip is not zero, the \spaceskip glue is used, with stretch and shrink components multiplied by f/1000 and 1000/f. Otherwise, the parameters of the current font are used.
The \spadesuit command is valid only in math mode. It generates a miscellaneous symbol: <mo>♠</mo> (Unicode U+2660, ♠). See description of the \ldots command.
When \span appears in a preamble, it causes the next token to be expanded. Otherwise, it marks the end of a cell in a table, and the beginning of a new one. These two cells are merged.
This does not work in Tralics. You should use \multicolumn instead.
If you say \special{foo}, nothing special happens. If you want, you can say \renewcommand\special{\xmlelt{special}} so that the expression above translates to <special>foo</special>.
The \sphericalangle command is valid only in math mode. It generates the symbol: <mo>∢</mo> (Unicode U+2222, ∢).
The split environment is used for splitting equations. \begin{split} XX \end{split} is equivalent to \begin{array}{rl} XX \end{array}. Example.
\begin{equation} \begin{split} (a+b)^4 &= (a+b)^ 2 (a+b)^2 \\ &= (a^2+2ab+b^2)(a^2+2ab+b^2) \\ &= a^4+4a^3b+6a^2b^2+4ab^3+b^4 \\ \end{split} \end{equation}
Translation
<formula id-texrt='1' id='uid' type='display'> <math mode='display' xmlns='http://www.w3.org/1998/Math/MathML'> <mtable displaystyle='true'> <mtr> <mtd columnalign='right'> <mrow><mrow><mo>(</mo><mi>a</mi><mo>+</mo><mi>b</mi></mrow> <msup><mo>)</mo> <mn>4</mn> </msup></mrow> </mtd> <mtd columnalign='left'> <mrow><mrow><mo>=</mo><mo>(</mo><mi>a</mi><mo>+</mo><mi>b</mi></mrow> <msup><mo>)</mo> <mn>2</mn> </msup> <mrow><mo>(</mo><mi>a</mi><mo>+</mo><mi>b</mi></mrow><msup><mo>)</mo> <mn>2</mn> </msup></mrow> </mtd> </mtr> <mtr> <mtd></mtd> <mtd columnalign='left'> <mrow><mrow><mo>=</mo><mo>(</mo></mrow><msup><mi>a</mi> <mn>2</mn></msup> <mo>+</mo><mn>2</mn><mi>a</mi><mi>b</mi><mo>+</mo> <msup><mi>b</mi> <mn>2</mn> </msup><mrow><mo>)</mo><mo>(</mo></mrow> <msup><mi>a</mi> <mn>2</mn> </msup><mo>+</mo><mn>2</mn> <mi>a</mi><mi>b</mi><mo>+</mo><msup><mi>b</mi> <mn>2</mn> </msup> <mrow><mo>)</mo></mrow></mrow> </mtd> </mtr> <mtr> <mtd></mtd> <mtd columnalign='left'> <mrow><mo>=</mo><msup><mi>a</mi> <mn>4</mn> </msup> <mo>+</mo><mn>4</mn><msup><mi>a</mi> <mn>3</mn> </msup><mi>b</mi> <mo>+</mo><mn>6</mn><msup><mi>a</mi> <mn>2</mn> </msup><msup><mi>b</mi> <mn>2</mn> </msup> <mo>+</mo><mn>4</mn><mi>a</mi><msup><mi>b</mi> <mn>3</mn> </msup> <mo>+</mo><msup><mi>b</mi> <mn>4</mn> </msup> </mrow> </mtd> </mtr> </mtable> </math> </formula>
Preview: .
The expansion of \splitbotmark is the mark text of the last mark that appears in the vertical list that was split off by the most recent \vsplit command. Since splitting is a no-op in Tralics, the expansion of \splitbotmark is empty. One extension of ε-TeX is to maintain a stack of marks. The six commands \marks, \firstmarks, \topmarks, \botmarks, \splitfirstmarks, and splitbotmarks generalise commands with the same name (without final s), they read an integer N, and set a mark at position N, or get the mark at position N. The value of the integer is ignored in Tralics.
This is an extension introduced by ε-TeX; an integer is read, expansion is empty. See \splitbotmark.
This is a no-op in Tralics. See \savingdiscards for explanations.
Expansion is empty (it is the first mark on a splitted box), see \splitbotmark.
You can say \splitmaxdepth=1.5in, as a result TeX
will make sure that the last line (box) of a splitted box has a depth not
exceeding 1.5in (by shifting it up if necessary). Ignored by Tralics,
since \vsplit is not implemented.
You can say \splittopskip=10pt plus 2pt minus 3pt.
10pt (maybe up to 2pt more, maybe up to 3pt less) of glue on the
top of each splitpage. Unused by Tralics (you should use
environments like quote or center instead).
The \sqcap command is valid only in math mode. It generates a binary operator: <mo>⊓</mo> (Unicode U+2293, ⊓). See description of the \pm command.
The \sqcup command is valid only in math mode. It generates a binary operator: <mo>⊔</mo> (Unicode U+2294, ⊔). See description of the \pm command.
The \sqrt command puts a square root sign over its argument.
It can take an optional argument, and
\sqrt[x]{y} is equivalent to \root x \of{y}.
It works only in math mode.
See also the
\acute command.
The \sqsubset command is valid only in math mode. It generates a relation symbol: <mo>⊏</mo> (Unicode U+228F, ⊏). See description of the \le command.
The \sqsubseteq command is valid only in math mode. It generates a relation symbol: <mo>⊑</mo> (Unicode U+2291, ⊑). See description of the \le command.
The \sqsupset command is valid only in math mode. It generates a relation symbol: <mo>⊐</mo> (Unicode U+2290, ⊐). See description of the \le command.
The \sqsupseteq command is valid only in math mode. It generates a relation symbol: <mo>⊐</mo> (Unicode U+2292, ⊒). See description of the \le command.
The \square command is valid only in math mode. It generates a miscellaneous symbol: <mo>□</mo> (Unicode U+25A1, □). See description of the \ldots command.
The translation of \SS is SS. It is the uppercase version of \ss.
The translation of \ss is ß or ß It is the lowercase version of \SS.
The \sslash command is valid only in math mode. It generates the operator: <mo>⫽</mo>, Unicode U+2AFD, ⫽.
The \stackrel command takes two arguments A and B,
it places A (superscript size) over B (that is expected to be a relation).
See also the
\acute command.
The \star command is valid only in math mode. It generates a binary operator: <mo>☆</mo> (Unicode U+2606, ☆). See description of the \pm command.
The \stepcounter command increments a counter, and resets all dependent ones. This is an example:
> \newcounter{foo} > \toks0=\expandafter{\stepcounter{foo}} > \showthe\toks0 \show: \global \advance \c@foo \@one \let \@elt \@stpelt \cl@foo
In LaTeX, you would see a different form: \addtocounter {foo}\@ne \begingroup \let \@elt \@stpelt \csname cl@foo\endcsname \endgroup.
The \stop command is equivalent to \@@end. This closes all files, forgets about all pending input, thus terminates the current job.
This command takes one argument, a counter name and sets it to zero.
You can say something like \hspace{\stretch{2.3}}. The effect is to add an horizontal space of natural width zero, but stretches like 2.3fill. Note that \stretch{1} is the same as \fill. The argument of \stretch should be (after expansion) a real number.
The \string command is a primitive, that reads a token, and whose expansion is a list of characters that represent that token. These characters are of \catcode 12, except for space, which has its usual catcode. For instance, \string{\string} is typeset in the same way as \char`{\char`}; the difference is that \char is evaluated, hence illegal in \csname. In the following example, we construct and use a command, whose name contains braces.
\expandafter\def\csname\string{\string}\endcsname#1#2{#2#1} \expandafter\csname\string{\string}\endcsname XY
The expansion of \string\foo is a list of four tokens. The first token is not always a backslash: if you say \escapechar=`A, it would be the letter A, and if \escapechar is out of range, it is omitted. After {\escapechar=-1 \xdef\foo{\string\}}}, the \foo macro expands to a closing brace character.
The \strip@prefix strips the prefix produced by \meaning for a macro; said otherwise, all tokens up a greater-than sign. See an example at \@expandtwoargs
If you say \strip@pt\topmargin the expansion may be 18 or 18.3. The LaTeX definition is given here. The important point is that \the\topmargin is executed, and this should return a dimension, as in 18.3pt, after that, the final pt and the dot are removed. No error is signaled by Tralics if these characters are not found.
This command is valid in math mode only; is translation is an invisible object (a mphantom) that has the same height and depth of a parenthesis (a mpadded element makes the width equal to zero).
The environment is currently ignored (but not its content).
The subfigure command takes two arguments, an optional one, and a required one; translation is of the form <subfigure id='uid2'> <leg>optional</leg> <texte>mandatory</texte></subfigure>. An anchor is added to the element since version 2.11.3, this means that if you put a \label in the argument, a reference to the label will refer to the subfigure, via the ID, uid2 in the example.
In what follows, we describe what happens when a subfigure is in a figure. One of the main difficulties when using Tralics for the RA (Inria's Activity Report) is the conversion of XML figures into Pdf. Consider an author that puts four images A, B, C, D in a figure. There are various tricks that can be used to get a correct placement (normal space, fill glue, or even negative space). Assume that the author wants two rows of two images; this can be achieved via \\ or a \par; in some cases there is no need to insert such a command because there is a natural line break between A and B. Assume now that, when the XML produced by Tralics is converted into Pdf, the alignement is different; for instance if the text with is 13cm and each figure has a width of 6.75cm, these will be vertically aligned. If the caption refers to B as to the upper-right image, it is wrong. If images are square, this gives a total height of 27cm, hence overflow, and the caption will be below the bottom of the page, and invisible. For this reason, it is better to use a table; the total width exceeds the textwidth by 1cm, this is small enough that the whole table will be visible on the page. One could argue that the author should use something like .45\textwidth, this should leave enough space between the images, but Tralics converts this to the value 6.75cm shown above.
There is a postprocess for the figure environment, it modifies the content, according to some complicated rules. The simple case is when the figure has a single image; another case is when the figure contains a table. If the figure has subfigures, a table is created for the reasons explained above; some people desagree, so that there is an alternative, but this assumes that the subfigure contains an image. In each case, Tralics uses the relevant elements discarding everything else. You may get a warning of the form Warning: junk in figure detected on line 17 of file foo.tex. In such a case discarded elements can be found in the XML file in a comment that starts with ignored_fig_contents.
We consider here the case where the figure contains a subfigure. Each paragraph is transformed into a table, each subfigure producing two cells, the mandatory argument (in general the image) on the first row, the optional argument (in general the caption) on the second row. When LaTeX typesets the whole thing, it inserts a prefix before each caption, for instance Figure 3 before the figure caption and (d) before the subfigure caption. This is not done by Tralics (figure numbers are added when the XML document is converted to HTML). A reference to the subfigure may be typeset by LaTeX as (3.d). Very often, people say: see part (d) of figure N, where N is obtained via a \ref to the figure. In old Tralics you cannot use a reference to the subfigure, so that (a), (b) and (c) are explicitly added.
Example. Here we have four \subfigures, containing as required argument, an image, the same in each case, with different scaling. In some cases the optional argument is given, in other cases it is not.
\begin{figure} \def\IC#1{\includegraphics[width=#1pt]{Logo-INRIA-couleur}} \subfigure[~one]{\IC{2}} \subfigure{\IC{3}} \par \subfigure[~two]{\IC{4}} \subfigure{\IC{1.3}} \caption{Caption of the figure} \end{figure}
This is the XML output.
<figure rend='array' id-text='1.1' id='uid35'> <head>Caption of the figure</head> <p> <table rend='inline'> <row> <cell id-text='1.1' id='uid36'> <figure rend='inline' width='2.0pt' file='Logo-INRIA-couleur'/> </cell> <cell id-text='1.2' id='uid37'> <figure rend='inline' width='3.0pt' file='Logo-INRIA-couleur'/> </cell> </row> <row> <cell>(a) one</cell> <cell>(b)</cell> </row> </table> </p> <p> <table rend='inline'> <row> <cell id-text='1.3' id='uid38'> <figure rend='inline' width='4.0pt' file='Logo-INRIA-couleur'/> </cell> <cell id-text='1.4' id='uid39'> <figure rend='inline' width='1.3pt' file='Logo-INRIA-couleur'/> </cell> </row> <row> <cell>(c) two</cell> <cell>(d)</cell> </row> </table> </p> </figure>
Preview
Since version 2.11.3, you can change this behaviour. It suffices to set the internal counter \tralics@use@subfigure to a non-zero value. This is done automatically when loading the subfigure package. No table is produced any more: translation of \subfigure is a <subfigure> element, that contains a single element <head> (containing the optional argument). Translation of the mandatory argument should be an inline figure (for instance \includegraphics{foo}), and all attributes from this figure are moved to the subfigure. The subfigure has two additional atributes; as mentioned above, it has an ID so that labels are allowed; it has also parid, that is the number of the paragraph (0 first the first paragraph, 1 for the second, etc). Example:
Reference to figure: \ref{fig:fig1} Reference to first subfigure: \ref{fig:fig1a} Reference to second subfigure: \ref{fig:fig1b} \begin{figure}[htbp] \XMLaddatt{FOO}{BAR} \centering \subfigure[first subfigure caption]{ \includegraphics{figure1a.eps} \label{fig:fig1a} } \hspace{2cm} \subfigure[second subfigure caption]{ \includegraphics[width=3cm]{figure1b.eps} \label{fig:fig1b} } \par \subfigure{\includegraphics{figure1c}} \caption{main figure caption} \label{fig:fig1} \end{figure}
Here is the translation. Note that the figure element has an attribute rend that indicates its type; it is `inline' for a non-float image, case where the file attribute is present. It is `array' if the figure contains one or more arrays of (in general) images, it is `subfigure' if the figure contains subfigures. The example demonstrates how attributes can be added to the figure (you could use this to compensate the fact that Tralics ignores \centering).
<p noindent='true'>Reference to figure: <ref target='uid79'/> Reference to first subfigure: <ref target='uid80'/> Reference to second subfigure: <ref target='uid81'/></p> <figure rend='subfigure' FOO='BAR' id-text='1' id='uid79' place='htbp'> <head>main figure caption</head> <subfigure file='figure1a' extension='eps' parid='0' id-text='1.2' id='uid80'> <head>first subfigure caption</head> </subfigure> <subfigure width='85.35826pt' file='figure1b' extension='eps' parid='0' id-text='1.2' id='uid81'> <head>second subfigure caption</head> </subfigure> <subfigure file='figure1c' parid='1' id-text=1.3' id='uid82'> <head/></subfigure> </figure>
Implemented as a no-op in Tralics for historical reasons. This command is used for sub-items in an index.
The \subparagraph command is used to divide a text in smaller
parts.
There is also a counter subparagraph.
The \subparagraphmark command takes one argument and does
nothing. You can redefine it. It is used to mark subparagraphs.
See \chaptermark
The \subsection command is used to divide a text in smaller parts.
There is also a counter subsection.
The \subsectionmark command takes one argument and does
nothing. You can redefine it. It is used to mark subsections.
See \chaptermark
The \subset command is valid only in math mode. It generates a relation symbol: <mo>⊂</mo> (Unicode U+2282, ⊂). See description of the \le command.
The \Subset command is valid only in math mode. It generates a relation symbol: <mo>⋐</mo> (Unicode U+22D0, ⋐).
The \subseteq command is valid only in math mode. It generates a relation symbol: <mo>⊆</mo> (Unicode U+2286, ⊆). See description of the \le command.
The \subseteqq command is valid only in math mode. It generates a relation symbol: <mo>⫅</mo> (Unicode U+2AC5, ⫅).
The \subsetneq command is valid only in math mode. It generates a relation symbol: <mo>⊊</mo> (Unicode U+228A, ⊊).
The \subsetneqq command is valid only in math mode. It generates a relation symbol: <mo>⫋</mo> (Unicode U+2ACB, ⫋).
The \subsubsection command is used to divide a text in smaller
parts. There is also a counter subsubsection.
The \subsubsectionmark command takes one argument and does
nothing. You can redefine it. It is used to mark subsubsections.
See \chaptermark
The \succ command is valid only in math mode. It generates a relation symbol: <mo>≻</mo> (Unicode U+227B, ≻). See description of the \le command.
The \succapprox command is valid only in math mode. It generates a relation symbol: <mo>⪸</mo> (Unicode U+2AB8, ⪸)
The \succcurlyeq command is valid only in math mode. It generates a relation symbol: <mo>≽</mo> (Unicode U+227D, ≽)
The \succeq command is valid only in math mode. It generates a relation symbol: <mo>⪰</mo> (Unicode U+2AB0, ⪰).
The \succnapprox command is valid only in math mode. It generates a relation symbol: <mo>⪺</mo> (Unicode U+2ABA, ⪺)
The \succneqq command is valid only in math mode. It generates a relation symbol: <mo>⪶</mo> (Unicode U+2AB6, ⪶)
The \succnsim command is valid only in math mode. It generates a relation symbol: <mo>⋩</mo> (Unicode U+22E9, ⋩).
The \succsim command is valid only in math mode. It generates a relation symbol: <mo>≿</mo> (Unicode U+227F, ≿).
The \sum command is valid only in math mode. Its translation is a variable-sized symbol: <mo>∑</mo> (Unicode U+2211, ∑). Here is the list of all these symbols:
$\coprod \bigvee \bigwedge \biguplus \bigcap \bigcup \int \sum \prod \bigotimes \bigoplus \oint \bigsqcup \bigodot$
The XML translation is
<formula type='inline'><math xmlns='http://www.w3.org/1998/Math/MathML'> <mrow><mo>∐</mo> <mo>⋁</mo> <mo>⋀</mo> <mo>⨄</mo> <mo>⋂</mo> <mo>⋃</mo> <mo>∫</mo> <mo>∑</mo> <mo>∏</mo> <mo>⨂</mo> <mo>⨁</mo> <mo>∮</mo> <mo>⨆</mo> <mo>⨀</mo> </mrow></math></formula>
<formula type='inline'> <math xmlns='http://www.w3.org/1998/Math/MathML'> <mrow><mo>∐</mo><mo>⋁</mo><mo>⋀</mo> <mo>⨄</mo><mo>⋂</mo><mo>⋃</mo><mo>∫</mo> <mo>∑</mo><mo>∏</mo><mo>⨂</mo><mo>⨁</mo> <mo>∮</mo><mo>⨆</mo><mo>⨀</mo></mrow> </math> </formula>
All commands are listed in Table 8.8 of the Latex Companion.
The \sup command is valid only in math mode. Its translation is
<mo form='prefix' movablelimits='true'>sup</mo>.
\log command.
The \supset command is valid only in math mode. It generates a relation symbol: <mo>⊃</mo> (Unicode U+2283, ⊃). See description of the \le command.
The \Supset command is valid only in math mode. It generates a relation symbol: <mo>⋑</mo> (Unicode U+22D1, ⋑).
The \supseteq command is valid only in math mode. It generates a relation symbol: <mo>⊇</mo> (Unicode U+2287, ⊇). See description of the \le command.
The \supseteqq command is valid only in math mode. It generates a relation symbol: <mo>⫆</mo> (Unicode U+2AC6, ⫆).
The \supsetneq command is valid only in math mode. It generates a relation symbol: <mo>⊋</mo> (Unicode U+228B, ⊋).
The \supsetneqq command is valid only in math mode. It generates a relation symbol: <mo>⫌</mo> (Unicode U+2ACC, ⫌).
The \surd command is valid only in math mode.
<mi>√</mi> (Unicode U+221A, √)
that looks like
\ldots command.
The \swarrow command is valid only in math mode. It generates an arrow that points South-West: <mo>↙</mo> (Unicode U+2199, ↙). See description of the \leftarrow command.
This command is a wrapper around \char in that the expansion of \symbol{48} is \char 48\relax.
The effect of this command is to inhibit dumping the XML tree at the end of the job.
back to home page
© INRIA 2003-2005, 2006
Last modified $Date: 2008/12/04 18:39:13 $
