This page contains the description of the following commands
\g@addto@macro,
\Game,
\gamma,
\Gamma,
\gcd,
\gdef,
\gdelpresetkeys,
\gdelsavekeys,
\ge,
\genfrac,
\geq,
\geqq,
\geqslant,
\gets,
\gg,
\ggg,
\gggtr,
\gimel,
\glo,
\global,
\globaldefs,
\glossary,
\glueexpr,
\glueshrink,
\glueshrinkorder,
\gluestretch,
\gluestretchorder,
\gluetomu,
\gnapprox,
\gneq,
\gneqq,
\gnsim,
\@gobble,
\@gobblefour,
\@gobbletwo,
\goodbreak,
\gpresetkeys,
\grave,
\gsavekeys,
\gtrapprox,
\gtrdot,
\gtreqless,
\gtreqqless,
\gtrless,
\gtrsim,
\guillemotleft,
\guillemotright,
\gunpresetkeys,
\gunsavekeys,
and environments
gather,
glossaire,
guillemets.
If you say \g@addt@macro\foo{bar}, this will have as effect to globally change the macro \foo, by appending to its right the tokens bar. This is similar to \addto@hook, but is more widely used because there is only a small number of token list registers. See also \@cons.
The \Game command is valid only in math mode. It generates <mi>⅁</mi> (Unicode U+2141, ⅁).
The \gamma command is valid only in math mode. It generates a Greek letter: <mi>γ</mi> (Unicode U+3B3, γ). See description of the \alpha command.
The \Gamma command is valid only in math mode. It generates an uppercase Greek letter: <mi>Γ</mi> (Unicode U+393, Γ). See description of the \alpha command.
This environment has to be used outside math mode, it contains equations separated by \\ commands.
\begin{gather}1<2\\3<4\end{gather}
Translation
<formula id-text='mid1' id='uid1' type='display'> <math mode='display' xmlns='http://www.w3.org/1998/Math/MathML'> <mtable displaystyle='true'> <mtr><mtd><mrow><mn>1</mn><mo><</mo><mn>2</mn></mrow></mtd></mtr> <mtr><mtd><mrow><mn>3</mn><mo><</mo><mn>4</mn></mrow></mtd></mtr> </mtable> </math> </formula>
The \gcd command is valid only in math mode. Its translation is a math operator of the same name: <mo form='prefix' movablelimits='true'>gcd</mo>. For an example see the \log command.
You can say \gdef\foo{bar}. The syntax is the same as \def, but the definition is global.
You can put the prefix \global before \gdef, but this is useless.
The \ge command (and is variant \geq) is valid only in math mode. It generates a relation symbol: <mo>≥</mo> (Unicode U+2265, ≥). See description of the \le command.
The \genfrac command is valid only in math mode. It takes six arguments, say L, R, w, s, N, D. The translation is a fraction N over D, with left and right delimiters L and R. The parameter w specifies the width of the fraction rule. It can be omitted. The parameter s specifies the style, it is a number between 0 and 3, interpreted as \displaystyle, \textstyle, scriptstyle, \scriptscriptstyle. It can be empty.
$$\genfrac{}{}{}{}12 % this is \frac \genfrac[]{2pt}{2}{aaa}{bbb} % brackets, small, thick \genfrac(){0cm}{0}nm % this is \dbinom $$
<formula type='display'> <math mode='display' xmlns='http://www.w3.org/1998/Math/MathML'> <mrow> <!-- \genfrac{}{}{}{}12 --> <mfrac><mn>1</mn> <mn>2</mn></mfrac> <!-- \genfrac[]{2pt}{2}{aaa}{bbb} --> <mfenced open='[' close=']'> <mstyle scriptlevel='1' displaystyle='false'> <mfrac linethickness='2.0pt'> <mrow><mi>a</mi><mi>a</mi><mi>a</mi></mrow> <mrow><mi>b</mi><mi>b</mi><mi>b</mi></mrow> </mfrac> </mstyle> </mfenced> <!--\genfrac(){0cm}{0}nm --> <mfenced open='(' close=')'> <mstyle scriptlevel='0' displaystyle='true'> <mfrac linethickness='0.0pt'><mi>n</mi> <mi>m</mi></mfrac> </mstyle> </mfenced> </mrow> </math> </formula>
Preview
The \geqq command is valid only in math mode; it is a variant of the greater-or-equal symbol: <mo>≧</mo> (Unicode U+2267, ≧).
The \geqslant command is valid only in math mode; it is a variant of the greater-or-equal symbol: <mo>⩾</mo> (Unicode U+2A7E, ⩾). See also description of the \smallint command.
The \gets command is equivalent to the \leftarrow command: <mo>←</mo> (Unicode U+2190, ←). See also description of the \smallint command.
The \gg command is valid only in math mode. It generates a relation symbol: <mo>≫</mo> (Unicode U+226B, ≫). See description of the \le command.
The \ggg command is valid only in math mode. It generates a relation symbol: <mo>⋙</mo> (Unicode U+22D9, ⋙).
The \gggtr command is valid only in math mode. It generates a relation symbol: <mo>⋙</mo> (Unicode U+22D9, ⋙).
The \gimel command is valid only in math mode. It generates <mi>ℷ</mi> (Unicode U+2137, ℷ).
If you say \global\def... then the definition will be global, unless \globaldefs is negative. The prefix can be used before any assignment, like \let, or \catcode25= \advance\count0. Note that \global\def is the same as \gdef and \global\edef is the same as \xdef.
When you say \globaldefs=75 (or any positive value), then all following assignments are global. If \globaldefs is negative, then all following assignments are local, even those prefixed with \global. If the value is zero, only those prefixed with \global are global. (See scanint for details of argument scanning).
Example. The following code translates to 023400. Note that the second assignment to \globaldefs is global, so that this variable is negative outside the group.
\count0=0 \count1=0 \count10=0 \count11=0 \count20=0 \count21=0 { \count0=1 \global\count1=2 \globaldefs=1 \count10=3 \global\count11=4 \globaldefs=-1 \count20=5 \global\count21=6 } \the\count0 \the\count1 \the\count10 \the\count11 \the\count20 \the\count21 \globaldefs=0
The \glo command takes two arguments. The translation of \glo{a}{b} is the same as \item[a]{b}, namely <label>a</label><item> <p>b</p></item>
This is an environment in which you can put \glo commands. (do not confuse with the \glossary command). Example.
\begin{glossaire} \glo{x1}{y1}\glo{x2}{y2}\end{glossaire}
The translation will be:
<list type='gloss'> <head>Glossary</head> <label>x1</label> <item><p>y1</p></item> <label>x2</label> <item><p>y2</p></item> </list>
Note that names are not hard-coded. If the configuration file contains the following
att_gloss_type = "Gloss" xml_gloitem_name = "Glolabel" xml_item_name = "Item" xml_labelitem_name = "Label" xml_list_name = "List" xml_head_name = "Head" xml_glo_name = "The famous glossary"
then the translation will be:
<List type='Gloss'> <Head>The famous glossary</Head> <Glolabel>x1</Glolabel> <Item><p>y1</p></Item> <Glolabel>x2</Glolabel> <Item><p>y2</p></Item> </List>
Like \numexpr, but scans glue.
The commands \gluestretchorder, \glueshrinkorder, \gluestretch, \glueshrink can be used when some internal quantity is scanned, for instance after \the. They read some glue and return one part of the glue, it can be the stretch order or the shrink order (an integer between 0 and 3), or the stretch or shrink value (as a dimension). In the case of 3pt plus 4pt minus 5pt, the stretch value is 4pt, the shrink value is 5pt, the strech and shrink orders are zero. The value 3pt can be obtained by converting the glue to a dimension. In the case of 3pt plus 4fil minus 5fill, the values are the same the stretch order is one, the shrink order is 2. Order 3 is obtained when filll is used.
The commands \gluetomu, \mutoglue read and return some glue. The eTeX manual says: glue is converted into muglue and vice versa by simply equating 1pt with 1mu. In the example here we use the commands described above, and store them somewhere.
\muskip0 = 18mu plus 36mu minus 1 fill \skip0 = 10pt plus 20pt minus 1 fil \edef\uselater{% \the\muskip0,% \the\mutoglue\muskip0,% \the\skip0,% \the\gluetomu\skip0,% \the\mutoglue\gluetomu\skip0,% \the\glueshrink\skip0,% \the\gluestretch\skip0,% \the\glueshrinkorder\skip0,% \the\gluestretchorder\skip0}
The command \xoo defined here contains the same characters as \uselater. The non-trivial point is that all characters produced by \the are of category code 12.
{\let\GDEF\gdef\let\XDEF\xdef\def\S{ } \catcode`m=12 \catcode`u=12 \catcode`p=12 \catcode`f=12 \catcode`i=12 \catcode`l=12 \catcode`n=12 \catcode`i=12 \catcode`s=12 \catcode`t=12 \GDEF\MU{mu}\GDEF\PT{pt}\GDEF\FIL{fil}\GDEF\FILL{fill}% \GDEF\PLUS{plus}\GDEF\MINUS{minus} \XDEF\xoo{18.0\MU\S \PLUS\S 36.0\MU\S \MINUS\S 1.0\FILL,% 18.0\PT\S \PLUS\S 36.0\PT\S \MINUS\S 1.0\FILL,% 10.0\PT\S \PLUS\S 20.0\PT\S \MINUS\S 1.0\FIL,% 10.0\MU\S \PLUS\S 20.0\MU\S \MINUS\S 1.0\FIL,% 10.0\PT\S \PLUS\S 20.0\PT\S \MINUS\S 1.0\FIL,% 1.0\PT,20.0\PT,1,0}}
The command \yoo defined here contains the same characters and same category codes as \uselater.
\edef\yoo{\detokenize{18.0mu plus 36.0mu minus 1.0fill,% 18.0pt plus 36.0pt minus 1.0fill,% 10.0pt plus 20.0pt minus 1.0fil,% 10.0mu plus 20.0mu minus 1.0fil,% 10.0pt plus 20.0pt minus 1.0fil,% 1.0pt,20.0pt,1,0}} \ifx\yoo\xoo\else\bad\fi
Inverse function of \mutoglue (See above for an example).
The \gnapprox command is valid only in math mode; it is a variant of the greater-or-equal symbol: <mo>⪊</mo> (Unicode U+2A8A, ⪊).
The \gneq command is valid only in math mode; it is a variant of the greater-or-equal symbol: <mo>⪈</mo> (Unicode U+2A88, ⪈).
The \geqq command is valid only in math mode; it is a variant of the greater-or-equal symbol: <mo>≩</mo> (Unicode U+2269, ≩).
The \gnsim command is valid only in math mode; it is a variant of the greater-or-equal symbol: <mo>⋧</mo> (Unicode U+22E7, ⋧).
The \@gobble command reads one argument and does nothing with it. In the same fashion \@gobbletwo and \@gobblefour read two and four arguments.
In Tralics, the \goodbreak command is the same as \par. In LaTeX, it adds also some penalty (value -500).
The \grave command puts a grave accent over a kernel. It works only in math mode. See also the \acute command.
The \gtrapprox is valid in math mode only; translation is <mo>⪆</mo> (Unicode U+2A86, ⪆).
The \gtrdot is valid in math mode only; translation is <mo>⋗</mo> (Unicode U+22D7, ⋗).
The \gtreqless is valid in math mode only; translation is <mo>⋛</mo> (Unicode U+22DB, ⋛).
The \gtreqqless is valid in math mode only; translation is <mo>⪌</mo> (Unicode U+2A8C, ⪌).
The \gtrless command gives a greater/less than symbol. It works only in math mode: <mo>≷</mo> (Unicode U+2277, ≷). See also description of the \smallint command.
The \gtrsim is valid in math mode only; translation is <mo>≳</mo> (Unicode U+2273, ≳).
If you say \begin{guillemets}xxx\end{guilemets}, it is the same as if you had said «xxx». But in a future version of the software the environment may produce much nicer results.
The \guillemotleft command translates into « or «. For more info see the latin supplement characters.
The \guillemotright command translates into » or ». For more info see the latin supplement characters.
These commands are provided by the xkeyval package.
back to home page
© INRIA 2003-2005, 2006
Last modified $Date: 2008/11/24 12:42:53 $
