Introduction
ASCII characters (between U+0020 and U+007F)
Latin one (between U+00A0 and U+00FF)
Latin extended-A (between U+0100 and U+017F)
Latin extended-B (between U+0180 and U+024F) [todo]
IPA Extensions (between U+0250 and U+02AF) [todo]
Greek, etc (between U+0370 and U+03FF) [todo]
Cyrillic, etc (between U+0400 and U+04FF) [todo]
Latin Extended Additional (between U+1E00 and U+1EFF)
Arrows (between U+2190 and U+21FF)
Mathematical Operators (between U+2200 and U+22FF)
Miscellaneous Technical (between U+2300 and U+23FF) [with holes]
Miscellaneous Symbols (between U+2600 and U+26FF) [with holes]
Dingbats (between U+2700 and U+27BF)
Mathematical Alphanumeric Symbols (between U+1D400 and U+1D5FF)
This file explains how to produce all characters defined by the Unicode standard, and even more. At the beginning Tralics used internally the iso-8859-1 encoding, and this is the default input encoding; you could tell Tralics that the text is encoded in UTF-8 format, this meant that some characters were converted into a sequence of the form \char567{} (this is read as a sequence of six tokens).
UTF-8 is a variable length format; each character consists in one to four bytes, A, AB, ABC, or ABCD, depending of the first byte. If the first bit of A is zero, so that A is an integer between 0 and 127, then one byte is used, and the value is A. Thus, an ASCII character represents itself in UTF8. Otherwise, A starts with 2, 3 or 4 bits equal to 1, and is followed by a zero bit, followed by some useful bits (say `a'). The total number of bytes is 2, 3 or 4, respectively, each byte B, C, D starts with a bit equal to 1 , and a bit equal to 0, and is followed by 6 useful bits, say `b', or `c', or `d'; the value of the character is `ab', `abc' or `abcd'. Thus, using 2, 3 or 4 bytes, we can represent 11, 16, or 21 bits. When a line of text is read from a file, it is converted to UTF8; at the end of the run, you may see something like Input conversion: 14 lines converted. This means that almost all lines contained only ASCII characters.
A construction like \char1000 means: insert the character number 1000 in the XML tree. The character must fit on 27 bits. A construction like ^^ab (two lower case hex chars) can be used to represent a 8bit character, and a construction like ^^^^abcd (four lower case hex chars) can be used to represent a 16bit character. An important property of a character is its category code. In the case of \foo, you get a command with 3 characters in its name if you replace o a letter (a character with category code 11). In you say \fée, the result is a 1-character command (it tries to put an accent on the character that follows). You can say \catcode`é=11\def\fée{fairy}, and then use the command \fée. All tables that hold character properties are of size 65536; this excludes characters that need 4 UTF8 bytes, but includes all characters that can be constructed via the double-hat or four-hat construction.
The translation of \char100\char1000\char100000 is a sequence of 3 characters: dϨ𘚠. The first character is ASCII, so that you will see an ASCII character, the last does not fit on 16bits, hence is represented as a character reference. For all other characters, the printed value depends on a flag (a parameter to the program). You can use one of -oe8, -oe1, -oe8a, -oe1a. If the letter a is given, then all non-7 bits characters are printed as character references, like Ϩ. In the case of oe1 (the default), characters that fit on 8bits, but not on 7, are printed using ISO-8859-1 encoding, characters that do not fit are printed as Ϩ. In the case of oe8, UTF-8 is used.
You can use one of -te8, -te1, -te8a, -te1a as option for controlling the encoding used in the transcript file. In verbose mode, you will see {Text:d^^^^03e8𘚠}. Note that the four-hat construction is used whenever possible. This encoding also used when Tralics prints something on the terminal. For instance, this is the output of \show, in UTF8 mode: \fée=macro: ->fairy.
You can use one of -utf8, -latin1 for indicating the default input encoding. In LaTeX, you can use the inputenc package for specifying alternate encodings, this is not yet implemented. All files are converted into UTF-8 while they are read; there is an exception: the main file is converted only after the configuration file has been read (this means that the configuration file could contain the definition of the encoding). Currently you can override the default encoding by putting `iso-8859-1' or `utf8-encoded' on the first line of the file. This works whatever the type of the file: configuration file, bibliography data base, or TeX file.
A given character can appear in one of three modes: typesetting text, typesetting maths, and other cases (in general, when creating the name of an element, of an attribute, the name of a file to be opened, etc). In the case of \input{xx}, the characters that are valid are system dependent, and Tralics accepts only latin1 characters, without further tests. In the same fashion, \xbox{á b}{\AddAttToCurrent{x=}{y}z} generates an XML element that contains a space in its name, and an attribute name that contains an equals sign. This is illegal, but not refused. If you say \xbox{x\xmllatex{\&\#x5678;}{}y}{} the result is an empty XML with a funny name: <x噸y/>.
In math mode, each character is classified as an identifier, a number, or an operator (such an element can consist of more than one character). Hence the translation of $x=1$ is: <mi>x</mi><mo>=</mo><mn>1</mn>. There is a built-in table that explains the type of every ASCII character. Non-ASCII latin1 characters are all considered as operators if their code is between 128 and 191, as identifiers otherwise. Thus, the translation of $±á$ is <mo>±</mo><mi>á</mi>. There is a large number of commands whose translation is a Unicode character. LaTeX makes a distinction between those that can be used in math, or outside math; this restriction has sometimes been removed. For instance \textohm is the same as ^^^^2126, and the following expression \xbox{\textohm b}{\textohm$\textohm$} is valid. The math formula contains an identifier.
If you say \mathchardef\foo1234, then TeX interprets \foo as \mathchar1234. See the TeX book for what character this produces. For simplicity, Tralics interprets this as \char1234; this is the character number 1234 (Unicode U+4D2, some Cyrillic character. Any 27 bit character can be used in this way. A command like \Omega can be used only in math mode. The translation is an identifier (but most math symbols are operators), the value is Ω. If the option -noentnames has been given, then translation is class='txt'Ω. Translation of \mathbb A is 𝔸 or 𝍘. If you specify the mathvariant option, then translation changes to <mi mathvariant='double-struck'>A</mi>.
In text mode, there are different ways to obtain a character, and they are all valid. For instance, if you want a acute, you can say á (latin1 input) or \char`\á \char"E1 (two variants of the \char command) or \'a \a'a (two variants of the accent command) or \xmllatex{\&\#xE1;}{} \xmllatex{\á}{} (two variants of the \xmllatex command that refers to a Unicode character via an entity).
Printing characters with code between 33 and 126 is not complicated. Character 32 is space, it is impossible to tell the difference between a cell that contains only space and an empty space. Character 127 is delete, it cannot be printed. For some strange reason, LaTeX provides no way for printing a hat or a tilde. This is why \char is used in the table below.
\begin{tabular}{cccccccccccccccc} &!&"&\#&\$&\%&\&&'&(&)&*&+&,&-&.&/\\ 0&1&2&3&4&5&6&7&8&9&:&;&<&=&>&?\\ @&A&B&C&D&E&F&G&H&I&J&K&L&M&N&O\\ P&Q&R&S&T&U&V&W&X&Y&Z&[&\textbackslash&]&\char`\^&\_\\ `&a&b&c&d&e&f&g&h&i&j&k&l&m&n&o\\ p&q&r&s&t&u&v&w&x&y&z&\{&|&\}&\char`\~& \end{tabular}
The translation is trivial. We only show the preview (LaTeX image) and the
HTML characters.
0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | : | ; | < | = | > | ? |
@ | A | B | C | D | E | F | G | H | I | J | K | L | M | N | O |
P | Q | R | S | T | U | V | W | X | Y | Z | [ | \ | ] | ^ | _ |
` | a | b | c | d | e | f | g | h | i | j | k | l | m | n | o |
p | q | r | s | t | u | v | w | x | y | z | { | | | } | ~ |
These are all the characters with code between x80 and xFF. In fact, characters in the range x80 and x9F are not printable. Character A0 is a space, character AD is a discretionary hyphen.
\begin{tabular}{cccccccccccccccc} ~&¡&¢&£&¤&¥&¦&§&¨&©&ª&«&¬&&®&¯\\ °&±&²&³&´&µ&¶&·&¸&¹&º&»&¼&½&¾&¿\\ À&Á&Â&Ã&Ä&Å&Æ&Ç&È&É&Ê&Ë&Ì&Í&Î&Ï\\ Ð&Ñ&Ò&Ó&Ô&Õ&Ö&×&Ø&Ù&Ú&Û&Ü&Ý&Þ&ß\\ à&á&â&ã&ä&å&æ&ç&è&é&ê&ë&ì&í&î&ï\\ ð&ñ&ò&ó&ô&õ&ö&÷&ø&ù&ú&û&ü&ý&þ&ÿ\\ \end{tabular}
¡ | ¢ | £ | ¤ | ¥ | ¦ | § | ¨ | © | ª | « | ¬ | | ® | ¯ | |
° | ± | ² | ³ | ´ | µ | ¶ | · | ¸ | ¹ | º | » | ¼ | ½ | ¾ | ¿ |
À | Á | Â | Ã | Ä | Å | Æ | Ç | È | É | Ê | Ë | Ì | Í | Î | Ï |
Ð | Ñ | Ò | Ó | Ô | Õ | Ö | × | Ø | Ù | Ú | Û | Ü | Ý | Þ | ß |
à | á | â | ã | ä | å | æ | ç | è | é | ê | ë | ì | í | î | ï |
ð | ñ | ò | ó | ô | õ | ö | ÷ | ø | ù | ú | û | ü | ý | þ | ÿ |
Seven bit input for the same characters.
\begin{tabular}{cccccccccccccccc} \nobreakspace&\textexclamdown&\textcent&\textsterling&\textcurrency&\textyen& \textbrokenbar&\textsection&\textasciidieresis&\textcopyright& \textordfeminine&\guillemotleft&\textlnot&\textsofthyphen& \textregistered&\textasciimacron\\ \textdegree&\textpm&\texttwosuperior&\textthreesuperior&\textasciiacute& \textmu&\textparagraph&\textperiodcentered&\textasciicedilla& \textonesuperior&\textordmasculine&\guillemotright&\textonequarter& \textonehalf&\textthreequarters&\textquestiondown\\ \`A&\'A&\^A&\~A&\"A&\AA&\AE&\c C&\`E&\'E&\^E&\"E&\`I&\'I&\^I&\"I\\ \DH&\~N&\`O&\'O&\^O&\~O&\"O&\texttimes&\O&\`U&\'U&\^U&\"U&\'Y&\TH&\ss\\ \`a&\'a&\^a&\~a&\"a&\aa&\ae&\c c&\`e&\'e&\^e&\"e&\`i&\'i&\^i&\"i\\ \dh&\~n&\`o&\'o&\^o&\~o&\"o&\textdiv&\o&\`u&\'u&\^u&\"u&\'y&\th&\"y\\ \end{tabular}
Notes: \textsection=\S, \textparagraph=\P, \textcopyright =\copyright. Concerning French guillemets, you can use \og, that produces a guillemet and a space, or \guillemotleft that produces only the guillemet, or « or (if the current language is French) << that produce intelligent guillemets: a space is removed if there is one, then another one is added. Example
{\language=1 a\fg{}b\og{}c\guillemotleft{}d\guillemotright{}e} {\language=0 a\fg{}b\og{}c\guillemotleft{}d\guillemotright{}e} {\language=1 a<<b<< c<<~d<<\,e\,>>f~>>g >>h>>i} {\language=0 a<<b<< c<<~d<<\,e\,>>f~>>g >>h>>i} {\language=1 a«b« c«~d«\,e\,»f~»g »h»i} {\language=0 a«b« c«~d«\,e\,»f~»g »h»i}
Translation (we replaced character U+A0 by an entity, in order to distinguish it from a space).
a »b« c« d »e a »b« c«d»e a« b« c«  d« e  »f  »g »h »i a<<b<< c<< d<< e >>f >>g >>h>>i a« b« c«  d« e  »f  »g »h »i a«b« c« d« e »f »g »h»i
These are all the characters with code between U+100 and U+17F.
\def\nument#1{\xmllatex{\&\#x#1;}{}} \begin{tabular}{cccccccccccccccc} \=A&\=a& \u A&\u a&\k A&\k a&\'C&\'c&\^C&\^c&\.C&\.c&\v C&\v c&\v D&\v d \\ \DJ&\dj&\=E&\=e&\u E&\u e&\.E&\.e&\k E&\k e&\v E&\v e&\^G&\^g&\u G&\u g\\ \.G&\.g&\c G&\c g&\^H&\^h&\=H&\=h&\~I&\~i&\=I&\=i&\u I&\u i&\k I&\k i\\ \.I&\i&\IJ&\ij&\^J&\^j&\c K&\c k&\nument{138}&\'L&\'l&\c L&\c l&\v L&\v l&\.L\\ \.l&\L&\l&\'N&\'n&\c N&\c n&\v N&\v n&\nument{149}&\NG&\ng&\=O&\=o&\u O&\u o\\ \H O&\H o&\OE&\oe&\'R&\'r&\c R&\c r&\v R&\v r&\'S&\'s&\^S&\^s&\c S&\c s&\\ \v S&\v s&\c T&\c t&\v T&\v t&\=T&\=t&\~U&\~u&\=U&\=u&\u U&\u u&\r U&\r u\\ \H U&\H u&\k U&\k u&\^W&\^w&\^Y&\^y&\"Y&\'Z&\'z&\.Z&\.z&\v Z&\v z&\nument{17F}\\ \end{tabular}
Characters U+138, U+149 and U+17F have no name in Tralics. The first one is: `latin small letter kra', the second is `latin small letter n preceded by apostrophe', and the last is `latin small letter long s'.
This is the XML translation, without the `tabular'.
Ā ā Ă ă Ą ą Ć ć Ĉ ĉ Ċ ċ Č č Ď ď Đ đ Ē ē Ĕ ĕ Ė ė Ę ę Ě ě Ĝ ĝ Ğ ğ Ġ ġ Ģ ģ Ĥ ĥ Ħ ħ Ĩ ĩ Ī ī Ĭ ĭ Į į İ ı IJ ij Ĵ ĵ Ķ ķ ĸ Ĺ ĺ Ļ ļ Ľ ľ Ŀ ŀ Ł ł Ń ń Ņ ņ Ň ň ʼn Ŋ ŋ Ō ō Ŏ ŏ Ő ő Œ œ Ŕ ŕ Ŗ ŗ Ř ř Ś ś Ŝ ŝ Ş ş Š š Ţ ţ Ť ť Ŧ ŧ Ũ ũ Ū ū Ŭ ŭ Ů ů Ű ű Ų ų Ŵ ŵ Ŷ ŷ Ÿ Ź ź Ż ż Ž ž ſ
As you can see, translation is trivial. In the initial version of the software, there was a possibility to obtain entity names.
Ā | ā | Ă | ă | Ą | ą | Ć | ć | Ĉ | ĉ | Ċ | ċ | Č | č | Ď | ď | |
Đ | đ | Ē | ē | Ĕ | ĕ | Ė | ė | Ę | ę | Ě | ě | Ĝ | ĝ | Ğ | ğ | |
Ġ | ġ | Ģ | ģ | Ĥ | ĥ | Ħ | ħ | Ĩ | ĩ | Ī | ī | Ĭ | ĭ | Į | į | |
İ | ı | IJ | ij | Ĵ | ĵ | Ķ | ķ | ĸ | Ĺ | ĺ | Ļ | ļ | Ľ | ľ | Ŀ | |
ŀ | Ł | ł | Ń | ń | Ņ | ņ | Ň | ň | ʼn | Ŋ | ŋ | Ō | ō | Ŏ | ŏ | |
Ő | ő | Œ | œ | Ŕ | ŕ | Ŗ | ŗ | Ř | ř | Ś | ś | Ŝ | ŝ | Ş | ş | |
Š | š | Ţ | ţ | Ť | ť | Ŧ | ŧ | Ũ | ũ | Ū | ū | Ŭ | ŭ | Ů | ů | |
Ű | ű | Ų | ų | Ŵ | ŵ | Ŷ | ŷ | Ÿ | Ź | ź | Ż | ż | Ž | ž | ſ |
We explain here how to obtain all characters between U+1E00 and U+1EFF. Character U+1e9a (latin small letter a with right half ring) is not implemented. There are two holes in the tables: of 4 and 6 characters respectively.
\def\xx#1{\xmllatex{\&\#x#1;}{}} \catcode`\&13\def&{ } \D A &\D a&\.B&\.b &\d B&\d b&\b B&\b b& \'{\c C} &\'{\c c}& \.D &\.d &\d D& \d d &\b D &\b d\\ \c D &\c d& \V D& \V d &\`{\=E}& \`{\=e} &\'{\=E}&\'{\=e}& \V E &\V e &\T E& \T e& \u{\c E}& \u{\c e}& \.F &\.f\\ \=G &\=g& \.H &\.h& \d H&\d h&\"H &\" h&\c H&\c h&\xx{1e2a}&\xx{1e2b} &\T I&\T i&\'{\"I}&\'{\"i}\\ \'K&\'k&\d K&\d k& \b K&\b k&\d L&\d l&\={\d L}&\={\d l}&\b L&\b l&\V L &\V l&\'M&\'m \\ \.M&\.m&\d M&\d m&\.N&\.n&\d N&\d n&\b N&\b n&\V N&\V n&\~{\'O}&\~{\'o} &\~{\"O}&\~{\"o}\\ \`{\=O}&\`{\=o}&\'{\=O}&\'{\=o}&\'P&\'p&\.P&\.p&\. R&\. r&\d R&\d r& \={\d R}&\={\d r}&\b R&\b r\\ \.S&\.s&\d S&\d s&\.{\'S}&\.{\'s}&\v{\.S}&\v{\.s}&\d{\.S}&\d{\.s} &\.T&\. t&\d T&\d t&\b T&\b t\\ \V T&\V t&\xx{1e72}&\xx{1e73}&\T U&\T u&\V U&\V u&\~{\'U}&\~{\'u}& \={\"U}&\={\"u}&\~V&\~v&\d V&\d v\\
Translation
<p>Ḁ ḁ Ḃ ḃ Ḅ ḅ Ḇ ḇ Ḉ ḉ Ḋ ḋ Ḍ ḍ Ḏ ḏ</p><p noindent='true'> Ḑ ḑ Ḓ ḓ Ḕ ḕ Ḗ ḗ Ḙ ḙ Ḛ ḛ Ḝ ḝ Ḟ ḟ</p><p noindent='true'> Ḡ ḡ Ḣ ḣ Ḥ ḥ Ḧ ḧ Ḩ ḩ ḪḫḬ ḭ Ḯ ḯ</p><p noindent='true'> Ḱ ḱ Ḳ ḳ Ḵ ḵ Ḷ ḷ Ḹ ḹ Ḻ ḻ Ḽ ḽ Ḿ ḿ</p><p noindent='true'> Ṁ ṁ Ṃ ṃ Ṅ ṅ Ṇ ṇ Ṉ ṉ Ṋ ṋ Ṍ ṍ Ṏ ṏ</p><p noindent='true'> Ṑ ṑ Ṓ ṓ Ṕ ṕ Ṗ ṗ Ṙ ṙ Ṛ ṛ Ṝ ṝ Ṟ ṟ</p><p noindent='true'> Ṡ ṡ Ṣ ṣ Ṥ ṥ Ṧ ṧ Ṩ ṩ Ṫ ṫ Ṭ ṭ Ṯ ṯ</p><p noindent='true'> Ṱ ṱ ṲṳṴ ṵ Ṷ ṷ Ṹ ṹ Ṻ ṻ Ṽ ṽ Ṿ ṿ</p>
Ḁ | ḁ | Ḃ | ḃ | Ḅ | ḅ | Ḇ | ḇ | Ḉ | ḉ | Ḋ | ḋ | Ḍ | ḍ | Ḏ | ḏ |
Ḑ | ḑ | Ḓ | ḓ | Ḕ | ḕ | Ḗ | ḗ | Ḙ | ḙ | Ḛ | ḛ | Ḝ | ḝ | Ḟ | ḟ |
Ḡ | ḡ | Ḣ | ḣ | Ḥ | ḥ | Ḧ | ḧ | Ḩ | ḩ | Ḫ | ḫ | Ḭ | ḭ | Ḯ | ḯ |
Ḱ | ḱ | Ḳ | ḳ | Ḵ | ḵ | Ḷ | ḷ | Ḹ | ḹ | Ḻ | ḻ | Ḽ | ḽ | Ḿ | ḿ |
Ṁ | ṁ | Ṃ | ṃ | Ṅ | ṅ | Ṇ | ṇ | Ṉ | ṉ | Ṋ | ṋ | Ṍ | ṍ | Ṏ | ṏ |
Ṑ | ṑ | Ṓ | ṓ | Ṕ | ṕ | Ṗ | ṗ | Ṙ | ṙ | Ṛ | ṛ | Ṝ | ṝ | Ṟ | ṟ |
Ṡ | ṡ | Ṣ | ṣ | Ṥ | ṥ | Ṧ | ṧ | Ṩ | ṩ | Ṫ | ṫ | Ṭ | ṭ | Ṯ | ṯ |
Ṱ | ṱ | Ṳ | ṳ | Ṵ | ṵ | Ṷ | ṷ | Ṹ | ṹ | Ṻ | ṻ | Ṽ | ṽ | Ṿ | ṿ |
\catcode`\&13\def&{ } \`W&\`w&\'W&\'w&\"W&\"w&\.W&\.w&\d W&\d w&\. X&\. x&\"X&\"x&\. Y&\.y\\ \^Z&\^z&\d Z&\d z&\b Z&\b z&\b h&\" t&\r w&\r y&?&\xx{1e9b}\\ \d A&\d a&\h A&\h a&\^{\'A}&\^{\'a}&\^{\`A}&\^{\`a}&{\^{\h A}}&\^{\h a}& \~{\^A}&\~{\^a}&\d{\^A}&\d{\^a}&\'{\u A}&\'{\u a}\\ \`{\u A}&\`{\u a}&\h{\u A}&\h{\u a}&\~{\u A}&\~{\u a}&\d{\u A}&\d{\u a}&\d E& \d e&\h E&\h e&\~ E&\~e&\'{\^E}&\'{\^e}\\ \^{\`E}&\^{\`e}&\^{\h E}&\^{\h e}&\~{\^E}&\~{\^e}&\^{\d E}&\^{\d e}&\h I& \h i&\d I&\d i& \d O &\d o&\h O&\h o\\ \'{\^O}&\'{\^o}&\`{\^O}&\`{\^o}&\^{\h O}&\^{\h o}&\~{\^O}&\~{\^o}& \^{\d O}&\^{\d o}&\'{\H O}&\'{\H o}&\`{\H O}&\`{\H o}&\h{\H O}&\h{\H o}\\ \~{\H O}&\~{\H o}&\d{\H O}&\d{\H o}&\d U&\d u&\h U&\h u&\'{\H U}&\'{\H u}& \`{\H U}&\`{\H u}&\h{\H U}&\h{\H u}&\~{\H U}&\~{\H u}\\ \H{\d U}&\H{\d u}&\` Y&\` y&\d Y&\d y&\h Y&\h y&\~ Y&\~y
<p> Ẁ ẁ Ẃ ẃ Ẅ ẅ Ẇ ẇ Ẉ ẉ Ẋ ẋ Ẍ ẍ Ẏ ẏ</p><p noindent='true'> Ẑ ẑ Ẓ ẓ Ẕ ẕ ẖ ẗ ẘ ẙ ? ẛ</p><p noindent='true'> Ạ ạ Ả ả Ấ ấ Ầ ầ Ẩ ẩ Ẫ ẫ Ậ ậ Ắ ắ</p><p noindent='true'> Ằ ằ Ẳ ẳ Ẵ ẵ Ặ ặ Ẹ ẹ Ẻ ẻ Ẽ ẽ Ế ế</p><p noindent='true'> Ề ề Ể ể Ễ ễ Ệ ệ Ỉ ỉ Ị ị Ọ ọ Ỏ ỏ</p><p noindent='true'> Ố ố Ồ ồ Ổ ổ Ỗ ỗ Ộ ộ Ớ ớ Ờ ờ Ở ở</p><p noindent='true'> Ỡ ỡ Ợ ợ Ụ ụ Ủ ủ Ứ ứ Ừ ừ Ử ử Ữ ữ</p><p noindent='true'> Ự ự Ỳ ỳ Ỵ ỵ Ỷ ỷ Ỹ ỹ</p>
Ẁ | ẁ | Ẃ | ẃ | Ẅ | ẅ | Ẇ | ẇ | Ẉ | ẉ | Ẋ | ẋ | Ẍ | ẍ | Ẏ | ẏ |
Ẑ | ẑ | Ẓ | ẓ | Ẕ | ẕ | ẖ | ẗ | ẘ | ẙ | ? | ẛ | ||||
Ạ | ạ | Ả | ả | Ấ | ấ | Ầ | ầ | Ẩ | ẩ | Ẫ | ẫ | Ậ | ậ | Ắ | ắ |
Ằ | ằ | Ẳ | ẳ | Ẵ | ẵ | Ặ | ặ | Ẹ | ẹ | Ẻ | ẻ | Ẽ | ẽ | Ế | ế |
Ề | ề | Ể | ể | Ễ | ễ | Ệ | ệ | Ỉ | ỉ | Ị | ị | Ọ | ọ | Ỏ | ỏ |
Ố | ố | Ồ | ồ | Ổ | ổ | Ỗ | ỗ | Ộ | ộ | Ớ | ớ | Ờ | ờ | Ở | ở |
Ỡ | ỡ | Ợ | ợ | Ụ | ụ | Ủ | ủ | Ứ | ứ | Ừ | ừ | Ử | ử | Ữ | ữ |
Ự | ự | Ỳ | ỳ | Ỵ | ỵ | Ỷ | ỷ | Ỹ | ỹ |
You can use the \ding command in order to access one character of the Zapf Dingbats fonts. The command takes one argument, an integer (it is parsed by the scanint routine, see scanint for details, so that \ding{`\A} is as valid as \char`\A). If the number is between 33 and 126, or between 161 and 239, or between 241 and 254, then you get one of the characters listed below. Otherwise, the translation is bad!
Example that shows the complete list.
{\LARGE \begin{tabular}{cccccccccccccccc} %\catcode`\&13\def&{ } &\ding{"21}&\ding{"22}&\ding{"23}&\ding{"24}&\ding{"25}&\ding{"26}&\ding{"27}& \ding{"28}&\ding{"29}&\ding{"2A}&\ding{"2B}&\ding{"2C}&\ding{"2D}&\ding{"2E}&\ding{"2F}\\ \ding{"30}&\ding{"31}&\ding{"32}&\ding{"33}&\ding{"34}&\ding{"35}&\ding{"36}&\ding{"37}& \ding{"38}&\ding{"39}&\ding{"3A}&\ding{"3B}&\ding{"3C}&\ding{"3D}&\ding{"3E}&\ding{"3F}\\ \ding{"40}&\ding{"41}&\ding{"42}&\ding{"43}&\ding{"44}&\ding{"45}&\ding{"46}&\ding{"47}& \ding{"48}&\ding{"49}&\ding{"4A}&\ding{"4B}&\ding{"4C}&\ding{"4D}&\ding{"4E}&\ding{"4F}\\ \ding{"50}&\ding{"51}&\ding{"52}&\ding{"53}&\ding{"54}&\ding{"55}&\ding{"56}&\ding{"57}& \ding{"58}&\ding{"59}&\ding{"5A}&\ding{"5B}&\ding{"5C}&\ding{"5D}&\ding{"5E}&\ding{"5F}\\ \ding{"60}&\ding{"61}&\ding{"62}&\ding{"63}&\ding{"64}&\ding{"65}&\ding{"66}&\ding{"67}& \ding{"68}&\ding{"69}&\ding{"6A}&\ding{"6B}&\ding{"6C}&\ding{"6D}&\ding{"6E}&\ding{"6F}\\ \ding{"70}&\ding{"71}&\ding{"72}&\ding{"73}&\ding{"74}&\ding{"75}&\ding{"76}&\ding{"77}& \ding{"78}&\ding{"79}&\ding{"7A}&\ding{"7B}&\ding{"7C}&\ding{"7D}&\ding{"7E}&\\ &\ding{"A1}&\ding{"A2}&\ding{"A3}&\ding{"A4}&\ding{"A5}&\ding{"A6}&\ding{"A7}& \ding{"A8}&\ding{"A9}&\ding{"AA}&\ding{"AB}&\ding{"AC}&\ding{"AD}&\ding{"AE}&\ding{"AF}\\ \ding{"B0}&\ding{"B1}&\ding{"B2}&\ding{"B3}&\ding{"B4}&\ding{"B5}&\ding{"B6}&\ding{"B7}& \ding{"B8}&\ding{"B9}&\ding{"BA}&\ding{"BB}&\ding{"BC}&\ding{"BD}&\ding{"BE}&\ding{"BF}\\ \ding{"C0}&\ding{"C1}&\ding{"C2}&\ding{"C3}&\ding{"C4}&\ding{"C5}&\ding{"C6}&\ding{"C7}& \ding{"C8}&\ding{"C9}&\ding{"CA}&\ding{"CB}&\ding{"CC}&\ding{"CD}&\ding{"CE}&\ding{"CF}\\ \ding{"D0}&\ding{"D1}&\ding{"D2}&\ding{"D3}&\ding{"D4}&\ding{"D5}&\ding{"D6}&\ding{"D7}& \ding{"D8}&\ding{"D9}&\ding{"DA}&\ding{"DB}&\ding{"DC}&\ding{"DD}&\ding{"DE}&\ding{"DF}\\ \ding{"E0}&\ding{"E1}&\ding{"E2}&\ding{"E3}&\ding{"E4}&\ding{"E5}&\ding{"E6}&\ding{"E7}& \ding{"E8}&\ding{"E9}&\ding{"EA}&\ding{"EB}&\ding{"EC}&\ding{"ED}&\ding{"EE}&\ding{"EF}\\ &\ding{"F1}&\ding{"F2}&\ding{"F3}&\ding{"F4}&\ding{"F5}&\ding{"F6}&\ding{"F7}& \ding{"F8}&\ding{"F9}&\ding{"FA}&\ding{"FB}&\ding{"FC}&\ding{"FD}&\ding{"FE}&\\ \end{tabular} }
Translation, without the table and the font change. As you can see, the codes are between U+2700 and U+27BF, with some exceptions. For instance character 169 gives U+2666. This is black diamond suit. But the file mmlalias.ent defines ♦ to be the same character, and this is used to translate $\diamondsuit$.
<p>✁ ✂ ✃ ✄ ☎ ✆ ✇ ✈ ✉ ☛ ☞ ✌ ✍ ✎ ✏</p> <p noindent='true'>✐ ✑ ✒ ✓ ✔ ✕ ✖ ✗ ✘ ✙ ✚ ✛ ✜ ✝ ✞ ✟</p> <p noindent='true'>✠ ✡ ✢ ✣ ✤ ✥ ✦ ✧ ★ ✩ ✪ ✫ ✬ ✭ ✮ ✯</p> <p noindent='true'>✰ ✱ ✲ ✳ ✴ ✵ ✶ ✷ ✸ ✹ ✺ ✻ ✼ ✽ ✾ ✿</p> <p noindent='true'>❀ ❁ ❂ ❃ ❄ ❅ ❆ ❇ ❈ ❉ ❊ ❋ ● ❍ ■ ❏</p> <p noindent='true'>❐ ❑ ❒ ▲ ▼ ◆ ❖ ◗ ❘ ❙ ❚ ❛ ❜ ❝ ❞ </p> <p noindent='true'> ❡ ❢ ❣ ❤ ❥ ❦ ❧ ♣ ♦ ♥ ♠ ① ② ③ ④</p> <p noindent='true'>⑤ ⑥ ⑦ ⑧ ⑨ ⑩ ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❾ ❿</p> <p noindent='true'>➀ ➁ ➂ ➃ ➄ ➅ ➆ ➇ ➈ ➉ ➊ ➋ ➌ ➍ ➎ ➏</p> <p noindent='true'>➐ ➑ ➒ ➓ ➔ → ↔ ↕ ➘ ➙ ➚ ➛ ➜ ➝ ➞ ➟</p> <p noindent='true'>➠ ➡ ➢ ➣ ➤ ➥ ➦ ➧ ➨ ➩ ➪ ➫ ➬ ➭ ➮ ➯</p> <p noindent='true'> ➱ ➲ ➳ ➴ ➵ ➶ ➷ ➸ ➹ ➺ ➻ ➼ ➽ ➾ </p>
This is the table
❡ | ❢ | ❣ | ❤ | ❥ | ❦ | ❧ | ♣ | ♦ | ♥ | ♠ | ① | ② | ③ | ④ | |
⑤ | ⑥ | ⑦ | ⑧ | ⑨ | ⑩ | ❶ | ❷ | ❸ | ❹ | ❺ | ❻ | ❼ | ❽ | ❾ | ❿ |
➀ | ➁ | ➂ | ➃ | ➄ | ➅ | ➆ | ➇ | ➈ | ➉ | ➊ | ➋ | ➌ | ➍ | ➎ | ➏ |
➐ | ➑ | ➒ | ➓ | ➔ | → | ↔ | ↕ | ➘ | ➙ | ➚ | ➛ | ➜ | ➝ | ➞ | ➟ |
Here is a list of commands that are known to YTralics but whose translation does not correspond to a Unicode character. Thus, an error is signaled.
%\textascendercompwordmark\textcapitalcompwordmark % \textlbrackdbl\textrbrackdbl\texttildelow\textleaf\textdivorced\textborn % \textquotestraightbase\textquotestraightdblbase\textmarried\textdied % \textinterrobangdown\textcopyleft\textdollaroldstyle\textdollaroldstyle % \textblank\textcentoldstyle\textcentoldstyle % \textcentoldstyle\textdblhyphen % \textfouroldstyle \textfiveoldstyle \texteightoldstyle\textnineoldstyle % \textoneoldstyle \textsevenoldstyle\textsixoldstyle % \textthreeoldstyle\textzerooldstyle \texttwooldstyle
Here is a list of commands whose name start with `text'.
\textacutedbl\ \textasciiacute\ \textasciiacutex\ \textasciibreve\ \textasciicaron\ \textasciicedilla\ \textasciicircum\ \textasciidieresis\ \textasciigrave\ \textasciimacron\ \textasciitilde\ \textasteriskcentered\ \textbackslash\ \textbaht\ \textbar\ \textbardbl\ \textbigcircle\ \textbraceleft\ \textbraceright\ \textbrokenbar\ \textbullet\ \textcelsius\ \textcent\ \textcircledP\ \textcolonmonetary\ \textcopyright\ \textcurrency\ \textdagger\ \textdaggerdbl\ \textdegree\ \textdiv\ \textdollar\ \textdong\ \textdownarrow\ \textellipsis\ \textemdash\ \textendash\ \textestimated\ \texteuro\ \textexclamdown\ \textflorin\ \textfractionsolidus\ \textfractionsolidus\ \textfrenchfranc\ \textgravedbl\ \textgreater\ \textinterrobang\ \textlangle\ \textleftarrow\ \textless\ \textlira\ \textlnot\ \textlquill\ \textmho\ \textminus\ \textmu\ \textmusicalnote\ \textnaira\ \textnormal\ \textnospace\ \textnumero\ \textohm\ \textonehalf\ \textonequarter\ \textonesuperior\ \textopenbullet\ \textordfeminine\ \textordmasculine\ \textparagraph\ \textperiodcentered\ \textpertenthousand\ \textperthousand\ \textpeso\ \textpilcrow\ \textpm\ \textquestiondown\ \textquotedblleft\ \textquotedblright\ \textquoteleft\ \textquoteright\ \textquotesingle\ \textrangle\ \textrecipe\ \textreferencemark\ \textregistered\ \textrightarrow\ \textrquill\ \textsection\ \textservicemark\ \textsofthyphen\ \textsterling \textsurd\ \textthreequarters\ \textthreequartersemdash\ \textthreesuperior\ \texttimes\ \texttrademark\ \texttwelveudash\ \texttwosuperior\ \textunderscore\ \textuparrow\ \textvisiblespace\ \textwon\ \textyen\
Translation: ″ ´ ′ ̆ ̌ ¸ ⌃ ¨ ‵ ¯ ~ ⁎ \ ฿ | ‖ ◯ { } ¦ • ℃ ¢ ℗ ₡ © ¤ † ‡ ° ÷ $ ₫ ↓ … — – ℮ € ¡ ƒ ⁄ ⁄ ₣ ‶ > ‽ 〈 ← < ₤ ¬ ⁅ ℧ — µ ♪ ₦ № Ω ½ ¼ ¹ ◦ ª º ¶ · ‱ ‰ ₱ ¶ ± ¿ “ ” ‘ ’ ' 〉 ℞ ※ ® → ⁆ § ℠ £√ ¾ — ³ × ™ — ² _ ↑ ␣ ₩ ¥
We present here some math characters; for a full and up-to-date list of
constructions consult
Producing MathML with Tralics. All
character tables shown here are converted from XML to Pdf via xmltex, then to
png images.
You can say \mathmo{\&\#x2190;} in order to access the Unicode
character U+2190 as a math operator. On the other hand ^^^^2190
produces the same charater as a math identifier.
In what follows, we assume the following definition
\def\unimp#1{\mathmo{\&\#x#1;}}
There is a file named tralics-iso.sty, that defines \mathslarr to be equivalent to \mathmo{\&\#x2190;}. The Unicode name of this character is: `leftwards arrow', and isoamsa defines the entity ← as `short left arrow'.
Characters with code between U+2190 and U+21FF are shown in the table below. Some symbols have no glyphs in the standard LaTeX fonts. They are shown in the table by a dot if there is no entity in the isoamsXXX files, their Unicode number otherwise.
$\begin{array}{lccccccccccccccccc} \text{2190}&\mathslarr&\mathuarr& \mathsrarr&\mathdarr& \mathharr& \mathvarr&\mathnwarr&\mathnearr& \mathsearr& \mathswarr& \mathnlarr&\mathnrarr& .&\mathrarrw& \mathLarr&\mathUarr\\ \text{21A0}&\mathRarr& \mathDarr& \mathlarrtl&\mathrarrtl& \mathmapstoleft&\mathmapstoup&\mathmap&\mathmapstodown& .&\mathlarrhk&\mathrarrhk&\mathlarrlp& \mathrarrlp&\mathharrw&\mathnharr&\unimp{21af}\\ \text{21B0}&\mathlsh&\mathrsh&\mathldsh&\mathrdsh& .&.&\mathcularr&\mathcurarr& . & .&\matholarr&\mathorarr& \mathlharu&\mathlhard&\mathuharr&\mathuharl\\ \text{21C0}&\mathrharu&\mathrhard&\mathdharr&\mathdharl& \mathrlarr&\mathudarr&\mathlrarr&\mathllarr& \mathuuarr&\mathrrarr&\mathddarr&\mathlrhar& \mathrlhar&\mathnlArr&\mathnhArr&\mathnrArr\\ \text{21D0}&\mathlArr&\mathuArr&\mathrArr&\mathdArr& \mathhArr&\mathvArr&\mathnwArr&\mathneArr& \mathseArr&\mathswArr&\mathlAarr&\mathrAarr& \unimp{21dc}&\mathzigrarr&.&.\\ \text{21E0}&\unimp{21e0}& .& \unimp{21e2}& .& \mathlarrb& \mathrarrb& .& .& .& .& . & . & . & .& .& .\\ \text{21F0}& .& .&. & .& . & \mathduarr& .& .& .& .& .& .& .& \mathloarr& \mathroarr& \mathhoarr\\ \end{array}$
Translation is trivial. We omit a big part of the table.
<formula type='inline'> <math xmlns='http://www.w3.org/1998/Math/MathML'> <mtable> <mtr> <mtd columnalign='left'><mrow><mtext>2190</mtext></mrow></mtd> <mtd><mo>←</mo></mtd> <mtd><mo>↑</mo></mtd> <mtd><mo>→</mo></mtd> ... <mtd><mo>⇾</mo></mtd> <mtd><mo>⇿</mo></mtd> </mtr> </mtable> </math> </formula>
This is the preview.
Characters with code between U+2200 and U+22FF are shown in the table below. Some symbols have no glyphs in the standard LaTeX fonts. Symbols between U+22F2 and U+22FF (variants of `element of') are not shown. Others are shown by their Unicode number.
$\begin{array}{lccccccccccccccccc} \text{2200}& \mathforall& \mathcomp&\mathpart&\mathexist& \mathnexist& \mathempty& \unimp{2206}&\mathnabla& \mathisin&\mathnotin&\unimp{220a}&\mathni& \mathnotni&\unimp{220d}&\unimp{220e}&\mathprod\\ \text{2210}&\mathcoprod&\mathsum&\mathminus&\mathmnplus& \mathplusdo&\unimp{2215}&\mathsetmn&\mathlowast& \mathcompfn&\unimp{2219}&\mathradic&\unimp{221B}& \unimp{221c}&\mathprop&\mathinfin&\mathangrt\\ \text{2220}&\mathang&\mathangmsd&\unimp{2222}&\mathshortmid& \mathnmid&\mathspar&\mathnpar&\mathand& \mathor&\mathcap&\mathcup&\mathint& \mathInt&\mathtint&\mathconint&\mathConint\\ \text{2230}&\mathCconint&\mathcwint&\mathcwconint&\mathawconint& \maththerefore&\mathbecaus&\mathratio&\mathColon& \mathminusd&\unimp{2239}&\mathmDDot&\mathhomtht& \maththksim&\mathbsim&\mathac&\mathmstpos\\ \text{2240}&\mathwreath&\mathnsim&\mathesim&\mathsime& \mathnsime&\mathcong&\mathsimne&\mathncong& \mathasymp&\mathnap&\mathape&\mathapid& \mathbcong&\mathasympeq&\mathbump&\mathbumpe\\ \text{2250}&\mathesdot&\matheDot&\mathefDot&\matherDot& \mathcolone&\mathecolon&\mathecir&\mathcire& \unimp{2258}&\unimp{2259}&\unimp{225a}&\unimp{225b}& \mathtrie&\unimp{225d}&\unimp{225e}&\mathequest\\ \text{2260}&\mathne&\mathequiv&\mathnequiv&\unimp{2263}& \mathle&\mathge&\mathlE&\mathgE& \mathlnE&\mathgnE&\mathLt&\mathGt& \mathtwixt&\mathNotCupCap&\mathnlt&\mathngt\\ \text{2270}&\mathnle&\mathnge&\mathlsim&\mathgsim& \mathnlsim&\mathngsim&\mathlg&\mathgl& \mathntlg&\mathntgl&\mathpr&\mathsc& \mathprcue&\mathsccue&\mathprsim&\mathscsim\\ \text{2280}&\mathnpr&\mathnsc&\mathsub&\mathsup& \mathnsub&\mathnsup&\mathsube&\mathsupe& \mathnsube&\mathnsupe&\mathsubne&\mathsupne& \unimp{228c}&\mathcupdot&\mathuplus&\mathsqsub\\ \text{2290}&\mathsqsup&\mathsqsube&\mathsqsupe&\mathsqcap& \mathsqcup&\mathoplus&\mathominus&\mathotimes& \mathosol&\mathodot&\mathocir&\mathoast& \unimp{229c}&\mathodash&\mathplusb&\mathminusb\\ \text{22a0}&\mathtimesb&\mathsdotb&\mathvdash&\mathdashv& \mathtop&\mathbottom&\unimp{22a6}&\mathmodels& \mathvDash&\mathVdash&\mathVvdash&\mathVDash& \mathnvdash&\mathnvDash&\mathnVdash&\mathnVDash\\ \text{22b0}&\mathprurel&\unimp{22b1}&\mathvltri&\mathvrtri& \mathltrie&\mathrtrie&\mathorigof&\mathimof& \mathmumap&\mathhercon&\mathintcal&\mathveebar& \unimp{22bc}&\mathbarvee&\mathangrtvb&\mathlrtri\\ \text{22c0}&\mathxwedge&\mathxvee&\mathxcap&\mathxcup& \mathdiam&\mathsdot&\mathsstarf&\mathdivonx& \mathbowtie&\mathltimes&\mathrtimes&\mathlthree& \mathrthree&\mathbsime&\mathcuvee&\mathcuwed\\ \text{22d0}&\mathSub&\mathSup&\mathCap&\mathCup& \mathfork&\mathepar&\mathlessdot&\mathgtrdot& \mathLl&\mathGg&\mathleg&\mathgel& \unimp{22dc}&\unimp{22dd}&\mathcuepr&\mathcuesc\\ \text{22e0}&\mathnprcue&\mathnsccue&\mathnsqsube&\mathnsqsupe& \unimp{22e4}&\unimp{22e5}&\mathlnsim&\mathgnsim& \mathprecnsim&\mathscnsim&\mathnltri&\mathnrtri& \mathnltrie&\mathnrtrie&\mathvellip&\mathctdot\\ \text{22f0}&\mathutdot&\mathdtdot&\mathdisin&\mathisinsv& \mathisins&\mathisindot&\mathnotinvc&\mathnotinvb& \unimp{22f8}&\mathisinE&\mathnisd&\mathxnis& \mathnis&\mathnotnivc&\mathnotnivb&\unimp{22ff}\\ \end{array}$
We consider here symbols between U+2300 and U+23FF. About 30 symbols are implemented. The table shows also some symbols between U+2600 and U+2607, and others between U+263D and U+2685.
$\begin{array}{lccccccccccccccccc} \text{2300}& \unimp{2300}&\unimp{2301}&\unimp{2302}&\unimp{2303}& \unimp{2304}&\mathbarwedge&\mathBarwed&\unimp{2307}& \mathlceil&\mathrceil&\mathlfloor&\mathrfloor& \mathdrcrop&\mathdlcrop&\mathurcrop&\mathulcrop\\ \text{2310}&\mathbnot& \unimp{2311}& \mathprofline&\mathprofsurf& \unimp{2314}& \mathtelrec&\mathtarget&\unimp{2317}& \unimp{2318}& \unimp{2319}& \unimp{231a}& \unimp{231b}& \mathulcorner& \mathurcorner&\mathllcorner&\mathlrcorner\\ \text{2320}&\unimp{2320}&\unimp{2321}&\mathfrown&\mathsmile& \unimp{2324}&\unimp{2325}&\unimp{2326}&\unimp{2327}& \unimp{2328}&\mathlangle&\mathrangle&\unimp{232b}& \unimp{232c}& \mathcylcty&\mathprofalar&\unimp{232f}\\ \text{2330}&&&&&&&\mathtopbot&&&\unimp{2339}&&&& \mathovbar& &\mathsolbar\\ \text{2340}&\unimp{2340}&&&&&&&\unimp{2347}&\unimp{2348}\\ \text{2350}&\unimp{2350}&&&&&&&\unimp{2357}\\ \text{2600}&&\unimp{2601}&&&&\mathbigstar&\mathstar&&&&&&\unimp{260C}& \unimp{260d}\unimp{263d}& \unimp{263e}&\unimp{263f}\\ \text{2640}&\mathfemale&\unimp{2641}&\mathmale&\unimp{2643} &\unimp{2644}&\unimp{2645}&\unimp{2646}&\unimp{2647}&\unimp{2648}& \unimp{2649}&\unimp{264A}&\unimp{264b}&\unimp{264c}& \unimp{264d}&\unimp{264e} &\unimp{264f}\\ \text{2650}&\unimp{2650}&\unimp{2651}&\unimp{2652}&\unimp{2653} &\unimp{2654}&\unimp{2655}&\unimp{2656}&\unimp{2657}&\unimp{2658}& \unimp{2659}&\unimp{265A}&\unimp{265b}&\unimp{265c}& \unimp{265d}&\unimp{265e} &\unimp{265f}\\ \text{2660}&\mathspadesuit&\unimp{2661}&\unimp{2662}&\mathclubsuit &\unimp{2664}&\mathheartsuit&\mathdiamondsuit&\unimp{2667}&& \unimp{2669}&\mathsung&&& \mathflat&\mathnatur &\mathsharp\\ \text{2680}&\unimp{2680}&\unimp{2681}&\unimp{2682}&\unimp{2683} &\unimp{2684}&\unimp{2685}\\ \end{array}$
Symbols between U+1D400 and U+1D7FF. First part. There are 12 empty slots in the table symbols. These characters are somewhere else. They are marked by a plus sign.
$\begin{array}{lccccccccccccccccc} \text{1d400}&\unimp{1d400}&\unimp{1d401}&\unimp{1d402}&\unimp{1d403}& \unimp{1d404}&\unimp{1d405}&\unimp{1d406}&\unimp{1d407}& \unimp{1d408}&\unimp{1d409}&\unimp{1d40a}&\unimp{1d40b}& \unimp{1d40c}&\unimp{1d40d}&\unimp{1d40e}&\unimp{1d40f}\\ \text{1d410}&\unimp{1d410}&\unimp{1d411}&\unimp{1d412}&\unimp{1d413}& \unimp{1d414}&\unimp{1d415}&\unimp{1d416}&\unimp{1d417}& \unimp{1d418}&\unimp{1d419}&\unimp{1d41a}&\unimp{1d41b}& \unimp{1d41c}&\unimp{1d41d}&\unimp{1d41e}&\unimp{1d41f}\\ \text{1d420}&\unimp{1d420}&\unimp{1d421}&\unimp{1d422}&\unimp{1d423}& \unimp{1d424}&\unimp{1d425}&\unimp{1d426}&\unimp{1d427}& \unimp{1d428}&\unimp{1d429}&\unimp{1d42a}&\unimp{1d42b}& \unimp{1d42c}&\unimp{1d42d}&\unimp{1d42e}&\unimp{1d42f}\\ \text{1d430}&\unimp{1d430}&\unimp{1d431}&\unimp{1d432}&\unimp{1d433}& \unimp{1d434}&\unimp{1d435}&\unimp{1d436}&\unimp{1d437}& \unimp{1d438}&\unimp{1d439}&\unimp{1d43a}&\unimp{1d43b}& \unimp{1d43c}&\unimp{1d43d}&\unimp{1d43e}&\unimp{1d43f}\\ \text{1d440}&\unimp{1d440}&\unimp{1d441}&\unimp{1d442}&\unimp{1d443}& \unimp{1d444}&\unimp{1d445}&\unimp{1d446}&\unimp{1d447}& \unimp{1d448}&\unimp{1d449}&\unimp{1d44a}&\unimp{1d44b}& \unimp{1d44c}&\unimp{1d44d}&\unimp{1d44e}&\unimp{1d44f}\\ \text{1d450}&\unimp{1d450}&\unimp{1d451}&\unimp{1d452}&\unimp{1d453}& \unimp{1d454}&+\unimp{210e}&\unimp{1d456}&\unimp{1d457}& \unimp{1d458}&\unimp{1d459}&\unimp{1d45a}&\unimp{1d45b}& \unimp{1d45c}&\unimp{1d45d}&\unimp{1d45e}&\unimp{1d45f}\\ \text{1d460}&\unimp{1d460}&\unimp{1d461}&\unimp{1d462}&\unimp{1d463}& \unimp{1d464}&\unimp{1d465}&\unimp{1d466}&\unimp{1d467}& \unimp{1d468}&\unimp{1d469}&\unimp{1d46a}&\unimp{1d46b}& \unimp{1d46c}&\unimp{1d46d}&\unimp{1d46e}&\unimp{1d46f}\\ \text{1d470}&\unimp{1d470}&\unimp{1d471}&\unimp{1d472}&\unimp{1d473}& \unimp{1d474}&\unimp{1d475}&\unimp{1d476}&\unimp{1d477}& \unimp{1d478}&\unimp{1d479}&\unimp{1d47a}&\unimp{1d47b}& \unimp{1d47c}&\unimp{1d47d}&\unimp{1d47e}&\unimp{1d47f}\\ \text{1d480}&\unimp{1d480}&\unimp{1d481}&\unimp{1d482}&\unimp{1d483}& \unimp{1d484}&\unimp{1d485}&\unimp{1d486}&\unimp{1d487}& \unimp{1d488}&\unimp{1d489}&\unimp{1d48a}&\unimp{1d48b}& \unimp{1d48c}&\unimp{1d48d}&\unimp{1d48e}&\unimp{1d48f}\\ \text{1d490}&\unimp{1d490}&\unimp{1d491}&\unimp{1d492}&\unimp{1d493}& \unimp{1d494}&\unimp{1d495}&\unimp{1d496}&\unimp{1d497}& \unimp{1d498}&\unimp{1d499}&\unimp{1d49a}&\unimp{1d49b}& \mathAscr&+\mathBscr&\mathCscr&\mathDscr\\ \text{1d4a0}&+\mathEscr&+\mathFscr&\mathGscr&+\mathHscr& +\mathIscr&\mathJscr&\mathKscr&+\mathLscr& +\mathMscr&\mathNscr&\mathOscr&\mathPscr& \mathQscr&+\mathRscr&\mathSscr&\mathTscr\\ \text{1d4b0}&\mathUscr&\mathVscr&\mathWscr&\mathXscr& \mathYscr&\mathZscr&\mathascr&\mathbscr& \mathcscr&\mathdscr&+\mathescr&\mathfscr& +\mathgscr&\mathhscr&\mathiscr&\mathjscr\\ \text{1d4c0}&\mathkscr&\mathlscr&\mathmscr&\mathnscr& +\mathoscr&\mathpscr&\mathqscr&\mathrscr& \mathsscr&\mathtscr&\mathuscr&\mathvscr& \mathwscr&\mathxscr&\mathyscr&\mathzscr\\ \text{1d4d0}&\unimp{1d4d0}&\unimp{1d4d1}&\unimp{1d4d2}&\unimp{1d4d3}& \unimp{1d4d4}&\unimp{1d4d5}&\unimp{1d4d6}&\unimp{1d4d7}& \unimp{1d4d8}&\unimp{1d4d9}&\unimp{1d4da}&\unimp{1d4db}& \unimp{1d4dc}&\unimp{1d4dd}&\unimp{1d4de}&\unimp{1d4df}\\ \text{1d4e0}&\unimp{1d4e0}&\unimp{1d4e1}&\unimp{1d4e2}&\unimp{1d4e3}& \unimp{1d4e4}&\unimp{1d4e5}&\unimp{1d4e6}&\unimp{1d4e7}& \unimp{1d4e8}&\unimp{1d4e9}&\unimp{1d4ea}&\unimp{1d4eb}& \unimp{1d4ec}&\unimp{1d4ed}&\unimp{1d4ee}&\unimp{1d4ef}\\ \text{1d4f0}&\unimp{1d4f0}&\unimp{1d4f1}&\unimp{1d4f2}&\unimp{1d4f3}& \unimp{1d4f4}&\unimp{1d4f5}&\unimp{1d4f6}&\unimp{1d4f7}& \unimp{1d4f8}&\unimp{1d4f9}&\unimp{1d4fa}&\unimp{1d4fb}& \unimp{1d4fc}&\unimp{1d4fd}&\unimp{1d4fe}&\unimp{1d4ff}\\ \end{array}$
$\begin{array}{lccccccccccccccccc} \text{1d500}&\unimp{1d500}&\unimp{1d501}&\unimp{1d502}&\unimp{1d503}& \mathAfr&\mathBfr&+\mathCfr&\mathDfr& \mathEfr&\mathFfr&\mathGfr&+\mathHfr& +\mathIfr&\mathJfr&\mathKfr&\mathLfr\\ \text{1d510}&\mathMfr&\mathNfr&\mathOfr&\mathPfr& \mathQfr&+\mathRfr&\mathSfr&\mathTfr& \mathUfr&\mathVfr&\mathWfr&\mathXfr& \mathYfr&+\mathZfr&\mathafr&\mathbfr\\ \text{1d520}&\mathcfr&\mathdfr&\mathefr&\mathffr& \mathgfr&\mathhfr&\mathifr&\mathjfr& \mathkfr&\mathlfr&\mathmfr&\mathnfr& \mathofr&\mathpfr&\mathqfr&\mathrfr\\ \text{1d530}&\mathsfr&\mathtfr&\mathufr&\mathvfr& \mathwfr&\mathxfr&\mathyfr&\mathzfr& \mathAopf&\mathBopf&+\mathCopf&\mathDopf& \mathEopf&\mathFopf&\mathGopf&+\mathHopf\\ \text{1d540}&\mathIopf&\mathJopf&\mathKopf&\mathLopf& \mathMopf&+\mathNopf&\mathOopf&+\mathPopf& +\mathQopf&+\mathRopf&\mathSopf&\mathTopf& \mathUopf&\mathVopf&\mathWopf&\mathXopf\\ \text{1d550}&\mathYopf&+\mathZopf&\mathaopf&\mathbopf& \mathcopf&\mathdopf&\matheopf&\mathfopf& \mathgopf&\mathhopf&\mathiopf&\mathjopf& \mathkopf&\mathlopf&\mathmopf&\mathnopf\\ \text{1d560}&\mathoopf&\mathpopf&\mathqopf&\mathropf& \mathsopf&\mathtopf&\mathuopf&\mathvopf& \mathwopf&\mathxopf&\mathyopf&\mathzopf& \unimp{1d56c}&\unimp{1d56d}&\unimp{1d56e}&\unimp{1d56f}\\ \text{1d570}&\unimp{1d570}&\unimp{1d571}&\unimp{1d572}&\unimp{1d573}& \unimp{1d574}&\unimp{1d575}&\unimp{1d576}&\unimp{1d577}& \unimp{1d578}&\unimp{1d579}&\unimp{1d57a}&\unimp{1d57b}& \unimp{1d57c}&\unimp{1d57d}&\unimp{1d57e}&\unimp{1d57f}\\ \text{1d580}&\unimp{1d580}&\unimp{1d581}&\unimp{1d582}&\unimp{1d583}& \unimp{1d584}&\unimp{1d585}&\unimp{1d586}&\unimp{1d587}& \unimp{1d588}&\unimp{1d589}&\unimp{1d58a}&\unimp{1d58b}& \unimp{1d58c}&\unimp{1d58d}&\unimp{1d58e}&\unimp{1d58f}\\ \text{1d590}&\unimp{1d590}&\unimp{1d591}&\unimp{1d592}&\unimp{1d593}& \unimp{1d594}&\unimp{1d595}&\unimp{1d596}&\unimp{1d597}& \unimp{1d598}&\unimp{1d599}&\unimp{1d59a}&\unimp{1d59b}& \unimp{1d59c}&\unimp{1d59d}&\unimp{1d59e}&\unimp{1d59f}\\ \text{1d5a0}&\unimp{1d5a0}&\unimp{1d5a1}&\unimp{1d5a2}&\unimp{1d5a3}& \unimp{1d5a4}&\unimp{1d5a5}&\unimp{1d5a6}&\unimp{1d5a7}& \unimp{1d5a8}&\unimp{1d5a9}&\unimp{1d5aa}&\unimp{1d5ab}& \unimp{1d5ac}&\unimp{1d5ad}&\unimp{1d5ae}&\unimp{1d5af}\\ \text{1d5b0}&\unimp{1d5b0}&\unimp{1d5b1}&\unimp{1d5b2}&\unimp{1d5b3}& \unimp{1d5b4}&\unimp{1d5b5}&\unimp{1d5b6}&\unimp{1d5b7}& \unimp{1d5b8}&\unimp{1d5b9}&\unimp{1d5ba}&\unimp{1d5bb}& \unimp{1d5bc}&\unimp{1d5bd}&\unimp{1d5be}&\unimp{1d5af}\\ \text{1d5c0}&\unimp{1d5c0}&\unimp{1d5c1}&\unimp{1d5c2}&\unimp{1d5c3}& \unimp{1d5c4}&\unimp{1d5c5}&\unimp{1d5c6}&\unimp{1d5c7}& \unimp{1d5c8}&\unimp{1d5c9}&\unimp{1d5ca}&\unimp{1d5cb}& \unimp{1d5cc}&\unimp{1d5cd}&\unimp{1d5ce}&\unimp{1d5cf}\\ \text{1d5d0}&\unimp{1d5d0}&\unimp{1d5d1}&\unimp{1d5d2}&\unimp{1d5d3}& \unimp{1d5d4}&\unimp{1d5d5}&\unimp{1d5d6}&\unimp{1d5d7}& \unimp{1d5d8}&\unimp{1d5d9}&\unimp{1d5da}&\unimp{1d5db}& \unimp{1d5dc}&\unimp{1d5dd}&\unimp{1d5de}&\unimp{1d5df}\\ \text{1d5e0}&\unimp{1d5e0}&\unimp{1d5e1}&\unimp{1d5e2}&\unimp{1d5e3}& \unimp{1d5e4}&\unimp{1d5e5}&\unimp{1d5e6}&\unimp{1d5e7}& \unimp{1d5e8}&\unimp{1d5e9}&\unimp{1d5ea}&\unimp{1d5eb}& \unimp{1d5ec}&\unimp{1d5ed}&\unimp{1d5ee}&\unimp{1d5ef}\\ \text{1d5f0}&\unimp{1d5f0}&\unimp{1d5f1}&\unimp{1d5f2}&\unimp{1d5f3}& \unimp{1d5f4}&\unimp{1d5f5}&\unimp{1d5f6}&\unimp{1d5f7}& \unimp{1d5f8}&\unimp{1d5f9}&\unimp{1d5fa}&\unimp{1d5fb}& \unimp{1d5fc}&\unimp{1d5fd}&\unimp{1d5fe}&\unimp{1d5ff}\\ \end{array}$
$\begin{array}{lccccccccccccccccc} \text{1d600}&\unimp{1d600}&\unimp{1d601}&\unimp{1d602}&\unimp{1d603}& \unimp{1d604}&\unimp{1d605}&\unimp{1d606}&\unimp{1d607}& \unimp{1d608}&\unimp{1d609}&\unimp{1d60a}&\unimp{1d60b}& \unimp{1d60c}&\unimp{1d60d}&\unimp{1d60e}&\unimp{1d60f}\\ \text{1d610}&\unimp{1d610}&\unimp{1d611}&\unimp{1d612}&\unimp{1d613}& \unimp{1d614}&\unimp{1d615}&\unimp{1d616}&\unimp{1d617}& \unimp{1d618}&\unimp{1d619}&\unimp{1d61a}&\unimp{1d61b}& \unimp{1d61c}&\unimp{1d61d}&\unimp{1d61e}&\unimp{1d61f}\\ \text{1d620}&\unimp{1d620}&\unimp{1d621}&\unimp{1d622}&\unimp{1d623}& \unimp{1d624}&\unimp{1d625}&\unimp{1d626}&\unimp{1d627}& \unimp{1d628}&\unimp{1d629}&\unimp{1d62a}&\unimp{1d62b}& \unimp{1d62c}&\unimp{1d62d}&\unimp{1d62e}&\unimp{1d62f}\\ \text{1d630}&\unimp{1d630}&\unimp{1d631}&\unimp{1d632}&\unimp{1d633}& \unimp{1d634}&\unimp{1d635}&\unimp{1d636}&\unimp{1d637}& \unimp{1d638}&\unimp{1d639}&\unimp{1d63a}&\unimp{1d63b}& \unimp{1d63c}&\unimp{1d63d}&\unimp{1d63e}&\unimp{1d63f}\\ \text{1d640}&\unimp{1d640}&\unimp{1d641}&\unimp{1d642}&\unimp{1d643}& \unimp{1d644}&\unimp{1d645}&\unimp{1d646}&\unimp{1d647}& \unimp{1d648}&\unimp{1d649}&\unimp{1d64a}&\unimp{1d64b}& \unimp{1d64c}&\unimp{1d64d}&\unimp{1d64e}&\unimp{1d64f}\\ \text{1d650}&\unimp{1d650}&\unimp{1d651}&\unimp{1d652}&\unimp{1d653}& \unimp{1d654}&\unimp{1d655}&\unimp{1d656}&\unimp{1d657}& \unimp{1d658}&\unimp{1d659}&\unimp{1d65a}&\unimp{1d65b}& \unimp{1d65c}&\unimp{1d65d}&\unimp{1d65e}&\unimp{1d65f}\\ \text{1d660}&\unimp{1d660}&\unimp{1d661}&\unimp{1d662}&\unimp{1d663}& \unimp{1d664}&\unimp{1d665}&\unimp{1d666}&\unimp{1d667}& \unimp{1d668}&\unimp{1d669}&\unimp{1d66a}&\unimp{1d66b}& \unimp{1d66c}&\unimp{1d66d}&\unimp{1d66e}&\unimp{1d66f}\\ \text{1d670}&\unimp{1d670}&\unimp{1d671}&\unimp{1d672}&\unimp{1d673}& \unimp{1d674}&\unimp{1d675}&\unimp{1d676}&\unimp{1d677}& \unimp{1d678}&\unimp{1d679}&\unimp{1d67a}&\unimp{1d67b}& \unimp{1d67c}&\unimp{1d67d}&\unimp{1d67e}&\unimp{1d67f}\\ \text{1d670}&\unimp{1d670}&\unimp{1d671}&\unimp{1d672}&\unimp{1d673}& \unimp{1d674}&\unimp{1d675}&\unimp{1d676}&\unimp{1d677}& \unimp{1d678}&\unimp{1d679}&\unimp{1d67a}&\unimp{1d67b}& \unimp{1d67c}&\unimp{1d67d}&\unimp{1d67e}&\unimp{1d67f}\\ \text{1d680}&\unimp{1d680}&\unimp{1d681}&\unimp{1d682}&\unimp{1d683}& \unimp{1d684}&\unimp{1d685}&\unimp{1d686}&\unimp{1d687}& \unimp{1d688}&\unimp{1d689}&\unimp{1d68a}&\unimp{1d68b}& \unimp{1d68c}&\unimp{1d68d}&\unimp{1d68e}&\unimp{1d68f}\\ \text{1d690}&\unimp{1d690}&\unimp{1d691}&\unimp{1d692}&\unimp{1d693}& \unimp{1d694}&\unimp{1d695}&\unimp{1d696}&\unimp{1d697}& \unimp{1d698}&\unimp{1d699}&\unimp{1d69a}&\unimp{1d69b}& \unimp{1d69c}&\unimp{1d69d}&\unimp{1d69e}&\unimp{1d69f}\\ \text{1d6a0}&\unimp{1d6a0}&\unimp{1d6a1}&\unimp{1d6a2}&\unimp{1d6a3}& &&&& \unimp{1d6a8}&\unimp{1d6a9}&\unimp{1d6aa}&\unimp{1d6ab}& \unimp{1d6ac}&\unimp{1d6ad}&\unimp{1d6ae}&\unimp{1d6af}\\ \text{1d6b0}&\unimp{1d6b0}&\unimp{1d6b1}&\unimp{1d6b2}&\unimp{1d6b3}& \unimp{1d6b4}&\unimp{1d6b5}&\unimp{1d6b6}&\unimp{1d6b7}& \unimp{1d6b8}&\unimp{1d6b9}&\unimp{1d6ba}&\unimp{1d6bb}& \unimp{1d6bc}&\unimp{1d6bd}&\unimp{1d6be}&\unimp{1d6bf}\\ \text{1d6c0}&\unimp{1d6c0}&\unimp{1d6c1}&\unimp{1d6c2}&\unimp{1d6c3}& \unimp{1d6c4}&\unimp{1d6c5}&\unimp{1d6c6}&\unimp{1d6c7}& \unimp{1d6c8}&\unimp{1d6c9}&\unimp{1d6ca}&\unimp{1d6cb}& \unimp{1d6cc}&\unimp{1d6cd}&\unimp{1d6ce}&\unimp{1d6cf}\\ \text{1d6d0}&\unimp{1d6d0}&\unimp{1d6d1}&\unimp{1d6d2}&\unimp{1d6d3}& \unimp{1d6d4}&\unimp{1d6d5}&\unimp{1d6d6}&\unimp{1d6d7}& \unimp{1d6d8}&\unimp{1d6d9}&\unimp{1d6da}&\unimp{1d6db}& \unimp{1d6dc}&\unimp{1d6dd}&\unimp{1d6de}&\unimp{1d6df}\\ \text{1d6e0}&\unimp{1d6e0}&\unimp{1d6e1}&\unimp{1d6e2}&\unimp{1d6e3}& \unimp{1d6e4}&\unimp{1d6e5}&\unimp{1d6e6}&\unimp{1d6e7}& \unimp{1d6e8}&\unimp{1d6e9}&\unimp{1d6ea}&\unimp{1d6eb}& \unimp{1d6ec}&\unimp{1d6ed}&\unimp{1d6ee}&\unimp{1d6ef}\\ \text{1d6f0}&\unimp{1d6f0}&\unimp{1d6f1}&\unimp{1d6f2}&\unimp{1d6f3}& \unimp{1d6f4}&\unimp{1d6f5}&\unimp{1d6f6}&\unimp{1d6f7}& \unimp{1d6f8}&\unimp{1d6f9}&\unimp{1d6fa}&\unimp{1d6fb}& \unimp{1d6fc}&\unimp{1d6fd}&\unimp{1d6fe}&\unimp{1d6ff}\\ \end{array}$
\text{1d700}&\unimp{1d700}&\unimp{1d701}&\unimp{1d702}&\unimp{1d703}& \unimp{1d704}&\unimp{1d705}&\unimp{1d706}&\unimp{1d707}& \unimp{1d708}&\unimp{1d709}&\unimp{1d70a}&\unimp{1d70b}& \unimp{1d70c}&\unimp{1d70d}&\unimp{1d70e}&\unimp{1d70f}\\ \text{1d710}&\unimp{1d710}&\unimp{1d711}&\unimp{1d712}&\unimp{1d713}& \unimp{1d714}&\unimp{1d715}&\unimp{1d716}&\unimp{1d717}& \unimp{1d718}&\unimp{1d719}&\unimp{1d71a}&\unimp{1d71b}& \unimp{1d71c}&\unimp{1d71d}&\unimp{1d71e}&\unimp{1d71f}\\ \text{1d720}&\unimp{1d720}&\unimp{1d721}&\unimp{1d722}&\unimp{1d723}& \unimp{1d724}&\unimp{1d725}&\unimp{1d726}&\unimp{1d727}& \unimp{1d728}&\unimp{1d729}&\unimp{1d72a}&\unimp{1d72b}& \unimp{1d72c}&\unimp{1d72d}&\unimp{1d72e}&\unimp{1d72f}\\ \text{1d730}&\unimp{1d730}&\unimp{1d731}&\unimp{1d732}&\unimp{1d733}& \unimp{1d734}&\unimp{1d735}&\unimp{1d736}&\unimp{1d737}& \unimp{1d738}&\unimp{1d739}&\unimp{1d73a}&\unimp{1d73b}& \unimp{1d73c}&\unimp{1d73d}&\unimp{1d73e}&\unimp{1d73f}\\ \text{1d740}&\unimp{1d740}&\unimp{1d741}&\unimp{1d742}&\unimp{1d743}& \unimp{1d744}&\unimp{1d745}&\unimp{1d746}&\unimp{1d747}& \unimp{1d748}&\unimp{1d749}&\unimp{1d74a}&\unimp{1d74b}& \unimp{1d74c}&\unimp{1d74d}&\unimp{1d74e}&\unimp{1d74f}\\ \text{1d750}&\unimp{1d750}&\unimp{1d751}&\unimp{1d752}&\unimp{1d753}& \unimp{1d754}&\unimp{1d755}&\unimp{1d756}&\unimp{1d757}& \unimp{1d758}&\unimp{1d759}&\unimp{1d75a}&\unimp{1d75b}& \unimp{1d75c}&\unimp{1d75d}&\unimp{1d75e}&\unimp{1d75f}\\ \text{1d760}&\unimp{1d760}&\unimp{1d761}&\unimp{1d762}&\unimp{1d763}& \unimp{1d764}&\unimp{1d765}&\unimp{1d766}&\unimp{1d767}& \unimp{1d768}&\unimp{1d769}&\unimp{1d76a}&\unimp{1d76b}& \unimp{1d76c}&\unimp{1d76d}&\unimp{1d76e}&\unimp{1d76f}\\ \text{1d7c0}&&&&& &&&&&&&& &&\unimp{1d7ce}&\unimp{1d7cf}\\ \text{1d7d0}&\unimp{1d7d0}&\unimp{1d7d1}&\unimp{1d7d2}&\unimp{1d7d3}& \unimp{1d7d4}&\unimp{1d7d5}&\unimp{1d7d6}&\unimp{1d7d7}& \unimp{1d7d8}&\unimp{1d7d9}&\unimp{1d7da}&\unimp{1d7db}& \unimp{1d7dc}&\unimp{1d7dd}&\unimp{1d7de}&\unimp{1d7df}\\ \text{1d7e0}&\unimp{1d7e0}&\unimp{1d7e1}&\unimp{1d7e2}&\unimp{1d7e3}& \unimp{1d7e4}&\unimp{1d7e5}&\unimp{1d7e6}&\unimp{1d7e7}& \unimp{1d7e8}&\unimp{1d7e9}&\unimp{1d7ea}&\unimp{1d7eb}& \unimp{1d7ec}&\unimp{1d7ed}&\unimp{1d7ee}&\unimp{1d7ef}\\ \text{1d7f0}&\unimp{1d7f0}&\unimp{1d7f1}&\unimp{1d7f2}&\unimp{1d7f3}& \unimp{1d7f4}&\unimp{1d7f5}&\unimp{1d7f6}&\unimp{1d7f7}& \unimp{1d7f8}&\unimp{1d7f9}&\unimp{1d7fa}&\unimp{1d7fb}& \unimp{1d7fc}&\unimp{1d7fd}&\unimp{1d7fe}&\unimp{1d7ff}\\ \end{array}$
Some characters are missing:
sans serif bold greek lower case
sans serif bold greek italic
Not all characters are available. In particular cyrillic letters are missing. Some characters, like \'\AE are recognised, but not shown in the tables.
back to home page
© INRIA 204, 2006
Last modified $Date: 2008/12/05 18:22:24 $
