Public Member Functions | |
| Service (Body body) | |
| Creates a new intance of Service based on the given body.   | |
| String | toString () |
| void | serve (Request request) |
| Serves the request given in parameter.   | |
| void | fifoServing () |
| Invoke the default FIFO policy to pick up the requests from the request queue.   | |
| void | lifoServing () |
| Invoke the LIFO policy to pick up the requests from the request queue.   | |
| void | blockingServeOldest () |
| Serves the oldest request in the request queue.   | |
| void | blockingServeOldest (long timeout) |
| Serves the oldest request in request queue.   | |
| void | blockingServeOldest (RequestFilter requestFilter, long timeout) |
| Serves the oldest request matching the criteria given be the filter.   | |
| void | blockingServeOldest (String methodName) |
Serves the oldest request for a method of name methodName.   | |
| void | blockingServeOldest (RequestFilter requestFilter) |
| void | serveOldest () |
| void | serveOldest (String methodName) |
| void | serveOldest (RequestFilter requestFilter) |
| void | blockingServeYoungest () |
| Serves the youngest request in the request queue.   | |
| void | blockingServeYoungest (long timeout) |
| Serves the youngest request in request queue.   | |
| void | blockingServeYoungest (String methodName) |
Serves the youngest request for a method of name methodName.   | |
| void | blockingServeYoungest (RequestFilter requestFilter) |
| Serves the youngest request matching the criteria given be the filter.   | |
| void | blockingServeYoungest (RequestFilter requestFilter, long timeout) |
| void | serveYoungest () |
| void | serveYoungest (String methodName) |
| void | serveYoungest (RequestFilter requestFilter) |
| void | serveAll (String methodName) |
Serves all requests for the method named methodName.   | |
| void | serveAll (RequestFilter requestFilter) |
| Serves all requests accepted by the given filter.   | |
| void | flushingServeYoungest () |
| Serves the youngest request and discard all other requests.   | |
| void | flushingServeYoungest (String methodName) |
Serves the most recent request (youngest) for the method named methodName and discards all the other requests of the same name.   | |
| void | flushingServeYoungest (RequestFilter requestFilter) |
| Serves the most recent request (youngest) accepted by the given filter and discards all the other requests also accepted by this sasme filter.   | |
| void | flushingServeOldest () |
| Serves the oldest request and discard all other requests.   | |
| void | flushingServeOldest (String methodName) |
Serves the oldest request for the method named methodName and discards all the other requests of the same name.   | |
| void | flushingServeOldest (RequestFilter requestFilter) |
| Serves the oldest request accepted by the given filter and discards all the other requests also accepted by this sasme filter.   | |
| void | waitForRequest () |
| blocks until a request is available or until the body terminate  | |
| boolean | hasRequestToServe () |
| true if and only if at least one request is available   | |
| boolean | hasRequestToServe (String methodName) |
| true if and only if at least one request with the given name is available   | |
| int | getRequestCount () |
| Returns the number of request(s) in the queue.   | |
| void | flushAll () |
| Removes all request from the queue.   | |
| Request | getOldest () |
| Returns the oldest request from the queue or null if the queue is empty The request queue is unchanged by this call.   | |
| Request | getOldest (String methodName) |
| Returns the oldest request whose method name is s or null if no match The request queue is unchanged by this call.   | |
| Request | getOldest (RequestFilter requestFilter) |
| Returns the oldest request that matches the criteria defined by the given filter The request queue is unchanged by this call.   | |
| Request | blockingGetOldest () |
| Returns the oldest request from the queue If no request is available the method block until one request can be returned The request queue is unchanged by this call.   | |
| Request | getYoungest () |
| Returns the youngest request from the queue or null if the queue is empty The request queue is unchanged by this call.   | |
| Request | getYoungest (String methodName) |
| Returns the youngest request whose method name is s or null if no match The request queue is unchanged by this call.   | |
| Request | getYoungest (RequestFilter requestFilter) |
| Returns the youngest request that matches the criteria defined by the given filter The request queue is unchanged by this call.   | |
| Request | blockingGetYoungest () |
| Returns the youngest request from the queue If no request is available the method block until one request can be returned The request queue is unchanged by this call.   | |
| Request | blockingRemoveOldest (RequestFilter requestFilter) |
| Blocks the calling thread until there is a request that can be accepted be the given RequestFilter.   | |
| Request | blockingRemoveOldest (RequestFilter requestFilter, long timeout) |
| Blocks the calling thread until there is a request that can be accepted be the given RequestFilter, but tries to limit the time the thread is blocked to timeout.   | |
| Request | blockingRemoveOldest (String methodName) |
| Blocks the calling thread until there is a request of name methodName Returns immediately if there is already one.   | |
| Request | blockingRemoveOldest () |
| Blocks the calling thread until there is a request available Returns immediately if there is already one.   | |
| Request | blockingRemoveOldest (long timeout) |
| Blocks the calling thread until there is a request available but try to limit the time the thread is blocked to timeout.   | |
| Request | blockingRemoveYoungest (RequestFilter requestFilter) |
| Request | blockingRemoveYoungest (RequestFilter requestFilter, long timeout) |
| Blocks the calling thread until there is a request that can be accepted be the given RequestFilter, but tries to limit the time the thread is blocked to the timeout.   | |
| Request | blockingRemoveYoungest (String methodName) |
| Request | blockingRemoveYoungest () |
| Request | blockingRemoveYoungest (long timeout) |
Protected Attributes | |
| Body | body |
| BlockingRequestQueue | requestQueue |
| LifeCycleController | lifeCycleController = null |
Classes | |
| class | AcceptAllRequestFilter |
| AcceptAllRequestFilter is a RequestFilter that matches any request.  More... | |
| class | FlushingServeOldestRequestProcessor |
| FlushingServeOldestRequestProcessor is a RequestProcessor that serves only the oldest request accepted by the given RequestFilter and removes all other requests accepted by that same Filter.  More... | |
| class | FlushingServeYoungestRequestProcessor |
| FlushingServeYoungestRequestProcessor is a RequestProcessor that serves only the youngest request accepted by the given RequestFilter and removes all other requests accepted by that same Filter.  More... | |
| class | RequestFilterOnMethodName |
| RequestFilterOnMethodName is a RequestFilter that matches only request of a given method name.  More... | |
| class | ServingRequestProcessor |
| ServingRequestProcessor is a simple RequestProcessor that serves and removes all requests accepted by a given RequestFilter.  More... | |
 public void runActivity(org.objectweb.proactive.Body body) {
   org.objectweb.proactive.Service service = new org.objectweb.proactive.Service(body);
  For intance the live method of the bounded buffer example :
    while (body.isActive()) {
      if (count == 0) {
        // if the buffer is empty
        service.blockingServeOldest("put"); // Serve the first buffer.put call
      } else if (count == size) {
        // if the buffer is full
        service.blockingServeOldest("get"); // Serve the first buffer.get call
      } else {
        // if the buffer is neither empty nor full
        service.blockingServeOldest(); // Serve the first buffer.xxx call
Definition at line 82 of file Service.java.
| org.objectweb.proactive.Service.Service | ( | Body | body | ) |
| body | the body that helper service is for. |
Definition at line 100 of file Service.java.
References org.objectweb.proactive.Service.body, org.objectweb.proactive.core.body.LocalBodyStrategy.getRequestQueue(), and org.objectweb.proactive.Service.lifeCycleController.
| void org.objectweb.proactive.Service.serve | ( | Request | request | ) |
| request | the request to be served |
Definition at line 124 of file Service.java.
References org.objectweb.proactive.Service.body, and org.objectweb.proactive.core.body.LocalBodyStrategy.serve().
Referenced by org.objectweb.proactive.core.body.migration.MixedLocationServer.runActivity().
| void org.objectweb.proactive.Service.fifoServing | ( | ) |
This does not return until the body terminate, as the active thread enters in an infinite loop for processing the request in the FIFO order.
Definition at line 133 of file Service.java.
References org.objectweb.proactive.Service.blockingServeOldest(), org.objectweb.proactive.Service.body, org.objectweb.proactive.Body.isActive(), and org.objectweb.proactive.Service.lifeCycleController.
| void org.objectweb.proactive.Service.lifoServing | ( | ) |
This does not return until the body terminate, as the active thread enters in an infinite loop for processing the request in the LIFO order.
Definition at line 151 of file Service.java.
References org.objectweb.proactive.Service.blockingServeYoungest(), org.objectweb.proactive.Service.body, and org.objectweb.proactive.Body.isActive().
| void org.objectweb.proactive.Service.blockingServeOldest | ( | ) |
The method blocks if there is no request until one request is received or until the body terminates.
Definition at line 164 of file Service.java.
Referenced by org.objectweb.proactive.Service.blockingServeOldest(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.endActivity(), org.objectweb.proactive.Service.fifoServing(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.getNodes(), org.objectweb.proactive.scheduler.policy.AbstractPolicy.runActivity(), org.objectweb.proactive.p2p.service.P2PAcquaintanceManager.runActivity(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.runActivity(), org.objectweb.proactive.p2p.loadbalancer.P2PLoadBalancer.runActivity(), org.objectweb.proactive.core.component.collectiveitfs.GatherFuturesHandler.runActivity(), org.objectweb.proactive.core.component.body.ComponentActivity.runActivity(), and org.objectweb.proactive.calcium.proactive.ActiveObjectSkernel< T >.runActivity().
| void org.objectweb.proactive.Service.blockingServeOldest | ( | long | timeout | ) |
The method blocks if there is no request until one request is received or until the body terminates. The method does not block more than the given timeout.
| timeout | how long the thread can be blocked for. |
Definition at line 175 of file Service.java.
References org.objectweb.proactive.Service.blockingServeOldest().
| void org.objectweb.proactive.Service.blockingServeOldest | ( | RequestFilter | requestFilter, | |
| long | timeout | |||
The method blocks if there is no matching request until one matching request is received or until the body terminates. The method does not block more than the given timeout.
| requestFilter | The request filter accepting the request | |
| timeout | the timeout in ms |
Definition at line 187 of file Service.java.
References org.objectweb.proactive.core.body.request.BlockingRequestQueue.blockingRemoveOldest(), org.objectweb.proactive.Service.body, org.objectweb.proactive.Service.requestQueue, and org.objectweb.proactive.core.body.LocalBodyStrategy.serve().
| void org.objectweb.proactive.Service.blockingServeOldest | ( | String | methodName | ) |
| methodName | The name of the request to serve |
Definition at line 197 of file Service.java.
| void org.objectweb.proactive.Service.blockingServeOldest | ( | RequestFilter | requestFilter | ) |
Definition at line 207 of file Service.java.
| void org.objectweb.proactive.Service.serveOldest | ( | ) |
If there is no request, the method returns with no effect.
Definition at line 215 of file Service.java.
References org.objectweb.proactive.Service.body, org.objectweb.proactive.core.body.request.RequestQueue.removeOldest(), org.objectweb.proactive.Service.requestQueue, and org.objectweb.proactive.core.body.LocalBodyStrategy.serve().
Referenced by org.objectweb.proactive.p2p.service.node.P2PNodeLookup.endActivity(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.getNodes(), org.objectweb.proactive.scheduler.JobNoDescriptor.runActivity(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.runActivity(), and org.objectweb.proactive.core.body.migration.MixedLocationServer.runActivity().
| void org.objectweb.proactive.Service.serveOldest | ( | String | methodName | ) |
If no matching request is found, the method returns with no effect.
Definition at line 224 of file Service.java.
| void org.objectweb.proactive.Service.serveOldest | ( | RequestFilter | requestFilter | ) |
Definition at line 233 of file Service.java.
| void org.objectweb.proactive.Service.blockingServeYoungest | ( | ) |
Definition at line 244 of file Service.java.
Referenced by org.objectweb.proactive.Service.blockingServeYoungest(), and org.objectweb.proactive.Service.lifoServing().
| void org.objectweb.proactive.Service.blockingServeYoungest | ( | long | timeout | ) |
| timeout | : for how long the thread can be blocked. |
Definition at line 255 of file Service.java.
References org.objectweb.proactive.Service.blockingServeYoungest().
| void org.objectweb.proactive.Service.blockingServeYoungest | ( | String | methodName | ) |
Definition at line 265 of file Service.java.
| void org.objectweb.proactive.Service.blockingServeYoungest | ( | RequestFilter | requestFilter | ) |
Definition at line 275 of file Service.java.
| void org.objectweb.proactive.Service.blockingServeYoungest | ( | RequestFilter | requestFilter, | |
Definition at line 287 of file Service.java.
References org.objectweb.proactive.core.body.request.BlockingRequestQueue.blockingRemoveYoungest(), org.objectweb.proactive.Service.body, org.objectweb.proactive.Service.requestQueue, and org.objectweb.proactive.core.body.LocalBodyStrategy.serve().
| void org.objectweb.proactive.Service.serveYoungest | ( | ) |
Definition at line 295 of file Service.java.
References org.objectweb.proactive.Service.body, org.objectweb.proactive.core.body.request.RequestQueue.removeYoungest(), org.objectweb.proactive.Service.requestQueue, and org.objectweb.proactive.core.body.LocalBodyStrategy.serve().
| void org.objectweb.proactive.Service.serveYoungest | ( | String | methodName | ) |
Definition at line 304 of file Service.java.
| void org.objectweb.proactive.Service.serveYoungest | ( | RequestFilter | requestFilter | ) |
Definition at line 313 of file Service.java.
| void org.objectweb.proactive.Service.serveAll | ( | String | methodName | ) |
If there is no request matching the method name, no request is served. All served requests are removed from the RequestQueue.
Definition at line 326 of file Service.java.
Referenced by org.objectweb.proactive.p2p.service.P2PService.askingNode().
| void org.objectweb.proactive.Service.serveAll | ( | RequestFilter | requestFilter | ) |
Definition at line 335 of file Service.java.
References org.objectweb.proactive.Service.body, org.objectweb.proactive.core.body.request.RequestQueue.processRequests(), and org.objectweb.proactive.Service.requestQueue.
| void org.objectweb.proactive.Service.flushingServeYoungest | ( | ) |
After the call the youngest request is served and the request queue is empty. If the request queue is already empty before the call the method has no effect
Definition at line 349 of file Service.java.
Referenced by org.objectweb.proactive.Service.flushingServeYoungest().
| void org.objectweb.proactive.Service.flushingServeYoungest | ( | String | methodName | ) |
The most recent request is the one served. If there is no match, no request is served or removed. All requests of method name methodName are removed from the request queue.
| methodName | The name of the request to serve and flush |
Definition at line 362 of file Service.java.
References org.objectweb.proactive.Service.flushingServeYoungest().
| void org.objectweb.proactive.Service.flushingServeYoungest | ( | RequestFilter | requestFilter | ) |
The most recent request is the one served. If there is no match, no request is served or removed. All requests accepted by the filter are removed from the request queue.
| requestFilter | The request filter accepting requests |
Definition at line 374 of file Service.java.
| void org.objectweb.proactive.Service.flushingServeOldest | ( | ) |
After the call the oldest request is served and the request queue is empty. If the request queue is already empty before the call the method has no effect
Definition at line 388 of file Service.java.
Referenced by org.objectweb.proactive.Service.flushingServeOldest().
| void org.objectweb.proactive.Service.flushingServeOldest | ( | String | methodName | ) |
The oldest request is the one served. If there is no match, no request is served or removed. All requests of method name methodName are removed from the request queue.
Definition at line 401 of file Service.java.
References org.objectweb.proactive.Service.flushingServeOldest().
| void org.objectweb.proactive.Service.flushingServeOldest | ( | RequestFilter | requestFilter | ) |
The oldest request is the one served. If there is no match, no request is served or removed. All requests accepted by the filter are removed from the request queue.
Definition at line 413 of file Service.java.
| boolean org.objectweb.proactive.Service.hasRequestToServe | ( | ) |
Definition at line 431 of file Service.java.
References org.objectweb.proactive.core.body.request.RequestQueue.isEmpty(), and org.objectweb.proactive.Service.requestQueue.
Referenced by org.objectweb.proactive.p2p.service.P2PService.askingNode(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.endActivity(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.getNodes(), org.objectweb.proactive.scheduler.policy.AbstractPolicy.runActivity(), org.objectweb.proactive.p2p.service.node.P2PNodeLookup.runActivity(), and org.objectweb.proactive.core.body.migration.MixedLocationServer.runActivity().
| boolean org.objectweb.proactive.Service.hasRequestToServe | ( | String | methodName | ) |
Definition at line 439 of file Service.java.
References org.objectweb.proactive.core.body.request.RequestQueue.hasRequest(), and org.objectweb.proactive.Service.requestQueue.
| int org.objectweb.proactive.Service.getRequestCount | ( | ) |
Definition at line 447 of file Service.java.
References org.objectweb.proactive.Service.requestQueue, and org.objectweb.proactive.core.body.request.RequestQueue.size().
| void org.objectweb.proactive.Service.flushAll | ( | ) |
No request is served.
Definition at line 454 of file Service.java.
References org.objectweb.proactive.core.body.request.RequestQueue.clear(), and org.objectweb.proactive.Service.requestQueue.
| Request org.objectweb.proactive.Service.getOldest | ( | ) |
Definition at line 467 of file Service.java.
References org.objectweb.proactive.core.body.request.RequestQueue.getOldest(), and org.objectweb.proactive.Service.requestQueue.
Referenced by org.objectweb.proactive.p2p.service.node.P2PNodeLookup.runActivity().
| Request org.objectweb.proactive.Service.getOldest | ( | String | methodName | ) |
| methodName | the name of the method to look for |
Definition at line 477 of file Service.java.
| Request org.objectweb.proactive.Service.getOldest | ( | RequestFilter | requestFilter | ) |
| requestFilter | the filter accepting request on a given criteria |
Definition at line 487 of file Service.java.
| Request org.objectweb.proactive.Service.blockingGetOldest | ( | ) |
Definition at line 497 of file Service.java.
References org.objectweb.proactive.core.body.request.RequestQueue.getOldest(), org.objectweb.proactive.core.body.request.BlockingRequestQueue.isDestroyed(), org.objectweb.proactive.Service.requestQueue, and org.objectweb.proactive.Service.waitForRequest().
| Request org.objectweb.proactive.Service.getYoungest | ( | ) |
Definition at line 515 of file Service.java.
References org.objectweb.proactive.core.body.request.RequestQueue.getYoungest(), and org.objectweb.proactive.Service.requestQueue.
| Request org.objectweb.proactive.Service.getYoungest | ( | String | methodName | ) |
Definition at line 525 of file Service.java.
| Request org.objectweb.proactive.Service.getYoungest | ( | RequestFilter | requestFilter | ) |
Definition at line 535 of file Service.java.
| Request org.objectweb.proactive.Service.blockingGetYoungest | ( | ) |
Definition at line 545 of file Service.java.
References org.objectweb.proactive.core.body.request.RequestQueue.getYoungest(), org.objectweb.proactive.core.body.request.BlockingRequestQueue.isDestroyed(), org.objectweb.proactive.Service.requestQueue, and org.objectweb.proactive.Service.waitForRequest().
| Request org.objectweb.proactive.Service.blockingRemoveOldest | ( | RequestFilter | requestFilter | ) |
Returns immediately if there is already one. The request returned is non null unless the thread has been asked not to wait anymore.
| requestFilter | the request filter that select the request to be returned |
Definition at line 566 of file Service.java.
References org.objectweb.proactive.Service.blockingRemoveOldest().
| Request org.objectweb.proactive.Service.blockingRemoveOldest | ( | RequestFilter | requestFilter, | |
| requestFilter | the request filter that select the request to be returned | |
Definition at line 579 of file Service.java.
References org.objectweb.proactive.core.body.request.BlockingRequestQueue.blockingRemoveOldest(), and org.objectweb.proactive.Service.requestQueue.
| Request org.objectweb.proactive.Service.blockingRemoveOldest | ( | String | methodName | ) |
| methodName | the name of the method to wait for |
Definition at line 591 of file Service.java.
| Request org.objectweb.proactive.Service.blockingRemoveOldest | ( | ) |
Definition at line 601 of file Service.java.
Referenced by org.objectweb.proactive.Service.blockingRemoveOldest().
| Request org.objectweb.proactive.Service.blockingRemoveOldest | ( | long | timeout | ) |
Returns immediately if there is already one. The request returned is non null if a request has been found during the given time.
Definition at line 613 of file Service.java.
| Request org.objectweb.proactive.Service.blockingRemoveYoungest | ( | RequestFilter | requestFilter | ) |
Definition at line 629 of file Service.java.
References org.objectweb.proactive.Service.blockingRemoveYoungest().
| Request org.objectweb.proactive.Service.blockingRemoveYoungest | ( | RequestFilter | requestFilter, | |
Definition at line 643 of file Service.java.
References org.objectweb.proactive.core.body.request.BlockingRequestQueue.blockingRemoveYoungest(), and org.objectweb.proactive.Service.requestQueue.
| Request org.objectweb.proactive.Service.blockingRemoveYoungest | ( | String | methodName | ) |
Definition at line 655 of file Service.java.
| Request org.objectweb.proactive.Service.blockingRemoveYoungest | ( | ) |
Definition at line 666 of file Service.java.
Referenced by org.objectweb.proactive.Service.blockingRemoveYoungest().
| Request org.objectweb.proactive.Service.blockingRemoveYoungest | ( | long | timeout | ) |
Definition at line 678 of file Service.java.
 1.5.1
