00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.component.collectiveitfs; 00032 00033 import java.io.Serializable; 00034 import java.util.List; 00035 00036 import org.objectweb.proactive.Body; 00037 import org.objectweb.proactive.ProActive; 00038 import org.objectweb.proactive.RunActive; 00039 import org.objectweb.proactive.Service; 00040 import org.objectweb.proactive.core.body.future.FutureResult; 00041 import org.objectweb.proactive.core.body.migration.MigrationException; 00042 import org.objectweb.proactive.core.body.request.Request; 00043 import org.objectweb.proactive.core.body.request.RequestFilter; 00044 import org.objectweb.proactive.core.component.representative.ItfID; 00045 import org.objectweb.proactive.core.exceptions.manager.ExceptionThrower; 00046 import org.objectweb.proactive.core.node.Node; 00047 00092 public class GatherFuturesHandler implements RunActive, Serializable { 00093 List<ItfID> senders; 00094 List<?> resultOfGatheredInvocation; 00095 Throwable exceptionToRaise; 00096 String methodName = null; 00097 int step = 0; 00098 00099 public GatherFuturesHandler() { 00100 } 00101 00102 public void setFutureOfGatheredInvocation(FutureResult future) { 00103 if (future.getExceptionToRaise() != null) { 00104 exceptionToRaise = future.getExceptionToRaise(); 00105 } else { 00106 // no cast for futures ==> need to get the result before casting 00107 resultOfGatheredInvocation = (List<?>) future.getResult(); 00108 ProActive.waitFor(resultOfGatheredInvocation); 00109 } 00110 } 00111 00112 // returns 00113 public Object distribute(ItfID sender) { 00114 if (exceptionToRaise != null) { 00115 ExceptionThrower.throwException(exceptionToRaise); // guillaume's exception thrower 00116 } 00117 00118 // redistribution policies for results can be applied here 00119 return resultOfGatheredInvocation.get(senders.indexOf(sender)); 00120 } 00121 00122 public void migrateTo(Node node) throws MigrationException { 00123 ProActive.migrateTo(node); 00124 } 00125 00126 public void setConnectedClientItfs(List<ItfID> connectedClientItfs) { 00127 senders = connectedClientItfs; 00128 } 00129 00130 public void setMethodName(String methodName) { 00131 this.methodName = methodName; 00132 } 00133 00134 public void passivate() { 00135 senders = null; 00136 methodName = null; 00137 } 00138 00139 00140 00141 00142 public void runActivity(Body body) { 00143 Service service = new Service(body); 00144 while (ProActive.getBodyOnThis().isActive()) { 00145 service.blockingServeOldest("setConnectedClientItfs"); 00146 00147 service.blockingServeOldest("setFutureOfGatheredInvocation"); 00148 int i = 1; 00149 for (ItfID senderID : senders) { 00150 service.blockingServeOldest("distribute"); 00151 i++; 00152 } 00153 00154 service.blockingServeOldest("passivate"); 00155 00156 } 00157 } 00158 00159 00160 }
1.5.1
