00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.scheduler.policy;
00032
00033 import java.io.Serializable;
00034 import java.util.Collection;
00035 import java.util.HashMap;
00036 import java.util.Iterator;
00037 import java.util.Set;
00038 import java.util.Vector;
00039
00040 import org.apache.log4j.Logger;
00041 import org.objectweb.proactive.Body;
00042 import org.objectweb.proactive.ProActive;
00043 import org.objectweb.proactive.RunActive;
00044 import org.objectweb.proactive.Service;
00045 import org.objectweb.proactive.core.node.Node;
00046 import org.objectweb.proactive.core.util.log.Loggers;
00047 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00048 import org.objectweb.proactive.core.util.wrapper.BooleanWrapper;
00049 import org.objectweb.proactive.scheduler.Agent;
00050 import org.objectweb.proactive.scheduler.DeployedTask;
00051 import org.objectweb.proactive.scheduler.GenericJob;
00052 import org.objectweb.proactive.scheduler.JobConstants;
00053 import org.objectweb.proactive.scheduler.Queue;
00054 import org.objectweb.proactive.scheduler.QueueFullException;
00055 import org.objectweb.proactive.scheduler.RessourceManager;
00056 import org.objectweb.proactive.scheduler.SchedulerConstants;
00057
00058
00067 public abstract class AbstractPolicy implements Serializable, RunActive,
00068     JobConstants, SchedulerConstants {
00069     private static Logger logger = ProActiveLogger.getLogger(Loggers.JOB_MANAGER);
00070     protected RessourceManager ressourceManager;
00071     protected Queue queue;
00072     protected HashMap deployedTasks;
00073
00074     public AbstractPolicy() {
00075     }
00076
00082     public AbstractPolicy(RessourceManager ressourceManager) {
00083         if (ressourceManager != null) {
00084             deployedTasks = new HashMap();
00085             queue = new Queue();
00086             this.ressourceManager = ressourceManager;
00087             logger.debug("job manager created");
00088         }
00089     }
00090
00095     public void runActivity(Body body) {
00096         Service service = new Service(body);
00097
00098         while (true) {
00099             this.execute();
00100
00101             if (service.hasRequestToServe()) {
00102                 service.blockingServeOldest();
00103             }
00104
00105             this.checkRunningTasks();
00106         }
00107     }
00108
00114     public void checkRunningTasks() {
00115         if (!this.deployedTasks.isEmpty()) {
00116             Set runningProcessIds = this.deployedTasks.keySet();
00117             Iterator iterator = runningProcessIds.iterator();
00118
00119             while (iterator.hasNext()) {
00120                 String processId = (String) iterator.next();
00121                 DeployedTask deployedTask = (DeployedTask) this.deployedTasks.get(processId);
00122
00123                 if (!(deployedTask.isAlive()).booleanValue()) {
00124                     this.deployedTasks.remove(processId);
00125
00126                     GenericJob job = deployedTask.getTaskDescription();
00127                     int ressourceNb = job.getRessourceNb() - 1;
00128                     System.out.println("Task '" + job.getClassName() +
00129                         "' finished ...");
00130                     System.out.println("Freeing " + ressourceNb +
00131                         ((ressourceNb > 1) ? " ressources ..." : " ressource ..."));
00132
00133                     ressourceManager.freeNodes(job.getJobID(), true);
00134                     job.setJobStatus("finished");
00135                     logger.debug("job finished " + job.getJobID());
00136
00137                     break;
00138                 }
00139             }
00140         }
00141     }
00142
00148     public BooleanWrapper sub(GenericJob job) {
00149         try {
00150             job.setJobStatus("queued");
00151             queue.put(job);
00152
00153             logger.debug("job added to the queue");
00154
00155             return new BooleanWrapper(true);
00156         } catch (QueueFullException e) {
00157             logger.error("Couldn't add job to the queue. Queue full ...");
00158             return new BooleanWrapper(false);
00159         }
00160     }
00161
00167     public BooleanWrapper del(String jobId) {
00168         try {
00169             if (queue.remove(jobId) == null) {
00170                 this.deployedTasks.remove(jobId);
00171                 this.ressourceManager.freeNodes(jobId, false);
00172             }
00173             logger.debug("job deleted");
00174             return new BooleanWrapper(true);
00175         } catch (Exception e) {
00176             logger.error("couldn't delete job");
00177             return new BooleanWrapper(false);
00178         }
00179     }
00180
00187     public Vector stat(String jobId) {
00188         Vector vector = new Vector();
00189         GenericJob jobDescription;
00190         if (jobId != null) {
00191             jobDescription = queue.get(jobId);
00192             if (jobDescription == null) {
00193                 DeployedTask deployedTask = (DeployedTask) this.deployedTasks.get(jobId);
00194                 if (deployedTask != null) {
00195                     jobDescription = deployedTask.getTaskDescription();
00196                 }
00197             }
00198
00199             if (jobDescription != null) {
00200                 vector.add(jobDescription);
00201             }
00202         } else {
00203             vector.addAll(this.queue.values());
00204
00205             Collection c = this.deployedTasks.values();
00206             Iterator iterator = c.iterator();
00207
00208             while (iterator.hasNext()) {
00209                 DeployedTask deployedTask = (DeployedTask) iterator.next();
00210                 vector.add(deployedTask.getTaskDescription());
00211             }
00212         }
00213         logger.debug("job status evoqued");
00214         return vector;
00215     }
00216
00224     abstract public boolean isToBeServed(GenericJob job1, GenericJob job2);
00225
00230     public String nextTask() {
00231
00232         String jobId = null;
00233         GenericJob job = null;
00234
00235
00236         String tmpId;
00237         GenericJob tmpTask;
00238
00239         Set set = queue.keySet();
00240         Iterator iterator = set.iterator();
00241
00242
00243         if (iterator.hasNext()) {
00244             jobId = (String) iterator.next();
00245             job = (GenericJob) queue.get(jobId);
00246         }
00247
00248
00249         while (iterator.hasNext()) {
00250             tmpId = (String) iterator.next();
00251
00252             tmpTask = (GenericJob) queue.get(tmpId);
00253
00254             if (isToBeServed(tmpTask, job)) {
00255                 jobId = tmpId;
00256                 job = tmpTask;
00257             }
00258         }
00259         logger.debug("next task evoked");
00260         return jobId;
00261     }
00262
00267     public HashMap getDeployedTasks() {
00268         return this.deployedTasks;
00269     }
00270
00276     public void execute() {
00277         int ressourceNb;
00278         int minRessourceNb;
00279
00280         if (!queue.isEmpty()) {
00281             String jobId = nextTask();
00282             GenericJob job = queue.get(jobId);
00283             ressourceNb = job.getRessourceNb();
00284             minRessourceNb = job.getMinNbOfNodes();
00285
00286             if (!ressourceManager.isAvailable(ressourceNb).booleanValue()) {
00287                 if (!ressourceManager.isAvailable(minRessourceNb).booleanValue()) {
00288                     return;
00289                 } else {
00290                     ressourceNb = minRessourceNb;
00291                 }
00292             }
00293
00294
00295
00296             queue.remove(jobId);
00297
00298             try {
00299                 Node node = ressourceManager.reserveNodes(jobId, ressourceNb);
00300
00301                 Agent agent = null;
00302                 String jobName = job.getClassName();
00303
00304
00305
00306
00307
00308
00309
00310                 if (jobName != null) {
00311
00312                     String xmlPath = job.getXMLFullPath();
00313
00314
00315
00316
00317
00318
00319
00320
00321
00322                     HashMap systemProperties = new HashMap();
00323                     systemProperties.put(XML_DESC, xmlPath);
00324                     systemProperties.put(JOB_ID, jobId);
00325
00326                     agent = (Agent) ProActive.newActive(Agent.class.getName(),
00327                             new Object[] { systemProperties }, node);
00328
00329
00330
00331
00332
00333
00334
00335
00336
00337
00338
00339
00340
00341                     ProActive.newMain(jobName, job.getMainParameters(), node);
00342
00343                     System.out.println("Starting '" + jobName + "' job ...");
00344                 }
00345
00346                 System.out.println("Allocation of " + ressourceNb +
00347                     ((ressourceNb > 1) ? " ressources ..." : " ressource ..."));
00348                 job.setJobStatus("deployed");
00349                 this.deployedTasks.put(jobId, new DeployedTask(job, agent));
00350                 logger.debug("job deployed successfully");
00351             } catch (Exception e) {
00352                 logger.error("error executing job");
00353             }
00354         }
00355     }
00356
00361     public void end() {
00362     }
00363
00368     public Queue getQueue() {
00369         return this.queue;
00370     }
00371 }
