Public Member Functions | |
| boolean | isAlive () |
| Returns whether the body is alive or not. | |
| boolean | isActive () |
| Returns whether the body is active or not. | |
| void | blockCommunication () |
| blocks all incoming communications. | |
| void | acceptCommunication () |
| Signals the body to accept all incoming communications. | |
| void | enterInThreadStore () |
| Allows the calling thread to enter in the ThreadStore of this body. | |
| void | exitFromThreadStore () |
| Allows the calling thread to exit from the ThreadStore of this body. | |
| UniversalBody | checkNewLocation (UniqueID uniqueID) |
| Tries to find a local version of the body of id uniqueID. | |
| UniversalBody | getShortcutTargetBody (ItfID functionalItfID) |
| Returns the body that is the target of this shortcut for this component interface. | |
| void | setPolicyServer (PolicyServer server) |
| set the policy server of the active object | |
| void | updateNodeURL (String newNodeURL) |
| Set the nodeURL of this body. | |
UniversalBody defines the remote accessible part of the body while LocalBody defines the local accessible part of the body.
The body of an ActiveObject provides needed services such as a the ability to sent and receive request and reply.
The interface also defines how the activity methods of an active object sees its Body.
A body has 2 associated states :
Note that a thread can be alive but not active, such as a forwarder that just forward request to another peer.
Definition at line 69 of file Body.java.
| boolean org.objectweb.proactive.Body.isAlive | ( | ) |
The body is alive as long as it is processing request and reply
Implemented in org.objectweb.proactive.core.body.AbstractBody, and org.objectweb.proactive.ext.security.EncryptedBody.
Referenced by org.objectweb.proactive.p2p.service.P2PFirstContact.runActivity().
| boolean org.objectweb.proactive.Body.isActive | ( | ) |
The body is active as long as it has an associated thread running to serve the requests by calling methods on the active object.
Implemented in org.objectweb.proactive.core.body.AbstractBody, org.objectweb.proactive.core.component.body.ComponentBodyImpl, and org.objectweb.proactive.ext.security.EncryptedBody.
Referenced by org.objectweb.proactive.Service.fifoServing(), org.objectweb.proactive.Service.lifoServing(), org.objectweb.proactive.p2p.service.P2PAcquaintanceManager.runActivity(), org.objectweb.proactive.p2p.loadbalancer.P2PLoadBalancer.runActivity(), org.objectweb.proactive.core.component.body.ComponentActivity.runActivity(), and org.objectweb.proactive.loadbalancing.LoadBalancer.sendActiveObjectsTo().
| void org.objectweb.proactive.Body.blockCommunication | ( | ) |
After this call, the body cannot receive any request or reply.
Referenced by org.objectweb.proactive.core.body.ft.checkpointing.Checkpoint.recover().
| void org.objectweb.proactive.Body.acceptCommunication | ( | ) |
This call undo a previous call to blockCommunication.
| UniversalBody org.objectweb.proactive.Body.checkNewLocation | ( | UniqueID | uniqueID | ) |
If a local version is found it is returned. If not, tries to find the body of id uniqueID in the known body of this body. If a body is found it is returned, else null is returned.
| uniqueID | the id of the body to lookup |
| UniversalBody org.objectweb.proactive.Body.getShortcutTargetBody | ( | ItfID | functionalItfID | ) |
| functionalItfID | the id of the interface on which the shortcut is available |
| void org.objectweb.proactive.Body.setPolicyServer | ( | PolicyServer | server | ) |
| server | the policy server |
| void org.objectweb.proactive.Body.updateNodeURL | ( | String | newNodeURL | ) |
| newNodeURL | the new URL of the node |
Implemented in org.objectweb.proactive.core.body.BodyImpl, org.objectweb.proactive.core.body.HalfBody, and org.objectweb.proactive.ext.security.EncryptedBody.
1.5.1
