PmWiki
Results
Simulation of near-field plasmonic interactions
with a local approximation order DGTD method
Results.DGTDPloc History
Show minor edits - Show changes to markup
June 09, 2016, at 07:35 PM by 82.228.254.112 -
Changed line 61 from:
Modulus of E field map in the nanolens device at t=12.3 fs, obtained with a DGTD-P1P3 method. Field values have been scaled to [0 , 10]
to:
Modulus of E field map in the bowtie antenna at t=12.3 fs, obtained with a DGTD-P1P3 method. Field values have been scaled to [0 , 10]
December 18, 2015, at 09:01 AM by 138.96.200.15 -
Changed lines 68-69 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_dt1.png (:table border='0' width='100%' align='center' cellspacing='1px':)
to:
(:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_dt1.png
December 18, 2015, at 09:00 AM by 138.96.200.15 -
Changed line 38 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_dt1.png
to:
(:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_dt1.png
Deleted line 38:
December 18, 2015, at 08:57 AM by 138.96.200.15 -
Changed lines 8-9 from:
To overcome this limitation, several strategies can be considered. The strategy discussed here relies on the use of non-uniform distribution of the polynomial order in the framework of a global time step DGDT method. By imposing low orders in small cells and high orders in large cells, it is possible to significantly alleviate both the global number of degrees of freedom and the time step restriction with a minimal impact on the method accuracy. Strategies exploiting locally adaptive (LA) formulations usually combine both h- and p- adaptivity in order to concentrate the computational effort in the areas of high field variations. Here, the adopted point of view is quite different: starting from a given mesh and an uniform distribution of the polynomial order k, the LA strategy exploits all the polynomial orders p, with p lesser or equal than k to obtain a solution of similar accuracy with a reduced computational cost.
to:
Several strategies can be considered to address this performance issue. The strategy discussed here relies on the use of non-uniform distribution of the polynomial order in the framework of a global time step DGDT method. By imposing low orders in small cells and high orders in large cells, it is possible to significantly alleviate both the global number of degrees of freedom and the time step restriction with a minimal impact on the method accuracy. Strategies exploiting locally adaptive (LA) formulations usually combine both h- and p- adaptivity in order to concentrate the computational effort in the areas of high field variations. Here, the adopted point of view is quite different: starting from a given mesh and an uniform distribution of the polynomial order k, the LA strategy exploits all the polynomial orders p, with p lesser or equal than k to obtain a solution of similar accuracy with a reduced computational cost.
Deleted lines 11-15:
http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_mesh.png | Mesh setup for a metallic nanolens. The gray cells correspond to the metallic spheres, the blue cells to vacuum, while the red cells constitute the PML region. For this mesh, the ratio between the largest and the smallest edge length of the tetrahedral mesh is above 400.
(:linebreaks:)
Added lines 16-19:
(:linebreaks:)
Added lines 46-49:
As a second application, we consider the computation of the extinction cross section of a metallic bowtie nanoantenna. These structures are actively studied for the very strong field enhancement they provide between the tips of the two triangular nanoparticles, which is known to be inversely proportionnal to the size of the gap. Hence, bowtie nanoantennas are good candidates for surface-enhanced Raman spectroscopy (SERS) applications. Recent advances in lithography techniques allowed the creation of structures with gaps as small as 3 nm, while the typical size of the full structure can get close to 200 nm. Additionally, realistic geometries of such antennas include small roundings at the edges and tips, whose typical size is between a few to a few tens of nanometers. In the present case, we consider a pair of 10 nm thick, equilateral prisms of edge length 100 nm, with a spacing gap of 3 nm. The rounding radius is 2 nm, and is uniform for all edges and tips. The material considered is gold, described by a Drude model.
(:linebreaks:)
Deleted lines 62-65:
(:linebreaks:)
December 18, 2015, at 08:56 AM by 138.96.200.15 -
Changed lines 47-48 from:
http://www-sop.inria.fr/nachos/pics/result/p_loc/bowtie3.png | Mesh setup for a bowtie nanoantenna. The gray cells correspond to the nanoantenna, the blue cells to vacuum, while the red cells constitute the PML region. For this mesh, the ratio between the largest and the smallest edge length of the tetrahedral mesh is close to 275.
to:
http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie3.png | Mesh setup for a bowtie nanoantenna. The gray cells correspond to the nanoantenna, the blue cells to vacuum, while the red cells constitute the PML region. For this mesh, the ratio between the largest and the smallest edge length of the tetrahedral mesh is close to 275.
December 18, 2015, at 08:55 AM by 138.96.200.15 -
to:
December 18, 2015, at 08:54 AM by 138.96.200.15 -
Added line 50:
Deleted lines 52-55:
(:linebreaks:)
Added lines 62-66:
(:linebreaks:)
December 18, 2015, at 08:53 AM by 138.96.200.15 -
Changed line 30 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_range.png
to:
December 18, 2015, at 08:52 AM by 138.96.200.15 -
Changed line 58 from:
(:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3_top.png
to:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3_top.png
December 18, 2015, at 08:51 AM by 138.96.200.15 -
Changed line 39 from:
to:
December 18, 2015, at 08:50 AM by 138.96.200.15 -
Changed line 70 from:
to:
December 18, 2015, at 08:17 AM by 138.96.200.15 -
to:
December 18, 2015, at 08:16 AM by 138.96.200.15 -
Added line 30:
Changed line 33 from:
Ey field map in the nanolens device at t=10 fs
to:
Ey field map in the nanolens device at t=10 fs. Field values have been scaled to [-15 , 15]
December 18, 2015, at 08:15 AM by 138.96.200.15 -
December 18, 2015, at 08:14 AM by 138.96.200.15 -
Added lines 51-54:
(:linebreaks:)
Changed lines 63-73 from:
to:
(:linebreaks:)
(:table border='0' width='100%' align='center' cellspacing='1px':) (:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_dt0.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_dt1.png (:table border='0' width='100%' align='center' cellspacing='1px':) (:tableend:)
Left figure : polynomial order repartition for the bowtie antenna mesh with respect to time-step for the P1P3 case. Right figure : extinction cross section of the bowtie nanoantenna obtained with DGTD-P1, DGTD-P3 and DGTD-P1P3 methods. Less than 2 % of relative error is observed between DGTD-P3 and DGTD-P1P3 computations, for a speedup factor of 2.0
December 17, 2015, at 05:14 PM by 138.96.200.15 -
Changed lines 52-53 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3_top.png
to:
Changed lines 55-56 from:
to:
(:table border='0' width='100%' align='center' cellspacing='1px':) (:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_range.png (:tableend:)
December 17, 2015, at 05:09 PM by 138.96.200.15 -
Changed lines 52-54 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3_top.png (:tableend:)
to:
December 17, 2015, at 05:07 PM by 138.96.200.15 -
to:
December 17, 2015, at 05:06 PM by 138.96.200.15 -
Deleted line 50:
Added line 51:
December 17, 2015, at 05:05 PM by 138.96.200.15 -
Added lines 51-54:
(:table border='0' width='100%' align='center' cellspacing='1px':) (:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_visu_P1P3_top.png (:tableend:)
December 17, 2015, at 05:01 PM by 138.96.200.15 -
Changed line 46 from:
to:
December 17, 2015, at 05:00 PM by 138.96.200.15 -
http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_mesh.png |
to:
Added lines 43-49:
(:linebreaks:)
http://www-sop.inria.fr/nachos/pics/results/p_loc/bowtie_mesh.png | Mesh setup for a bowtie nanoantenna. The gray cells correspond to the nanoantenna, the blue cells to vacuum, while the red cells constitute the PML region. For this mesh, the ratio between the largest and the smallest edge length of the tetrahedral mesh is close to 275.
(:linebreaks:)
December 17, 2015, at 04:34 PM by 138.96.200.15 -
Changed lines 42-43 from:
Left figure : polynomial order repartition for the nanolens mesh with respect to time-step for the P1P3 case Right figure : field enhancement in the vicinity of the smallest sphere of a self-similar nanolens obtained with DGTD-P1, DGTD-P3 and DGTD-P1P3 methods. Less than 1 % of relative error is observed between DGTD-P3 and DGTD-P1P3 computations, for a speedup factor of 2.6
to:
Left figure : polynomial order repartition for the nanolens mesh with respect to time-step for the P1P3 case. Right figure : field enhancement in the vicinity of the smallest sphere of a self-similar nanolens obtained with DGTD-P1, DGTD-P3 and DGTD-P1P3 methods. Less than 1 % of relative error is observed between DGTD-P3 and DGTD-P1P3 computations, for a speedup factor of 2.6
Changed line 42 from:
Left figure : polynomial order repartition for the nanolens mesh with respect to time-step for the P1P3 case. The red elements correspond to P1 approximation, the green ones to P2, and the gray ones to P3
to:
December 17, 2015, at 04:33 PM by 138.96.200.15 -
Deleted line 42:
Changed lines 42-44 from:
Left figure : polynomial order repartition for the nanolens mesh with respect to time-step for the P1P3 case. The red elements correspond to P1 approximation, the green ones to P2, and the gray ones to P3.
to:
December 17, 2015, at 04:32 PM by 138.96.200.15 -
to:
December 17, 2015, at 04:31 PM by 138.96.200.15 -
Added lines 41-43:
December 17, 2015, at 04:26 PM by 138.96.200.15 -
Right figure: field enhancement in the vicinity of the smallest sphere of a self-similar nanolens obtained with DGTD-P1, DGTD-P3 and DGTD-P1P3 methods. Less than 1 % of relative error is observed between DGTD-P3 and DGTD-P1P3 computations, for a speedup factor of 2.6
to:
Right figure: field enhancement in the vicinity of the smallest sphere of a self-similar nanolens} obtained with DGTD-P1, DGTD-P3 and DGTD-P1P3 methods. Less than 1 % of relative error is observed between DGTD-P3 and DGTD-P1P3 computations, for a speedup factor of 2.6
to:
December 17, 2015, at 04:25 PM by 138.96.200.15 -
Added line 39:
Added lines 41-42:
December 17, 2015, at 04:21 PM by 138.96.200.15 -
Changed lines 37-38 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_dt0.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_dt1.png
to:
December 17, 2015, at 04:20 PM by 138.96.200.15 -
to:
Added lines 33-40:
(:linebreaks:)
(:table border='0' width='100%' align='center' cellspacing='1px':) (:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_dt0.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_dt1.png (:tableend:)
December 16, 2015, at 04:37 PM by 138.96.200.15 -
Changed lines 22-23 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P1.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P3.png
to:
Changed line 28 from:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P1P3.png
to:
Changed line 32 from:
to:
December 16, 2015, at 04:35 PM by 138.96.200.15 -
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P1.png (:cellnr align='center':) DGTD method with affine elements
to:
(:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P1.png (:cell align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P3.png (:cellnr align='center':) DGTD-P1 method (:cell align='center':) DGTD-P3 method (:tableend:) (:table border='0' width='100%' align='center' cellspacing='1px':)
Changed line 29 from:
(:cellnr align='center':) DGTD method with curvilinear elements
to:
(:cellnr align='center':) DGTD-P1P3 method
December 16, 2015, at 04:32 PM by 138.96.200.15 -
Added lines 18-28:
(:linebreaks:)
(:table border='0' width='100%' align='center' cellspacing='1px':) (:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P1.png (:cellnr align='center':) DGTD method with affine elements (:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_visu_P1P3.png (:cellnr align='center':) DGTD method with curvilinear elements (:tableend:)
December 16, 2015, at 04:30 PM by 138.96.200.15 -
Deleted line 14:
(:linebreaks:)
Changed lines 12-14 from:
%lfloat text-align=center width=300px http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_mesh.png | Mesh setup for a metallic nanolens. The gray cells correspond to the metallic spheres, the blue cells to vacuum, while the red cells constitute the PML region. For this mesh, the ratio between the largest and the smallest edge length of the tetrahedral mesh is above 400.%
to:
(:linebreaks:)
December 16, 2015, at 04:29 PM by 138.96.200.15 -
Changed lines 12-13 from:
http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_mesh.png | Mesh setup for a metallic nanolens. The gray cells correspond to the metallic spheres, the blue cells to vacuum, while the red cells constitute the PML region. For this mesh, the ratio between the largest and the smallest edge length of the tetrahedral mesh is above 400.\\
to:
Changed line 13 from:
to:
December 16, 2015, at 04:28 PM by 138.96.200.15 -
Added lines 16-17:
To overcome the limitation of the diffraction limit, it is possible to exploit the focusing effect provided by coupled surface plasmons. A typical nanolens is composed of a chain of metallic nanoparticles (nanospheres being the most common) of decreasing size, aligned with the polarization direction of the incident field. When the nanospheres are of significantly different sizes, the local field enhancement of the first particle is not perturbed by the second one because of its small relative size. As a result, the locally enhanced field of the first particle acts as an incident field for the second particle, resulting in a second enhancement, and so on. Eventually, the strongest enhancement is obtained in the gap between the two smaller particles.
December 16, 2015, at 04:20 PM by 138.96.200.15 -
to:
(:linebreaks:)
December 16, 2015, at 04:19 PM by 138.96.200.15 -
to:
December 16, 2015, at 04:18 PM by 138.96.200.15 -
to:
width=320px% http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_mesh.png | Mesh setup for a metallic nanolens. The gray cells correspond to the metallic spheres, the blue cells to vacuum, while the red cells constitute the PML region. For this mesh, the ratio between the largest and the smallest edge length of the tetrahedral mesh is above 400.
to:
Changed lines 12-16 from:
(:table border='0' width='90%' align='center' cellspacing='1px':) (:cellnr align='center':) http://www-sop.inria.fr/nachos/pics/results/p_loc/nanolens_mesh.png (:tableend:)
to:
December 16, 2015, at 04:16 PM by 138.96.200.15 -
Added lines 9-16:
(:linebreaks:)
December 16, 2015, at 04:05 PM by 138.96.200.15 -
Changed line 8 from:
to:
To overcome this limitation, several strategies can be considered. The strategy discussed here relies on the use of non-uniform distribution of the polynomial order in the framework of a global time step DGDT method. By imposing low orders in small cells and high orders in large cells, it is possible to significantly alleviate both the global number of degrees of freedom and the time step restriction with a minimal impact on the method accuracy. Strategies exploiting locally adaptive (LA) formulations usually combine both h and p- adaptivity in order to concentrate the computational effort in the areas of high field variations. Here, the adopted point of view is quite different: starting from a given mesh and an uniform distribution of the polynomial order k, the LA strategy exploits all the polynomial orders p, with p lesser or equal than k to obtain a solution of similar accuracy with a reduced computational cost.
to:
Changed line 9 from:
combine both h- and p-adaptivity in order to concentrate the computational effort in the areas of high field variations. Here, the adopted point of view is quite different: starting from a given mesh and an uniform distribution of the polynomial order k, the LA strategy exploits all the polynomial orders p, with p lesser or equal than k to obtain a solution of similar accuracy with a reduced computational cost.
to:
December 16, 2015, at 04:04 PM by 138.96.200.15 -
Changed lines 6-15 from:
In most of the existing works on the development of high order DGTD methods for the numerical modeling of light/matter interactions on the nanoscale, the formulation of the method is derived assuming a uniform distribution of the polynomial order to the cells of the underlying mesh. However, in the case of a mesh showing large variations in cell size, the time step imposed by the smallest cells can be a serious hindrance when trying to exploit high approximation orders. Indeed, a potentially large part of the CPU time is spent in the update of the physical field inside small cells where high polynomial orders might not be essential, while they are necessary in the larger cells.
to:
To overcome this limitation, several strategies can be considered. The strategy discussed here relies on the use of non-uniform distribution of the polynomial order in the framework of a global time step DGDT method. By imposing low orders in small cells and high orders in large cells, it is possible to significantly alleviate both the global number of degrees of freedom and the time step restriction with a minimal impact on the method accuracy. Strategies exploiting locally adaptive (LA) formulations usually combine both h- and p-adaptivity in order to concentrate the computational effort in the areas of high field variations. Here, the adopted point of view is quite different: starting from a given mesh and an uniform distribution of the polynomial order k, the LA strategy exploits all the polynomial orders p, with p lesser or equal than k to obtain a solution of similar accuracy with a reduced computational cost.
December 16, 2015, at 04:01 PM by 138.96.200.15 -
Changed lines 4-15 from:
(:linebreaks:)
to:
(:linebreaks:)
December 16, 2015, at 04:00 PM by 138.96.200.15 -
Changed lines 1-2 from:
(:title Simulation of near-field plasmonic interactions
to:
(:title Simulation of near-field plasmonic interactions\\\
Added line 2:
Added lines 1-4:
(:linebreaks:)
