org.objectweb.proactive.Active Interface Reference
Inheritance diagram for org.objectweb.proactive.Active:
[legend]
Detailed Description
Active is the root of the all interfaces related to the activity of an active object. It is a convenience for having a common interface that can be used to type objects implementing one or more of the others.
So far we considered three steps in the lifecycle of an active object.
the initialization of the activity (done only once)
the activity itself
the end of the activity (unique event)
In case of a migration, an active object stops and restarts its activity automatically without invoking the init or ending phases. Only the activity itself is restarted.
- Author:
- ProActive Team
- Version:
- 1.0, 2002/06
- Since:
- ProActive 0.9.3
Definition at line 57 of file Active.java.
The documentation for this interface was generated from the following file:
Generated on Mon Jan 22 15:16:13 2007 for ProActive by
1.5.1
