Collaboration diagram for org.objectweb.proactive.ProActive:
Public Member Functions | |
| void | enableExitOnEmpty () |
| After this call, when the JVM has no more active objects it will be killed. | |
Static Public Member Functions | |
| static void | newMain (String classname, String[] mainParameters, Node node) throws ClassNotFoundException, NoSuchMethodException, ProActiveException |
| Launches the main method of the main class through the node node. | |
| static void | newRemote (String classname, Node node) throws ClassNotFoundException, ProActiveException |
| Creates an instance of the remote class. | |
| static Object | newActive (String classname, Object[] constructorParameters) throws ActiveObjectCreationException, NodeException |
| Creates a new ActiveObject based on classname attached to a default node in the local JVM. | |
| static Object | newActive (String classname, Object[] constructorParameters, String nodeURL) throws ActiveObjectCreationException, NodeException |
| Creates a new ActiveObject based on classname attached to the node of the given URL. | |
| static Object | newActive (String classname, Object[] constructorParameters, Node node) throws ActiveObjectCreationException, NodeException |
| Creates a new ActiveObject based on classname attached to the given node or on a default node in the local JVM if the given node is null. | |
| static Object[] | newActiveInParallel (String className, Object[][] constructorParameters, Node[] nodes) throws ClassNotFoundException |
| static Object[] | newActiveInParallel (String className, Object[] constructorParameters, VirtualNode virtualNode) throws NodeException, ClassNotFoundException |
| static Object | newActiveAsGroup (String classname, Object[] constructorParameters, VirtualNode virtualnode) throws ActiveObjectCreationException, NodeException |
| Creates a new group of Active Objects. | |
| static Object | newActiveAsGroup (String className, Object[] constructorParameters, VirtualNode virtualNode, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Component | newActiveComponent (String className, Object[] constructorParameters, Node node, Active activity, MetaObjectFactory factory, ComponentParameters componentParameters) throws ActiveObjectCreationException, NodeException |
| Creates a new ProActive component over the specified base class, according to the given component parameters, and returns a reference on the component of type Component. | |
| static Component | newActiveComponent (String className, Object[] constructorParameters, VirtualNode vn, ComponentParameters componentParameters) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target) throws ActiveObjectCreationException, NodeException |
| Turns the target object into an ActiveObject attached to a default node in the local JVM. | |
| static Object | turnActive (Object target, String nodeURL) throws ActiveObjectCreationException, NodeException |
| Turns the target object into an Active Object and send it to the Node identified by the given url. | |
| static Object | turnActive (Object target, Node node) throws ActiveObjectCreationException, NodeException |
| Turns the target object into an Active Object and send it to the given Node or to a default node in the local JVM if the given node is null. | |
| static Object | turnActive (Object target, Node node, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, String nameOfTargetType, Node node) throws ActiveObjectCreationException, NodeException |
| Turns a Java object into an Active Object and send it to a remote Node or to a local node if the given node is null. | |
| static Object | turnActive (Object target, String nameOfTargetType, Node node, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Object | turnActiveAsGroup (Object target, String nameOfTargetType, VirtualNode virtualnode) throws ActiveObjectCreationException, NodeException |
| Turns a Java object into a group of Active Objects and sends the elements of the group to remote Nodes mapped to the given virtualnode in the XML deployment descriptor. | |
| static Object | newActive (String classname, Class[] genericParameters, Object[] constructorParameters) throws ActiveObjectCreationException, NodeException |
| static Object | newActive (String classname, Class[] genericParameters, Object[] constructorParameters, String nodeURL) throws ActiveObjectCreationException, NodeException |
| static Object | newActive (String classname, Class[] genericParameters, Object[] constructorParameters, Node node) throws ActiveObjectCreationException, NodeException |
| static Object | newActive (String classname, Class[] genericParameters, Object[] constructorParameters, Node node, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Object[] | newActiveInParallel (String className, Class[] genericParameters, Object[][] constructorParameters, Node[] nodes) throws ClassNotFoundException |
| static Object[] | newActiveInParallel (String className, Class[] genericParameters, Object[] constructorParameters, VirtualNode virtualNode) throws NodeException, ClassNotFoundException |
| static Object | newActiveAsGroup (String classname, Class[] genericParameters, Object[] constructorParameters, VirtualNode virtualnode) throws ActiveObjectCreationException, NodeException |
| static Object | newActiveAsGroup (String classname, Class[] genericParameters, Object[] constructorParameters, VirtualNode virtualnode, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, String nameOfTargetType, Class[] genericParameters, Node node, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Component | newActiveComponent (String classname, Class[] genericParameters, Object[] constructorParameters, Node node, Active activity, MetaObjectFactory factory, ComponentParameters componentParameters) throws ActiveObjectCreationException, NodeException |
| static Component | newActiveComponent (String className, Class[] genericParameters, Object[] constructorParameters, VirtualNode vn, ComponentParameters componentParameters) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, Class[] genericParameters) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, Class[] genericParameters, String nodeURL) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, Class[] genericParameters, Node node) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, Class[] genericParameters, Node node, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, Class[] genericParameters, String nameOfTargetType, Node node) throws ActiveObjectCreationException, NodeException |
| static Object | turnActive (Object target, Class[] genericParameters, String nameOfTargetType, Node node, Active activity, MetaObjectFactory factory) throws ActiveObjectCreationException, NodeException |
| static Object | turnActiveAsGroup (Object target, Class[] genericParameters, String nameOfTargetType, VirtualNode virtualnode) throws ActiveObjectCreationException, NodeException |
| static void | register (Object obj, String url) throws java.io.IOException |
| Registers an active object into a registry(RMI or IBIS or HTTP, default is RMI). | |
| static void | unregister (String url) throws java.io.IOException |
| Unregisters an active object previously registered into a registry. | |
| static Object | lookupActive (String classname, String url) throws ActiveObjectCreationException, java.io.IOException |
| Looks-up an active object previously registered in a registry(RMI, IBIS, HTTP). | |
| static String[] | listActive (String url) throws java.io.IOException |
| Looks-up all Active Objects registered on a host, using a registry(RMI or JINI or HTTP or IBIS) The registry where to look for is fully determined with the protocol included in the url. | |
| static String | getActiveObjectNodeUrl (Object activeObject) |
Return the URL of the remote activeObject. | |
| static boolean | isException (Object future) |
| Find out if the object contains an exception that should be thrown. | |
| static void | waitFor (Object future) |
Blocks the calling thread until the object future is available. | |
| static void | waitFor (Object future, long timeout) throws ProActiveException |
Blocks the calling thread until the object future is available or until the timeout expires. | |
| static ProActiveDescriptor | getProactiveDescriptor () throws ProActiveException, IOException |
Returns a ProActiveDescriptor that gives an object representation of the XML document located at the url given by proactive.pad system's property. | |
| static ProActiveDescriptor | getProactiveDescriptor (String xmlDescriptorUrl) throws ProActiveException |
Returns a ProActiveDescriptor that gives an object representation of the XML document located at the given url. | |
| static ProActiveDescriptor | getProactiveDescriptor (String xmlDescriptorUrl, VariableContract variableContract) throws ProActiveException |
Returns a ProActiveDescriptor that gives an object representation of the XML document located at the given url, and uses the given Variable Contract. | |
| static void | registerVirtualNode (VirtualNode virtualNode, String registrationProtocol, boolean replacePreviousBinding) throws ProActiveException, AlreadyBoundException |
| Registers locally the given VirtualNode in a registry such RMIRegistry or JINI Lookup Service or HTTP registry. | |
| static VirtualNode | lookupVirtualNode (String url) throws ProActiveException |
| Looks-up a VirtualNode previously registered in a registry(RMI or JINI or HTTP or IBIS) The registry where to look for is fully determined with the protocol included in the url. | |
| static void | unregisterVirtualNode (VirtualNode virtualNode) throws ProActiveException |
| Unregisters the virtualNode previoulsy registered in a registry such as JINI or RMI. | |
| static Body | getBodyOnThis () |
| When an active object is created, it is associated with a Body that takes care of all non fonctionnal properties. | |
| static StubObject | getStubOnThis () |
| Returns a Stub-Proxy couple pointing to the local body associated to the active object whose active thread is calling this method. | |
| static void | migrateTo (Object activeObject) throws MigrationException |
| Migrates the active object whose active thread is calling this method to the same location as the active object given in parameter. | |
| static void | migrateTo (String nodeURL) throws MigrationException |
| Migrates the active object whose active thread is calling this method to the node caracterized by the given url. | |
| static void | migrateTo (Node node) throws MigrationException |
| Migrates the active object whose active thread is calling this method to the given node. | |
| static void | migrateTo (Body bodyToMigrate, Object activeObject, boolean isNFRequest) throws MigrationException |
| Migrates the given body to the same location as the active object given in parameter. | |
| static void | migrateTo (Body bodyToMigrate, String nodeURL, boolean isNFRequest) throws MigrationException |
| Migrates the given body to the node caracterized by the given url. | |
| static void | migrateTo (Body bodyToMigrate, Node node, boolean isNFRequest) throws MigrationException |
Migrates the body bodyToMigrate to the given node. | |
| static void | migrateTo (Body bodyToMigrate, Node node, boolean isNFRequest, int priority) throws MigrationException |
| static int | waitForAny (java.util.Vector futures) |
| Blocks the calling thread until one of the futures in the vector is available. | |
| static int | waitForAny (java.util.Vector futures, long timeout) throws ProActiveException |
| Blocks the calling thread until one of the futures in the vector is available or until the timeout expires. | |
| static void | waitForAll (java.util.Vector futures) |
| Blocks the calling thread until all futures in the vector are available. | |
| static void | waitForAll (java.util.Vector futures, long timeout) throws ProActiveException |
| Blocks the calling thread until all futures in the vector are available or until the timeout expires. | |
| static void | waitForTheNth (java.util.Vector futures, int n) |
| Blocks the calling thread until the N-th of the futures in the vector is available. | |
| static void | waitForTheNth (java.util.Vector futures, int n, long timeout) throws ProActiveException |
| static boolean | allAwaited (java.util.Vector futures) |
Return false if one object of futures is available. | |
| static boolean | isAwaited (Object future) |
Return false if the object future is available. | |
| static Object | getFutureValue (Object future) |
| Return the object contains by the future (ie its target). | |
| static void | enableAC (Object obj) throws java.io.IOException |
| Enable the automatic continuation mechanism for this active object. | |
| static void | disableAC (Object obj) throws java.io.IOException |
| Disable the automatic continuation mechanism for this active object. | |
| static void | terminateActiveObject (Object ao, boolean immediate) |
| Kill an Active Object while calling terminate() method on its body. | |
| static void | setImmediateService (Object obj, String methodName) throws java.io.IOException |
| Set an immediate execution for the target active object obj of the method String, ie request of name methodName will be executed right away upon arrival at the target AO context. | |
| static void | setImmediateService (Object obj, String methodName, Class[] parametersTypes) throws IOException |
| static void | removeImmediateService (Object obj, String methodName, Class[] parametersTypes) throws IOException |
| Removes an immmediate execution for the active object obj, i.e. | |
| static String | getJobId () |
| static void | exposeAsWebService (Object o, String url, String urn, String[] methods) |
| Expose an active object as a web service. | |
| static void | unExposeAsWebService (String urn, String url) |
| Delete the service on a web server. | |
| static void | exposeComponentAsWebService (Component component, String url, String componentName) |
| Deploy a component as a webservice. | |
| static void | unExposeComponentAsWebService (String componentName, String url, Component component) |
| Undeploy component interfaces on a web server. | |
| static Object | createStubObject (String className, UniversalBody body) throws MOPException |
| static void | tryWithCatch (Class c) |
| This has to be called just before a try block for a single exception. | |
| static void | tryWithCatch (Class[] c) |
| This has to be called just before a try block for many exceptions. | |
| static void | endTryWithCatch () |
| This has to be called at the end of the try block. | |
| static void | removeTryWithCatch () |
| This has to be called at the beginning of the finally block, so it requires one. | |
| static void | throwArrivedException () |
| This can be used to query a potential returned exception, and throw it if it exists. | |
| static void | waitForPotentialException () |
| This is used to wait for the return of every call, so that we know the execution can continue safely with no pending exception. | |
| static void | addNFEListenerOnJVM (NFEListener listener) |
| Add a listener for NFE reaching the local JVM. | |
| static void | removeNFEListenerOnJVM (NFEListener listener) |
| Remove a listener for NFE reaching the local JVM. | |
| static void | addNFEListenerOnAO (Object ao, NFEListener listener) |
| Add a listener for NFE reaching a given active object. | |
| static void | removeNFEListenerOnAO (Object ao, NFEListener listener) |
| Remove a listener for NFE reaching a given active object. | |
| static void | addNFEListenerOnProxy (Object ao, NFEListener listener) |
| Add a listener for NFE reaching the client side of a given active object. | |
| static void | removeNFEListenerOnProxy (Object ao, NFEListener listener) |
| Remove a listener for NFE reaching the client side of a given active object. | |
| static void | addNFEListenerOnGroup (Object group, NFEListener listener) |
| Add a listener for NFE regarding a group. | |
| static void | removeNFEListenerOnGroup (Object group, NFEListener listener) |
| Remove a listener for NFE regarding a group. | |
| static Collection | getAllExceptions () |
| Get the exceptions that have been caught in the current ProActive.tryWithCatch()/ProActive.removeTryWithCatch() block. | |
| static Node | getNode () throws NodeException |
| static void | exitSuccess () |
| Call this method at the end of the application if it completed successfully, for the launcher to be aware of it. | |
| static void | exitFailure () |
| Call this method at the end of the application if it did not complete successfully, for the launcher to be aware of it. | |
| static String | getProActiveVersion () |
| Returns the number of this version. | |
Static Public Attributes | |
| static final Logger | loggerGroup = ProActiveLogger.getLogger(Loggers.GROUPS) |
Static Protected Attributes | |
| static final Logger | logger = ProActiveLogger.getLogger(Loggers.CORE) |
Static Package Functions | |
| [static initializer] | |
..), futures, deployment descritpors, components, groups. This class is the central point of the library.
newActive(...) turnActive(...)
Active Object Manipulation
getBodyOnThis() getActiveObjectNodeUrl(Object) getStubOnThis() migrateTo(...) lookupActive(String, String) register(Object, String) setImmediateService(...)
isAwaited(Object) waitFor(Object) waitForAll(Vector) waitForAny(Vector) waitForPotentialException() waitForTheNth(Vector, int) Previous methods provide also the ability to pass a timeout value
allAwaited(Vector) getFutureValue(Object) isException(Object)
newActiveAsGroup(...)
newActiveComponent(...)
getProactiveDescriptor(String)
addNFEListenerOnAO(Object, NFEListener) addNFEListenerOnJVM(NFEListener) addNFEListenerOnProxy(Object, NFEListener) removeNFEListenerOnAO(Object, NFEListener) removeNFEListenerOnJVM(NFEListener) removeNFEListenerOnProxy(Object, NFEListener)
tryWithCatch(Class) removeTryWithCatch() endTryWithCatch() throwArrivedException()
enableAC(Object) disableAC(Object)
exposeAsWebService(Object, String, String, String[]) exposeComponentAsWebService(Component, String, String)
ProActiveGroup
Definition at line 201 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.newMain | ( | String | classname, | |
| String[] | mainParameters, | |||
| Node | node | |||
| ) | throws ClassNotFoundException, NoSuchMethodException, ProActiveException [static] |
| classname | classname of the main method to launch | |
| mainParameters | parameters | |
| node | node in which launch the main method |
| ClassNotFoundException | ||
| NoSuchMethodException | ||
Definition at line 235 of file ProActive.java.
References org.objectweb.proactive.core.runtime.ProActiveRuntime.launchMain().
| static void org.objectweb.proactive.ProActive.newRemote | ( | String | classname, | |
| Node | node | |||
| ) | throws ClassNotFoundException, ProActiveException [static] |
This instance is created with the default constructor
| classname | ||
| node |
Definition at line 250 of file ProActive.java.
References org.objectweb.proactive.core.runtime.ProActiveRuntime.newRemote().
| static Object org.objectweb.proactive.ProActive.newActive | ( | String | classname, | |
| Object[] | constructorParameters | |||
| ) | throws ActiveObjectCreationException, NodeException [static] |
| classname | the name of the class to instanciate as active | |
| constructorParameters | the parameters of the constructor. |
| ActiveObjectCreationException | if a problem occur while creating the stub or the body | |
| NodeException | if the DefaultNode cannot be created |
Definition at line 264 of file ProActive.java.
Referenced by org.objectweb.proactive.ProActive.newActive(), and org.objectweb.proactive.ProActive.newActiveAsGroup().
| Object[] | constructorParameters, | |||
| String | nodeURL | |||
| constructorParameters | the parameters of the constructor. | |
| nodeURL | the URL of the node where to create the active object. If null, the active object is created localy on a default node |
| NodeException | if the node URL cannot be resolved as an existing Node |
Definition at line 281 of file ProActive.java.
References org.objectweb.proactive.ProActive.newActive().
| Node | node | |||
| node | the possibly null node where to create the active object. |
| NodeException | if the node was null and that the DefaultNode cannot be created |
Definition at line 303 of file ProActive.java.
| static Object [] org.objectweb.proactive.ProActive.newActiveInParallel | ( | String | className, | |
| Object | constructorParameters[][], | |||
| Node[] | nodes | |||
| ) | throws ClassNotFoundException [static] |
Create a set of active objects with given construtor parameters. The object activation is optimized by a thread pool.
The total of active objects created is equal to the number of nodes and to the total of constructor paramaters also.
The condition to use this method is that: constructorParameters.length == nodes.length
| className | the name of the class to instanciate as active. | |
| constructorParameters | the array that contains the parameters used to build the active objects. All active objects have the same constructor parameters. | |
| nodes | the array of nodes where the active objects are created. |
| ClassNotFoundException | in the case of className is not a class. |
Definition at line 327 of file ProActive.java.
Referenced by org.objectweb.proactive.ProActive.newActiveInParallel().
| VirtualNode | virtualNode | |||
| ) | throws NodeException, ClassNotFoundException [static] |
Create a set of identical active objects on a given virtual node. The object activation is optimized by a thread pool.
When the given virtual node is not previously activated, this method employ the node creation event producer/listerner mechanism joined to the thread pool. That aims to create an active object just after the node deploying.
| virtualNode | the virtual node where the active objects are created. |
| NodeException | happens when the given virtualNode is already activated and throws an exception. | |
Definition at line 352 of file ProActive.java.
References org.objectweb.proactive.ProActive.newActiveInParallel().
| static Object org.objectweb.proactive.ProActive.newActiveAsGroup | ( | String | classname, | |
| VirtualNode | virtualnode | |||
The type of the group and the type of the active objects it contains correspond to the classname parameter. This group will contain one active object per node mapped onto the virtual node given as a parameter.
| classname | classname the name of the class to instanciate as active | |
| constructorParameters | constructorParameters the parameters of the constructor. | |
| virtualnode | The virtualnode where to create active objects. Active objects will be created on each node mapped to the given virtualnode in XML deployment descriptor. |
| NodeException | if the virtualnode was null |
Definition at line 372 of file ProActive.java.
Referenced by org.objectweb.proactive.ProActive.newActiveAsGroup().
| static Object org.objectweb.proactive.ProActive.newActiveAsGroup | ( | String | className, | |
| VirtualNode | virtualNode, | |||
| Active | activity, | |||
| MetaObjectFactory | factory | |||
| className | classname the name of the class to instanciate as active | |
| virtualNode | The virtualnode where to create active objects. Active objects will be created on each node mapped to the given virtualnode in XML deployment descriptor. | |
| activity | the possibly null activity object defining the different step in the activity of the object. see the definition of the activity in the javadoc of this classe for more information. | |
| factory | the possibly null meta factory giving all factories for creating the meta-objects part of the body associated to the reified object. If null the default ProActive MataObject factory is used. |
Definition at line 397 of file ProActive.java.
References org.objectweb.proactive.ProActive.newActiveAsGroup().
| static Component org.objectweb.proactive.ProActive.newActiveComponent | ( | String | className, | |
| Node | node, | |||
| MetaObjectFactory | factory, | |||
| ComponentParameters | componentParameters | |||
A reference on the active object base class can be retreived through the component parameters controller's method "getStubOnReifiedObject".
| className | the name of the base class. "Composite" if the component is a composite, "ParallelComposite" if the component is a parallel composite component | |
| constructorParameters | the parameters of the constructor of the object to instantiate as active. If some parameters are primitive types, the wrapper class types should be given here. null can be used to specify that no parameter are passed to the constructor. | |
| node | the possibly null node where to create the active object. If null, the active object is created localy on a default node | |
| factory | should be null for components (automatically created) | |
| componentParameters | the parameters of the component |
| ActiveObjectCreationException | if a problem occurs while creating the stub or the body | |
Definition at line 427 of file ProActive.java.
Referenced by org.objectweb.proactive.ProActive.newActiveComponent().
| VirtualNode | vn, | |||
This method allows automatic of primitive components on Virtual Nodes. In that case, the appendix -cyclicInstanceNumber-number is added to the name of each of these components. If the component is not a primitive, only one instance of the component is created, on the first node retreived from the specified virtual node.
| vn | the possibly null node where to create the active object. If null, the active object is created localy on a default node | |
Definition at line 460 of file ProActive.java.
References org.objectweb.proactive.ProActive.newActiveComponent().
| static Object org.objectweb.proactive.ProActive.turnActive | ( | Object | target | ) | throws ActiveObjectCreationException, NodeException [static] |
The type of the stub is is the type of the existing object.
| target | The object to turn active |
Definition at line 476 of file ProActive.java.
Referenced by org.objectweb.proactive.ProActive.turnActive(), and org.objectweb.proactive.ProActive.turnActiveAsGroup().
| static Object org.objectweb.proactive.ProActive.turnActive | ( | Object | target, | |
| target | The object to turn active | |
| nodeURL | the URL of the node where to create the active object on. If null, the active object is created localy on a default node |
Definition at line 492 of file ProActive.java.
References org.objectweb.proactive.ProActive.turnActive().
| Node | node | |||
The type of the stub is is the type of the target object.
| node | The Node the object should be sent to or null to create the active object in the local JVM |
Definition at line 514 of file ProActive.java.
| Node | node, | |||
| node | The Node the object should be sent to or null to create the active object in the local JVM | |
Definition at line 535 of file ProActive.java.
| String | nameOfTargetType, | |||
| Node | node | |||
The type of the stub is given by the parameter nameOfTargetType.
| nameOfTargetType | the fully qualified name of the type the stub class should inherit from. That type can be less specific than the type of the target object. | |
Definition at line 555 of file ProActive.java.
| Node | node, | |||
The type of the stub is given by the parameter nameOfTargetType. A Stub is dynamically generated for the existing object. The result of the call will be an instance of the Stub class pointing to the proxy object pointing to the body object pointing to the existing object. The body can be remote or local depending if the existing is sent remotely or not.
Definition at line 581 of file ProActive.java.
| static Object org.objectweb.proactive.ProActive.turnActiveAsGroup | ( | Object | target, | |
| virtualnode | The VirtualNode where the target object will be turn into an Active Object Target object will be turned into an Active Object on each node mapped to the given virtualnode in XML deployment descriptor. |
Definition at line 601 of file ProActive.java.
| Class[] | genericParameters, | |||
| genericParameters | parameterizing types (of class | |
| classname) | ||
Definition at line 619 of file ProActive.java.
| classname) | ||
Definition at line 639 of file ProActive.java.
| Node | node | |||
| classname) | ||
Definition at line 664 of file ProActive.java.
| Node | node, | |||
The object returned is a stub class that extends the target class and that is automatically generated on the fly. The Stub class reference a the proxy object that reference the body of the active object. The body referenced by the proxy can either be local of remote, depending or the respective location of the object calling the newActive and the active object itself.
| classname) | ||
| factory | the possibly null meta factory giving all factories for creating the meta-objects part of the body associated to the reified object. If null the default ProActive MetaObject factory is used. |
Definition at line 695 of file ProActive.java.
References org.objectweb.proactive.core.body.MetaObjectFactory.clone(), org.objectweb.proactive.ProActive.createStubObject(), org.objectweb.proactive.ext.security.ProActiveSecurityManager.generateSiblingCertificate(), org.objectweb.proactive.core.body.MetaObjectFactory.getProActiveSecurityManager(), org.objectweb.proactive.core.mop.MOPException.getTargetException(), org.objectweb.proactive.core.body.MetaObjectFactory.setProActiveSecurityManager(), org.objectweb.proactive.core.util.timer.CompositeAverageMicroTimer.setTimer(), org.objectweb.proactive.core.util.timer.CompositeAverageMicroTimer.start(), and org.objectweb.proactive.core.util.timer.CompositeAverageMicroTimer.stop().
| genericParameters | genericParameters parameterizing types | |
Definition at line 770 of file ProActive.java.
Definition at line 821 of file ProActive.java.
Definition at line 871 of file ProActive.java.
| VirtualNode | virtualnode, | |||
| virtualnode | The virtualnode where to create active objects. Active objects will be created on each node mapped to the given virtualnode in XML deployment descriptor. | |
Definition at line 898 of file ProActive.java.
| Node | node, | |||
| classname) | ||
Definition at line 953 of file ProActive.java.
References org.objectweb.proactive.core.body.MetaObjectFactory.clone(), org.objectweb.proactive.ProActive.createStubObject(), org.objectweb.proactive.core.mop.MOPException.getTargetException(), and org.objectweb.proactive.core.body.MetaObjectFactory.setProActiveSecurityManager().
| static Component org.objectweb.proactive.ProActive.newActiveComponent | ( | String | classname, | |
| Node | node, | |||
| classname | the name of the base class. "Composite" if the component is a composite, "ParallelComposite" if the component is a parallel composite component | |
Definition at line 1021 of file ProActive.java.
Definition at line 1071 of file ProActive.java.
References org.objectweb.proactive.core.component.factory.ProActiveGenericFactory.newFcInstance().
| Class[] | genericParameters | |||
Definition at line 1102 of file ProActive.java.
Definition at line 1120 of file ProActive.java.
| Node | node | |||
Definition at line 1144 of file ProActive.java.
| Node | node, | |||
Definition at line 1166 of file ProActive.java.
| Node | node | |||
Definition at line 1187 of file ProActive.java.
| Node | node, | |||
Definition at line 1216 of file ProActive.java.
| classname) | ||
Definition at line 1275 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.register | ( | Object | obj, | |
| String | url | |||
| ) | throws java.io.IOException [static] |
In fact it is the remote version of the body of the active object that is registered into the registry under the given URL. According to the type of the associated body(default is Rmi), the registry in which to register is automatically found.
| obj | the active object to register. | |
| url | the url under which the remote body is registered. The url must point to the localhost since registering is always a local action. The url can take the form:protocol://localhost:port/nam or //localhost:port/name if protocol is RMI or //localhost/name if port is 1099 or only the name. The registered object will be reachable with the following url: protocol://machine_name:port/name using lookupActive method. Protocol and port can be removed if default |
| java.io.IOException | if the remote body cannot be registered |
Definition at line 1319 of file ProActive.java.
References org.objectweb.proactive.ProActive.logger.
| static void org.objectweb.proactive.ProActive.unregister | ( | String | url | ) | throws java.io.IOException [static] |
| url | the url under which the active object is registered. |
| java.io.IOException | if the remote object cannot be removed from the registry |
Definition at line 1333 of file ProActive.java.
| static Object org.objectweb.proactive.ProActive.lookupActive | ( | String | classname, | |
| String | url | |||
| ) | throws ActiveObjectCreationException, java.io.IOException [static] |
In fact it is the remote version of the body of an active object that can be registered into the Registry under a given URL. If the lookup is successful, the method reconstructs a Stub-Proxy couple and point it to the RmiRemoteBody found. The registry where to look for is fully determined with the protocol included in the url
| classname | the fully qualified name of the class the stub should inherit from. | |
| url | the url under which the remote body is registered. The url takes the following form: protocol://machine_name:port/name. Protocol and port can be ommited if respectively RMI and 1099: //machine_name/name |
classname pointing to the remote body found | java.io.IOException | if the remote body cannot be found under the given url or if the object found is not of type RmiRemoteBody | |
| ActiveObjectCreationException | if the stub-proxy couple cannot be created |
Definition at line 1369 of file ProActive.java.
References org.objectweb.proactive.core.mop.MOPException.getTargetException().
| static String [] org.objectweb.proactive.ProActive.listActive | ( | String | url | ) | throws java.io.IOException [static] |
| url | The url where to perform the lookup. The url takes the following form: protocol://machine_name:port. Protocol and port can be ommited if respectively RMI and 1099: //machine_name |
| IOException | If the given url does not map to a physical host, or if the connection is refused. |
Definition at line 1419 of file ProActive.java.
| static String org.objectweb.proactive.ProActive.getActiveObjectNodeUrl | ( | Object | activeObject | ) | [static] |
| activeObject | the remote active object. |
activeObject. Definition at line 1445 of file ProActive.java.
References org.objectweb.proactive.core.body.UniversalBody.getNodeURL().
| static boolean org.objectweb.proactive.ProActive.isException | ( | Object | future | ) | [static] |
| future | the future object that is examinated |
Definition at line 1455 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.waitFor | ( | Object | future | ) | [static] |
future must be the result object of an asynchronous call. Usually the the wait by necessity model take care of blocking the caller thread asking for a result not yet available. This method allows to block before the result is first used.
| future | object to wait for |
Definition at line 1479 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.waitFor | ( | Object | future, | |
| long | timeout | |||
| ) | throws ProActiveException [static] |
| future | object to wait for | |
| timeout | to wait in ms |
| ProActiveException | if the timeout expire |
Definition at line 1505 of file ProActive.java.
| static ProActiveDescriptor org.objectweb.proactive.ProActive.getProactiveDescriptor | ( | ) | throws ProActiveException, IOException [static] |
| ProActiveException | ||
| RemoteException |
Definition at line 1529 of file ProActive.java.
| static ProActiveDescriptor org.objectweb.proactive.ProActive.getProactiveDescriptor | ( | String | xmlDescriptorUrl | ) | throws ProActiveException [static] |
| xmlDescriptorUrl | The url of the XML document |
| ProActiveException | if a problem occurs during the creation of the object |
Definition at line 1552 of file ProActive.java.
| static ProActiveDescriptor org.objectweb.proactive.ProActive.getProactiveDescriptor | ( | String | xmlDescriptorUrl, | |
| VariableContract | variableContract | |||
Definition at line 1568 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.registerVirtualNode | ( | VirtualNode | virtualNode, | |
| String | registrationProtocol, | |||
| boolean | replacePreviousBinding | |||
| ) | throws ProActiveException, AlreadyBoundException [static] |
The VirtualNode to register must exist on the local runtime. This is done when using XML Deployment Descriptors
| virtualNode | the VirtualNode to register. | |
| registrationProtocol | The protocol used for registration or null in order to use the protocol used to start the jvm. At this time RMI, JINI, HTTP, IBIS are supported. If set to null, the registration protocol will be set to the system property: proactive.communication.protocol | |
| ProActiveException | If the VirtualNode with the given name has not been yet activated or does not exist on the local runtime |
Definition at line 1683 of file ProActive.java.
References org.objectweb.proactive.core.runtime.ProActiveRuntime.getVirtualNode(), and org.objectweb.proactive.core.runtime.ProActiveRuntime.registerVirtualNode().
| static VirtualNode org.objectweb.proactive.ProActive.lookupVirtualNode | ( | String | url | ) | throws ProActiveException [static] |
| url | The url where to perform the lookup. The url takes the following form: protocol://machine_name:port/name. Protocol and port can be ommited if respectively RMI and 1099: //machine_name/name |
| ProActiveException | If no objects are bound with the given url |
Definition at line 1714 of file ProActive.java.
References org.objectweb.proactive.core.runtime.ProActiveRuntime.getVirtualNode().
| static void org.objectweb.proactive.ProActive.unregisterVirtualNode | ( | VirtualNode | virtualNode | ) | throws ProActiveException [static] |
Calling this method removes the VirtualNode from the local runtime.
| virtualNode | The VirtualNode to unregister |
| ProActiveException | if a problem occurs whle unregistering the VirtualNode |
Definition at line 1733 of file ProActive.java.
References org.objectweb.proactive.core.descriptor.data.VirtualNodeImpl.getName(), and org.objectweb.proactive.core.runtime.ProActiveRuntime.unregisterVirtualNode().
| static Body org.objectweb.proactive.ProActive.getBodyOnThis | ( | ) | [static] |
Assuming that the active object is only accessed by the different Stub objects, all method calls end-up as Requests sent to this Body. Therefore the only thread calling the method of the active object is the active thread managed by the body. There is an unique mapping between the active thread and the body responsible for it. From any method in the active object the current thread caller of the method is the active thread. When a reified method wants to get a reference to the Body associated to the active object, it can invoke this method. Assuming that the current thread is the active thread, the associated body is returned.
Definition at line 1763 of file ProActive.java.
| static StubObject org.objectweb.proactive.ProActive.getStubOnThis | ( | ) | [static] |
Definition at line 1773 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.migrateTo | ( | Object | activeObject | ) | throws MigrationException [static] |
This method must be called from an active object using the active thread as the current thread will be used to find which active object is calling the method. The object given as destination must be an active object.
| activeObject | the active object indicating the destination of the migration. |
| MigrationException | if the migration fails |
Definition at line 1796 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.migrateTo | ( | String | nodeURL | ) | throws MigrationException [static] |
This method must be called from an active object using the active thread as the current thread will be used to find which active object is calling the method. The url must be the url of an existing node.
| nodeURL | the url of an existing where to migrate to. |
Definition at line 1810 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.migrateTo | ( | Node | node | ) | throws MigrationException [static] |
| node | an existing node where to migrate to. |
Definition at line 1826 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.migrateTo | ( | Body | bodyToMigrate, | |
| Object | activeObject, | |||
| boolean | isNFRequest | |||
This method can be called from any object and does not perform the migration. Instead it generates a migration request that is sent to the targeted body. The object given as destination must be an active object.
| bodyToMigrate | the body to migrate. | |
| activeObject | the active object indicating the destination of the migration. | |
| isNFRequest | a boolean indicating that the request is not functional i.e it does not modify the application's computation |
Definition at line 1849 of file ProActive.java.
| String | nodeURL, | |||
| nodeURL | the url of an existing where to migrate to. | |
Definition at line 1866 of file ProActive.java.
| Node | node, | |||
| node | an existing node where to migrate to. | |
Definition at line 1881 of file ProActive.java.
| Node | node, | |||
| boolean | isNFRequest, | |||
| int | priority | |||
| isNFRequest | a boolean indicating that the request is not functional i.e it does not modify the application's computation | |
| priority | the level of priority of the non functional request. Levels are defined in Request interface of ProActive. |
Definition at line 1900 of file ProActive.java.
References org.objectweb.proactive.core.body.request.BodyRequest.send().
| static int org.objectweb.proactive.ProActive.waitForAny | ( | java.util.Vector | futures | ) | [static] |
THIS METHOD MUST BE CALLED FROM AN ACTIVE OBJECT.
| futures | vector of futures |
Definition at line 1927 of file ProActive.java.
| static int org.objectweb.proactive.ProActive.waitForAny | ( | java.util.Vector | futures, | |
| futures | vector of futures | |
| ProActiveException | if the timeout expires |
Definition at line 1946 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.waitForAll | ( | java.util.Vector | futures | ) | [static] |
Definition at line 1974 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.waitForAll | ( | java.util.Vector | futures, | |
Definition at line 1991 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.waitForTheNth | ( | java.util.Vector | futures, | |
| int | n | |||
| ) | [static] |
Definition at line 2023 of file ProActive.java.
| int | n, | |||
| n | ||
Definition at line 2043 of file ProActive.java.
| static boolean org.objectweb.proactive.ProActive.allAwaited | ( | java.util.Vector | futures | ) | [static] |
| futures | a table with futures. |
true if all futures are awaited, else false . Definition at line 2063 of file ProActive.java.
| static boolean org.objectweb.proactive.ProActive.isAwaited | ( | Object | future | ) | [static] |
This method is recursive, i.e. if result of future is a future too, isAwaited is called again on this result, and so on.
Definition at line 2085 of file ProActive.java.
| static Object org.objectweb.proactive.ProActive.getFutureValue | ( | Object | future | ) | [static] |
If parameter is not a future, it is returned. A wait-by-necessity occurs if future is not available. This method is recursive, i.e. if result of future is a future too, getFutureValue is called again on this result, and so on.
Definition at line 2112 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.terminateActiveObject | ( | Object | ao, | |
| boolean | immediate | |||
| ) | [static] |
| ao | the active object to kill | |
| immediate | if this boolean is true, this method is served as an immediate service. The active object dies immediatly. Else, the kill request is served as a normal request, it is put on the request queue. |
Definition at line 2153 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.setImmediateService | ( | Object | obj, | |
| String | methodName | |||
Warning: the execution of an Immediate Service method is achieved in parallel of the current services, so it is the programmer responsibility to ensure that Immediate Services do not interfere with any other methods.
| obj | the object on which to set this immediate service | |
| methodName | the name of the method |
| IOException |
Definition at line 2177 of file ProActive.java.
References org.objectweb.proactive.core.body.UniversalBody.setImmediateService().
| String | methodName, | |||
| Class[] | parametersTypes | |||
| ) | throws IOException [static] |
| methodName | the name of the method | |
| parametersTypes | the types of the parameters of the method |
| IOException |
Definition at line 2195 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.removeImmediateService | ( | Object | obj, | |
requests corresponding to the name and types of parameters will be executed by the calling thread, and not added in the request queue. BE CAREFUL : for the first release of this method, do not make use of getCurrentThreadBody nor getStubOnThis in the method defined by methodName !!
| obj | the object from which to remove this immediate service | |
| IOException |
Definition at line 2212 of file ProActive.java.
References org.objectweb.proactive.core.body.UniversalBody.removeImmediateService().
| static void org.objectweb.proactive.ProActive.exposeAsWebService | ( | Object | o, | |
| String | url, | |||
| String | urn, | |||
| String[] | methods | |||
| ) | [static] |
| o | The object to expose as a web service | |
| url | The url of the host where the object will be seployed (typically http://localhost:8080) | |
| urn | The name of the object | |
| methods | The methods that will be exposed as web services functionnalities |
Definition at line 2256 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.unExposeAsWebService | ( | String | urn, | |
| String | url | |||
| ) | [static] |
| url | The url of the web server |
Definition at line 2266 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.exposeComponentAsWebService | ( | Component | component, | |
| String | url, | |||
| String | componentName | |||
| ) | [static] |
Each interface of the component will be accessible by the urn [componentName]_[interfaceName]in order to identify the component an interface belongs to. All the interfaces public methods will be exposed.
| componentName | The name of the component | |
| url | The web server url where to deploy the service - typically "http://localhost:8080" | |
| component | The component owning the interfaces that will be deployed as web services. |
Definition at line 2278 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.unExposeComponentAsWebService | ( | String | componentName, | |
| String | url, | |||
| Component | component | |||
| ) | [static] |
| url | The url of the web server | |
| component | The component owning the services interfaces |
Definition at line 2289 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.tryWithCatch | ( | Class | c | ) | [static] |
| c | the caught exception type in the catch block |
Definition at line 2389 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.tryWithCatch | ( | Class[] | c | ) | [static] |
| c | the caught exception types in the catch block |
Definition at line 2398 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.addNFEListenerOnJVM | ( | NFEListener | listener | ) | [static] |
| listener | The listener to add |
Definition at line 2438 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.removeNFEListenerOnJVM | ( | NFEListener | listener | ) | [static] |
| listener | The listener to remove |
Definition at line 2447 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.addNFEListenerOnAO | ( | Object | ao, | |
| NFEListener | listener | |||
| ) | [static] |
| ao | The active object receiving the NFE | |
Definition at line 2457 of file ProActive.java.
References org.objectweb.proactive.core.exceptions.manager.NFEProducer.addNFEListener().
| static void org.objectweb.proactive.ProActive.removeNFEListenerOnAO | ( | Object | ao, | |
| ) | [static] |
Definition at line 2470 of file ProActive.java.
References org.objectweb.proactive.core.exceptions.manager.NFEProducer.removeNFEListener().
| static void org.objectweb.proactive.ProActive.addNFEListenerOnProxy | ( | Object | ao, | |
| ) | [static] |
Definition at line 2481 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.removeNFEListenerOnProxy | ( | Object | ao, | |
| ) | [static] |
Definition at line 2496 of file ProActive.java.
| static void org.objectweb.proactive.ProActive.addNFEListenerOnGroup | ( | Object | group, | |
| ) | [static] |
| group | The group receiving the NFE | |
Definition at line 2527 of file ProActive.java.
References org.objectweb.proactive.core.body.proxy.AbstractProxy.addNFEListener().
| static void org.objectweb.proactive.ProActive.removeNFEListenerOnGroup | ( | Object | group, | |
| ) | [static] |
Definition at line 2537 of file ProActive.java.
| static Collection org.objectweb.proactive.ProActive.getAllExceptions | ( | ) | [static] |
This waits for every call in this block to return.
Definition at line 2549 of file ProActive.java.
| static Node org.objectweb.proactive.ProActive.getNode | ( | ) | throws NodeException [static] |
| NodeException | problem with the node. |
Definition at line 2557 of file ProActive.java.
References org.objectweb.proactive.core.body.proxy.BodyProxy.getBody(), and org.objectweb.proactive.core.body.UniversalBody.getNodeURL().
| static String org.objectweb.proactive.ProActive.getProActiveVersion | ( | ) | [static] |
1.5.1
