- ra
: org.objectweb.proactive.ext.security.crypto.SessionTicketProperty
- random
: org.objectweb.proactive.core.rmi.RandomPortSocketFactory
, org.objectweb.proactive.ext.security.crypto.AuthenticationTicket
- random1
: org.objectweb.proactive.ext.security.crypto.ConfidentialityTicket
, org.objectweb.proactive.ext.security.crypto.AuthenticationTicketProperty
, org.objectweb.proactive.ext.security.crypto.ConfidentialityTicketProperty
- random2
: org.objectweb.proactive.ext.security.crypto.AuthenticationTicketProperty
- randomizer
: org.objectweb.proactive.loadbalancing.LoadBalancer
, org.objectweb.proactive.p2p.loadbalancer.P2PLoadBalancer
- randomLongGenerator
: org.objectweb.proactive.ext.security.ProActiveSecurityManager
- range
- ranking
: org.objectweb.proactive.p2p.loadbalancer.P2PLoadBalancer
- readBufferMap
: org.objectweb.proactive.core.filetransfer.FileTransferService
- RECEIVED_FUTURE_RESULT
: org.objectweb.proactive.core.event.FutureEvent
- receiveReply
: org.objectweb.proactive.ext.security.SecurityContext
- receiveRequest
- RECOVER
: org.objectweb.proactive.core.body.ft.protocols.cic.managers.FTManagerCIC
- RECOVERING
: org.objectweb.proactive.core.body.ft.servers.recovery.RecoveryProcess
- recovery
: org.objectweb.proactive.core.body.ft.protocols.FTManager
- RECYCLE_POOL_SIZE
: org.objectweb.proactive.core.body.future.FutureProxy
- ReflectionException
: org.objectweb.proactive.jmx.ProActiveConnection
- REGISTER_TAG
: org.objectweb.proactive.core.descriptor.xml.ProActiveDescriptorConstants
- registeredRuntimeName
: org.objectweb.proactive.core.event.RuntimeRegistrationEvent
- registeredRuntimes
: org.objectweb.proactive.core.runtime.ProActiveRuntimeForwarderImpl
- registrar
: org.objectweb.proactive.core.jini.ServiceLocatorHelper
- registrarsTable
: org.objectweb.proactive.core.runtime.jini.JiniRuntimeImpl
- registry
: org.objectweb.proactive.core.rmi.RegistryHelper
, org.objectweb.proactive.core.component.adl.implementations.ProActiveImplementationBuilderImpl
, org.objectweb.proactive.core.component.adl.RegistryManagerImpl
- REGISTRY_BINDING
: org.objectweb.proactive.core.component.adl.implementations.ProActiveImplementationBuilderImpl
- registryChecked
- registryCreator
- registryHelper
: org.objectweb.proactive.core.runtime.ibis.IbisRuntimeFactory
, org.objectweb.proactive.core.runtime.rmi.RmiRuntimeFactory
- registryPortNumber
, org.objectweb.proactive.core.node.StartNode
- reifiedConstructor
: org.objectweb.proactive.core.mop.ConstructorCallImpl
- REL_PATH_TAG
- remoteBody
: org.objectweb.proactive.core.body.AbstractUniversalBody
- remoteBodyFactory
- remoteBodyFactoryInstance
: org.objectweb.proactive.core.body.ProActiveMetaObjectFactory
- remoteFilePath
: org.objectweb.proactive.core.process.glite.GLiteProcess
- remotePath
: org.objectweb.proactive.core.process.mpi.MPIProcess
- REMOVE
: org.objectweb.proactive.core.body.request.RequestProcessor
- REMOVE_AND_SERVE
- REMOVE_REQUEST
: org.objectweb.proactive.core.event.RequestQueueEvent
- REMOVED
: org.objectweb.proactive.ext.scilab.monitor.SciTaskInfo
- repeat
: org.objectweb.proactive.core.process.AbstractListProcessDecorator
- REPLY_RECEIVED
: org.objectweb.proactive.core.event.MessageEvent
- REPLY_SENT
- replyReceiver
: org.objectweb.proactive.core.body.BodyImpl
- replyReceiverFactoryInstance
- replyToResend
: org.objectweb.proactive.core.body.ft.protocols.cic.infos.CheckpointInfoCIC
- REPRESENTATIVE_DEFAULT_SUFFIX
: org.objectweb.proactive.core.component.gen.Utils
- REQUEST_RECEIVED
- REQUEST_SENT
- requestFactoryInstance
- requestFilterOnMethodName
: org.objectweb.proactive.core.body.request.RequestQueueImpl
- requestQueue
: org.objectweb.proactive.Service
, org.objectweb.proactive.core.body.request.RequestQueueImpl
- requestQueueFactoryInstance
- requestQueueLength
- requestReceiver
- requestReceiverFactoryInstance
- REQUESTS
: org.objectweb.proactive.core.util.log.Loggers
- requestToResend
- REQUIRED
: org.objectweb.proactive.ext.security.Communication
- res
: org.objectweb.proactive.ext.scilab.gui.IconRenderer
- RES_REQ_TAG
- res_requirement
: org.objectweb.proactive.core.process.lsf.LSFBSubProcess
- RESEND_MESSAGE
- resources
: org.objectweb.proactive.core.process.oar.OARGRIDSubProcess
, org.objectweb.proactive.core.process.oar.OARSubProcess
- RESSOURCE_LISTENER
- RESSOURCE_MANAGER
- ressourceManager
: org.objectweb.proactive.scheduler.policy.AbstractPolicy
- RESTARTING_AFTER_MIGRATING
: org.objectweb.proactive.core.event.MigrationEvent
- result
: org.objectweb.proactive.core.body.reply.ReplyImpl
- resultList
: org.objectweb.proactive.core.xml.handler.CollectionUnmarshaller
- resultObject
: org.objectweb.proactive.core.descriptor.xml.ProcessDefinitionHandler.GLiteProcessHandler
, org.objectweb.proactive.core.xml.handler.BasicUnmarshaller
, org.objectweb.proactive.core.xml.handler.BasicUnmarshallerDecorator
- resultOfGatheredInvocation
: org.objectweb.proactive.core.component.collectiveitfs.GatherFuturesHandler
- resultsReturned
: org.objectweb.proactive.core.component.collectiveitfs.GatherRequestsQueue
- returnedObject
: org.objectweb.proactive.core.body.http.util.HttpMessage
- REUSABLE_EXCEPTION
: org.objectweb.proactive.ext.locationserver.BouncingRequestReceiver
- reused
: org.objectweb.proactive.core.component.collectiveitfs.GatherFuturesHandlerPool
- RIGHT
: org.objectweb.proactive.loadbalancing.util.JacobiWorker
- RLOGIN_PROCESS_TAG
- RMI
- RMI_LOOKUP_TAG
- RMI_PROTOCOL_IDENTIFIER
: org.objectweb.proactive.core.Constants
- rmiClassLoaderSpi
: org.objectweb.proactive.core.classloader.ProActiveRMIClassLoaderSpi
- RMISSH_PROTOCOL_IDENTIFIER
- ROUTER
: org.objectweb.proactive.ext.webservices.WSConstants
- rsa_eng
- RSH_PROCESS_TAG
- RT_URL
: org.objectweb.proactive.ext.webservices.utils.ProActiveWSUtils
- RULE_AOCREATION_AUTHORIZED
: org.objectweb.proactive.ext.security.ProActiveSecurityDescriptorHandler
- RULE_COMMUNICATION_AOCREATION_TAG
- RULE_COMMUNICATION_ATTRIBUTES_TAG
- RULE_COMMUNICATION_FROM_TAG
- RULE_COMMUNICATION_MIGRATION_TAG
- RULE_COMMUNICATION_TAG
- RULE_COMMUNICATION_TO_TAG
- RULE_MIGRATION_AUTHORIZED
- RULE_MIGRATION_DENIED
- RULE_TAG
- RULES_TAG
- run
: org.objectweb.proactive.benchmarks.timit.util.Parameter
- running
: org.objectweb.proactive.core.util.timer.AverageMicroTimer
- RUNNING
, org.objectweb.proactive.ext.scilab.monitor.SciTaskInfo
- RUNTIME
- RUNTIME_ACQUIRED
- RUNTIME_REGISTERED
- RUNTIME_UNREGISTERED
- runtimeArray
: org.objectweb.proactive.core.descriptor.services.SchedulerLookupService
, org.objectweb.proactive.core.descriptor.services.RMIRegistryLookupService
- runtimeHostForLookup
: org.objectweb.proactive.core.descriptor.data.VirtualNodeLookup
- runtimeLogger
: org.objectweb.proactive.core.runtime.RemoteProActiveRuntime
, org.objectweb.proactive.core.runtime.RemoteProActiveRuntimeForwarder
, org.objectweb.proactive.core.runtime.ProActiveRuntimeForwarder
, org.objectweb.proactive.core.runtime.RuntimeFactory
- runtimePortForLookup
- runtimeProperties
: org.objectweb.proactive.core.descriptor.data.RuntimeDeploymentProperties
- runtimeReady
: org.objectweb.proactive.core.classloader.ProActiveClassLoader
Generated on Mon Jan 22 15:16:13 2007 for ProActive by
1.5.1
