org.objectweb.proactive.ext.scilab.SciResult Class Reference
This class represents a Scilab result. More...
List of all members.
Public Member Functions
 SciResult ()
 default constructor
 SciResult (String id)
void add (SciData data)
 add an Out data
SciData get (String name)
Parameters:
name data id
ArrayList< SciData > getList ()
Returns:
list of all out data
int getState ()
void setState (int state)
long getTimeExecution ()
void setTimeExecution (long timeExecution)
String getId ()
Static Public Attributes
static final int SUCCESS = 0
static final int ABORT = 1
Detailed Description
Definition at line 43 of file SciResult.java.
Member Function Documentation
void org.objectweb.proactive.ext.scilab.SciResult.add ( SciData  data  )
add an Out data
Parameters:
data
Definition at line 66 of file SciResult.java.
SciData org.objectweb.proactive.ext.scilab.SciResult.get ( String  name  )
Parameters:
name data id
Returns:
the data
Definition at line 75 of file SciResult.java.
Referenced by org.objectweb.proactive.ext.scilab.test.SciTest3.SciTest3(), and org.objectweb.proactive.ext.scilab.test.SciTestLibrary.SciTestLibrary().
The documentation for this class was generated from the following file:
Generated on Mon Jan 22 15:16:35 2007 for ProActive by  doxygen 1.5.1
