org.objectweb.proactive.ProActiveInternalObject Interface Reference
This is a marker which must be implemented by all non functional active objects, e.g.
More...
Inheritance diagram for org.objectweb.proactive.ProActiveInternalObject:
[legend]
Detailed Description
load balancing objects, p2p objects, IC2D spy.
- Author:
 - cdelbe
- Since:
 - 2.2
Definition at line 40 of file ProActiveInternalObject.java.
The documentation for this interface was generated from the following file:
Generated on Mon Jan 22 15:16:13 2007 for ProActive by
 1.5.1
