00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.runtime.rmi;
00032
00033 import java.io.IOException;
00034 import java.lang.reflect.InvocationTargetException;
00035 import java.rmi.AlreadyBoundException;
00036 import java.rmi.RemoteException;
00037 import java.rmi.server.RMIClientSocketFactory;
00038 import java.rmi.server.RMIServerSocketFactory;
00039 import java.security.PublicKey;
00040 import java.security.cert.X509Certificate;
00041 import java.util.ArrayList;
00042
00043 import org.objectweb.proactive.Body;
00044 import org.objectweb.proactive.core.ProActiveException;
00045 import org.objectweb.proactive.core.UniqueRuntimeID;
00046 import org.objectweb.proactive.core.body.UniversalBody;
00047 import org.objectweb.proactive.core.body.ft.checkpointing.Checkpoint;
00048 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00049 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00050 import org.objectweb.proactive.core.mop.ConstructorCall;
00051 import org.objectweb.proactive.core.mop.ConstructorCallExecutionFailedException;
00052 import org.objectweb.proactive.core.node.NodeException;
00053 import org.objectweb.proactive.core.process.ExternalProcess;
00054 import org.objectweb.proactive.core.process.UniversalProcess;
00055 import org.objectweb.proactive.core.runtime.ProActiveRuntime;
00056 import org.objectweb.proactive.core.runtime.ProActiveRuntimeForwarder;
00057 import org.objectweb.proactive.core.runtime.VMInformation;
00058 import org.objectweb.proactive.ext.security.Communication;
00059 import org.objectweb.proactive.ext.security.ProActiveSecurityManager;
00060 import org.objectweb.proactive.ext.security.SecurityContext;
00061 import org.objectweb.proactive.ext.security.crypto.KeyExchangeException;
00062 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00063 import org.objectweb.proactive.ext.security.exceptions.SecurityNotAvailableException;
00064 import org.objectweb.proactive.ext.security.securityentity.Entity;
00065
00066
00067 public class RmiProActiveRuntimeForwarderImpl extends RmiProActiveRuntimeImpl
00068 implements RmiProActiveRuntimeForwarder {
00069 protected transient ProActiveRuntimeForwarder proActiveRuntimeF;
00070
00071
00072
00073
00074 public RmiProActiveRuntimeForwarderImpl()
00075 throws RemoteException, AlreadyBoundException {
00076 super();
00077 proActiveRuntimeF = (ProActiveRuntimeForwarder) super.proActiveRuntime;
00078 }
00079
00080 public RmiProActiveRuntimeForwarderImpl(boolean isJini)
00081 throws RemoteException {
00082 super(isJini);
00083 proActiveRuntimeF = (ProActiveRuntimeForwarder) super.proActiveRuntime;
00084 }
00085
00086 public RmiProActiveRuntimeForwarderImpl(RMIClientSocketFactory csf,
00087 RMIServerSocketFactory ssf)
00088 throws RemoteException, AlreadyBoundException {
00089 super(csf, ssf);
00090 proActiveRuntimeF = (ProActiveRuntimeForwarder) super.proActiveRuntime;
00091 }
00092
00093
00094
00095
00096 public void addAcquaintance(UniqueRuntimeID urid,
00097 String proActiveRuntimeName) throws IOException, ProActiveException {
00098 proActiveRuntimeF.addAcquaintance(urid, proActiveRuntimeName);
00099 }
00100
00101 public UniversalBody createBody(UniqueRuntimeID urid, String nodeName,
00102 ConstructorCall bodyConstructorCall, boolean isNodeLocal)
00103 throws IOException, ConstructorCallExecutionFailedException,
00104 InvocationTargetException, ProActiveException {
00105 return proActiveRuntimeF.createBody(urid, nodeName,
00106 bodyConstructorCall, isNodeLocal);
00107 }
00108
00109 public String createLocalNode(UniqueRuntimeID urid, String nodeName,
00110 boolean replacePreviousBinding, ProActiveSecurityManager ps,
00111 String VNname, String jobId)
00112 throws IOException, NodeException, AlreadyBoundException {
00113 if (urid == null) {
00114 return super.createLocalNode(nodeName, replacePreviousBinding, ps, VNname, jobId);
00115 } else {
00116 return proActiveRuntimeF.createLocalNode(urid, nodeName,
00117 replacePreviousBinding, ps, VNname, jobId);
00118 }
00119 }
00120
00121 public void createVM(UniqueRuntimeID urid, UniversalProcess remoteProcess)
00122 throws IOException, ProActiveException {
00123 proActiveRuntimeF.createVM(urid, remoteProcess);
00124 }
00125
00126 public String[] getAcquaintances(UniqueRuntimeID urid)
00127 throws IOException, ProActiveException {
00128 return proActiveRuntimeF.getAcquaintances(urid);
00129 }
00130
00131 public ArrayList getActiveObjects(UniqueRuntimeID urid, String nodeName,
00132 String objectName) throws IOException, ProActiveException {
00133 return proActiveRuntimeF.getActiveObjects(urid, nodeName, objectName);
00134 }
00135
00136 public ArrayList getActiveObjects(UniqueRuntimeID urid, String nodeName)
00137 throws IOException, ProActiveException {
00138 return proActiveRuntimeF.getActiveObjects(urid, nodeName);
00139 }
00140
00141 public byte[] getClassDataFromParentRuntime(UniqueRuntimeID urid,
00142 String className) throws IOException, ProActiveException {
00143 return proActiveRuntimeF.getClassDataFromParentRuntime(urid, className);
00144 }
00145
00146 public byte[] getClassDataFromThisRuntime(UniqueRuntimeID urid,
00147 String className) throws IOException, ProActiveException {
00148 return proActiveRuntimeF.getClassDataFromThisRuntime(urid, className);
00149 }
00150
00151 public ArrayList<Entity> getEntities(UniqueRuntimeID urid)
00152 throws IOException, SecurityNotAvailableException {
00153 return proActiveRuntimeF.getEntities(urid);
00154 }
00155
00156 public String getJobID(UniqueRuntimeID urid, String nodeUrl)
00157 throws IOException, ProActiveException {
00158 return proActiveRuntimeF.getJobID(urid, nodeUrl);
00159 }
00160
00161 public String[] getLocalNodeNames(UniqueRuntimeID urid)
00162 throws IOException, ProActiveException {
00163 return proActiveRuntimeF.getLocalNodeNames(urid);
00164 }
00165
00166 public SecurityContext getPolicy(UniqueRuntimeID urid, SecurityContext sc)
00167 throws IOException, SecurityNotAvailableException {
00168 return proActiveRuntimeF.getPolicy(urid, sc);
00169 }
00170
00171 public ProActiveRuntime getProActiveRuntime(UniqueRuntimeID urid,
00172 String proActiveRuntimeName) throws IOException, ProActiveException {
00173 return proActiveRuntimeF.getProActiveRuntime(urid, proActiveRuntimeName);
00174 }
00175
00176 public ProActiveRuntime[] getProActiveRuntimes(UniqueRuntimeID urid)
00177 throws IOException, ProActiveException {
00178 return proActiveRuntimeF.getProActiveRuntimes(urid);
00179 }
00180
00181 public ExternalProcess getProcessToDeploy(UniqueRuntimeID urid,
00182 ProActiveRuntime proActiveRuntimeDist, String creatorID, String vmName,
00183 String padURL) throws ProActiveException, IOException {
00184 return proActiveRuntimeF.getProcessToDeploy(urid, proActiveRuntimeDist,
00185 creatorID, vmName, padURL);
00186 }
00187
00188 public String getURL(UniqueRuntimeID urid)
00189 throws IOException, ProActiveException {
00190 return proActiveRuntimeF.getURL(urid);
00191 }
00192
00193 public VirtualNode getVirtualNode(UniqueRuntimeID urid,
00194 String virtualNodeName) throws IOException, ProActiveException {
00195 return proActiveRuntimeF.getVirtualNode(urid, virtualNodeName);
00196 }
00197
00198 public VMInformation getVMInformation(UniqueRuntimeID urid)
00199 throws IOException {
00200 return proActiveRuntimeF.getVMInformation();
00201 }
00202
00203 public String getVNName(UniqueRuntimeID urid, String Nodename)
00204 throws IOException, ProActiveException {
00205 return proActiveRuntimeF.getVNName(urid, Nodename);
00206 }
00207
00208 public void killAllNodes(UniqueRuntimeID urid)
00209 throws IOException, ProActiveException {
00210 proActiveRuntimeF.killAllNodes(urid);
00211 }
00212
00213 public void killNode(UniqueRuntimeID urid, String nodeName)
00214 throws IOException, ProActiveException {
00215 proActiveRuntimeF.killNode(urid, nodeName);
00216 }
00217
00218 public void killRT(UniqueRuntimeID urid, boolean softly)
00219 throws Exception {
00220 proActiveRuntimeF.killRT(urid, softly);
00221 }
00222
00223 public UniversalBody receiveBody(UniqueRuntimeID urid, String nodeName,
00224 Body body) throws IOException, ProActiveException {
00225 return proActiveRuntimeF.receiveBody(urid, nodeName, body);
00226 }
00227
00228 public UniversalBody receiveCheckpoint(UniqueRuntimeID urid,
00229 String nodeName, Checkpoint ckpt, int inc)
00230 throws IOException, ProActiveException {
00231 return proActiveRuntimeF.receiveCheckpoint(urid, nodeName, ckpt, inc);
00232 }
00233
00234 public void register(UniqueRuntimeID urid,
00235 ProActiveRuntime proActiveRuntimeDist, String proActiveRuntimeName,
00236 String creatorID, String creationProtocol, String vmName)
00237 throws IOException, ProActiveException {
00238 proActiveRuntimeF.register(urid, proActiveRuntimeDist,
00239 proActiveRuntimeName, creatorID, creationProtocol, vmName);
00240 }
00241
00242 public void registerVirtualNode(UniqueRuntimeID urid,
00243 String virtualNodeName, boolean replacePreviousBinding)
00244 throws IOException, ProActiveException, java.rmi.AlreadyBoundException {
00245 proActiveRuntimeF.registerVirtualNode(urid, virtualNodeName,
00246 replacePreviousBinding);
00247 }
00248
00249 public void rmAcquaintance(UniqueRuntimeID urid, String proActiveRuntimeName)
00250 throws IOException, ProActiveException {
00251 proActiveRuntimeF.rmAcquaintance(urid, proActiveRuntimeName);
00252 }
00253
00254 public void unregister(UniqueRuntimeID urid,
00255 ProActiveRuntime proActiveRuntimeDist, String proActiveRuntimeName,
00256 String creatorID, String creationProtocol, String vmName)
00257 throws IOException, ProActiveException {
00258 proActiveRuntimeF.unregister(urid, proActiveRuntimeDist,
00259 proActiveRuntimeURL, creatorID, creationProtocol, vmName);
00260 }
00261
00262 public void unregisterAllVirtualNodes(UniqueRuntimeID urid)
00263 throws IOException, ProActiveException {
00264 proActiveRuntimeF.unregisterAllVirtualNodes(urid);
00265 }
00266
00267 public void unregisterVirtualNode(UniqueRuntimeID urid,
00268 String virtualNodeName) throws IOException, ProActiveException {
00269 proActiveRuntimeF.unregisterVirtualNode(urid, virtualNodeName);
00270 }
00271
00272 public X509Certificate getCertificate(UniqueRuntimeID urid)
00273 throws SecurityNotAvailableException, IOException {
00274 return proActiveRuntimeF.getCertificate(urid);
00275 }
00276
00277 public byte[] getCertificateEncoded(UniqueRuntimeID urid)
00278 throws SecurityNotAvailableException, IOException {
00279 return proActiveRuntimeF.getCertificateEncoded(urid);
00280 }
00281
00282 public ProActiveDescriptor getDescriptor(UniqueRuntimeID urid, String url,
00283 boolean isHierarchicalSearch) throws IOException, ProActiveException {
00284 return proActiveRuntimeF.getDescriptor(urid, url, isHierarchicalSearch);
00285 }
00286
00287 public PublicKey getPublicKey(UniqueRuntimeID urid)
00288 throws SecurityNotAvailableException, IOException {
00289 return proActiveRuntimeF.getPublicKey(urid);
00290 }
00291
00292 public void launchMain(UniqueRuntimeID urid, String className,
00293 String[] parameters)
00294 throws IOException, ClassNotFoundException, NoSuchMethodException,
00295 ProActiveException {
00296 proActiveRuntimeF.launchMain(className, parameters);
00297 }
00298
00299 public void newRemote(UniqueRuntimeID urid, String className)
00300 throws IOException, ClassNotFoundException, ProActiveException {
00301 proActiveRuntimeF.newRemote(className);
00302 }
00303
00304 public byte[][] publicKeyExchange(UniqueRuntimeID urid, long sessionID,
00305 byte[] myPublicKey, byte[] myCertificate, byte[] signature)
00306 throws SecurityNotAvailableException, RenegotiateSessionException,
00307 KeyExchangeException, IOException {
00308 return proActiveRuntimeF.publicKeyExchange(urid, sessionID,
00309 myPublicKey, myCertificate, signature);
00310 }
00311
00312 public byte[] randomValue(UniqueRuntimeID urid, long sessionID,
00313 byte[] clientRandomValue)
00314 throws SecurityNotAvailableException, RenegotiateSessionException,
00315 IOException {
00316 return proActiveRuntimeF.randomValue(urid, sessionID, clientRandomValue);
00317 }
00318
00319 public byte[][] secretKeyExchange(UniqueRuntimeID urid, long sessionID,
00320 byte[] encodedAESKey, byte[] encodedIVParameters,
00321 byte[] encodedClientMacKey, byte[] encodedLockData,
00322 byte[] parametersSignature)
00323 throws SecurityNotAvailableException, RenegotiateSessionException,
00324 IOException {
00325 return proActiveRuntimeF.secretKeyExchange(urid, sessionID,
00326 encodedAESKey, encodedIVParameters, encodedClientMacKey,
00327 encodedLockData, parametersSignature);
00328 }
00329
00330 public long startNewSession(UniqueRuntimeID urid, Communication policy)
00331 throws SecurityNotAvailableException, RenegotiateSessionException,
00332 IOException {
00333 return proActiveRuntimeF.startNewSession(policy);
00334 }
00335
00336 public void terminateSession(UniqueRuntimeID urid, long sessionID)
00337 throws IOException, SecurityNotAvailableException {
00338
00339 }
00340
00341 public Object setLocalNodeProperty(UniqueRuntimeID runtimeID,
00342 String nodeName, String key, String value)
00343 throws IOException, ProActiveException {
00344 return this.proActiveRuntimeF.setLocalNodeProperty(runtimeID, nodeName,
00345 key, value);
00346 }
00347
00348 public String getLocalNodeProperty(UniqueRuntimeID runtimeID,
00349 String nodeName, String key) throws IOException, ProActiveException {
00350 return this.proActiveRuntimeF.getLocalNodeProperty(runtimeID, nodeName,
00351 key);
00352 }
00353 }
