org/objectweb/proactive/core/body/request/Request.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.request;
00032
00033 import org.objectweb.proactive.Body;
00034 import org.objectweb.proactive.core.body.UniversalBody;
00035 import org.objectweb.proactive.core.body.message.Message;
00036 import org.objectweb.proactive.core.body.reply.Reply;
00037 import org.objectweb.proactive.core.exceptions.proxy.ProxyNonFunctionalException;
00038 import org.objectweb.proactive.core.mop.MethodCall;
00039 import org.objectweb.proactive.ext.security.Securizable;
00040 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00041
00042
00059 public interface Request extends Message, Securizable {
00060
00061
00062         // Next request to serve
00063         public static final int NFREQUEST_IMMEDIATE_PRIORITY = 2;
00064         // FIFO among non functional requests
00065         public static final int NFREQUEST_PRIORITY = 1;
00066         // FIFO among all requests
00067         public static final int NFREQUEST_NO_PRIORITY = 0;
00068
00073     public boolean hasBeenForwarded();
00074
00078     public void resetSendCounter();
00079
00087     public Object getParameter(int index);
00088
00093     public MethodCall getMethodCall();
00094
00099     public UniversalBody getSender();
00100
00107     public int send(UniversalBody destinationBody)
00108         throws java.io.IOException, RenegotiateSessionException;
00109
00118     public Reply serve(Body targetBody) throws ServeException;
00119
00126     public Reply serveAlternate(Body targetBody, ProxyNonFunctionalException nfe);
00127
00136     public void notifyReception(UniversalBody bodyReceiver)
00137         throws java.io.IOException;
00138
00144     public boolean isFunctionalRequest();
00145
00150     public void setFunctionalRequest(boolean isFunctionalRequest);
00151
00152
00160     public void setNFRequestPriority(int NFReqPriority);
00161
00166     public int getNFRequestPriority();
00167 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
