00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.ext.locationserver;
00032
00033 import org.apache.log4j.Logger;
00034 import org.objectweb.proactive.Body;
00035 import org.objectweb.proactive.ProActive;
00036 import org.objectweb.proactive.core.UniqueID;
00037 import org.objectweb.proactive.core.body.LocalBodyStore;
00038 import org.objectweb.proactive.core.body.UniversalBody;
00039 import org.objectweb.proactive.core.body.ft.protocols.FTManager;
00040 import org.objectweb.proactive.core.body.future.FutureProxy;
00041 import org.objectweb.proactive.core.body.reply.Reply;
00042 import org.objectweb.proactive.core.body.request.RequestImpl;
00043 import org.objectweb.proactive.core.body.request.ServeException;
00044 import org.objectweb.proactive.core.mop.MethodCall;
00045 import org.objectweb.proactive.core.mop.StubObject;
00046 import org.objectweb.proactive.core.util.log.Loggers;
00047 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00048
00049
00050 public class RequestWithLocationServer extends RequestImpl
00051     implements java.io.Serializable {
00052     private static final int MAX_TRIES = 30;
00053     static Logger logger = ProActiveLogger.getLogger(Loggers.MIGRATION);
00054
00058     private int tries;
00059     private transient LocationServer server;
00060
00061     public RequestWithLocationServer(MethodCall methodCall,
00062         UniversalBody sender, boolean isOneWay, long nextSequenceID,
00063         LocationServer server) {
00064         super(methodCall, sender, isOneWay, nextSequenceID);
00065         this.server = server;
00066     }
00067
00068     public Reply serve(Body targetBody) throws ServeException {
00069         Reply r = super.serve(targetBody);
00070         return r;
00071     }
00072
00073     protected int sendRequest(UniversalBody destinationBody)
00074         throws java.io.IOException {
00075         int ftres = FTManager.NON_FT;
00076         try {
00077
00078             ftres = destinationBody.receiveRequest(this);
00079
00080
00081         } catch (Exception e) {
00082             this.backupSolution(destinationBody);
00083         }
00084         return ftres;
00085     }
00086
00090     protected void backupSolution(UniversalBody destinationBody)
00091         throws java.io.IOException {
00092         boolean ok = false;
00093         tries = 0;
00094
00095         UniqueID bodyID = destinationBody.getID();
00096         while (!ok && (tries < MAX_TRIES)) {
00097             UniversalBody remoteBody = null;
00098             UniversalBody mobile = queryServer(bodyID);
00099
00100
00101             remoteBody = (UniversalBody) ((FutureProxy) ((StubObject) mobile).getProxy()).getResult();
00102             try {
00103                 remoteBody.receiveRequest(this);
00104
00105
00106
00107                 if (sender != null) {
00108                     sender.updateLocation(bodyID, remoteBody);
00109                 } else {
00110                     LocalBodyStore.getInstance().getLocalBody(getSourceBodyID())
00111                                   .updateLocation(bodyID, remoteBody);
00112                 }
00113                 ok = true;
00114             } catch (Exception e) {
00115                 logger.debug(
00116                     "RequestWithLocationServer:  .............. FAILED = " +
00117                     " for method " + methodName);
00118                 tries++;
00119             }
00120         }
00121     }
00122
00123     protected UniversalBody queryServer(UniqueID bodyID) {
00124         if (server == null) {
00125             server = LocationServerFactory.getLocationServer();
00126         }
00127         UniversalBody mobile = (UniversalBody) server.searchObject(bodyID);
00128
00129         logger.debug(
00130             "RequestWithLocationServer: backupSolution() server has sent an answer");
00131
00132         ProActive.waitFor(mobile);
00133         return mobile;
00134     }
00135 }
