00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.body.request; 00032 00033 import java.io.IOException; 00034 00035 import org.objectweb.proactive.Body; 00036 import org.objectweb.proactive.core.body.UniversalBody; 00037 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException; 00038 00039 00040 public class RequestReceiverForwarder implements RequestReceiver { 00041 private UniversalBody remoteBody; 00042 00043 public RequestReceiverForwarder(UniversalBody b) { 00044 this.remoteBody = b; 00045 } 00046 00047 public int receiveRequest(Request request, Body bodyReceiver) 00048 throws java.io.IOException, RenegotiateSessionException { 00049 return request.send(remoteBody); 00050 } 00051 00052 public void setImmediateService(String methodName) 00053 throws java.io.IOException { 00054 remoteBody.setImmediateService(methodName); 00055 } 00056 00057 public void removeImmediateService(String methodName, 00058 Class[] parametersTypes) throws IOException { 00059 remoteBody.removeImmediateService(methodName, parametersTypes); 00060 } 00061 00062 public void setImmediateService(String methodName, Class[] parametersTypes) 00063 throws IOException { 00064 remoteBody.setImmediateService(methodName, parametersTypes); 00065 } 00066 }
1.5.1
