org/objectweb/proactive/core/runtime/RemoteProActiveRuntime.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.runtime;
00032
00033 import java.io.IOException;
00034 import java.io.Serializable;
00035 import java.rmi.AlreadyBoundException;
00036 import java.security.PublicKey;
00037 import java.security.cert.X509Certificate;
00038 import java.util.ArrayList;
00039
00040 import org.apache.log4j.Logger;
00041 import org.objectweb.proactive.Body;
00042 import org.objectweb.proactive.core.ProActiveException;
00043 import org.objectweb.proactive.core.body.UniversalBody;
00044 import org.objectweb.proactive.core.body.ft.checkpointing.Checkpoint;
00045 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00046 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00047 import org.objectweb.proactive.core.mop.ConstructorCall;
00048 import org.objectweb.proactive.core.mop.ConstructorCallExecutionFailedException;
00049 import org.objectweb.proactive.core.node.NodeException;
00050 import org.objectweb.proactive.core.process.ExternalProcess;
00051 import org.objectweb.proactive.core.process.UniversalProcess;
00052 import org.objectweb.proactive.core.util.log.Loggers;
00053 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00054 import org.objectweb.proactive.ext.security.Communication;
00055 import org.objectweb.proactive.ext.security.ProActiveSecurityManager;
00056 import org.objectweb.proactive.ext.security.SecurityContext;
00057 import org.objectweb.proactive.ext.security.crypto.KeyExchangeException;
00058 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00059 import org.objectweb.proactive.ext.security.exceptions.SecurityNotAvailableException;
00060 import org.objectweb.proactive.ext.security.securityentity.Entity;
00061
00062
00073 public interface RemoteProActiveRuntime extends Serializable {
00074     static Logger runtimeLogger = ProActiveLogger.getLogger(Loggers.RUNTIME);
00075
00076     public String createLocalNode(String nodeName,
00077         boolean replacePreviousBinding,
00078         ProActiveSecurityManager securityManager, String VNname, String jobId)
00079         throws IOException, NodeException, AlreadyBoundException;
00080
00081     public void killAllNodes() throws IOException, ProActiveException;
00082
00083     public void killNode(String nodeName)
00084         throws IOException, ProActiveException;
00085
00086     public void createVM(UniversalProcess remoteProcess)
00087         throws java.io.IOException, ProActiveException;
00088
00089     public String[] getLocalNodeNames() throws IOException, ProActiveException;
00090
00091     public VMInformation getVMInformation() throws IOException;
00092
00093     public void register(ProActiveRuntime proActiveRuntimeDist,
00094         String proActiveRuntimeName, String creatorID, String creationProtocol,
00095         String vmName) throws IOException, ProActiveException;
00096
00097     public void unregister(ProActiveRuntime proActiveRuntimeDist,
00098         String proActiveRuntimeName, String creatorID, String creationProtocol,
00099         String vmName) throws IOException, ProActiveException;
00100
00101     public ProActiveRuntime[] getProActiveRuntimes()
00102         throws IOException, ProActiveException;
00103
00104     public ProActiveRuntime getProActiveRuntime(String proActiveRuntimeName)
00105         throws IOException, ProActiveException;
00106
00107     public void addAcquaintance(String proActiveRuntimeName)
00108         throws IOException, ProActiveException;
00109
00110     public String[] getAcquaintances() throws IOException, ProActiveException;
00111
00112     public void rmAcquaintance(String proActiveRuntimeName)
00113         throws IOException, ProActiveException;
00114
00115     public void killRT(boolean softly) throws Exception;
00116
00117     public String getURL() throws IOException, ProActiveException;
00118
00119     public ArrayList getActiveObjects(String nodeName)
00120         throws IOException, ProActiveException;
00121
00122     public ArrayList getActiveObjects(String nodeName, String objectName)
00123         throws IOException, ProActiveException;
00124
00125     public VirtualNode getVirtualNode(String virtualNodeName)
00126         throws IOException, ProActiveException;
00127
00128     public void registerVirtualNode(String virtualNodeName,
00129         boolean replacePreviousBinding)
00130         throws IOException, AlreadyBoundException, ProActiveException;
00131
00132     public void unregisterVirtualNode(String virtualNodeName)
00133         throws IOException, ProActiveException;
00134
00135     public void unregisterAllVirtualNodes()
00136         throws IOException, ProActiveException;
00137
00138     public String getJobID(String nodeUrl)
00139         throws IOException, ProActiveException;
00140
00141     public UniversalBody createBody(String nodeName,
00142         ConstructorCall bodyConstructorCall, boolean isNodeLocal)
00143         throws IOException, ConstructorCallExecutionFailedException,
00144             java.lang.reflect.InvocationTargetException, ProActiveException;
00145
00146     public UniversalBody receiveBody(String nodeName, Body body)
00147         throws IOException, ProActiveException;
00148
00149     public UniversalBody receiveCheckpoint(String nodeName, Checkpoint ckpt,
00150         int inc) throws IOException, ProActiveException;
00151
00152     public ExternalProcess getProcessToDeploy(
00153         ProActiveRuntime proActiveRuntimeDist, String creatorID, String vmName,
00154         String padURL) throws ProActiveException, IOException;
00155
00159     public byte[] getClassDataFromParentRuntime(String className)
00160         throws IOException, ProActiveException;
00161
00165     public byte[] getClassDataFromThisRuntime(String className)
00166         throws IOException, ProActiveException;
00167
00168     public String getVNName(String Nodename)
00169         throws IOException, ProActiveException;
00170
00171     public void launchMain(String className, String[] parameters)
00172         throws IOException, ClassNotFoundException, NoSuchMethodException,
00173             ProActiveException;
00174
00175     public void newRemote(String className)
00176         throws IOException, ClassNotFoundException, ProActiveException;
00177
00178     public ProActiveDescriptor getDescriptor(String url,
00179         boolean isHierarchicalSearch) throws IOException, ProActiveException;
00180
00181     //
00182     // -- Security
00183     //
00184     public X509Certificate getCertificate()
00185         throws SecurityNotAvailableException, java.io.IOException;
00186
00187     public long startNewSession(Communication policy)
00188         throws SecurityNotAvailableException, RenegotiateSessionException,
00189             java.io.IOException;
00190
00191     public PublicKey getPublicKey()
00192         throws SecurityNotAvailableException, java.io.IOException;
00193
00194     public byte[] randomValue(long sessionID, byte[] clientRandomValue)
00195         throws SecurityNotAvailableException, RenegotiateSessionException,
00196             java.io.IOException;
00197
00198     public byte[][] publicKeyExchange(long sessionID, byte[] myPublicKey,
00199         byte[] myCertificate, byte[] signature)
00200         throws SecurityNotAvailableException, RenegotiateSessionException,
00201             KeyExchangeException, java.io.IOException;
00202
00203     byte[][] secretKeyExchange(long sessionID, byte[] encodedAESKey,
00204         byte[] encodedIVParameters, byte[] encodedClientMacKey,
00205         byte[] encodedLockData, byte[] parametersSignature)
00206         throws SecurityNotAvailableException, RenegotiateSessionException,
00207             java.io.IOException;
00208
00209     public SecurityContext getPolicy(SecurityContext securityContext)
00210         throws SecurityNotAvailableException, java.io.IOException;
00211
00212     public byte[] getCertificateEncoded()
00213         throws SecurityNotAvailableException, java.io.IOException;
00214
00215     public ArrayList<Entity> getEntities()
00216         throws SecurityNotAvailableException, java.io.IOException;
00217
00218     public void terminateSession(long sessionID)
00219         throws java.io.IOException, SecurityNotAvailableException;
00220
00221     public Object setLocalNodeProperty(String nodeName, String key, String value)
00222         throws IOException, ProActiveException;
00223
00224     public String getLocalNodeProperty(String nodeName, String key)
00225         throws IOException, ProActiveException;
00226 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
