org/objectweb/proactive/core/runtime/ProActiveRuntimeForwarderImpl.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.runtime;
00032
00033 import java.io.IOException;
00034 import java.lang.reflect.InvocationTargetException;
00035 import java.rmi.AlreadyBoundException;
00036 import java.rmi.RemoteException;
00037 import java.security.PublicKey;
00038 import java.security.cert.X509Certificate;
00039 import java.util.ArrayList;
00040 import java.util.HashMap;
00041 import java.util.concurrent.ConcurrentHashMap;
00042
00043 import org.objectweb.proactive.Body;
00044 import org.objectweb.proactive.core.ProActiveException;
00045 import org.objectweb.proactive.core.UniqueRuntimeID;
00046 import org.objectweb.proactive.core.body.BodyAdapterForwarder;
00047 import org.objectweb.proactive.core.body.BodyForwarderImpl;
00048 import org.objectweb.proactive.core.body.RemoteBodyForwarder;
00049 import org.objectweb.proactive.core.body.UniversalBody;
00050 import org.objectweb.proactive.core.body.ft.checkpointing.Checkpoint;
00051 import org.objectweb.proactive.core.body.rmi.RmiRemoteBodyForwarderImpl;
00052 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00053 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00054 import org.objectweb.proactive.core.mop.ConstructorCall;
00055 import org.objectweb.proactive.core.mop.ConstructorCallExecutionFailedException;
00056 import org.objectweb.proactive.core.node.NodeException;
00057 import org.objectweb.proactive.core.process.ExternalProcess;
00058 import org.objectweb.proactive.core.process.HierarchicalProcess;
00059 import org.objectweb.proactive.core.process.JVMProcess;
00060 import org.objectweb.proactive.core.process.UniversalProcess;
00061 import org.objectweb.proactive.core.ssh.rmissh.SshRMIClientSocketFactory;
00062 import org.objectweb.proactive.core.ssh.rmissh.SshRMIServerSocketFactory;
00063 import org.objectweb.proactive.ext.security.Communication;
00064 import org.objectweb.proactive.ext.security.ProActiveSecurityManager;
00065 import org.objectweb.proactive.ext.security.SecurityContext;
00066 import org.objectweb.proactive.ext.security.crypto.KeyExchangeException;
00067 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00068 import org.objectweb.proactive.ext.security.exceptions.SecurityNotAvailableException;
00069 import org.objectweb.proactive.ext.security.securityentity.Entity;
00070
00071
00078 public class ProActiveRuntimeForwarderImpl extends ProActiveRuntimeImpl
00079     implements ProActiveRuntimeForwarder, LocalProActiveRuntime {
00080
00083     protected ConcurrentHashMap<UniqueRuntimeID, ProActiveRuntime> registeredRuntimes;
00084
00087     private HashMap<Object, ExternalProcess> hierarchicalProcesses;
00088
00090     private ProActiveRuntime parentRuntime = null;
00091
00096     private BodyForwarderImpl bodyForwarder = null;
00097     private BodyAdapterForwarder bodyAdapterForwarder = null;
00098     private RemoteBodyForwarder remoteBodyForwarder = null;
00099
00100     protected ProActiveRuntimeForwarderImpl() {
00101         super();
00102         registeredRuntimes = new ConcurrentHashMap<UniqueRuntimeID, ProActiveRuntime>();
00103         hierarchicalProcesses = new HashMap<Object, ExternalProcess>();
00104         bodyForwarder = new BodyForwarderImpl();
00105
00106         // Create the BodyForwarder, protocol specific
00107         if ("ibis".equals(System.getProperty("proactive.communication.protocol"))) {
00108             if (logger.isDebugEnabled()) {
00109                 logger.debug("Factory is ibis");
00110             }
00111
00112             logger.info("Ibis forwarding not yet implemented");
00113
00114             // TODO support Ibis forwarding
00115         } else if ("http".equals(System.getProperty(
00116                         "proactive.communication.protocol"))) {
00117             if (logger.isDebugEnabled()) {
00118                 logger.debug("Factory is http");
00119             }
00120
00121             logger.info("Http forwarding not yet implemented");
00122
00123             // TODO support Http forwarding
00124         } else if ("rmissh".equals(System.getProperty(
00125                         "proactive.communication.protocol"))) {
00126             if (logger.isDebugEnabled()) {
00127                 logger.debug("Factory is rmissh");
00128             }
00129
00130             try {
00131                 remoteBodyForwarder = new RmiRemoteBodyForwarderImpl(bodyForwarder,
00132                         new SshRMIServerSocketFactory(),
00133                         new SshRMIClientSocketFactory());
00134             } catch (RemoteException e) {
00135                 logger.info("Local forwarder cannot be created.");
00136             }
00137         } else {
00138             if (logger.isDebugEnabled()) {
00139                 logger.debug("Factory is rmi");
00140             }
00141
00142             try {
00143                 remoteBodyForwarder = new RmiRemoteBodyForwarderImpl(bodyForwarder);
00144             } catch (RemoteException e) {
00145                 logger.info("Local forwarder cannot be created.");
00146             }
00147         }
00148
00149         bodyAdapterForwarder = new BodyAdapterForwarder(remoteBodyForwarder);
00150     }
00151
00152     /* Some methods in proactive.core.body package need to get acces to the BodyForwarder
00153      * currently running, so the three following methods are public
00154      */
00155     public BodyAdapterForwarder getBodyAdapterForwarder() {
00156         return bodyAdapterForwarder;
00157     }
00158
00159     public BodyForwarderImpl getBodyForwarder() {
00160         return bodyForwarder;
00161     }
00162
00163     public RemoteBodyForwarder getRemoteBodyForwarder() {
00164         return remoteBodyForwarder;
00165     }
00166
00167     public boolean isRoot() {
00168         String val = System.getProperty("proactive.hierarchicalRuntime");
00169
00170         return ((val != null) && val.equals("root"));
00171     }
00172
00173     //
00174     // --- OVERIDING SOME METHODS
00175     //
00176     public void setParent(ProActiveRuntime parentPARuntime) {
00177         this.parentRuntime = parentPARuntime;
00178         super.setParent(parentPARuntime);
00179     }
00180
00181     public void register(ProActiveRuntime proActiveRuntimeDist,
00182         String proActiveRuntimeName, String creatorID, String creationProtocol,
00183         String vmName) {
00184
00185         /* Act like a forwarder even if it's not a prefixed method.
00186          * A forwarder is fully transparent, so a bootstrap is needed. A forwarder insert itself
00187          * in the chain by intercepting register calls of deployed process
00188          */
00189         try {
00190             // erk !
00191             ProActiveRuntimeAdapterForwarderImpl adapter = new ProActiveRuntimeAdapterForwarderImpl((ProActiveRuntimeAdapterForwarderImpl) RuntimeFactory.getDefaultRuntime(),
00192                     proActiveRuntimeDist);
00193
00194             if (parentRuntime != null) {
00195                 parentRuntime.register(adapter, proActiveRuntimeName,
00196                     creatorID, creationProtocol, vmName);
00197             } else {
00198                 if (isRoot()) {
00199                     super.register(proActiveRuntimeDist, proActiveRuntimeName,
00200                         creatorID, creationProtocol, vmName);
00201                 } else {
00202                     logger.warn(
00203                         "setParent() as not yet be called. Cannot forward the registration");
00204                 }
00205             }
00206         } catch (ProActiveException e) {
00207             e.printStackTrace();
00208             logger.warn("Cannot register this runtime: " +
00209                 proActiveRuntimeName);
00210         }
00211     }
00212
00213     static private Object buildKey(String padURL, String vmName) {
00214         return padURL + "??" + vmName;
00215     }
00216
00217     public ExternalProcess getProcessToDeploy(
00218         ProActiveRuntime proActiveRuntimeDist, String creatorID, String vmName,
00219         String padURL) throws ProActiveException {
00220         if (this.isRoot()) {
00221             return super.getProcessToDeploy(proActiveRuntimeDist, creatorID,
00222                 vmName, padURL);
00223         } else {
00224
00225             /* Used only in multi-heriarchical deployment. */
00226             HierarchicalProcess hp = (HierarchicalProcess) hierarchicalProcesses.get(buildKey(
00227                         padURL, vmName));
00228
00229             if (hp != null) {
00230                 return hp.getHierarchicalProcess();
00231             } else {
00232                 return null;
00233             }
00234         }
00235     }
00236
00244     protected void setProcessesToDeploy(String padURL, String vmName,
00245         ExternalProcess process) {
00246         JVMProcess jvmProcess = (JVMProcess) process.getFinalProcess();
00247         jvmProcess.resetParameters();
00248         hierarchicalProcesses.put(buildKey(padURL, vmName), process);
00249     }
00250
00251     public UniversalBody createBody(UniqueRuntimeID urid, String nodeName,
00252         ConstructorCall bodyConstructorCall, boolean isNodeLocal)
00253         throws ProActiveException, ConstructorCallExecutionFailedException,
00254             InvocationTargetException {
00255         if (urid == null) {
00256             return this.createBody(nodeName, bodyConstructorCall, isNodeLocal);
00257         }
00258
00259         ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00260
00261         if (part == null) {
00262             logErrorAndDumpTable(urid);
00263
00264             return null;
00265         }
00266
00267         UniversalBody rBody = part.createBody(nodeName, bodyConstructorCall,
00268                 isNodeLocal);
00269
00270         bodyForwarder.addcreatedBody(rBody.getID());
00271
00272         return rBody;
00273     }
00274
00275     //
00276     // --- MULTIPLEXER ---
00277     //
00278     public String createLocalNode(UniqueRuntimeID urid, String nodeName,
00279         boolean replacePreviousBinding, ProActiveSecurityManager psm,
00280         String vnName, String jobId)
00281         throws NodeException, AlreadyBoundException {
00282         if (urid == null) {
00283             return this.createLocalNode(nodeName, replacePreviousBinding, psm,
00284                 vnName, jobId);
00285         } else {
00286             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00287
00288             if (part != null) {
00289                 return part.createLocalNode(nodeName, replacePreviousBinding,
00290                     psm, vnName, jobId);
00291             } else {
00292                 logErrorAndDumpTable(urid);
00293             }
00294         }
00295
00296         return null;
00297     }
00298
00299     public void killAllNodes(UniqueRuntimeID urid) throws ProActiveException {
00300         if (urid == null) {
00301             this.killAllNodes();
00302         } else {
00303             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00304
00305             if (part != null) {
00306                 part.killAllNodes();
00307             } else {
00308                 logErrorAndDumpTable(urid);
00309             }
00310         }
00311     }
00312
00313     public void killNode(UniqueRuntimeID urid, String nodeName)
00314         throws ProActiveException {
00315         if (urid == null) {
00316             this.killNode(nodeName);
00317         } else {
00318             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00319
00320             if (part != null) {
00321                 part.killNode(nodeName);
00322             } else {
00323                 logErrorAndDumpTable(urid);
00324             }
00325         }
00326     }
00327
00328     public void createVM(UniqueRuntimeID urid, UniversalProcess remoteProcess)
00329         throws IOException, ProActiveException {
00330         if (urid == null) {
00331             this.createVM(remoteProcess);
00332         } else {
00333             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00334
00335             if (part != null) {
00336                 part.createVM(remoteProcess);
00337             } else {
00338                 logErrorAndDumpTable(urid);
00339             }
00340         }
00341     }
00342
00343     public String[] getLocalNodeNames(UniqueRuntimeID urid)
00344         throws ProActiveException {
00345         if (urid == null) {
00346             return this.getLocalNodeNames();
00347         } else {
00348             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00349
00350             if (part != null) {
00351                 return part.getLocalNodeNames();
00352             } else {
00353                 logErrorAndDumpTable(urid);
00354             }
00355         }
00356
00357         return null;
00358     }
00359
00360     public VMInformation getVMInformation(UniqueRuntimeID urid) {
00361         if (urid == null) {
00362             return this.getVMInformation();
00363         } else {
00364             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00365
00366             if (part != null) {
00367                 return part.getVMInformation();
00368             } else {
00369                 logErrorAndDumpTable(urid);
00370             }
00371         }
00372
00373         return null;
00374     }
00375
00376     public void register(UniqueRuntimeID urid,
00377         ProActiveRuntime proActiveRuntimeDist, String proActiveRuntimeUrl,
00378         String creatorID, String creationProtocol, String rurid)
00379         throws ProActiveException {
00380         if (urid == null) {
00381             this.register(proActiveRuntimeDist, proActiveRuntimeUrl, creatorID,
00382                 creationProtocol, rurid);
00383         } else {
00384             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00385
00386             if (part != null) {
00387                 part.register(proActiveRuntimeDist, proActiveRuntimeUrl,
00388                     creatorID, creationProtocol, rurid);
00389             } else {
00390                 logErrorAndDumpTable(urid);
00391             }
00392         }
00393     }
00394
00395     public void unregister(UniqueRuntimeID urid,
00396         ProActiveRuntime proActiveRuntimeDist, String proActiveRuntimeUrl,
00397         String creatorID, String creationProtocol, String rurid)
00398         throws ProActiveException {
00399         if (urid == null) {
00400             this.unregister(proActiveRuntimeDist, proActiveRuntimeUrl,
00401                 creatorID, creationProtocol, rurid);
00402         } else {
00403             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00404
00405             if (part != null) {
00406                 part.unregister(proActiveRuntimeDist, proActiveRuntimeUrl,
00407                     creatorID, creationProtocol, rurid);
00408             } else {
00409                 logErrorAndDumpTable(urid);
00410             }
00411         }
00412     }
00413
00414     public ProActiveRuntime[] getProActiveRuntimes(UniqueRuntimeID urid)
00415         throws ProActiveException {
00416         if (urid == null) {
00417             return this.getProActiveRuntimes();
00418         } else {
00419             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00420
00421             if (part != null) {
00422                 return part.getProActiveRuntimes();
00423             } else {
00424                 logErrorAndDumpTable(urid);
00425             }
00426         }
00427
00428         return null;
00429     }
00430
00431     public ProActiveRuntime getProActiveRuntime(UniqueRuntimeID urid,
00432         String proActiveRuntimeName) throws ProActiveException {
00433         if (urid == null) {
00434             return this.getProActiveRuntime(proActiveRuntimeName);
00435         } else {
00436             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00437
00438             if (part != null) {
00439                 return part.getProActiveRuntime(proActiveRuntimeName);
00440             } else {
00441                 logErrorAndDumpTable(urid);
00442             }
00443         }
00444
00445         return null;
00446     }
00447
00448     public void addAcquaintance(UniqueRuntimeID urid,
00449         String proActiveRuntimeName) throws ProActiveException {
00450         if (urid == null) {
00451             this.addAcquaintance(proActiveRuntimeName);
00452         } else {
00453             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00454
00455             if (part != null) {
00456                 part.addAcquaintance(proActiveRuntimeName);
00457             } else {
00458                 logErrorAndDumpTable(urid);
00459             }
00460         }
00461     }
00462
00463     public String[] getAcquaintances(UniqueRuntimeID urid)
00464         throws ProActiveException {
00465         if (urid == null) {
00466             return this.getAcquaintances();
00467         } else {
00468             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00469
00470             if (part != null) {
00471                 return part.getAcquaintances();
00472             } else {
00473                 logErrorAndDumpTable(urid);
00474             }
00475         }
00476
00477         return null;
00478     }
00479
00480     public void rmAcquaintance(UniqueRuntimeID urid, String proActiveRuntimeName)
00481         throws ProActiveException {
00482         if (urid == null) {
00483             this.rmAcquaintance(proActiveRuntimeName);
00484         } else {
00485             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00486
00487             if (part != null) {
00488                 part.rmAcquaintance(proActiveRuntimeName);
00489             } else {
00490                 logErrorAndDumpTable(urid);
00491             }
00492         }
00493     }
00494
00495     public void killRT(UniqueRuntimeID urid, boolean softly)
00496         throws Exception {
00497         if (urid == null) {
00498             this.killRT(softly);
00499         } else {
00500             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00501
00502             if (part != null) {
00503                 part.killRT(softly);
00504             } else {
00505                 logErrorAndDumpTable(urid);
00506             }
00507         }
00508     }
00509
00510     public String getURL(UniqueRuntimeID urid) {
00511         if (urid == null) {
00512             return this.getURL();
00513         } else {
00514             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00515
00516             if (part != null) {
00517                 return part.getURL();
00518             } else {
00519                 logErrorAndDumpTable(urid);
00520             }
00521         }
00522
00523         return null;
00524     }
00525
00526     public ArrayList getActiveObjects(UniqueRuntimeID urid, String nodeName)
00527         throws ProActiveException {
00528         if (urid == null) {
00529             return this.getActiveObjects(nodeName);
00530         } else {
00531             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00532
00533             if (part != null) {
00534                 return part.getActiveObjects(nodeName);
00535             } else {
00536                 logErrorAndDumpTable(urid);
00537             }
00538         }
00539
00540         return null;
00541     }
00542
00543     public ArrayList getActiveObjects(UniqueRuntimeID urid, String nodeName,
00544         String className) throws ProActiveException {
00545         if (urid == null) {
00546             return this.getActiveObjects(nodeName, className);
00547         } else {
00548             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00549
00550             if (part != null) {
00551                 return part.getActiveObjects(nodeName, className);
00552             } else {
00553                 logErrorAndDumpTable(urid);
00554             }
00555         }
00556
00557         return null;
00558     }
00559
00560     public VirtualNode getVirtualNode(UniqueRuntimeID urid,
00561         String virtualNodeName) throws ProActiveException {
00562         if (urid == null) {
00563             return this.getVirtualNode(virtualNodeName);
00564         } else {
00565             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00566
00567             if (part != null) {
00568                 return part.getVirtualNode(virtualNodeName);
00569             } else {
00570                 logErrorAndDumpTable(urid);
00571             }
00572         }
00573
00574         return null;
00575     }
00576
00577     public void registerVirtualNode(UniqueRuntimeID urid,
00578         String virtualNodeName, boolean replacePreviousBinding)
00579         throws ProActiveException, AlreadyBoundException {
00580         if (urid == null) {
00581             this.registerVirtualNode(virtualNodeName, replacePreviousBinding);
00582         } else {
00583             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00584
00585             if (part != null) {
00586                 part.registerVirtualNode(virtualNodeName, replacePreviousBinding);
00587             } else {
00588                 logErrorAndDumpTable(urid);
00589             }
00590         }
00591     }
00592
00593     public void unregisterVirtualNode(UniqueRuntimeID urid,
00594         String virtualNodeName) throws ProActiveException {
00595         if (urid == null) {
00596             this.unregisterVirtualNode(virtualNodeName);
00597         } else {
00598             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00599
00600             if (part != null) {
00601                 part.unregisterVirtualNode(virtualNodeName);
00602             } else {
00603                 logErrorAndDumpTable(urid);
00604             }
00605         }
00606     }
00607
00608     public void unregisterAllVirtualNodes(UniqueRuntimeID urid)
00609         throws ProActiveException {
00610         if (urid == null) {
00611             this.unregisterAllVirtualNodes();
00612         } else {
00613             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00614
00615             if (part != null) {
00616                 part.unregisterAllVirtualNodes();
00617             } else {
00618                 logErrorAndDumpTable(urid);
00619             }
00620         }
00621     }
00622
00623     public String getJobID(UniqueRuntimeID urid, String nodeUrl)
00624         throws ProActiveException {
00625         if (urid == null) {
00626             return this.getJobID(nodeUrl);
00627         } else {
00628             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00629
00630             if (part != null) {
00631                 return part.getJobID(nodeUrl);
00632             } else {
00633                 logErrorAndDumpTable(urid);
00634             }
00635         }
00636
00637         return null;
00638     }
00639
00640     public UniversalBody receiveBody(UniqueRuntimeID urid, String nodeName,
00641         Body body) throws ProActiveException {
00642         if (urid == null) {
00643             return this.receiveBody(nodeName, body);
00644         } else {
00645             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00646
00647             if (part != null) {
00648                 return part.receiveBody(nodeName, body);
00649             } else {
00650                 logErrorAndDumpTable(urid);
00651             }
00652         }
00653
00654         return null;
00655     }
00656
00657     public UniversalBody receiveCheckpoint(UniqueRuntimeID urid,
00658         String nodeURL, Checkpoint ckpt, int inc) throws ProActiveException {
00659         if (urid == null) {
00660             return this.receiveCheckpoint(nodeURL, ckpt, inc);
00661         } else {
00662             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00663
00664             if (part != null) {
00665                 return part.receiveCheckpoint(nodeURL, ckpt, inc);
00666             } else {
00667                 logErrorAndDumpTable(urid);
00668             }
00669         }
00670
00671         return null;
00672     }
00673
00674     public ExternalProcess getProcessToDeploy(UniqueRuntimeID urid,
00675         ProActiveRuntime proActiveRuntimeDist, String creatorID, String vmName,
00676         String padURL) throws ProActiveException {
00677         if (urid == null) {
00678             return this.getProcessToDeploy(proActiveRuntimeDist, creatorID,
00679                 vmName, padURL);
00680         } else {
00681             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00682
00683             if (part != null) {
00684                 return part.getProcessToDeploy(proActiveRuntimeDist, creatorID,
00685                     vmName, padURL);
00686             } else {
00687                 logErrorAndDumpTable(urid);
00688             }
00689         }
00690
00691         return null;
00692     }
00693
00694     public String getVNName(UniqueRuntimeID urid, String Nodename)
00695         throws ProActiveException {
00696         if (urid == null) {
00697             return this.getVNName(Nodename);
00698         } else {
00699             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00700
00701             if (part != null) {
00702                 return part.getVNName(Nodename);
00703             } else {
00704                 logErrorAndDumpTable(urid);
00705             }
00706         }
00707
00708         return null;
00709     }
00710
00711     public ArrayList<Entity> getEntities(UniqueRuntimeID urid)
00712         throws IOException, SecurityNotAvailableException {
00713         if (urid == null) {
00714             return this.getEntities();
00715         } else {
00716             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00717
00718             if (part != null) {
00719                 return part.getEntities();
00720             } else {
00721                 logErrorAndDumpTable(urid);
00722             }
00723         }
00724
00725         return null;
00726     }
00727
00728     public SecurityContext getPolicy(UniqueRuntimeID urid, SecurityContext sc)
00729         throws SecurityNotAvailableException, IOException {
00730         if (urid == null) {
00731             return this.getPolicy(sc);
00732         } else {
00733             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00734
00735             if (part != null) {
00736                 return part.getPolicy(sc);
00737             } else {
00738                 logErrorAndDumpTable(urid);
00739             }
00740         }
00741
00742         return null;
00743     }
00744
00745     public byte[] getClassDataFromThisRuntime(UniqueRuntimeID urid,
00746         String className) throws ProActiveException {
00747         if (urid == null) {
00748             return this.getClassDataFromThisRuntime(className);
00749         } else {
00750             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00751
00752             if (part != null) {
00753                 return part.getClassDataFromThisRuntime(className);
00754             } else {
00755                 logErrorAndDumpTable(urid);
00756             }
00757         }
00758
00759         return null;
00760     }
00761
00762     public byte[] getClassDataFromParentRuntime(UniqueRuntimeID urid,
00763         String className) throws ProActiveException {
00764         if (urid == null) {
00765             return this.getClassDataFromParentRuntime(className);
00766         } else {
00767             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00768
00769             if (part != null) {
00770                 return part.getClassDataFromParentRuntime(className);
00771             } else {
00772                 logErrorAndDumpTable(urid);
00773             }
00774         }
00775
00776         return null;
00777     }
00778
00779     public X509Certificate getCertificate(UniqueRuntimeID urid)
00780         throws SecurityNotAvailableException, IOException {
00781         if (urid == null) {
00782             return this.getCertificate();
00783         } else {
00784             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00785
00786             if (part != null) {
00787                 return part.getCertificate();
00788             } else {
00789                 logErrorAndDumpTable(urid);
00790             }
00791         }
00792
00793         return null;
00794     }
00795
00796     public byte[] getCertificateEncoded(UniqueRuntimeID urid)
00797         throws SecurityNotAvailableException, IOException {
00798         if (urid == null) {
00799             return this.getCertificateEncoded();
00800         } else {
00801             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00802
00803             if (part != null) {
00804                 return part.getCertificateEncoded();
00805             } else {
00806                 logErrorAndDumpTable(urid);
00807             }
00808         }
00809
00810         return null;
00811     }
00812
00813     public PublicKey getPublicKey(UniqueRuntimeID urid)
00814         throws SecurityNotAvailableException, IOException {
00815         if (urid == null) {
00816             return this.getPublicKey();
00817         } else {
00818             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00819
00820             if (part != null) {
00821                 return part.getPublicKey();
00822             } else {
00823                 logErrorAndDumpTable(urid);
00824             }
00825         }
00826
00827         return null;
00828     }
00829
00830     public byte[][] publicKeyExchange(UniqueRuntimeID urid, long sessionID,
00831         byte[] myPublicKey, byte[] myCertificate, byte[] signature)
00832         throws SecurityNotAvailableException, RenegotiateSessionException,
00833             KeyExchangeException, IOException {
00834         if (urid == null) {
00835             return this.publicKeyExchange(sessionID, myPublicKey,
00836                 myCertificate, signature);
00837         } else {
00838             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00839
00840             if (part != null) {
00841                 return part.publicKeyExchange(sessionID, myPublicKey,
00842                     myCertificate, signature);
00843             } else {
00844                 logErrorAndDumpTable(urid);
00845             }
00846         }
00847
00848         return null;
00849     }
00850
00851     public byte[] randomValue(UniqueRuntimeID urid, long sessionID,
00852         byte[] clientRandomValue)
00853         throws SecurityNotAvailableException, RenegotiateSessionException,
00854             IOException {
00855         if (urid == null) {
00856             return this.randomValue(sessionID, clientRandomValue);
00857         } else {
00858             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00859
00860             if (part != null) {
00861                 return part.randomValue(sessionID, clientRandomValue);
00862             } else {
00863                 logErrorAndDumpTable(urid);
00864             }
00865         }
00866
00867         return null;
00868     }
00869
00870     public byte[][] secretKeyExchange(UniqueRuntimeID urid, long sessionID,
00871         byte[] encodedAESKey, byte[] encodedIVParameters,
00872         byte[] encodedClientMacKey, byte[] encodedLockData,
00873         byte[] parametersSignature)
00874         throws SecurityNotAvailableException, RenegotiateSessionException,
00875             IOException {
00876         if (urid == null) {
00877             return this.secretKeyExchange(sessionID, encodedAESKey,
00878                 encodedIVParameters, encodedClientMacKey, encodedLockData,
00879                 parametersSignature);
00880         } else {
00881             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00882
00883             if (part != null) {
00884                 return part.secretKeyExchange(sessionID, encodedAESKey,
00885                     encodedIVParameters, encodedClientMacKey, encodedLockData,
00886                     parametersSignature);
00887             } else {
00888                 logErrorAndDumpTable(urid);
00889             }
00890         }
00891
00892         return null;
00893     }
00894
00895     public long startNewSession(UniqueRuntimeID urid, Communication policy)
00896         throws SecurityNotAvailableException, RenegotiateSessionException,
00897             IOException {
00898         if (urid == null) {
00899             return this.startNewSession(policy);
00900         } else {
00901             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00902
00903             if (part != null) {
00904                 return part.startNewSession(policy);
00905             } else {
00906                 logErrorAndDumpTable(urid);
00907             }
00908         }
00909
00910         return 0;
00911     }
00912
00913     public void terminateSession(UniqueRuntimeID urid, long sessionID)
00914         throws SecurityNotAvailableException, IOException {
00915         if (urid == null) {
00916             this.terminateSession(sessionID);
00917         } else {
00918             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00919
00920             if (part != null) {
00921                 part.terminateSession(sessionID);
00922             } else {
00923                 logErrorAndDumpTable(urid);
00924             }
00925         }
00926     }
00927
00928     public ProActiveDescriptor getDescriptor(UniqueRuntimeID urid, String url,
00929         boolean isHierarchicalSearch) throws IOException, ProActiveException {
00930         if (urid == null) {
00931             return this.getDescriptor(url, isHierarchicalSearch);
00932         } else {
00933             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00934
00935             if (part != null) {
00936                 return part.getDescriptor(url, isHierarchicalSearch);
00937             } else {
00938                 logErrorAndDumpTable(urid);
00939             }
00940         }
00941
00942         return null;
00943     }
00944
00945     public String getJobID(UniqueRuntimeID urid) {
00946         if (urid == null) {
00947             return this.getJobID();
00948         } else {
00949             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00950
00951             if (part != null) {
00952                 return part.getJobID();
00953             } else {
00954                 logErrorAndDumpTable(urid);
00955             }
00956         }
00957
00958         return null;
00959     }
00960
00961     public void launchMain(UniqueRuntimeID urid, String className,
00962         String[] parameters)
00963         throws ClassNotFoundException, NoSuchMethodException, ProActiveException {
00964         if (urid == null) {
00965             this.launchMain(className, parameters);
00966         } else {
00967             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00968
00969             if (part != null) {
00970                 part.launchMain(className, parameters);
00971             } else {
00972                 logErrorAndDumpTable(urid);
00973             }
00974         }
00975     }
00976
00977     public void newRemote(UniqueRuntimeID urid, String className)
00978         throws ClassNotFoundException, ProActiveException {
00979         if (urid == null) {
00980             this.newRemote(className);
00981         } else {
00982             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(urid);
00983
00984             if (part != null) {
00985                 part.newRemote(className);
00986             } else {
00987                 logErrorAndDumpTable(urid);
00988             }
00989         }
00990     }
00991
00992     public Object setLocalNodeProperty(UniqueRuntimeID runtimeID,
00993         String nodeName, String key, String value)
00994         throws ProActiveException, IOException {
00995         if (runtimeID == null) {
00996             return this.setLocalNodeProperty(nodeName, key, value);
00997         } else {
00998             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(runtimeID);
00999
01000             if (part != null) {
01001                 return part.setLocalNodeProperty(nodeName, key, value);
01002             } else {
01003             }
01004         }
01005         return null;
01006     }
01007
01008     public void logErrorAndDumpTable(UniqueRuntimeID runtimeID) {
01009         logger.warn("No runtime associated to this urid :" + runtimeID);
01010         logger.warn("Registered runtimes are:");
01011         for (UniqueRuntimeID urid : registeredRuntimes.keySet()) {
01012             logger.warn("\t" + urid);
01013         }
01014     }
01015
01016     public String getLocalNodeProperty(UniqueRuntimeID runtimeID,
01017         String nodeName, String key) throws ProActiveException, IOException {
01018         if (runtimeID == null) {
01019             return this.getLocalNodeProperty(nodeName, key);
01020         } else {
01021             ProActiveRuntime part = (ProActiveRuntime) registeredRuntimes.get(runtimeID);
01022
01023             if (part != null) {
01024                 return part.getLocalNodeProperty(nodeName, key);
01025             } else {
01026                 logErrorAndDumpTable(runtimeID);
01027             }
01028         }
01029         return null;
01030     }
01031 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
