org/objectweb/proactive/core/runtime/ProActiveRuntimeAdapterForwarderImpl.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.runtime;
00032
00033 import java.io.IOException;
00034 import java.io.Serializable;
00035 import java.lang.reflect.InvocationTargetException;
00036 import java.rmi.AlreadyBoundException;
00037 import java.rmi.UnmarshalException;
00038 import java.security.PublicKey;
00039 import java.security.cert.X509Certificate;
00040 import java.util.ArrayList;
00041
00042 import org.objectweb.proactive.Body;
00043 import org.objectweb.proactive.core.ProActiveException;
00044 import org.objectweb.proactive.core.UniqueRuntimeID;
00045 import org.objectweb.proactive.core.body.UniversalBody;
00046 import org.objectweb.proactive.core.body.ft.checkpointing.Checkpoint;
00047 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00048 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00049 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00050 import org.objectweb.proactive.core.mop.ConstructorCall;
00051 import org.objectweb.proactive.core.mop.ConstructorCallExecutionFailedException;
00052 import org.objectweb.proactive.core.node.NodeException;
00053 import org.objectweb.proactive.core.process.ExternalProcess;
00054 import org.objectweb.proactive.core.process.UniversalProcess;
00055 import org.objectweb.proactive.ext.security.Communication;
00056 import org.objectweb.proactive.ext.security.ProActiveSecurityManager;
00057 import org.objectweb.proactive.ext.security.SecurityContext;
00058 import org.objectweb.proactive.ext.security.crypto.KeyExchangeException;
00059 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00060 import org.objectweb.proactive.ext.security.exceptions.SecurityNotAvailableException;
00061 import org.objectweb.proactive.ext.security.securityentity.Entity;
00062
00063
00076 public class ProActiveRuntimeAdapterForwarderImpl
00077     extends ProActiveRuntimeAdapter implements Serializable, Cloneable {
00078     private UniqueRuntimeID urid; // Cached for speed issue
00079     protected RemoteProActiveRuntimeForwarder proActiveRuntime;
00080     protected String proActiveRuntimeURL;
00081
00082     // this boolean is used when killing the runtime.
00083     // Indeed in case of co-allocation, we avoid a second call to the runtime which is already dead
00084     protected boolean alreadykilled = false;
00085
00086     //
00087     // -- Constructors -----------------------------------------------
00088     //
00089     public ProActiveRuntimeAdapterForwarderImpl() {
00090     }
00091
00092     public ProActiveRuntimeAdapterForwarderImpl(
00093         RemoteProActiveRuntimeForwarder proActiveRuntime)
00094         throws ProActiveException {
00095         this.proActiveRuntime = proActiveRuntime;
00096
00097         try {
00098             this.vmInformation = proActiveRuntime.getVMInformation();
00099             this.proActiveRuntimeURL = proActiveRuntime.getURL();
00100         } catch (IOException e) {
00101             throw new ProActiveException(e);
00102         }
00103     }
00104
00105     public ProActiveRuntimeAdapterForwarderImpl(
00106         ProActiveRuntimeAdapterForwarderImpl localAdapter,
00107         ProActiveRuntime remoteAdapter) throws ProActiveException {
00108         this.proActiveRuntime = (RemoteProActiveRuntimeForwarder) localAdapter.proActiveRuntime;
00109         this.vmInformation = remoteAdapter.getVMInformation();
00110         this.proActiveRuntimeURL = remoteAdapter.getURL();
00111         this.urid = new UniqueRuntimeID(remoteAdapter.getVMInformation()
00112                                                      .getName(),
00113                 remoteAdapter.getVMInformation().getVMID());
00114     }
00115
00116     private void readObject(java.io.ObjectInputStream in)
00117         throws java.io.IOException, ClassNotFoundException {
00118         in.defaultReadObject();
00119
00120         if (ProActiveConfiguration.isForwarder()) {
00121             // on a forwarder and during the deserialization of a ProActiveAdapterForwarderImpl.
00122             ProActiveRuntimeForwarderImpl partf = (ProActiveRuntimeForwarderImpl) ProActiveRuntimeImpl.getProActiveRuntime();
00123
00124             if (!partf.registeredRuntimes.containsKey(urid)) {
00125                 try {
00126                     // Add this unknown runtime to the table of forwarded runtimes
00127                     partf.registeredRuntimes.put(urid, (ProActiveRuntime)this.clone());
00128                 } catch (CloneNotSupportedException e) {
00129                     runtimeLogger.warn(e);
00130                 }
00131             }
00132
00133             try {
00134                 // Change the RMI reference to point on this forwarder. That's all, it's automagic !
00135                 proActiveRuntime = ((ProActiveRuntimeAdapterForwarderImpl) RuntimeFactory.getDefaultRuntime()).proActiveRuntime;
00136             } catch (ProActiveException e) {
00137                 runtimeLogger.warn(e);
00138             }
00139         }
00140     }
00141
00142     //
00143     // -- PUBLIC METHODS -----------------------------------------------
00144     //
00145     public boolean equals(Object o) {
00146         if (!(o instanceof ProActiveRuntimeAdapterForwarderImpl)) {
00147             return false;
00148         }
00149
00150         ProActiveRuntimeAdapterForwarderImpl runtime = (ProActiveRuntimeAdapterForwarderImpl) o;
00151
00152         return this.urid.equals(runtime.urid);
00153     }
00154
00155     public int hashCode() {
00156         return urid.hashCode();
00157     }
00158
00159     //
00160     // -- Implements ProActiveRuntime -----------------------------------------------
00161     //
00162
00167     public String createLocalNode(String nodeName,
00168         boolean replacePreviousBinding, ProActiveSecurityManager psm,
00169         String vnName, String jobId) throws NodeException {
00170         try {
00171             return proActiveRuntime.createLocalNode(urid, nodeName,
00172                 replacePreviousBinding, psm, vnName, jobId);
00173         } catch (Exception e) {
00174             throw new NodeException(e);
00175         }
00176     }
00177
00182     public void killAllNodes() throws ProActiveException {
00183         try {
00184             proActiveRuntime.killAllNodes(urid);
00185         } catch (IOException e) {
00186             throw new ProActiveException(e);
00187         }
00188     }
00189
00194     public void killNode(String nodeName) throws ProActiveException {
00195         try {
00196             proActiveRuntime.killNode(urid, nodeName);
00197         } catch (IOException e) {
00198             throw new ProActiveException(e);
00199         }
00200     }
00201
00207     public void createVM(UniversalProcess remoteProcess)
00208         throws IOException, ProActiveException {
00209         proActiveRuntime.createVM(urid, remoteProcess);
00210     }
00211
00216     public String[] getLocalNodeNames() throws ProActiveException {
00217         try {
00218             return proActiveRuntime.getLocalNodeNames(urid);
00219         } catch (IOException e) {
00220             throw new ProActiveException(e);
00221         }
00222     }
00223
00227     public VMInformation getVMInformation() {
00228         return vmInformation;
00229     }
00230
00235     public void register(ProActiveRuntime proActiveRuntimeDist,
00236         String proActiveRuntimeUrl, String creatorID, String creationProtocol,
00237         String vmName) throws ProActiveException {
00238         try {
00239             proActiveRuntime.register(urid, proActiveRuntimeDist,
00240                 proActiveRuntimeUrl, creatorID, creationProtocol, vmName);
00241         } catch (IOException e) {
00242             throw new ProActiveException(e);
00243         }
00244     }
00245
00250     public void unregister(ProActiveRuntime proActiveRuntimeDist,
00251         String proActiveRuntimeUrl, String creatorID, String creationProtocol,
00252         String vmName) throws ProActiveException {
00253         try {
00254             this.proActiveRuntime.unregister(urid, proActiveRuntimeDist,
00255                 proActiveRuntimeUrl, creatorID, creationProtocol, vmName);
00256         } catch (IOException e) {
00257             throw new ProActiveException(e);
00258         }
00259     }
00260
00265     public ProActiveRuntime[] getProActiveRuntimes() throws ProActiveException {
00266         try {
00267             return proActiveRuntime.getProActiveRuntimes(urid);
00268         } catch (IOException e) {
00269             throw new ProActiveException(e);
00270         }
00271     }
00272
00277     public ProActiveRuntime getProActiveRuntime(String proActiveRuntimeName)
00278         throws ProActiveException {
00279         try {
00280             return proActiveRuntime.getProActiveRuntime(urid,
00281                 proActiveRuntimeName);
00282         } catch (IOException e) {
00283             throw new ProActiveException(e);
00284         }
00285     }
00286
00291     public void addAcquaintance(String proActiveRuntimeName)
00292         throws ProActiveException {
00293         try {
00294             proActiveRuntime.addAcquaintance(urid, proActiveRuntimeName);
00295         } catch (IOException e) {
00296             throw new ProActiveException(e);
00297         }
00298     }
00299
00304     public String[] getAcquaintances() throws ProActiveException {
00305         try {
00306             return proActiveRuntime.getAcquaintances(urid);
00307         } catch (IOException e) {
00308             throw new ProActiveException(e);
00309         }
00310     }
00311
00316     public void rmAcquaintance(String proActiveRuntimeName)
00317         throws ProActiveException {
00318         try {
00319             proActiveRuntime.rmAcquaintance(urid, proActiveRuntimeName);
00320         } catch (IOException e) {
00321             throw new ProActiveException(e);
00322         }
00323     }
00324
00328     public void killRT(boolean softly) throws Exception {
00329         try {
00330             if (!alreadykilled) {
00331                 proActiveRuntime.killRT(urid, softly);
00332             }
00333
00334             alreadykilled = true;
00335         } catch (UnmarshalException e) {
00336             //here should be caught the exception from System.exit
00337             alreadykilled = true;
00338             throw e;
00339         }
00340     }
00341
00345     public String getURL() {
00346         return proActiveRuntimeURL;
00347     }
00348
00353     public ArrayList getActiveObjects(String nodeName)
00354         throws ProActiveException {
00355         try {
00356             return proActiveRuntime.getActiveObjects(urid, nodeName);
00357         } catch (IOException e) {
00358             throw new ProActiveException(e);
00359         }
00360     }
00361
00366     public ArrayList getActiveObjects(String nodeName, String className)
00367         throws ProActiveException {
00368         try {
00369             return proActiveRuntime.getActiveObjects(urid, nodeName, className);
00370         } catch (IOException e) {
00371             throw new ProActiveException(e);
00372         }
00373     }
00374
00379     public VirtualNode getVirtualNode(String virtualNodeName)
00380         throws ProActiveException {
00381         try {
00382             return proActiveRuntime.getVirtualNode(urid, virtualNodeName);
00383         } catch (IOException e) {
00384             throw new ProActiveException(e);
00385         }
00386     }
00387
00392     public void registerVirtualNode(String virtualNodeName,
00393         boolean replacePreviousBinding)
00394         throws ProActiveException, AlreadyBoundException {
00395         try {
00396             proActiveRuntime.registerVirtualNode(urid, virtualNodeName,
00397                 replacePreviousBinding);
00398         } catch (IOException e) {
00399             throw new ProActiveException(e);
00400         }
00401     }
00402
00407     public void unregisterVirtualNode(String virtualNodeName)
00408         throws ProActiveException {
00409         try {
00410             proActiveRuntime.unregisterVirtualNode(urid, virtualNodeName);
00411         } catch (IOException e) {
00412             throw new ProActiveException(e);
00413         }
00414     }
00415
00420     public void unregisterAllVirtualNodes() throws ProActiveException {
00421         try {
00422             proActiveRuntime.unregisterAllVirtualNodes(urid);
00423         } catch (IOException e) {
00424             throw new ProActiveException(e);
00425         }
00426     }
00427
00432     public String getJobID(String nodeUrl) throws ProActiveException {
00433         try {
00434             return proActiveRuntime.getJobID(urid, nodeUrl);
00435         } catch (IOException e) {
00436             throw new ProActiveException(e);
00437         }
00438     }
00439
00444     public UniversalBody createBody(String nodeName,
00445         ConstructorCall bodyConstructorCall, boolean isNodeLocal)
00446         throws ConstructorCallExecutionFailedException,
00447             InvocationTargetException, ProActiveException {
00448         try {
00449             return proActiveRuntime.createBody(urid, nodeName,
00450                 bodyConstructorCall, isNodeLocal);
00451         } catch (IOException e) {
00452             throw new ProActiveException(e);
00453         }
00454     }
00455
00460     public UniversalBody receiveBody(String nodeName, Body body)
00461         throws ProActiveException {
00462         try {
00463             return proActiveRuntime.receiveBody(urid, nodeName, body);
00464         } catch (IOException e) {
00465             throw new ProActiveException(e);
00466         }
00467     }
00468
00473     public UniversalBody receiveCheckpoint(String nodeName, Checkpoint ckpt,
00474         int inc) throws ProActiveException {
00475         try {
00476             return proActiveRuntime.receiveCheckpoint(urid, nodeName, ckpt, inc);
00477         } catch (IOException e) {
00478             throw new ProActiveException(e);
00479         }
00480     }
00481
00486     public String getVNName(String Nodename) throws ProActiveException {
00487         try {
00488             return proActiveRuntime.getVNName(urid, Nodename);
00489         } catch (IOException e) {
00490             throw new ProActiveException(e);
00491         }
00492     }
00493
00498     public byte[] getClassDataFromThisRuntime(String className)
00499         throws ProActiveException {
00500         try {
00501             return proActiveRuntime.getClassDataFromThisRuntime(urid, className);
00502         } catch (IOException e) {
00503             throw new ProActiveException(e);
00504         }
00505     }
00506
00511     public byte[] getClassDataFromParentRuntime(String className)
00512         throws ProActiveException {
00513         try {
00514             return proActiveRuntime.getClassDataFromParentRuntime(urid,
00515                 className);
00516         } catch (IOException e) {
00517             throw new ProActiveException(e);
00518         }
00519     }
00520
00521     public ExternalProcess getProcessToDeploy(
00522         ProActiveRuntime proActiveRuntimeDist, String creatorID, String vmName,
00523         String padURL) throws ProActiveException {
00524         try {
00525             return proActiveRuntime.getProcessToDeploy(urid,
00526                 proActiveRuntimeDist, creatorID, vmName, padURL);
00527         } catch (IOException e) {
00528             throw new ProActiveException(e);
00529         }
00530     }
00531
00532     //
00533     // Implements Job Interface
00534     //
00535
00539     public String getJobID() {
00540         return vmInformation.getJobID();
00541     }
00542
00543     public ProActiveDescriptor getDescriptor(String url,
00544         boolean isHierarchicalSearch) throws IOException, ProActiveException {
00545         try {
00546             return proActiveRuntime.getDescriptor(urid, url,
00547                 isHierarchicalSearch);
00548         } catch (IOException e) {
00549             throw new ProActiveException(e);
00550         }
00551     }
00552
00553     public void launchMain(String className, String[] parameters)
00554         throws ClassNotFoundException, NoSuchMethodException, ProActiveException {
00555         try {
00556             proActiveRuntime.launchMain(urid, className, parameters);
00557         } catch (IOException e) {
00558             throw new ProActiveException(e);
00559         }
00560     }
00561
00562     public void newRemote(String className)
00563         throws ClassNotFoundException, ProActiveException {
00564         try {
00565             proActiveRuntime.newRemote(urid, className);
00566         } catch (IOException e) {
00567             throw new ProActiveException(e);
00568         }
00569     }
00570
00571     public X509Certificate getCertificate()
00572         throws SecurityNotAvailableException, IOException {
00573         return proActiveRuntime.getCertificate(urid);
00574     }
00575
00576     public byte[] getCertificateEncoded()
00577         throws SecurityNotAvailableException, IOException {
00578         return proActiveRuntime.getCertificateEncoded(urid);
00579     }
00580
00581     public ArrayList<Entity> getEntities()
00582         throws SecurityNotAvailableException, IOException {
00583         return proActiveRuntime.getEntities(urid);
00584     }
00585
00586     public PublicKey getPublicKey()
00587         throws SecurityNotAvailableException, IOException {
00588         return proActiveRuntime.getPublicKey(urid);
00589     }
00590
00591     public byte[][] publicKeyExchange(long sessionID, byte[] myPublicKey,
00592         byte[] myCertificate, byte[] signature)
00593         throws SecurityNotAvailableException, RenegotiateSessionException,
00594             KeyExchangeException, IOException {
00595         return proActiveRuntime.publicKeyExchange(urid, sessionID, myPublicKey,
00596             myCertificate, signature);
00597     }
00598
00599     public byte[] randomValue(long sessionID, byte[] clientRandomValue)
00600         throws SecurityNotAvailableException, RenegotiateSessionException,
00601             IOException {
00602         return proActiveRuntime.randomValue(urid, sessionID, clientRandomValue);
00603     }
00604
00605     public byte[][] secretKeyExchange(long sessionID, byte[] encodedAESKey,
00606         byte[] encodedIVParameters, byte[] encodedClientMacKey,
00607         byte[] encodedLockData, byte[] parametersSignature)
00608         throws SecurityNotAvailableException, RenegotiateSessionException,
00609             IOException {
00610         return proActiveRuntime.secretKeyExchange(urid, sessionID,
00611             encodedAESKey, encodedIVParameters, encodedClientMacKey,
00612             encodedLockData, parametersSignature);
00613     }
00614
00615     public long startNewSession(Communication policy)
00616         throws SecurityNotAvailableException, RenegotiateSessionException,
00617             IOException {
00618         return proActiveRuntime.startNewSession(urid, policy);
00619     }
00620
00621     public void terminateSession(long sessionID)
00622         throws SecurityNotAvailableException, IOException {
00623         proActiveRuntime.terminateSession(urid, sessionID);
00624     }
00625
00626     public SecurityContext getPolicy(SecurityContext securityContext)
00627         throws SecurityNotAvailableException, IOException {
00628         return proActiveRuntime.getPolicy(urid, securityContext);
00629     }
00630
00631     public Object setLocalNodeProperty(String nodeName, String key, String value)
00632         throws ProActiveException {
00633         try {
00634             return this.proActiveRuntime.setLocalNodeProperty(this.urid,
00635                 nodeName, key, value);
00636         } catch (IOException e) {
00637             throw new ProActiveException(e);
00638         }
00639     }
00640
00641     public String getLocalNodeProperty(String nodeName, String key)
00642         throws ProActiveException {
00643         try {
00644             return this.proActiveRuntime.getLocalNodeProperty(this.urid,
00645                 nodeName, key);
00646         } catch (IOException e) {
00647             throw new ProActiveException(e);
00648         }
00649     }
00650 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
