org/objectweb/proactive/core/body/migration/MigrationManager.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.migration;
00032
00033 import org.objectweb.proactive.Body;
00034 import org.objectweb.proactive.core.body.UniversalBody;
00035 import org.objectweb.proactive.core.body.reply.ReplyReceiver;
00036 import org.objectweb.proactive.core.body.request.RequestReceiver;
00037 import org.objectweb.proactive.core.event.MigrationEventListener;
00038 import org.objectweb.proactive.core.node.Node;
00039
00040
00041 public interface MigrationManager {
00042     public Node checkNode(Node node) throws MigrationException;
00043
00044     public UniversalBody migrateTo(Node node, Body body)
00045         throws MigrationException;
00046
00047     public void changeBodyAfterMigration(MigratableBody body, UniversalBody migratedBody);
00048
00049     public void startingAfterMigration(Body body);
00050
00051     public RequestReceiver createRequestReceiver(UniversalBody remoteBody,
00052         RequestReceiver currentRequestReceiver);
00053
00054     public ReplyReceiver createReplyReceiver(UniversalBody remoteBody,
00055         ReplyReceiver currentReplyReceiver);
00056
00057     public void addMigrationEventListener(MigrationEventListener listener);
00058
00059     public void removeMigrationEventListener(MigrationEventListener listener);
00060
00061     public void setMigrationStrategy(int ttl, boolean updatingForwarder, int maxMigrationNb, int maxTimeOnSite);
00062 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
