org/objectweb/proactive/core/body/migration/MigrationManagerImpl.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.migration;
00032
00033 import java.util.Timer;
00034
00035 import org.apache.log4j.Logger;
00036 import org.objectweb.proactive.Body;
00037 import org.objectweb.proactive.core.body.LocalBodyStore;
00038 import org.objectweb.proactive.core.body.UniversalBody;
00039 import org.objectweb.proactive.core.body.reply.ReplyReceiver;
00040 import org.objectweb.proactive.core.body.reply.ReplyReceiverForwarder;
00041 import org.objectweb.proactive.core.body.request.RequestReceiver;
00042 import org.objectweb.proactive.core.body.request.RequestReceiverForwarder;
00043 import org.objectweb.proactive.core.event.AbstractEventProducer;
00044 import org.objectweb.proactive.core.event.MigrationEvent;
00045 import org.objectweb.proactive.core.event.MigrationEventListener;
00046 import org.objectweb.proactive.core.event.ProActiveEvent;
00047 import org.objectweb.proactive.core.event.ProActiveListener;
00048 import org.objectweb.proactive.core.node.Node;
00049 import org.objectweb.proactive.core.node.NodeFactory;
00050 import org.objectweb.proactive.core.runtime.ProActiveRuntime;
00051 import org.objectweb.proactive.core.util.log.Loggers;
00052 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00053 import org.objectweb.proactive.ext.locationserver.LocationServer;
00054 import org.objectweb.proactive.ext.locationserver.LocationServerFactory;
00055
00056 public class MigrationManagerImpl extends AbstractEventProducer implements
00057                 MigrationManager, java.io.Serializable {
00058         protected static Logger logger = ProActiveLogger
00059                         .getLogger(Loggers.MIGRATION);
00060
00061         transient protected LocationServer locationServer;
00062
00063         protected int nbOfMigrationWithoutUpdate; // used to compare with maxMigrationNb
00064
00065         protected int migrationCounter; // used to set the version for the update
00066
00067         public static final int INFINITE_TTL = -1;
00068
00069         public static final int INFINITE_MAX_MIGRATION_NB = -1;
00070
00071         public static final int INFINITE_MAX_TIME_ON_SITE = -1;
00072
00073         // -- PRIVATE MEMBERS -----------------------------------------------
00074         //
00075         private int ttl;
00076
00077         private boolean updatingForwarder;
00078
00079         private int maxMigrationNb;
00080
00081         private int maxTimeOnSite;
00082
00083         private transient Timer maxTimeOnSiteTimer;
00084
00085         private transient Timer ttlTimer;
00086
00087         //
00088         // -- CONSTRUCTORS -----------------------------------------------
00089         //
00090         public MigrationManagerImpl() {
00091                 super(true);
00092
00093                 if (System.getProperty("proactive.mixedlocation.ttl") != null) {
00094                         this.ttl = Integer.valueOf(
00095                                         System.getProperty("proactive.mixedlocation.ttl")).intValue();
00096                 } else {
00097                         this.ttl = INFINITE_TTL;
00098                 }
00099
00100                 if (System.getProperty("proactive.mixedlocation.updatingForwarder") != null) {
00101                         this.updatingForwarder = Boolean.parseBoolean(System
00102                                         .getProperty("proactive.mixedlocation.updatingForwarder"));
00103                 } else {
00104                         this.updatingForwarder = false;
00105                 }
00106
00107                 if (System.getProperty("proactive.mixedlocation.maxMigrationNb") != null) {
00108                         this.maxMigrationNb = Integer.valueOf(
00109                                         System.getProperty("proactive.mixedlocation.maxMigrationNb")).intValue();
00110                 } else {
00111                         this.maxMigrationNb = INFINITE_MAX_MIGRATION_NB;
00112                 }
00113
00114                 if (System.getProperty("proactive.mixedlocation.maxTimeOnSite") != null) {
00115                         this.maxTimeOnSite = Integer.valueOf(
00116                                         System.getProperty("proactive.mixedlocation.maxTimeOnSite")).intValue();
00117                 } else {
00118                         this.maxTimeOnSite = INFINITE_MAX_TIME_ON_SITE;
00119                 }
00120
00121                 this.nbOfMigrationWithoutUpdate = 0;
00122                 this.migrationCounter = 0;
00123
00124         }
00125
00126         // -- PUBLIC METHODS -----------------------------------------------
00127         //
00128
00129         public void updateLocation(UniversalBody body) {
00130                 if (locationServer == null) {
00131                         this.locationServer = LocationServerFactory.getLocationServer();
00132                 }
00133                 if (locationServer != null) {
00134                         locationServer.updateLocation(body.getID(),
00135                                         body.getRemoteAdapter(), this.migrationCounter);
00136                 }
00137                 resetNbOfMigrationWithoutUpdate();
00138         }
00139
00140
00141         public void resetNbOfMigrationWithoutUpdate() {
00142                 this.nbOfMigrationWithoutUpdate = 0;
00143         }
00144
00145         public void launchTimeToLive(MigratableBody body, UniversalBody migratedBody) {
00146                 if (this.ttl != INFINITE_TTL) {
00147                         ttlTimer = new Timer();
00148                         ttlTimer
00149                                         .schedule(
00150                                                         new TimeToLiveTimerTask(this, body, migratedBody),
00151                                                         this.ttl);
00152                 }
00153         }
00154
00155
00156
00157         //
00158         // -- Implements MigrationManager
00159         // -----------------------------------------------
00160         //
00161         public Node checkNode(Node node) throws MigrationException {
00162                 if (node == null) {
00163                         throw new MigrationException(
00164                                         "The RemoteNodeImpl could not be found");
00165                 }
00166
00167                 // check if the node is remote
00168                 if (NodeFactory.isNodeLocal(node)) {
00169                         MigrationException me = new MigrationException("The given node "
00170                                         + node.getNodeInformation().getURL()
00171                                         + " is in the same virtual machine");
00172                         if (hasListeners()) {
00173                                 notifyAllListeners(new MigrationEvent(me));
00174                         }
00175                         throw me;
00176                 }
00177                 return node;
00178         }
00179
00180         public UniversalBody migrateTo(Node node, Body body)
00181                         throws MigrationException {
00182                 if (hasListeners()) {
00183                         notifyAllListeners(new MigrationEvent(body,
00184                                         MigrationEvent.BEFORE_MIGRATION));
00185                 }
00186                 try {
00187                         long l1 = 0;
00188                         if (logger.isDebugEnabled()) {
00189                                 l1 = System.currentTimeMillis();
00190                         }
00191
00192                         //
00193                         // UniversalBody remoteBody = node.receiveBody(body);
00194                         // --------------------added lines---------------------------
00195                         ProActiveRuntime part = node.getProActiveRuntime();
00196                         UniversalBody remoteBody = part.receiveBody(node
00197                                         .getNodeInformation().getName(), body);
00198
00199                         if (logger.isDebugEnabled()) {
00200                                 logger.debug("runtime = " + part);
00201                                 logger.debug("remoteBody = " + remoteBody);
00202                         }
00203
00204                         // --------------------added lines--------------------------
00205                         // activityStopped();
00206                         //
00207                         long l2 = 0;
00208                         if (logger.isDebugEnabled()) {
00209                                 l2 = System.currentTimeMillis();
00210                                 logger.debug("Migration took " + (l2 - l1));
00211                         }
00212                         if (hasListeners()) {
00213                                 notifyAllListeners(new MigrationEvent(body,
00214                                                 MigrationEvent.AFTER_MIGRATION));
00215                         }
00216
00217                         // we are not on this site anymore,
00218                         // so there is no need to send this
00219                         // position to the server
00220                         if (maxTimeOnSiteTimer != null)
00221                                 maxTimeOnSiteTimer.cancel();
00222
00223                         return remoteBody;
00224                 //} catch (ProActiveException e) {
00225                 } catch (Exception e) {
00226                         MigrationException me = new MigrationException(
00227                                         "Exception while sending the Object", e.getCause());
00228                         if (hasListeners()) {
00229                                 notifyAllListeners(new MigrationEvent(me));
00230                         }
00231                         throw me;
00232                 }
00233         }
00234
00240         public void changeBodyAfterMigration(MigratableBody body,
00241                         UniversalBody migratedBody) {
00242                 if (this.ttl == 0) {
00243                         // we don't need forwarders so we don't create them
00244                         // the body is dead now
00245                         body.terminate();
00246                 } else {
00247                         body.setRequestReceiver(createRequestReceiver(migratedBody, body
00248                                         .getRequestReceiver()));
00249                         body.setReplyReceiver(createReplyReceiver(migratedBody, body
00250                                         .getReplyReceiver()));
00251
00252                         body.setHasMigrated();
00253
00254                         LocalBodyStore.getInstance().registerForwarder(body);
00255
00256                         // the migration has succeeded so
00257                         // we have to launch the TTL
00258                         // of the forwarder
00259                         launchTimeToLive(body, migratedBody);
00260                 }
00261
00262         }
00263
00264         public void startingAfterMigration(Body body) {
00265                 if (hasListeners()) {
00266                         notifyAllListeners(new MigrationEvent(body,
00267                                         MigrationEvent.RESTARTING_AFTER_MIGRATING));
00268                 }
00269
00270                 this.nbOfMigrationWithoutUpdate++;
00271                 this.migrationCounter++;
00272                 if (logger.isDebugEnabled()) {
00273                         logger.debug("XXX counter == " + this.nbOfMigrationWithoutUpdate);
00274                 }
00275
00276                 // TTU : maxMigrationNb
00277                 if (this.maxMigrationNb != INFINITE_MAX_MIGRATION_NB
00278                                 && this.nbOfMigrationWithoutUpdate >= this.maxMigrationNb) {
00279                         updateLocation(body);
00280                 }
00281
00282                 // TTU : maxTimeOnSite
00283                 else if (this.maxTimeOnSite != INFINITE_MAX_TIME_ON_SITE) {
00284                         maxTimeOnSiteTimer = new Timer();
00285                         maxTimeOnSiteTimer.schedule(new MaxTimeOnSiteTimerTask(this, body),
00286                                         maxTimeOnSite);
00287                 }
00288         }
00289
00290         public RequestReceiver createRequestReceiver(UniversalBody remoteBody,
00291                         RequestReceiver currentRequestReceiver) {
00292                 return new RequestReceiverForwarder(remoteBody);
00293         }
00294
00295         public ReplyReceiver createReplyReceiver(UniversalBody remoteBody,
00296                         ReplyReceiver currentReplyReceiver) {
00297                 return new ReplyReceiverForwarder(remoteBody);
00298         }
00299
00300         public void addMigrationEventListener(MigrationEventListener listener) {
00301                 addListener(listener);
00302         }
00303
00304         public void removeMigrationEventListener(MigrationEventListener listener) {
00305                 removeListener(listener);
00306         }
00307
00308         public void setMigrationStrategy(int ttl, boolean updatingForwarder, int maxMigrationNb, int maxTimeOnSite){
00309                 this.ttl = ttl;
00310                 this.updatingForwarder = updatingForwarder;
00311                 this.maxMigrationNb = maxMigrationNb;
00312                 this.maxTimeOnSite = maxTimeOnSite;
00313         }
00314
00315         //
00316         // -- PROTECTED METHODS -----------------------------------------------
00317         //
00318         protected void notifyOneListener(ProActiveListener listener,
00319                         ProActiveEvent event) {
00320                 MigrationEvent migrationEvent = (MigrationEvent) event;
00321                 MigrationEventListener migrationEventListener = (MigrationEventListener) listener;
00322                 switch (event.getType()) {
00323                 case MigrationEvent.BEFORE_MIGRATION:
00324                         migrationEventListener.migrationAboutToStart(migrationEvent);
00325                         break;
00326                 case MigrationEvent.AFTER_MIGRATION:
00327                         migrationEventListener.migrationFinished(migrationEvent);
00328                         break;
00329                 case MigrationEvent.MIGRATION_EXCEPTION:
00330                         migrationEventListener.migrationExceptionThrown(migrationEvent);
00331                         break;
00332                 case MigrationEvent.RESTARTING_AFTER_MIGRATING:
00333                         migrationEventListener.migratedBodyRestarted(migrationEvent);
00334                         break;
00335                 }
00336         }
00337
00338         // -- INNER CLASSES -----------------------------------------------
00339         //
00340
00341         protected class MaxTimeOnSiteTimerTask extends java.util.TimerTask {
00342                 protected MigrationManagerImpl migrationManager;
00343
00344                 protected Body body;
00345
00346                 public MaxTimeOnSiteTimerTask(MigrationManagerImpl migrationManager,
00347                                 Body body) {
00348                         this.migrationManager = migrationManager;
00349                         this.body = body;
00350
00351                 }
00352
00353                 public void run() {
00354                         this.body.enterInThreadStore(); // make sure that the body isn't
00355                         // trying to migrate
00356                         if ((this.body instanceof Migratable)
00357                                         && !((Migratable) this.body).hasJustMigrated()) {
00358                                 this.migrationManager.updateLocation(this.body);
00359                         }
00360                         this.body.exitFromThreadStore();
00361                 }
00362         }
00363
00364         protected class TimeToLiveTimerTask extends java.util.TimerTask {
00365                 protected MigrationManagerImpl migrationManager;
00366
00367                 protected MigratableBody body;
00368
00369                 protected UniversalBody migratedBody;
00370
00371                 private long creationTime;
00372
00373                 public TimeToLiveTimerTask(MigrationManagerImpl migrationManager,
00374                                 MigratableBody body, UniversalBody migratedBody) {
00375                         this.migrationManager = migrationManager;
00376                         this.body = body;
00377                         this.migratedBody = migratedBody;
00378                         this.creationTime = System.currentTimeMillis();
00379                 }
00380
00381                 public void run() {
00382
00383                         if (this.migrationManager.updatingForwarder)
00384                                 this.migrationManager.updateLocation(this.migratedBody.getRemoteAdapter());
00385                                 //this.migrationManager.updateRemoteLocation(this.migratedBody.getRemoteAdapter());
00386
00387                         LocalBodyStore.getInstance().unregisterForwarder(body);
00388
00389                         this.body.terminate();
00390                         body.setRequestReceiver(null);
00391                         body.setReplyReceiver(null);
00392
00393
00394
00395                 }
00396         }
00397 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
