00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.runtime;
00032
00033 import java.io.IOException;
00034 import java.util.ArrayList;
00035 import java.util.Properties;
00036
00037 import org.objectweb.proactive.Body;
00038 import org.objectweb.proactive.core.UniqueID;
00039 import org.objectweb.proactive.core.body.LocalBodyStore;
00040 import org.objectweb.proactive.core.util.log.Loggers;
00041 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00042 import org.objectweb.proactive.ext.security.ProActiveSecurityManager;
00043
00044
00050 public class LocalNode {
00051     private String name;
00052     private ArrayList<UniqueID> activeObjectsId;
00053     private String jobId;
00054     private ProActiveSecurityManager securityManager;
00055     private String virtualNodeName;
00056     private Properties localProperties;
00057
00058     public LocalNode(String nodeName, String jobId,
00059         ProActiveSecurityManager securityManager, String virtualNodeName) {
00060         this.name = nodeName;
00061         this.jobId = jobId;
00062         this.securityManager = securityManager;
00063         this.virtualNodeName = virtualNodeName;
00064         this.activeObjectsId = new ArrayList<UniqueID>();
00065         this.localProperties = new Properties();
00066
00067         if (this.securityManager != null) {
00068             ProActiveLogger.getLogger(Loggers.SECURITY_RUNTIME)
00069                            .debug("Local Node : " + this.name + " VN name : " +
00070                 this.virtualNodeName + " policyserver for app :" +
00071                 this.securityManager.getPolicyServer().getApplicationName());
00072
00073
00074             this.securityManager.setVNName(this.virtualNodeName);
00075
00076             ProActiveLogger.getLogger(Loggers.SECURITY_RUNTIME)
00077                            .debug("registering node certificate for VN " +
00078                 this.virtualNodeName);
00079         }
00080     }
00081
00085     public ArrayList<UniqueID> getActiveObjectsId() {
00086         return activeObjectsId;
00087     }
00088
00093     public void setActiveObjects(ArrayList<UniqueID> activeObjects) {
00094         this.activeObjectsId = activeObjects;
00095     }
00096
00100     public String getJobId() {
00101         return jobId;
00102     }
00103
00107     public void setJobId(String jobId) {
00108         this.jobId = jobId;
00109     }
00110
00114     public String getName() {
00115         return name;
00116     }
00117
00121     public void setName(String name) {
00122         this.name = name;
00123     }
00124
00128     public ProActiveSecurityManager getSecurityManager() {
00129         return securityManager;
00130     }
00131
00135     public void setSecurityManager(ProActiveSecurityManager securityManager) {
00136         this.securityManager = securityManager;
00137     }
00138
00143     public String getVirtualNodeName() {
00144         return virtualNodeName;
00145     }
00146
00150     public void setVirtualNodeName(String virtualNodeName) {
00151         this.virtualNodeName = virtualNodeName;
00152     }
00153
00154     public void terminateActiveObjects() {
00155     }
00156
00157     public ArrayList getActiveObjects() {
00158         ArrayList localBodies = new ArrayList();
00159         LocalBodyStore localBodystore = LocalBodyStore.getInstance();
00160
00161         if (activeObjectsId == null) {
00162
00163             return localBodies;
00164         }
00165
00166         synchronized (activeObjectsId) {
00167             for (int i = 0; i < activeObjectsId.size(); i++) {
00168                 UniqueID bodyID = (UniqueID) activeObjectsId.get(i);
00169
00170
00171                 Body body = localBodystore.getLocalBody(bodyID);
00172
00173                 if (body == null) {
00174
00175
00176
00177                     activeObjectsId.remove(bodyID);
00178                 } else {
00179
00180
00181                     ArrayList bodyAndObjectClass = new ArrayList(2);
00182
00183
00184                     bodyAndObjectClass.add(0, body.getRemoteAdapter());
00185
00186
00187                     bodyAndObjectClass.add(1,
00188                         body.getReifiedObject().getClass().getName());
00189                     localBodies.add(bodyAndObjectClass);
00190                 }
00191             }
00192         }
00193         return localBodies;
00194     }
00195
00200     public void unregisterBody(UniqueID bodyID) {
00201         activeObjectsId.remove(bodyID);
00202     }
00203
00209     public void registerBody(UniqueID bodyID) {
00210         activeObjectsId.add(bodyID);
00211     }
00212
00213     public void terminate() {
00214         ArrayList activeObjects = this.getActiveObjectsId();
00215
00216         for (int i = 0; i < activeObjects.size(); i++) {
00217             UniqueID bodyID = (UniqueID) activeObjects.get(i);
00218
00219
00220             Body body = LocalBodyStore.getInstance().getLocalBody(bodyID);
00221
00222             if (body != null) {
00223                 try {
00224                     ProActiveLogger.getLogger(Loggers.NODE)
00225                                    .info("node " + this.name +
00226                         " is being killed, terminating body " + bodyID);
00227                     body.terminate();
00228                 } catch (IOException e) {
00229                     e.printStackTrace();
00230                 }
00231             }
00232         }
00233     }
00234
00242     public Object setProperty(String key, String value) {
00243         return this.localProperties.setProperty(key, value);
00244     }
00245
00252     public String getProperty(String key) {
00253         return this.localProperties.getProperty(key);
00254     }
00255 }
