00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.body; 00032 00033 import org.apache.log4j.Logger; 00034 import org.objectweb.proactive.Body; 00035 import org.objectweb.proactive.core.UniqueID; 00036 import org.objectweb.proactive.core.event.BodyEventListener; 00037 import org.objectweb.proactive.core.event.BodyEventProducerImpl; 00038 import org.objectweb.proactive.core.util.log.Loggers; 00039 import org.objectweb.proactive.core.util.log.ProActiveLogger; 00040 00041 00056 public class LocalBodyStore { 00057 // 00058 // -- STATIC MEMBERS ----------------------------------------------- 00059 // 00060 static Logger logger = ProActiveLogger.getLogger(Loggers.BODY); 00061 private static LocalBodyStore instance = new LocalBodyStore(); 00062 00063 // 00064 // -- PRIVATE MEMBERS ----------------------------------------------- 00065 // 00066 00072 private BodyMap localBodyMap = new BodyMap(); 00073 00079 private BodyMap localHalfBodyMap = new BodyMap(); 00080 00089 private BodyMap localForwarderMap = new BodyMap(); 00090 00095 private BodyEventProducerImpl bodyEventProducer = new BodyEventProducerImpl(); 00096 private ThreadLocal<Body> bodyPerThread = new ThreadLocal<Body>(); 00097 private MetaObjectFactory halfBodyMetaObjectFactory = null; 00098 00100 private boolean exitOnEmpty = false; 00101 00102 // 00103 // -- CONSTRUCTORS ----------------------------------------------- 00104 // 00105 00110 private LocalBodyStore() { 00111 } 00112 00113 // 00114 // -- STATIC METHODS ----------------------------------------------- 00115 // 00116 public static LocalBodyStore getInstance() { 00117 return instance; 00118 } 00119 00120 // 00121 // -- PUBLIC METHODS ----------------------------------------------- 00122 // 00123 public synchronized MetaObjectFactory getHalfBodyMetaObjectFactory() { 00124 if (this.halfBodyMetaObjectFactory == null) { 00125 halfBodyMetaObjectFactory = ProActiveMetaObjectFactory.newInstance(); 00126 } 00127 return halfBodyMetaObjectFactory; 00128 } 00129 00130 public synchronized void setHalfBodyMetaObjectFactory( 00131 MetaObjectFactory factory) { 00132 halfBodyMetaObjectFactory = factory; 00133 } 00134 00140 public Body getCurrentThreadBody() { 00141 AbstractBody body = (AbstractBody) bodyPerThread.get(); 00142 if (body == null) { 00143 // If we cannot find the body from the current thread we assume that the current thread 00144 // is not the one from an active object. Therefore in this case we create an HalfBody 00145 // that handle the futures 00146 body = HalfBody.getHalfBody(this.getHalfBodyMetaObjectFactory()); 00147 bodyPerThread.set(body); 00148 registerHalfBody(body); 00149 } 00150 00151 return body; 00152 } 00153 00158 public void setCurrentThreadBody(Body body) { 00159 bodyPerThread.set(body); 00160 } 00161 00168 public Body getLocalBody(UniqueID bodyID) { 00169 return (Body) localBodyMap.getBody(bodyID); 00170 } 00171 00178 public Body getLocalHalfBody(UniqueID bodyID) { 00179 return (Body) localHalfBodyMap.getBody(bodyID); 00180 } 00181 00188 public Body getForwarder(UniqueID bodyID) { 00189 return (Body) localForwarderMap.getBody(bodyID); 00190 } 00191 00196 public BodyMap getLocalBodies() { 00197 return (BodyMap) localBodyMap.clone(); 00198 } 00199 00204 public BodyMap getLocalHalfBodies() { 00205 return (BodyMap) localHalfBodyMap.clone(); 00206 } 00207 00213 public void addBodyEventListener(BodyEventListener listener) { 00214 bodyEventProducer.addBodyEventListener(listener); 00215 } 00216 00221 public void removeBodyEventListener(BodyEventListener listener) { 00222 bodyEventProducer.removeBodyEventListener(listener); 00223 } 00224 00225 private void checkExitOnEmpty() { 00226 if (this.exitOnEmpty && this.localBodyMap.size() == 0) { 00227 System.exit(0); 00228 } 00229 } 00230 00236 public void enableExitOnEmpty() { 00237 this.exitOnEmpty = true; 00238 checkExitOnEmpty(); 00239 } 00240 00241 // 00242 // -- FRIENDLY METHODS ----------------------------------------------- 00243 // 00244 void registerBody(AbstractBody body) { 00245 if (localBodyMap.getBody(body.getID()) != null) { 00246 logger.warn("Body already registered in the body map"); 00247 } 00248 localBodyMap.putBody(body.bodyID, body); 00249 bodyEventProducer.fireBodyCreated(body); 00250 } 00251 00252 void unregisterBody(AbstractBody body) { 00253 localBodyMap.removeBody(body.bodyID); 00254 bodyEventProducer.fireBodyRemoved(body); 00255 checkExitOnEmpty(); 00256 } 00257 00258 void registerHalfBody(AbstractBody body) { 00259 localHalfBodyMap.putBody(body.bodyID, body); 00260 00261 //bodyEventProducer.fireBodyCreated(body); 00262 } 00263 00264 void unregisterHalfBody(AbstractBody body) { 00265 localHalfBodyMap.removeBody(body.bodyID); 00266 //bodyEventProducer.fireBodyRemoved(body); 00267 } 00268 00269 public void registerForwarder(AbstractBody body) { 00270 if (localForwarderMap.getBody(body.bodyID) != null) { 00271 logger.debug("Forwarder already registered in the body map"); 00272 localForwarderMap.removeBody(body.bodyID); 00273 } 00274 localForwarderMap.putBody(body.bodyID, body); 00275 } 00276 00277 public void unregisterForwarder(AbstractBody body) { 00278 localForwarderMap.removeBody(body.bodyID); 00279 } 00280 }
1.5.1
