org/objectweb/proactive/core/body/http/util/messages/HttpReply.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.http.util.messages;
00032
00033 import java.io.IOException;
00034 import java.io.Serializable;
00035
00036 import org.objectweb.proactive.Body;
00037 import org.objectweb.proactive.core.UniqueID;
00038 import org.objectweb.proactive.core.body.http.util.HttpMessage;
00039 import org.objectweb.proactive.core.body.http.util.HttpUtils;
00040 import org.objectweb.proactive.core.body.reply.Reply;
00041
00042
00048 public class HttpReply extends HttpMessage implements Serializable {
00049     private Reply reply;
00050     private UniqueID idBody;
00051
00057     public HttpReply(Reply reply, UniqueID idBody, String url) {
00058         super(url);
00059         this.reply = reply;
00060         this.idBody = idBody;
00061     }
00062
00063     public int getReturnedObject() {
00064         if (this.returnedObject != null) {
00065             return ((Integer) this.returnedObject).intValue();
00066         }
00067         return 0; // or throws an exception ...
00068     }
00069
00070     public Object processMessage() {
00071         try {
00072             Body body = HttpUtils.getBody(idBody);
00073             if (this.reply != null) {
00074                 return new Integer(body.receiveReply(this.reply));
00075             }
00076         } catch (IOException e) {
00077             e.printStackTrace();
00078         }
00079
00080         return null;
00081     }
00082 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
