00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.runtime.http;
00032
00033 import java.io.IOException;
00034 import java.lang.reflect.InvocationTargetException;
00035 import java.net.MalformedURLException;
00036 import java.net.URL;
00037 import java.net.UnknownHostException;
00038 import java.rmi.AlreadyBoundException;
00039 import java.security.PublicKey;
00040 import java.security.cert.X509Certificate;
00041 import java.util.ArrayList;
00042
00043 import org.objectweb.proactive.Body;
00044 import org.objectweb.proactive.core.ProActiveException;
00045 import org.objectweb.proactive.core.body.UniversalBody;
00046 import org.objectweb.proactive.core.body.ft.checkpointing.Checkpoint;
00047 import org.objectweb.proactive.core.body.http.util.exceptions.HTTPRemoteException;
00048 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00049 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00050 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00051 import org.objectweb.proactive.core.mop.ConstructorCall;
00052 import org.objectweb.proactive.core.mop.ConstructorCallExecutionFailedException;
00053 import org.objectweb.proactive.core.node.NodeException;
00054 import org.objectweb.proactive.core.process.ExternalProcess;
00055 import org.objectweb.proactive.core.process.UniversalProcess;
00056 import org.objectweb.proactive.core.rmi.ClassServer;
00057 import org.objectweb.proactive.core.rmi.ClassServerServlet;
00058 import org.objectweb.proactive.core.runtime.ProActiveRuntime;
00059 import org.objectweb.proactive.core.runtime.ProActiveRuntimeImpl;
00060 import org.objectweb.proactive.core.runtime.RemoteProActiveRuntime;
00061 import org.objectweb.proactive.core.runtime.VMInformation;
00062 import org.objectweb.proactive.core.runtime.http.messages.RuntimeRequest;
00063 import org.objectweb.proactive.core.util.UrlBuilder;
00064 import org.objectweb.proactive.ext.security.Communication;
00065 import org.objectweb.proactive.ext.security.ProActiveSecurityManager;
00066 import org.objectweb.proactive.ext.security.SecurityContext;
00067 import org.objectweb.proactive.ext.security.crypto.KeyExchangeException;
00068 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00069 import org.objectweb.proactive.ext.security.exceptions.SecurityNotAvailableException;
00070 import org.objectweb.proactive.ext.security.securityentity.Entity;
00071
00072
00081 public class HttpProActiveRuntime implements RemoteProActiveRuntime {
00082 private transient ProActiveRuntime localruntime;
00083 private boolean isLocal;
00084 private String url;
00085 protected VMInformation vmInformation;
00086
00087
00088
00089
00090 protected boolean alreadykilled = false;
00091
00092 public HttpProActiveRuntime() {
00093 isLocal = true;
00094 this.localruntime = ProActiveRuntimeImpl.getProActiveRuntime();
00095
00096 if (ProActiveConfiguration.osgiServletEnabled()) {
00097 this.url = ClassServerServlet.getUrl();
00098 } else {
00099 this.url = ClassServer.getUrl();
00100 }
00101
00102
00103
00104 this.vmInformation = localruntime.getVMInformation();
00105 }
00106
00110 public HttpProActiveRuntime(String newurl) {
00111 runtimeLogger.debug("Adapter URL = " + newurl);
00112
00113 try {
00114 this.url = UrlBuilder.checkUrl(newurl);
00115 isLocal = false;
00116 runtimeLogger.debug("New Remote XML Adapter : " + url);
00117 } catch (UnknownHostException e) {
00118
00119 e.printStackTrace();
00120 }
00121 }
00122
00123
00124
00125
00126 public ExternalProcess getProcessToDeploy(
00127 ProActiveRuntime proActiveRuntimeDist, String creatorID, String vmName,
00128 String padURL) throws ProActiveException {
00129 ArrayList<Object> params = new ArrayList<Object>();
00130 params.add(proActiveRuntimeDist);
00131 params.add(creatorID);
00132 params.add(vmName);
00133 params.add(padURL);
00134
00135 try {
00136 new RuntimeRequest("getProcessToDeploy", params, this.url).send();
00137 } catch (Exception e) {
00138 e.printStackTrace();
00139 }
00140
00141 return null;
00142 }
00143
00144 public String createLocalNode(String nodeName,
00145 boolean replacePreviousBinding,
00146 ProActiveSecurityManager securityManager, String vname, String jobId)
00147 throws NodeException, HTTPRemoteException, AlreadyBoundException {
00148 String nodeURL = null;
00149 try {
00150 nodeURL = buildNodeURL(nodeName);
00151 } catch (UnknownHostException e1) {
00152 e1.printStackTrace();
00153 }
00154
00155
00156 String name = UrlBuilder.getNameFromUrl(nodeURL);
00157 if (isLocal) {
00158 localruntime.createLocalNode(name, replacePreviousBinding,
00159 securityManager, vname, jobId);
00160 } else {
00161 ArrayList<Object> paramsList = new ArrayList<Object>();
00162 paramsList.add(name);
00163 paramsList.add(new Boolean(replacePreviousBinding));
00164 paramsList.add(securityManager);
00165 paramsList.add(vname);
00166 paramsList.add(jobId);
00167
00168 RuntimeRequest req = new RuntimeRequest("createLocalNode",
00169 paramsList, this.url);
00170 req.send();
00171 }
00172
00173 runtimeLogger.info(nodeURL + " successfully registered ");
00174
00175 return nodeURL;
00176 }
00177
00178 public void killAllNodes() throws HTTPRemoteException, ProActiveException {
00179 if (isLocal) {
00180 localruntime.killAllNodes();
00181
00182 return;
00183 }
00184
00185 new RuntimeRequest("killAllNodes", this.url).send();
00186 }
00187
00188 public void killNode(String nodeName)
00189 throws ProActiveException, HTTPRemoteException {
00190 String name = UrlBuilder.getNameFromUrl(nodeName);
00191
00192 if (isLocal) {
00193 localruntime.killNode(name);
00194
00195 return;
00196 }
00197
00198 ArrayList<Object> params = new ArrayList<Object>();
00199 params.add(name);
00200 new RuntimeRequest("killNode", params, this.url).send();
00201 }
00202
00203 public void createVM(UniversalProcess remoteProcess)
00204 throws IOException, ProActiveException {
00205 if (isLocal) {
00206 localruntime.createVM(remoteProcess);
00207
00208 return;
00209 }
00210
00211 ArrayList<Object> params = new ArrayList<Object>();
00212 params.add(remoteProcess);
00213 new RuntimeRequest("createVM", params, this.url).send();
00214 }
00215
00216 public String[] getLocalNodeNames()
00217 throws ProActiveException, HTTPRemoteException {
00218 if (isLocal) {
00219 return localruntime.getLocalNodeNames();
00220 }
00221
00222 RuntimeRequest req = new RuntimeRequest("getLocalNodeNames", this.url);
00223 req.send();
00224
00225 try {
00226 return (String[]) req.getReturnedObject();
00227 } catch (Exception e) {
00228 throw new ProActiveException(e);
00229 }
00230 }
00231
00232 public VMInformation getVMInformation() throws HTTPRemoteException {
00233 if (this.vmInformation == null) {
00234 if (isLocal) {
00235 this.vmInformation = localruntime.getVMInformation();
00236 }
00237
00238 RuntimeRequest req = new RuntimeRequest("getVMInformation", this.url);
00239 req.send();
00240
00241 try {
00242 this.vmInformation = (VMInformation) req.getReturnedObject();
00243 } catch (Exception e) {
00244 e.printStackTrace();
00245 }
00246 }
00247
00248 return this.vmInformation;
00249 }
00250
00251 public void register(ProActiveRuntime proActiveRuntimeDist,
00252 String proActiveRuntimeName, String creatorID, String creationProtocol,
00253 String vmName) throws ProActiveException, HTTPRemoteException {
00254 if (isLocal) {
00255 localruntime.register(proActiveRuntimeDist, proActiveRuntimeName,
00256 creatorID, creationProtocol, vmName);
00257
00258 return;
00259 }
00260
00261 ArrayList<Object> params = new ArrayList<Object>();
00262 ArrayList<Class> paramsTypes = new ArrayList<Class>();
00263
00264 params.add(proActiveRuntimeDist);
00265 paramsTypes.add(ProActiveRuntime.class);
00266 params.add(proActiveRuntimeName);
00267 paramsTypes.add(String.class);
00268 params.add(creatorID);
00269 paramsTypes.add(String.class);
00270 params.add(creationProtocol);
00271 paramsTypes.add(String.class);
00272 params.add(vmName);
00273 paramsTypes.add(String.class);
00274
00275 new RuntimeRequest("register", params, paramsTypes, this.url).send();
00276 }
00277
00283 public void unregister(ProActiveRuntime proActiveRuntimeDist,
00284 String proActiveRuntimeUrl, String creatorID, String creationProtocol,
00285 String vmName) throws ProActiveException, HTTPRemoteException {
00286 if (isLocal) {
00287 localruntime.unregister(proActiveRuntimeDist, proActiveRuntimeUrl,
00288 creatorID, creationProtocol, vmName);
00289
00290 return;
00291 }
00292
00293 ArrayList<Object> params = new ArrayList<Object>();
00294 ArrayList<Class> paramsTypes = new ArrayList<Class>();
00295
00296 params.add(proActiveRuntimeDist);
00297 paramsTypes.add(ProActiveRuntime.class);
00298 params.add(proActiveRuntimeUrl);
00299 paramsTypes.add(String.class);
00300 params.add(creatorID);
00301 paramsTypes.add(String.class);
00302 params.add(creationProtocol);
00303 paramsTypes.add(String.class);
00304 params.add(vmName);
00305 paramsTypes.add(String.class);
00306
00307 new RuntimeRequest("unregister", params, paramsTypes, this.url).send();
00308 }
00309
00310 public ProActiveRuntime[] getProActiveRuntimes()
00311 throws ProActiveException, HTTPRemoteException {
00312 RuntimeRequest req = new RuntimeRequest("getProActiveRuntimes", this.url);
00313
00314 if (isLocal) {
00315 return localruntime.getProActiveRuntimes();
00316 }
00317
00318 req.send();
00319
00320 try {
00321 return (ProActiveRuntime[]) req.getReturnedObject();
00322 } catch (Exception e) {
00323 throw new ProActiveException(e);
00324 }
00325 }
00326
00327 public ProActiveRuntime getProActiveRuntime(String proActiveRuntimeName)
00328 throws ProActiveException, HTTPRemoteException {
00329 if (isLocal) {
00330 return localruntime.getProActiveRuntime(proActiveRuntimeName);
00331 }
00332
00333 ArrayList<Object> params = new ArrayList<Object>();
00334 params.add(proActiveRuntimeName);
00335
00336 RuntimeRequest req = new RuntimeRequest("getProActiveRuntime", params,
00337 this.url);
00338 req.send();
00339
00340 try {
00341 return (ProActiveRuntime) req.getReturnedObject();
00342 } catch (Exception e) {
00343 throw new ProActiveException(e);
00344 }
00345 }
00346
00347 public void killRT(boolean softly) throws Exception {
00348 if (!alreadykilled) {
00349 if (isLocal) {
00350 localruntime.killRT(softly);
00351 } else {
00352 ArrayList<Object> params = new ArrayList<Object>();
00353 params.add(new Boolean(softly));
00354
00355 new RuntimeRequest("killRT", params, this.url).send();
00356 }
00357 }
00358
00359 alreadykilled = true;
00360 }
00361
00362 public String getURL() throws ProActiveException {
00363 return this.url;
00364 }
00365
00366 public ArrayList getActiveObjects(String nodeName)
00367 throws ProActiveException, HTTPRemoteException {
00368 if (isLocal) {
00369 return localruntime.getActiveObjects(nodeName);
00370 }
00371
00372 ArrayList<Object> params = new ArrayList<Object>();
00373 params.add(nodeName);
00374
00375 RuntimeRequest req = new RuntimeRequest("getActiveObjects", params,
00376 this.url);
00377 req.send();
00378
00379 try {
00380 return (ArrayList) req.getReturnedObject();
00381 } catch (Exception e) {
00382 throw new ProActiveException(e);
00383 }
00384 }
00385
00386 public ArrayList getActiveObjects(String nodeName, String objectName)
00387 throws ProActiveException, HTTPRemoteException {
00388 if (isLocal) {
00389 return localruntime.getActiveObjects(nodeName, objectName);
00390 }
00391
00392 ArrayList<Object> params = new ArrayList<Object>();
00393 params.add(nodeName);
00394 params.add(objectName);
00395
00396 RuntimeRequest req = new RuntimeRequest("getActiveObjects", params,
00397 this.url);
00398 req.send();
00399
00400 try {
00401 return (ArrayList) req.getReturnedObject();
00402 } catch (Exception e) {
00403 throw new ProActiveException(e);
00404 }
00405 }
00406
00407 public VirtualNode getVirtualNode(String virtualNodeName)
00408 throws ProActiveException, HTTPRemoteException {
00409 if (isLocal) {
00410 return localruntime.getVirtualNode(virtualNodeName);
00411 }
00412
00413 ArrayList<Object> params = new ArrayList<Object>();
00414 params.add(virtualNodeName);
00415
00416 RuntimeRequest req = new RuntimeRequest("getVirtualNode", params,
00417 this.url);
00418 req.send();
00419
00420 try {
00421 return (VirtualNode) req.getReturnedObject();
00422 } catch (Exception e) {
00423 throw new ProActiveException(e);
00424 }
00425 }
00426
00427 public void registerVirtualNode(String virtualNodeName,
00428 boolean replacePreviousBinding)
00429 throws ProActiveException, HTTPRemoteException {
00430
00431
00432
00433 String vn_url;
00434
00435 try {
00436 vn_url = buildNodeURL(virtualNodeName);
00437 } catch (UnknownHostException e) {
00438 throw new ProActiveException(e);
00439 }
00440
00441 runtimeLogger.info(virtualNodeName + " successfully registered at " +
00442 vn_url);
00443 }
00444
00445 public void unregisterVirtualNode(String virtualNodeName)
00446 throws ProActiveException, HTTPRemoteException {
00447 if (isLocal) {
00448 localruntime.unregisterVirtualNode(virtualNodeName);
00449
00450 return;
00451 }
00452
00453 ArrayList<Object> params = new ArrayList<Object>();
00454 params.add(virtualNodeName);
00455
00456 new RuntimeRequest("unregisterVirtualNode", params, this.url).send();
00457 }
00458
00459 public void unregisterAllVirtualNodes() throws ProActiveException {
00460 if (isLocal) {
00461 localruntime.unregisterAllVirtualNodes();
00462
00463 return;
00464 }
00465
00466 try {
00467 new RuntimeRequest("unregisterAllVirtualNodes", this.url).send();
00468 } catch (HTTPRemoteException e) {
00469
00470 e.printStackTrace();
00471 }
00472 }
00473
00474 public UniversalBody createBody(String nodeName,
00475 ConstructorCall bodyConstructorCall, boolean isNodeLocal)
00476 throws ProActiveException, ConstructorCallExecutionFailedException,
00477 InvocationTargetException, HTTPRemoteException {
00478 if (isLocal) {
00479 return localruntime.createBody(nodeName, bodyConstructorCall,
00480 isNodeLocal);
00481 }
00482
00483 ArrayList<Object> params = new ArrayList<Object>();
00484 params.add(nodeName);
00485 params.add(bodyConstructorCall);
00486 params.add(new Boolean(isNodeLocal));
00487
00488 RuntimeRequest req = new RuntimeRequest("createBody", params, this.url);
00489 req.send();
00490
00491 try {
00492 return (UniversalBody) req.getReturnedObject();
00493 } catch (ConstructorCallExecutionFailedException e) {
00494 throw e;
00495 } catch (InvocationTargetException e) {
00496 throw e;
00497 } catch (Exception e) {
00498 throw new ProActiveException(e);
00499 }
00500 }
00501
00502 public UniversalBody receiveBody(String nodeName, Body body)
00503 throws ProActiveException, HTTPRemoteException {
00504 if (isLocal) {
00505 return localruntime.receiveBody(nodeName, body);
00506 }
00507
00508 ArrayList<Object> params = new ArrayList<Object>();
00509 params.add(nodeName);
00510 params.add(body);
00511
00512 RuntimeRequest req = new RuntimeRequest("receiveBody", params, this.url);
00513 req.send();
00514
00515 try {
00516 return (UniversalBody) req.getReturnedObject();
00517 } catch (Exception e) {
00518 throw new ProActiveException(e);
00519 }
00520 }
00521
00526 public String getJobID(String nodeUrl)
00527 throws ProActiveException, HTTPRemoteException {
00528 if (isLocal) {
00529 return localruntime.getJobID(nodeUrl);
00530 }
00531
00532 ArrayList<Object> params = new ArrayList<Object>();
00533 params.add(nodeUrl);
00534
00535 RuntimeRequest req = new RuntimeRequest("getJobID", params, this.url);
00536 req.send();
00537
00538 try {
00539 return (String) req.getReturnedObject();
00540 } catch (Exception e) {
00541 throw new ProActiveException(e);
00542 }
00543 }
00544
00545 public void addAcquaintance(String proActiveRuntimeName)
00546 throws ProActiveException, HTTPRemoteException {
00547 if (isLocal) {
00548 localruntime.addAcquaintance(proActiveRuntimeName);
00549
00550 return;
00551 }
00552
00553 ArrayList<Object> params = new ArrayList<Object>();
00554 params.add(proActiveRuntimeName);
00555
00556 new RuntimeRequest("addAcquaintance", params, this.url).send();
00557 }
00558
00559 public String[] getAcquaintances()
00560 throws ProActiveException, HTTPRemoteException {
00561 if (isLocal) {
00562 return localruntime.getAcquaintances();
00563 }
00564
00565 RuntimeRequest req = new RuntimeRequest("getAcquaintances", this.url);
00566 req.send();
00567
00568 try {
00569 return (String[]) req.getReturnedObject();
00570 } catch (Exception e) {
00571 throw new ProActiveException(e);
00572 }
00573 }
00574
00580 public void rmAcquaintance(String proActiveRuntimeName)
00581 throws ProActiveException, HTTPRemoteException {
00582 if (isLocal) {
00583 localruntime.rmAcquaintance(proActiveRuntimeName);
00584
00585 return;
00586 }
00587
00588 ArrayList<Object> params = new ArrayList<Object>();
00589 params.add(proActiveRuntimeName);
00590
00591 new RuntimeRequest("rmAcquaintance", params, this.url).send();
00592 }
00593
00594 public byte[] getClassDataFromParentRuntime(String className)
00595 throws ProActiveException, HTTPRemoteException {
00596 if (isLocal) {
00597 return localruntime.getClassDataFromParentRuntime(className);
00598 }
00599
00600 ArrayList<Object> params = new ArrayList<Object>();
00601 params.add(className);
00602
00603 RuntimeRequest req = new RuntimeRequest("getClassDataFromParentRuntime",
00604 params, this.url);
00605 req.send();
00606
00607 try {
00608 return (byte[]) req.getReturnedObject();
00609 } catch (Exception e) {
00610 throw new ProActiveException(e);
00611 }
00612 }
00613
00614 public byte[] getClassDataFromThisRuntime(String className)
00615 throws ProActiveException, HTTPRemoteException {
00616 if (isLocal) {
00617 return localruntime.getClassDataFromThisRuntime(className);
00618 }
00619
00620 ArrayList<Object> params = new ArrayList<Object>();
00621 params.add(className);
00622
00623 RuntimeRequest req = new RuntimeRequest("getClassDataFromThisRuntime",
00624 params, this.url);
00625 req.send();
00626
00627 try {
00628 return (byte[]) req.getReturnedObject();
00629 } catch (Exception e) {
00630 e.printStackTrace();
00631
00632 return null;
00633 }
00634 }
00635
00636
00637
00638
00639 public UniversalBody receiveCheckpoint(String nodeURL, Checkpoint ckpt,
00640 int inc) throws ProActiveException, HTTPRemoteException {
00641 if (isLocal) {
00642 return localruntime.receiveCheckpoint(nodeURL, ckpt, inc);
00643 }
00644
00645 ArrayList<Object> params = new ArrayList<Object>();
00646 params.add(nodeURL);
00647 params.add(ckpt);
00648 params.add(new Integer(inc));
00649
00650 RuntimeRequest req = new RuntimeRequest("receiveCheckpoint", params,
00651 this.url);
00652 req.send();
00653
00654 try {
00655 return (UniversalBody) req.getReturnedObject();
00656 } catch (Exception e) {
00657 throw new ProActiveException(e);
00658 }
00659 }
00660
00661 public ProActiveDescriptor getDescriptor(String url,
00662 boolean isHierarchicalSearch) throws IOException, ProActiveException {
00663 if (isLocal) {
00664 return localruntime.getDescriptor(url, isHierarchicalSearch);
00665 }
00666
00667 ArrayList<Object> params = new ArrayList<Object>();
00668 params.add(url);
00669 params.add(new Boolean(isHierarchicalSearch));
00670
00671 RuntimeRequest req = new RuntimeRequest("getDescriptor", params,
00672 this.url);
00673 req.send();
00674
00675 try {
00676 return (ProActiveDescriptor) req.getReturnedObject();
00677 } catch (Exception e) {
00678 throw new ProActiveException(e);
00679 }
00680 }
00681
00682 public void launchMain(String className, String[] parameters)
00683 throws IOException, ClassNotFoundException, NoSuchMethodException,
00684 ProActiveException {
00685 if (isLocal) {
00686 localruntime.launchMain(className, parameters);
00687
00688 return;
00689 }
00690
00691 ArrayList<Object> params = new ArrayList<Object>();
00692 params.add(className);
00693 params.add(parameters);
00694
00695 RuntimeRequest req = new RuntimeRequest("launchMain", params, this.url);
00696 req.send();
00697 }
00698
00699 public void newRemote(String className)
00700 throws IOException, ClassNotFoundException, ProActiveException {
00701 if (isLocal) {
00702 localruntime.newRemote(className);
00703
00704 return;
00705 }
00706
00707 ArrayList<Object> params = new ArrayList<Object>();
00708 params.add(className);
00709
00710 RuntimeRequest req = new RuntimeRequest("newRemote", params, this.url);
00711 req.send();
00712 }
00713
00714 protected String buildNodeURL(String url)
00715 throws java.net.UnknownHostException {
00716 int i = url.indexOf('/');
00717
00718 if (i != -1) {
00719 URL u_ = null;
00720 int port = 0;
00721 try {
00722 u_ = new URL(url);
00723 port = u_.getPort();
00724 if ((port == 0) || (port == -1)) {
00725 port = ClassServer.getServerSocketPort();
00726 url = u_.getProtocol() + "://" + u_.getHost() + ":" + port +
00727 u_.getPath();
00728 }
00729 } catch (MalformedURLException e) {
00730 }
00731 } else {
00732 String host = null;
00733 try {
00734 host = UrlBuilder.getHostNameorIP(getVMInformation()
00735 .getInetAddress());
00736 } catch (HTTPRemoteException e) {
00737 e.printStackTrace();
00738 }
00739
00740 url = "http://" + host + ":" + ClassServer.getServerSocketPort() +
00741 "/" + url;
00742
00743
00744
00745
00746
00747
00748
00749
00750
00751 }
00752
00753
00754
00755
00756
00757
00758
00759
00760
00761
00762
00763 url = UrlBuilder.checkUrl(url);
00764 return url;
00765 }
00766
00767 private void readObject(java.io.ObjectInputStream in)
00768 throws IOException, ClassNotFoundException {
00769 in.defaultReadObject();
00770 this.isLocal = false;
00771 }
00772
00773 public String getVNName(String nodename)
00774 throws ProActiveException, HTTPRemoteException {
00775 if (isLocal) {
00776 return localruntime.getVNName(nodename);
00777 }
00778
00779 ArrayList<Object> params = new ArrayList<Object>();
00780 params.add(nodename);
00781
00782 RuntimeRequest req = new RuntimeRequest("getVNName", params, this.url);
00783 req.send();
00784
00785 try {
00786 return (String) req.getReturnedObject();
00787 } catch (Exception e) {
00788 throw new ProActiveException(e);
00789 }
00790 }
00791
00792 public X509Certificate getCertificate()
00793 throws SecurityNotAvailableException, IOException {
00794 if (isLocal) {
00795 return localruntime.getCertificate();
00796 }
00797
00798 ArrayList<Object> params = new ArrayList<Object>();
00799
00800 RuntimeRequest req = new RuntimeRequest("getCertificate", params,
00801 this.url);
00802 req.send();
00803
00804 try {
00805 return (X509Certificate) req.getReturnedObject();
00806 } catch (SecurityException e) {
00807 throw e;
00808 } catch (IOException e) {
00809 throw e;
00810 } catch (Exception e) {
00811 e.printStackTrace();
00812
00813 return null;
00814 }
00815 }
00816
00817 public long startNewSession(Communication policy)
00818 throws SecurityNotAvailableException, RenegotiateSessionException,
00819 IOException {
00820 if (isLocal) {
00821 return localruntime.startNewSession(policy);
00822 }
00823
00824 ArrayList<Object> params = new ArrayList<Object>();
00825 params.add(policy);
00826
00827 RuntimeRequest req = new RuntimeRequest("startNewSession", params,
00828 this.url);
00829
00830 req.send();
00831
00832 try {
00833 return ((Long) req.getReturnedObject()).longValue();
00834 } catch (SecurityException e) {
00835 throw e;
00836 } catch (IOException e) {
00837 throw e;
00838 } catch (Exception e) {
00839 e.printStackTrace();
00840
00841 return 0;
00842 }
00843 }
00844
00845 public PublicKey getPublicKey()
00846 throws SecurityNotAvailableException, IOException {
00847 if (isLocal) {
00848 return localruntime.getPublicKey();
00849 }
00850
00851 ArrayList<Object> params = new ArrayList<Object>();
00852
00853 RuntimeRequest req = new RuntimeRequest("getPublicKey", params, this.url);
00854
00855 req.send();
00856
00857 try {
00858 return (PublicKey) req.getReturnedObject();
00859 } catch (SecurityException e) {
00860 throw e;
00861 } catch (IOException e) {
00862 throw e;
00863 } catch (Exception e) {
00864 e.printStackTrace();
00865
00866 return null;
00867 }
00868 }
00869
00870 public byte[] randomValue(long sessionID, byte[] clientRandomValue)
00871 throws SecurityNotAvailableException, RenegotiateSessionException,
00872 IOException {
00873 if (isLocal) {
00874 return localruntime.randomValue(sessionID, clientRandomValue);
00875 }
00876
00877 ArrayList<Object> params = new ArrayList<Object>();
00878 params.add(new Long(sessionID));
00879 params.add(clientRandomValue);
00880
00881 RuntimeRequest req = new RuntimeRequest("randomValue", params, this.url);
00882
00883 req.send();
00884
00885 try {
00886 return (byte[]) req.getReturnedObject();
00887 } catch (SecurityException e) {
00888 throw e;
00889 } catch (IOException e) {
00890 throw e;
00891 } catch (Exception e) {
00892 e.printStackTrace();
00893
00894 return null;
00895 }
00896 }
00897
00898 public byte[][] publicKeyExchange(long sessionID, byte[] myPublicKey,
00899 byte[] myCertificate, byte[] signature)
00900 throws SecurityNotAvailableException, RenegotiateSessionException,
00901 KeyExchangeException, IOException {
00902 if (isLocal) {
00903 return localruntime.publicKeyExchange(sessionID, myPublicKey,
00904 myCertificate, signature);
00905 }
00906
00907 ArrayList<Object> params = new ArrayList<Object>();
00908 params.add(new Long(sessionID));
00909 params.add(myPublicKey);
00910 params.add(myCertificate);
00911 params.add(signature);
00912
00913 RuntimeRequest req = new RuntimeRequest("publicKeyExchange", params,
00914 this.url);
00915
00916 req.send();
00917
00918 try {
00919 return (byte[][]) req.getReturnedObject();
00920 } catch (SecurityException e) {
00921 throw e;
00922 } catch (IOException e) {
00923 throw e;
00924 } catch (Exception e) {
00925 e.printStackTrace();
00926
00927 return null;
00928 }
00929 }
00930
00931 public byte[][] secretKeyExchange(long sessionID, byte[] encodedAESKey,
00932 byte[] encodedIVParameters, byte[] encodedClientMacKey,
00933 byte[] encodedLockData, byte[] parametersSignature)
00934 throws SecurityNotAvailableException, RenegotiateSessionException,
00935 IOException {
00936 if (isLocal) {
00937 return localruntime.secretKeyExchange(sessionID, encodedAESKey,
00938 encodedIVParameters, encodedClientMacKey, encodedLockData,
00939 parametersSignature);
00940 }
00941
00942 ArrayList<Object> params = new ArrayList<Object>();
00943 params.add(new Long(sessionID));
00944 params.add(encodedAESKey);
00945 params.add(encodedIVParameters);
00946 params.add(encodedClientMacKey);
00947 params.add(encodedLockData);
00948 params.add(parametersSignature);
00949
00950 RuntimeRequest req = new RuntimeRequest("secretKeyExchange", params,
00951 this.url);
00952
00953 req.send();
00954
00955 try {
00956 return (byte[][]) req.getReturnedObject();
00957 } catch (SecurityException e) {
00958 throw e;
00959 } catch (RenegotiateSessionException e) {
00960 throw e;
00961 } catch (IOException e) {
00962 throw e;
00963 } catch (Exception e) {
00964 e.printStackTrace();
00965
00966 return null;
00967 }
00968 }
00969
00970 public SecurityContext getPolicy(SecurityContext securityContext)
00971 throws SecurityNotAvailableException, IOException {
00972 if (isLocal) {
00973 return localruntime.getPolicy(securityContext);
00974 }
00975
00976 ArrayList<Object> params = new ArrayList<Object>();
00977 params.add(securityContext);
00978
00979 RuntimeRequest req = new RuntimeRequest("getPolicy", params, this.url);
00980
00981 req.send();
00982
00983 try {
00984 return (SecurityContext) req.getReturnedObject();
00985 } catch (SecurityNotAvailableException e) {
00986 throw e;
00987 } catch (IOException e) {
00988 throw e;
00989 } catch (Exception e) {
00990 e.printStackTrace();
00991
00992 return null;
00993 }
00994 }
00995
00996 public byte[] getCertificateEncoded()
00997 throws SecurityNotAvailableException, IOException {
00998 if (isLocal) {
00999 return localruntime.getCertificateEncoded();
01000 }
01001
01002 ArrayList<Object> params = new ArrayList<Object>();
01003
01004 RuntimeRequest req = new RuntimeRequest("getCertificateEncoded",
01005 params, this.url);
01006
01007 req.send();
01008
01009 try {
01010 return (byte[]) req.getReturnedObject();
01011 } catch (SecurityException e) {
01012 throw e;
01013 } catch (IOException e) {
01014 throw e;
01015 } catch (Exception e) {
01016 e.printStackTrace();
01017
01018 return null;
01019 }
01020 }
01021
01022 public ArrayList<Entity> getEntities()
01023 throws SecurityNotAvailableException, IOException {
01024 if (isLocal) {
01025 return localruntime.getEntities();
01026 }
01027
01028 ArrayList<Object> params = new ArrayList<Object>();
01029
01030 RuntimeRequest req = new RuntimeRequest("getEntities", params, this.url);
01031
01032 req.send();
01033
01034 try {
01035 return (ArrayList<Entity>) req.getReturnedObject();
01036 } catch (SecurityException e) {
01037 throw e;
01038 } catch (IOException e) {
01039 throw e;
01040 } catch (Exception e) {
01041 e.printStackTrace();
01042
01043 return null;
01044 }
01045 }
01046
01047 public void terminateSession(long sessionID)
01048 throws IOException, SecurityNotAvailableException {
01049 if (isLocal) {
01050 localruntime.terminateSession(sessionID);
01051 }
01052
01053 ArrayList<Object> params = new ArrayList<Object>();
01054 params.add(new Long(sessionID));
01055
01056 RuntimeRequest req = new RuntimeRequest("terminateSession", params,
01057 this.url);
01058
01059 req.send();
01060
01061 try {
01062 req.getReturnedObject();
01063 } catch (SecurityException e) {
01064 throw e;
01065 } catch (IOException e) {
01066 throw e;
01067 } catch (Exception e) {
01068 e.printStackTrace();
01069 }
01070 }
01071
01072 public Object setLocalNodeProperty(String nodeName, String key, String value)
01073 throws IOException, ProActiveException {
01074 if (isLocal) {
01075 return localruntime.setLocalNodeProperty(nodeName, key, value);
01076 }
01077
01078 ArrayList<Object> params = new ArrayList<Object>();
01079 params.add(nodeName);
01080 params.add(key);
01081 params.add(value);
01082
01083 RuntimeRequest req = new RuntimeRequest("setLocalNodeProperty", params,
01084 this.url);
01085
01086 req.send();
01087
01088 try {
01089 return (Object) req.getReturnedObject();
01090 } catch (SecurityException e) {
01091 throw e;
01092 } catch (IOException e) {
01093 throw e;
01094 } catch (Exception e) {
01095 e.printStackTrace();
01096
01097 return null;
01098 }
01099 }
01100
01101 public String getLocalNodeProperty(String nodeName, String key)
01102 throws IOException, ProActiveException {
01103 if (isLocal) {
01104 return localruntime.getLocalNodeProperty(nodeName, key);
01105 }
01106
01107 ArrayList<Object> params = new ArrayList<Object>();
01108 params.add(nodeName);
01109 params.add(key);
01110
01111 RuntimeRequest req = new RuntimeRequest("getLocalNodeProperty", params,
01112 this.url);
01113
01114 req.send();
01115
01116 try {
01117 return (String) req.getReturnedObject();
01118 } catch (SecurityException e) {
01119 throw e;
01120 } catch (IOException e) {
01121 throw e;
01122 } catch (Exception e) {
01123 e.printStackTrace();
01124
01125 return null;
01126 }
01127 }
01128 }
