00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.locationserver; 00032 00033 import java.io.IOException; 00034 00035 import org.objectweb.proactive.Body; 00036 import org.objectweb.proactive.core.body.request.Request; 00037 import org.objectweb.proactive.core.body.request.RequestReceiver; 00038 import org.objectweb.proactive.core.event.MessageEventListener; 00039 00040 00041 public class BouncingRequestReceiver implements RequestReceiver { 00042 protected static java.io.IOException REUSABLE_EXCEPTION = new java.io.IOException( 00043 "Object has migrated"); 00044 00045 public int receiveRequest(Request r, Body bodyReceiver) 00046 throws java.io.IOException { 00047 //System.out.println("BouncingRequestReceiver: receiveRequest()"); 00048 throw REUSABLE_EXCEPTION; 00049 } 00050 00051 public void addMessageEventListener(MessageEventListener listener) { 00052 } 00053 00054 public void removeMessageEventListener(MessageEventListener listener) { 00055 } 00056 00057 public void setImmediateService(String methodName) { 00058 } 00059 00060 public void removeImmediateService(String methodName, 00061 Class[] parametersTypes) throws IOException { 00062 } 00063 00064 public void setImmediateService(String methodName, Class[] parametersTypes) 00065 throws IOException { 00066 } 00067 }
1.5.1
