org/objectweb/proactive/core/body/BodyAdapterForwarder.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body;
00032
00033 import java.io.IOException;
00034 import java.security.PublicKey;
00035 import java.security.cert.X509Certificate;
00036 import java.util.ArrayList;
00037
00038 import org.objectweb.proactive.Body;
00039 import org.objectweb.proactive.core.ProActiveException;
00040 import org.objectweb.proactive.core.ProActiveRuntimeException;
00041 import org.objectweb.proactive.core.UniqueID;
00042 import org.objectweb.proactive.core.body.ft.internalmsg.FTMessage;
00043 import org.objectweb.proactive.core.body.reply.Reply;
00044 import org.objectweb.proactive.core.body.request.Request;
00045 import org.objectweb.proactive.core.component.request.Shortcut;
00046 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00047 import org.objectweb.proactive.core.exceptions.NonFunctionalException;
00048 import org.objectweb.proactive.core.exceptions.manager.NFEListener;
00049 import org.objectweb.proactive.core.runtime.ProActiveRuntimeForwarderImpl;
00050 import org.objectweb.proactive.core.runtime.ProActiveRuntimeImpl;
00051 import org.objectweb.proactive.ext.security.Communication;
00052 import org.objectweb.proactive.ext.security.SecurityContext;
00053 import org.objectweb.proactive.ext.security.crypto.KeyExchangeException;
00054 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00055 import org.objectweb.proactive.ext.security.exceptions.SecurityNotAvailableException;
00056 import org.objectweb.proactive.ext.security.securityentity.Entity;
00057
00058
00070 public class BodyAdapterForwarder extends BodyAdapter implements Cloneable,
00071     RemoteBody {
00072
00076     protected RemoteBodyForwarder proxiedRemoteBody;
00077
00082     public BodyAdapterForwarder(RemoteBodyForwarder remoteBodyForwarder) {
00083         this.proxiedRemoteBody = remoteBodyForwarder;
00084         bodyID = null; // never used for the local adapter
00085     }
00086
00092     public BodyAdapterForwarder(RemoteBodyForwarder remoteBodyForwarder,
00093         UniqueID id) {
00094         this.proxiedRemoteBody = remoteBodyForwarder;
00095
00096         try {
00097             this.bodyID = id;
00098             this.jobID = remoteBodyForwarder.getJobID(id);
00099         } catch (IOException e) {
00100             jobID = null;
00101             System.err.println("Connexion to RemoteBodyForwarder(id=" + id +
00102                 "failled, this BodyAdapterForwarder will be unusable");
00103             System.err.println(
00104                 "You probably need to check your hierarchical deployment configuration file.");
00105         }
00106     }
00107
00114     public BodyAdapterForwarder(BodyAdapterForwarder defaultAdapterForwarder,
00115         BodyAdapter remoteAdapter) {
00116         this.proxiedRemoteBody = defaultAdapterForwarder.proxiedRemoteBody;
00117         this.bodyID = remoteAdapter.bodyID;
00118         this.jobID = remoteAdapter.jobID;
00119     }
00120
00121     private void readObject(java.io.ObjectInputStream in)
00122         throws java.io.IOException, ClassNotFoundException {
00123         in.defaultReadObject();
00124
00125         /*
00126          * This adapter forwarder is being deserialized on a forwarder.
00127          * This can only happen when a forwarder talks to another forwarder.
00128          *
00129          * We put this adapter into our cache (multiplexer), and create a new
00130          * adapter with the same ID but pointing on the current forwarder.
00131          *
00132          *  All calls doing on the adapter will be send to the forwarder which
00133          *  will forward the call.
00134          */
00135         if (ProActiveConfiguration.isForwarder()) {
00136             ProActiveRuntimeForwarderImpl partf = (ProActiveRuntimeForwarderImpl) ProActiveRuntimeImpl.getProActiveRuntime();
00137
00138             try {
00139                 partf.getBodyForwarder().add((BodyAdapterForwarder) this.clone());
00140                 this.proxiedRemoteBody = partf.getBodyAdapterForwarder().proxiedRemoteBody;
00141             } catch (CloneNotSupportedException e) {
00142                 e.printStackTrace();
00143                 UniversalBody.bodyLogger.warn(
00144                     "Cannot create a forwarder for this RemoteObject.");
00145             }
00146         }
00147     }
00148
00149     //------------------------------------------
00150     // Adpater Methods
00151     //------------------------------------------
00152     public void changeProxiedBody(Body newBody) throws IOException {
00153         this.proxiedRemoteBody.changeProxiedBody(bodyID, newBody);
00154     }
00155
00156     public UniversalBody lookup(String url) throws java.io.IOException {
00157         return this.proxiedRemoteBody.lookup(bodyID, url);
00158     }
00159
00160     public void register(String url) throws java.io.IOException {
00161         this.proxiedRemoteBody.register(bodyID, url);
00162     }
00163
00164     public void unregister(String url) throws java.io.IOException {
00165         this.proxiedRemoteBody.unregister(bodyID, url);
00166     }
00167
00168     public boolean equals(Object o) {
00169         if (!(o instanceof BodyAdapterForwarder)) {
00170             return false;
00171         }
00172
00173         BodyAdapterForwarder rba = (BodyAdapterForwarder) o;
00174
00175         return rba.bodyID == this.bodyID;
00176     }
00177
00178     public int hashCode() {
00179         return bodyID.hashCode();
00180     }
00181
00182     protected void construct(BodyAdapterForwarder localBody,
00183         BodyAdapter remoteBody, UniqueID id) throws ProActiveException {
00184         this.bodyID = id;
00185         this.proxiedRemoteBody = localBody.proxiedRemoteBody;
00186
00187         if (BodyAdapter.bodyLogger.isDebugEnabled()) {
00188             BodyAdapter.bodyLogger.debug(proxiedRemoteBody.getClass());
00189         }
00190
00191         this.bodyID = remoteBody.getID();
00192         this.jobID = remoteBody.getJobID();
00193     }
00194
00195     //--------------------------------------------
00196     // implements Job
00197     //--------------------------------------------
00198     public String getJobID() {
00199         return jobID;
00200     }
00201
00202     //--------------------------------------------
00203     // implements UniversalBody
00204     //--------------------------------------------
00205     public int receiveRequest(Request request)
00206         throws IOException, RenegotiateSessionException {
00207         return proxiedRemoteBody.receiveRequest(bodyID, request);
00208     }
00209
00213     public int receiveReply(Reply r) throws IOException {
00214         return proxiedRemoteBody.receiveReply(bodyID, r);
00215     }
00216
00220     public String getNodeURL() {
00221         try {
00222             return proxiedRemoteBody.getNodeURL(bodyID);
00223         } catch (IOException e) {
00224             return "cannot contact the body to get the nodeURL";
00225         }
00226     }
00227
00231     public UniqueID getID() {
00232         return bodyID;
00233     }
00234
00238     public void updateLocation(UniqueID uid, UniversalBody body)
00239         throws IOException {
00240         proxiedRemoteBody.updateLocation(bodyID, uid, body);
00241     }
00242
00246     public void createShortcut(Shortcut shortcut) throws IOException {
00247         //      TODO implement
00248         throw new ProActiveRuntimeException(
00249             "create shortcut method not implemented yet");
00250     }
00251
00255     public BodyAdapter getRemoteAdapter() {
00256         try {
00257             return proxiedRemoteBody.getRemoteAdapter(bodyID);
00258         } catch (IOException e) {
00259             e.printStackTrace();
00260
00261             return null; // XXX
00262         }
00263     }
00264
00268     public void terminate() throws IOException {
00269         proxiedRemoteBody.terminate(bodyID);
00270     }
00271
00275     public void enableAC() throws IOException {
00276         proxiedRemoteBody.enableAC(bodyID);
00277     }
00278
00282     public void disableAC() throws IOException {
00283         proxiedRemoteBody.disableAC(bodyID);
00284     }
00285
00289     public void setImmediateService(String methodName)
00290         throws IOException {
00291         proxiedRemoteBody.setImmediateService(bodyID, methodName);
00292     }
00293
00297     public void setImmediateService(String methodName, Class[] parametersTypes)
00298         throws IOException {
00299         proxiedRemoteBody.setImmediateService(bodyID, methodName,
00300             parametersTypes);
00301     }
00302
00306     public void removeImmediateService(String methodName,
00307         Class[] parametersTypes) throws IOException {
00308         proxiedRemoteBody.removeImmediateService(bodyID, methodName,
00309             parametersTypes);
00310     }
00311
00315     public void terminateSession(long sessionID)
00316         throws IOException, SecurityNotAvailableException {
00317         proxiedRemoteBody.terminateSession(bodyID, sessionID);
00318     }
00319
00323     public X509Certificate getCertificate()
00324         throws SecurityNotAvailableException, IOException {
00325         return proxiedRemoteBody.getCertificate(bodyID);
00326     }
00327
00331     public long startNewSession(Communication policy)
00332         throws SecurityNotAvailableException, IOException,
00333             RenegotiateSessionException {
00334         return proxiedRemoteBody.startNewSession(bodyID, policy);
00335     }
00336
00340     public PublicKey getPublicKey()
00341         throws SecurityNotAvailableException, IOException {
00342         return proxiedRemoteBody.getPublicKey(bodyID);
00343     }
00344
00348     public byte[] randomValue(long sessionID, byte[] cl_rand)
00349         throws SecurityNotAvailableException, RenegotiateSessionException,
00350             IOException {
00351         return proxiedRemoteBody.randomValue(bodyID, sessionID, cl_rand);
00352     }
00353
00357     public byte[][] secretKeyExchange(long sessionID, byte[] encodedAESKey,
00358         byte[] encodedIVParameters, byte[] encodedClientMacKey,
00359         byte[] encodedLockData, byte[] parametersSignature)
00360         throws SecurityNotAvailableException, RenegotiateSessionException,
00361             IOException {
00362         return proxiedRemoteBody.secretKeyExchange(bodyID, sessionID,
00363             encodedAESKey, encodedIVParameters, encodedClientMacKey,
00364             encodedLockData, parametersSignature);
00365     }
00366
00370     public SecurityContext getPolicy(SecurityContext securityContext)
00371         throws SecurityNotAvailableException, IOException {
00372         return proxiedRemoteBody.getPolicy(bodyID, securityContext);
00373     }
00374
00378     public byte[] getCertificateEncoded()
00379         throws SecurityNotAvailableException, IOException {
00380         return proxiedRemoteBody.getCertificateEncoded(bodyID);
00381     }
00382
00386     public ArrayList<Entity> getEntities()
00387         throws SecurityNotAvailableException, IOException {
00388         return proxiedRemoteBody.getEntities(bodyID);
00389     }
00390
00391     /* (non-Javadoc)
00392      * @see org.objectweb.proactive.core.body.UniversalBody#receiveFTMessage(org.objectweb.proactive.core.body.ft.internalmsg.FTMessage)
00393      */
00394     public Object receiveFTMessage(FTMessage ev) throws IOException {
00395         return this.proxiedRemoteBody.receiveFTMessage(bodyID, ev);
00396     }
00397
00398     //--------------------------------
00399     //  NFEProducer implementation
00400     //--------------------------------
00401     public void addNFEListener(NFEListener listener) {
00402         try {
00403             proxiedRemoteBody.addNFEListener(bodyID, listener);
00404         } catch (IOException e) {
00405             // TODO Auto-generated catch block
00406             e.printStackTrace();
00407         }
00408     }
00409
00410     public void removeNFEListener(NFEListener listener) {
00411         try {
00412             proxiedRemoteBody.removeNFEListener(bodyID, listener);
00413         } catch (IOException e) {
00414             // TODO Auto-generated catch block
00415             e.printStackTrace();
00416         }
00417     }
00418
00419     public int fireNFE(NonFunctionalException e) {
00420         try {
00421             return proxiedRemoteBody.fireNFE(bodyID, e);
00422         } catch (IOException e1) {
00423             // TODO Auto-generated catch block
00424             e1.printStackTrace();
00425
00426             return 0;
00427         }
00428     }
00429
00430     public byte[][] publicKeyExchange(long sessionID, byte[] myPublicKey,
00431         byte[] myCertificate, byte[] signature)
00432         throws SecurityNotAvailableException, RenegotiateSessionException,
00433             KeyExchangeException, IOException {
00434         try {
00435             return proxiedRemoteBody.publicKeyExchange(bodyID, sessionID,
00436                 myPublicKey, myCertificate, signature);
00437         } catch (IOException e1) {
00438             // TODO Auto-generated catch block
00439             e1.printStackTrace();
00440
00441             return null;
00442         }
00443     }
00444
00448     public String[] list(String url) throws IOException {
00449         throw new IOException ("Lookup is not implemented for this Adapter");
00450     }
00451 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
