org/objectweb/proactive/core/body/proxy/AbstractBodyProxy.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.proxy;
00032
00033 import java.lang.reflect.Type;
00034 import java.lang.reflect.TypeVariable;
00035 import java.util.Collections;
00036 import java.util.HashSet;
00037 import java.util.Set;
00038
00039 import org.apache.log4j.Level;
00040 import org.apache.log4j.Logger;
00041 import org.objectweb.proactive.Body;
00042 import org.objectweb.proactive.core.Constants;
00043 import org.objectweb.proactive.core.ProActiveRuntimeException;
00044 import org.objectweb.proactive.core.UniqueID;
00045 import org.objectweb.proactive.core.body.future.Future;
00046 import org.objectweb.proactive.core.body.future.FutureProxy;
00047 import org.objectweb.proactive.core.exceptions.manager.NFEManager;
00048 import org.objectweb.proactive.core.exceptions.proxy.FutureCreationException;
00049 import org.objectweb.proactive.core.exceptions.proxy.ProxyNonFunctionalException;
00050 import org.objectweb.proactive.core.exceptions.proxy.SendRequestCommunicationException;
00051 import org.objectweb.proactive.core.mop.MOP;
00052 import org.objectweb.proactive.core.mop.MOPException;
00053 import org.objectweb.proactive.core.mop.MethodCall;
00054 import org.objectweb.proactive.core.mop.MethodCallExecutionFailedException;
00055 import org.objectweb.proactive.core.mop.Proxy;
00056 import org.objectweb.proactive.core.mop.StubObject;
00057 import org.objectweb.proactive.core.util.log.Loggers;
00058 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00059 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00060
00061
00062 public abstract class AbstractBodyProxy extends AbstractProxy
00063     implements BodyProxy, java.io.Serializable {
00064     //
00065     // -- STATIC MEMBERS -----------------------------------------------
00066     //
00067     private static Logger syncCallLogger = ProActiveLogger.getLogger(Loggers.SYNC_CALL);
00068
00069     //
00070     // -- PROTECTED MEMBERS -----------------------------------------------
00071     //
00072     protected UniqueID bodyID;
00073     protected Integer cachedHashCode = null;
00074
00075     //
00076     // -- CONSTRUCTORS -----------------------------------------------
00077     //
00078     public AbstractBodyProxy() {
00079     }
00080
00081     AbstractBodyProxy(UniqueID bodyID) {
00082         this.bodyID = bodyID;
00083     }
00084
00085     //
00086     // -- PUBLIC METHODS -----------------------------------------------
00087     //
00088     //
00089     // -- implements BodyProxy -----------------------------------------------
00090     //
00091     public UniqueID getBodyID() {
00092         return bodyID;
00093     }
00094
00095     //
00096     // -- implements Proxy -----------------------------------------------
00097     //
00098
00114     public Object reify(MethodCall methodCall) throws Throwable {
00115         Object cachedMethodResult = checkOptimizedMethod(methodCall);
00116         if (cachedMethodResult != null) {
00117             return cachedMethodResult;
00118         }
00119         return invokeOnBody(methodCall);
00120     }
00121
00122     /*
00123      * HACK: toString() can be implicitly called by log4j, which may result in a
00124      * deadlock if we call log4j inside log4j, so for now, we disable the message
00125      * for toString().
00126      */
00127     private static boolean isToString(MethodCall methodCall) {
00128         return (methodCall.getNumberOfParameter() == 0) &&
00129         "toString".equals(methodCall.getName());
00130     }
00131
00132     private static Set<String> loggedSyncCalls = Collections.synchronizedSet(new HashSet<String>());
00133
00134     private Object invokeOnBody(MethodCall methodCall)
00135         throws Exception, RenegotiateSessionException, Throwable {
00136         // Now gives the MethodCall object to the body
00137         try {
00138             if (isOneWayCall(methodCall)) {
00139                 reifyAsOneWay(methodCall);
00140                 return null;
00141             }
00142             String reason = methodCall.getSynchronousReason();
00143             if (reason == null) {
00144                 return reifyAsAsynchronous(methodCall);
00145             }
00146             if (!isToString(methodCall) &&
00147                     syncCallLogger.isEnabledFor(Level.DEBUG)) {
00148                 String msg = "[WARNING: synchronous call] All calls to the method below are synchronous "
00149                                 + "(not an error, but may lead to performance issues or deadlocks):"
00150                     + System.getProperty("line.separator") +
00151                     methodCall.getReifiedMethod()
00152                     + System.getProperty("line.separator") +
00153                     "They are synchronous for the following reason: " + reason;
00154 ;
00155                 if (loggedSyncCalls.add(msg)) {
00156                     syncCallLogger.debug(msg);
00157                 }
00158             }
00159             return reifyAsSynchronous(methodCall);
00160         } catch (MethodCallExecutionFailedException e) {
00161             throw new ProActiveRuntimeException(e.getMessage(),
00162                 e.getTargetException());
00163         }
00164     }
00165
00166     // optimization may be a local execution or a caching mechanism
00167     // returns null if not applicable
00168     private Object checkOptimizedMethod(MethodCall methodCall)
00169         throws Exception, RenegotiateSessionException, Throwable {
00170         if (methodCall.getName().equals("equals") &&
00171                 (methodCall.getNumberOfParameter() == 1)) {
00172             Object arg = methodCall.getParameter(0);
00173             if (MOP.isReifiedObject(arg)) {
00174                 Proxy proxy = ((StubObject) arg).getProxy();
00175                 if (proxy instanceof AbstractBodyProxy) {
00176                     return new Boolean(bodyID.equals(
00177                             ((AbstractBodyProxy) proxy).bodyID));
00178                 }
00179             }
00180             return new Boolean(false);
00181         }
00182
00183         if (methodCall.getName().equals("hashCode") &&
00184                 (methodCall.getNumberOfParameter() == 0)) {
00185             if (cachedHashCode == null) {
00186                 return cachedHashCode = (Integer) invokeOnBody(methodCall);
00187             } else {
00188                 return cachedHashCode;
00189             }
00190         }
00191
00192         return null;
00193     }
00194
00198     protected void reifyAsOneWay(MethodCall methodCall)
00199         throws Exception, RenegotiateSessionException {
00200         try {
00201             sendRequest(methodCall, null);
00202         } catch (java.io.IOException e) {
00203             // old stuff
00204             // throw new MethodCallExecutionFailedException("Exception occured in reifyAsOneWay while sending request for methodcall ="+methodCall.getName(), e);
00205             // Create a non functional exception encapsulating the network exception
00206             ProxyNonFunctionalException nfe = new SendRequestCommunicationException(
00207                     "Exception occured in reifyAsOneWay while sending request for methodcall = " +
00208                     methodCall.getName(), e);
00209
00210             NFEManager.fireNFE(nfe, this);
00211         }
00212     }
00213
00214     /*
00215      * Dummy Future used to reply to a one-way method call with exceptions
00216      * Declared as public to accomodate the MOP
00217      */
00218     public static class VoidFuture {
00219         public VoidFuture() {
00220         }
00221     }
00222
00223     protected Object reifyAsAsynchronous(MethodCall methodCall)
00224         throws Exception, RenegotiateSessionException {
00225         StubObject futureobject = null;
00226
00227         // Creates a stub + FutureProxy for representing the result
00228         try {
00229             Class returnType = null;
00230             Type t = methodCall.getReifiedMethod().getGenericReturnType();
00231             if (t instanceof TypeVariable) {
00232                 returnType = methodCall.getGenericTypesMapping().get(t);
00233             } else {
00234                 returnType = methodCall.getReifiedMethod().getReturnType();
00235             }
00236
00237
00238
00239             if (returnType.equals(java.lang.Void.TYPE)) {
00240                 /* A future for a void call is used to put the potential exception inside */
00241                 futureobject = (StubObject) MOP.newInstance(VoidFuture.class,
00242                         null, Constants.DEFAULT_FUTURE_PROXY_CLASS_NAME, null);
00243             } else {
00244                 futureobject = (StubObject) MOP.newInstance(returnType, null,
00245                         Constants.DEFAULT_FUTURE_PROXY_CLASS_NAME, null);
00246             }
00247         } catch (MOPException e) {
00248             // Create a non functional exception encapsulating the network exception
00249             ProxyNonFunctionalException nfe = new FutureCreationException(
00250                     "Exception occured in reifyAsAsynchronous while creating future for methodcall = " +
00251                     methodCall.getName(), e);
00252
00253             NFEManager.fireNFE(nfe, this);
00254         } catch (ClassNotFoundException e) {
00255             // Create a non functional exception encapsulating the network exception
00256             ProxyNonFunctionalException nfe = new FutureCreationException(
00257                     "Exception occured in reifyAsAsynchronous while creating future for methodcall = " +
00258                     methodCall.getName(), e);
00259
00260             NFEManager.fireNFE(nfe, this);
00261         }
00262
00263         // Set the id of the body creator in the created future
00264         FutureProxy fp = (FutureProxy) (futureobject.getProxy());
00265         fp.setCreatorID(bodyID);
00266         fp.setOriginatingProxy(this);
00267
00268         try {
00269             sendRequest(methodCall, fp);
00270         } catch (java.io.IOException e) {
00271             // old stuff
00272             // throw new MethodCallExecutionFailedException("Exception occured in reifyAsAsynchronous while sending request for methodcall ="+methodCall.getName(), e);
00273             // Create a non functional exception encapsulating the network exception
00274             ProxyNonFunctionalException nfe = new SendRequestCommunicationException(
00275                     "Exception occured in reifyAsAsynchronous while sending request for methodcall = " +
00276                     methodCall.getName(), e);
00277
00278             NFEManager.fireNFE(nfe, this);
00279         }
00280
00281         // And return the future object
00282         return futureobject;
00283     }
00284
00285     protected Object reifyAsSynchronous(MethodCall methodCall)
00286         throws Throwable, Exception, RenegotiateSessionException {
00287         // Setting methodCall.res to null means that we do not use the future mechanism
00288         FutureProxy fp = FutureProxy.getFutureProxy();
00289         fp.setCreatorID(bodyID);
00290         fp.setOriginatingProxy(this);
00291
00292         try {
00293             sendRequest(methodCall, fp);
00294         } catch (java.io.IOException e) {
00295             // old stuff
00296             // throw new MethodCallExecutionFailedException("Exception occured in reifyAsSynchronous while sending request for methodcall ="+methodCall.getName(), e);
00297             // Create a non functional exception encapsulating the network exception
00298             ProxyNonFunctionalException nfe = new SendRequestCommunicationException(
00299                     "Exception occured in reifyAsSynchronous while sending request for methodcall = " +
00300                     methodCall.getName(), e);
00301
00302             NFEManager.fireNFE(nfe, this);
00303         }
00304
00305         // Returns the result (exception returned is a functional one -> NFE is not needed)
00306         if (fp.getRaisedException() != null) {
00307             throw fp.getRaisedException();
00308         } else {
00309             return fp.getResult();
00310         }
00311     }
00312
00313     protected abstract void sendRequest(MethodCall methodCall, Future future)
00314         throws java.io.IOException, RenegotiateSessionException;
00315
00316     protected abstract void sendRequest(MethodCall methodCall, Future future,
00317         Body sourceBody)
00318         throws java.io.IOException, RenegotiateSessionException;
00319 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
