1 - Phase diagram of a long bar under a higher-order active contour energy: application to hydrographic network extraction from VHR satellite images. A. El Ghoul et I. H. Jermyn et J. Zerubia. Dans International Conference on Pattern Recognition (ICPR), Tampa, Florida, décembre 2008. Mots-clés : Phase diagram, Higher-order actif contours, Forme, river extraction.
@INPROCEEDINGS{ElGhoul08b,
author |
{El Ghoul, A. and Jermyn, I. H. and Zerubia, J.}, |
title |
{Phase diagram of a long bar under a higher-order active contour energy: application to hydrographic network extraction from VHR satellite images}, |
year |
{2008}, |
month |
{décembre}, |
booktitle |
{International Conference on Pattern Recognition (ICPR)}, |
address |
{Tampa, Florida}, |
url |
{http://hal.inria.fr/index.php?action_todo=search&view_this_doc=inria-00316619&version=1&halsid=4912mc8beemv68g1nleda8ksa0}, |
pdf |
{http://hal.inria.fr/docs/00/31/66/19/PDF/icpr08aymenelghoul.pdf}, |
keyword |
{Phase diagram, Higher-order actif contours, Forme, river extraction} |
Abstract :
The segmentation of networks is important in several imaging domains, and models incorporating prior shape knowledge are often essential for the automatic performance of this task. Higher-order active contours
provide a way to include such knowledge, but their behaviour can vary significantly with parameter values: e.g. the same energy can model networks or a ‘gas of circles’. In this paper, we present a stability analysis
of a HOAC energy leading to the phase diagram of a long bar. The results, which are confirmed by numerical experiments, enable the selection of parameter values for the modelling of network shapes using the energy.
We apply the resulting model to the problem of hydrographic network extraction from VHR satellite images. |
