Publications de Elena Zhizhina
Résultat de la recherche dans la liste des publications :
6 Articles |
1 - A Marked Point Process Model Including Strong Prior Shape Information Applied to Multiple Object Extraction From Images. M. S. Kulikova et I. H. Jermyn et X. Descombes et E. Zhizhina et J. Zerubia. International Journal of Computer Vision and Image Processing, 1(2): pages 1-12, 2011. Mots-clés : Contour actif, Processus ponctuels marques, multiple birth-and-death dynamics, multiple object extraction, Shape prior.
@ARTICLE{kulikova_ijcvip2010,
author |
{Kulikova, M. S. and Jermyn, I. H. and Descombes, X. and Zhizhina, E. and Zerubia, J.}, |
title |
{A Marked Point Process Model Including Strong Prior Shape Information Applied to Multiple Object Extraction From Images}, |
year |
{2011}, |
journal |
{International Journal of Computer Vision and Image Processing}, |
volume |
{1}, |
number |
{2}, |
pages |
{1-12}, |
url |
{http://hal.archives-ouvertes.fr/hal-00804118}, |
keyword |
{Contour actif, Processus ponctuels marques, multiple birth-and-death dynamics, multiple object extraction, Shape prior} |
Abstract :
Object extraction from images is one of the most important tasks in remote sensing image analysis. For accurate extraction from very high resolution (VHR) images, object geometry needs to be taken into account. A method for incorporating strong yet flexible prior shape information into a marked point process model for the extraction of multiple objects of complex shape is presented. To control the computational complexity, the objects considered are defined using the image data and the prior shape information. To estimate the optimal configuration of objects, the process is sampled using a Markov chain based on a stochastic birth-and-death process on the space of multiple objects. The authors present several experimental results on the extraction of tree crowns from VHR aerial images. |
2 - A Point Process for Fully Automatic Road Network Detection in Satellite and Aerial Images. P. Cariou et X. Descombes et E. Zhizhina. Problems of Information Transmission, 10(3): pages 247-256, 2010. Mots-clés : Marked point process, birth and death process, Road network extraction.
@ARTICLE{cariou2010,
author |
{Cariou, P. and Descombes, X. and Zhizhina, E.}, |
title |
{A Point Process for Fully Automatic Road Network Detection in Satellite and Aerial Images}, |
year |
{2010}, |
journal |
{Problems of Information Transmission}, |
volume |
{10}, |
number |
{3}, |
pages |
{247-256}, |
url |
{ http://www.jip.ru/2010/247-256-2010.pdf}, |
keyword |
{Marked point process, birth and death process, Road network extraction} |
3 - Object Extraction Using a Stochastic Birth-and-Death Dynamics in Continuum. X. Descombes et R. Minlos et E. Zhizhina. Journal of Mathematical Imaging and Vision, 33(3): pages 347-359, 2009. Mots-clés : birth and death process, Processus ponctuels marques, Extraction d'objets. Copyright : Springer
@ARTICLE{DZM08,
author |
{Descombes, X. and Minlos, R. and Zhizhina, E.}, |
title |
{Object Extraction Using a Stochastic Birth-and-Death Dynamics in Continuum}, |
year |
{2009}, |
journal |
{Journal of Mathematical Imaging and Vision}, |
volume |
{33}, |
number |
{3}, |
pages |
{347-359}, |
pdf |
{http://dx.doi.org/10.1007/s10851-008-0117-y}, |
keyword |
{birth and death process, Processus ponctuels marques, Extraction d'objets} |
Abstract :
We define a new birth and death dynamics dealing with configurations of disks in the plane. We prove the convergence of the continuous process and propose a discrete scheme converging to the continuous case. This framework is developed to address image processing problems consisting in detecting a configuration of objects from a digital image. The derived algorithm is applied for tree crown extraction and bird detection from aerial images. The performance of this approach is shown on real data. |
4 - The Gibbs fields approach and related dynamics in image processing. X. Descombes et E. Zhizhina. Condensed Matter Physics, 11(2(54)): pages 293-312, 2008. Copyright : Institute for Condensed Matter
@ARTICLE{LNA08,
author |
{Descombes, X. and Zhizhina, E.}, |
title |
{The Gibbs fields approach and related dynamics in image processing}, |
year |
{2008}, |
journal |
{Condensed Matter Physics}, |
volume |
{11}, |
number |
{2(54)}, |
pages |
{293-312}, |
keyword |
5 - Applications of Gibbs fields methods to image processing problems. X. Descombes et E. Zhizhina. Problems of Information Transmission, 40(3): pages 108--125, septembre 2004. Note : in Russian
@ARTICLE{DES04br,
author |
title |
{Applications of Gibbs fields methods to image processing problems}, |
year |
{2004}, |
month |
{septembre}, |
journal |
volume |
{40}, |
number |
{3}, |
pages |
{108--125}, |
note |
{in Russian}, |
keyword |
6 - Applications of Gibbs fields methods to image processing problems. X. Descombes et E. Zhizhina. Problems of Information Transmission, 40(3): pages 279-295, septembre 2004. Note : in English
@ARTICLE{DES04be,
author |
title |
year |
{2004}, |
month |
{septembre}, |
journal |
volume |
{40}, |
number |
{3}, |
pages |
{279-295}, |
note |
{in English}, |
keyword |
haut de la page
4 Articles de conférence |
1 - Extraction of arbitrarily shaped objects using stochastic multiple birth-and-death dynamics and active contours. M. S. Kulikova et I. H. Jermyn et X. Descombes et E. Zhizhina et J. Zerubia. Dans Proc. IS&T/SPIE Electronic Imaging, San Jose, USA, janvier 2010. Mots-clés : Extraction d'objets, Processus ponctuels marques, Shape prior, Contour actif, birth-and-death dynamics. Copyright : Copyright 2010 by SPIE and IS&T. This paper was published in the proceedings of IS&T/SPIE Electronic Imaging 2010 Conference in San Jose, USA, and is made available as an electronic reprint with permission of SPIE and IS&T. One print or electronic copy may be made for personal use only. Systematic or multiple reproduction, distribution to multiple locations via electronic or other means, duplication of any material in this paper for a fee or for commercial purposes, or modification of the content of the paper are prohibited.
@INPROCEEDINGS{Kulikova10a,
author |
title |
{Extraction of arbitrarily shaped objects using stochastic multiple birth-and-death dynamics and active contours}, |
year |
{2010}, |
month |
{janvier}, |
booktitle |
{Proc. IS&T/SPIE Electronic Imaging}, |
address |
{San Jose, USA}, |
pdf |
{http://hal.archives-ouvertes.fr/docs/00/46/54/72/PDF/Kulikova_SPIE2010.pdf}, |
keyword |
{Extraction d'objets, Processus ponctuels marques, Shape prior, Contour actif, birth-and-death dynamics} |
Abstract :
We extend the marked point process models that have been used for object extraction from images to arbitrarily shaped objects, without greatly increasing the computational complexity of sampling and estimation. From an alternative point of view, the approach can be viewed as an extension of the active contour methodology to an a priori unknown number of
objects. Sampling and estimation are based on a stochastic birth-and-death process defined on the configuration space of an arbitrary number of objects, where the objects are defined by the image data and prior information. The performance of the approach is demonstrated via experimental results on synthetic and real data. |
2 - A marked point process model with strong prior shape information for extraction of multiple, arbitrarily-shaped objects. M. S. Kulikova et I. H. Jermyn et X. Descombes et E. Zhizhina et J. Zerubia. Dans Proc. IEEE SITIS, Publ. IEEE Computer Society, Marrakech, Maroc, décembre 2009. Mots-clés : Extraction d'objets, Processus ponctuels marques, Shape prior, Contour actif, multiple birth-and-death dynamics.
@INPROCEEDINGS{Kulikova09a,
author |
title |
{A marked point process model with strong prior shape information for extraction of multiple, arbitrarily-shaped objects}, |
year |
{2009}, |
month |
{décembre}, |
booktitle |
{Proc. IEEE SITIS}, |
publisher |
{IEEE Computer Society}, |
address |
{Marrakech, Maroc}, |
pdf |
{http://hal.inria.fr/docs/00/43/63/20/PDF/PID1054029.pdf}, |
keyword |
{Extraction d'objets, Processus ponctuels marques, Shape prior, Contour actif, multiple birth-and-death dynamics} |
Abstract :
We define a method for incorporating strong prior shape information into a recently extended Markov point process model for the extraction of arbitrarily-shaped objects from images. To estimate the optimal configuration of objects, the process is sampled using a Markov chain based on a stochastic birth-and-death process defined in a space of multiple
objects. The single objects considered are defined by both the image data
and the prior information in a way that controls the computational
complexity of the estimation problem. The method is tested via experiments
on a very high resolution aerial image of a scene composed of tree crowns. |
3 - Reconstruction 3D du bâti par la technique des ombres chinoises. P. Lukashevish et A. Kraushonak et X. Descombes et J.D. Durou et B. Zalessky et E. Zhizhina. Dans GRETSI Dijon, Dijon, France, novembre 2009. Mots-clés : Reconstruction en 3D.
@INPROCEEDINGS{luka09,
author |
{Lukashevish, P. and Kraushonak, A. and Descombes, X. and Durou, J.D. and Zalessky, B. and Zhizhina, E.}, |
title |
{Reconstruction 3D du bâti par la technique des ombres chinoises}, |
year |
{2009}, |
month |
{novembre}, |
booktitle |
{GRETSI Dijon}, |
address |
{Dijon, France}, |
url |
{http://hal.inria.fr/inria-00399208/fr/}, |
keyword |
{Reconstruction en 3D} |
4 - Image deconvolution using a stochastic differential equation approach. X. Descombes et M. Lebellego et E. Zhizhina. Dans Proc. nternational Conference on Computer Vision Theory
and Applications, Barcelona, Spain, mars 2007. Mots-clés : Deconvolution, Stochastic Differential Equation.
@INPROCEEDINGS{xavBarca2,
author |
{Descombes, X. and Lebellego, M. and Zhizhina, E.}, |
title |
{Image deconvolution using a stochastic differential equation approach}, |
year |
{2007}, |
month |
{mars}, |
booktitle |
{Proc. nternational Conference on Computer Vision Theory
and Applications}, |
address |
{Barcelona, Spain}, |
pdf |
{ftp://ftp-sop.inria.fr/ariana/Articles/2007_xavBarca2.pdf}, |
keyword |
{Deconvolution, Stochastic Differential Equation} |
haut de la page
2 Rapports de recherche et Rapports techniques |
1 - Object extraction using a stochastic birth-and-death dynamics in continuum. X. Descombes et R. Minlos et E. Zhizhina. Rapport de Recherche 6135, INRIA, 2007. Mots-clés : birth and death process, Stochastic modeling, Ondelettes.
@TECHREPORT{RR-6135,
author |
title |
{Object extraction using a stochastic birth-and-death dynamics in continuum}, |
year |
{2007}, |
institution |
{INRIA}, |
type |
{Research Report}, |
number |
{6135}, |
url |
{https://hal.inria.fr/inria-00133726}, |
pdf |
{http://hal.inria.fr/inria-00133726}, |
keyword |
{birth and death process, Stochastic modeling, Ondelettes} |
Abstract :
We define a new birth and death dynamics dealing with configurations of discs in the plane. We prove the convergence of the continuous process and propose a discrete scheme converging to the continuous case. This framework is developed to address image processing problems consisting in extracting objects. The derived algorithm is applied for tree crown extraction and bird detection from aerial images. The performance of this approach is shown on real data. |
2 - Image Denoising using Stochastic Differential Equations. X. Descombes et E. Zhizhina. Rapport de Recherche 4814, INRIA, France, mai 2003. Mots-clés : Debruitage.
@TECHREPORT{4814,
author |
title |
{Image Denoising using Stochastic Differential Equations}, |
year |
{2003}, |
month |
{mai}, |
institution |
{INRIA}, |
type |
number |
{4814}, |
address |
{France}, |
url |
{http://www.inria.fr/rrrt/rr-4814.html}, |
pdf |
{ftp://ftp.inria.fr/INRIA/publication/publi-pdf/RR/RR-4814.pdf}, |
ps |
{ftp://ftp.inria.fr/INRIA/publication/publi-ps-gz/RR/RR-4814.ps.gz}, |
keyword |
{Debruitage} |
Résumé :
Ce rapport concerne le problème de la restauration d'image avec une approche par Équation Différentielle Stochastique. Nous considérons un processus de diffusion convergeant vers une mesure de Gibbs. L'hamiltonien de la mesure de Gibbs contient un terme d'interactions, apportant des contraintes de lissage sur la solution, et un terme d'attache aux données. Nous étudions deux schémas d'approximation discrète de la dynamique de Langevin associée à ce processus de diffusion : les approximation d'Euler et explicite forte de Taylor. La vitesse de convergence des algorithmes correspondants est comparée à celle de l'algorithme de Metropolis-Hasting. Des résultats sont montrés sur des images de synthèse et réelles. Il montrent la supériorité de l'approche proposée lorsque l'on considère un faible nombre d'itérations. |
Abstract :
We address the problem of image denoising using a Stochastic Differential Equation approach. We consider a diffusion process which converges to a Gibbs measure. The Hamiltonian of the Gibbs measure embeds an interaction term, providing smoothing properties, and a data term. We study two discrete approximations of the Langevin dynamics associated with this diffusion process: the Euler and the Explicit Strong Taylor approximations. We compare the convergence speed of the associated algorithms and the Metropolis-Hasting algorithm. Results are shown on synthetic and real data. They show that the proposed approach provides better results when considering a small number of iterations. |
haut de la page
Ces pages sont générées par
