Publications of J.D. Durou
Article |
1 - A Multiresolution Approach for Shape from Shading Coupling Deterministic and Stochastic Optimization. A. Crouzil and X. Descombes and J.D. Durou. IEEE Trans. Pattern Analysis ans Machine Intelligence, 25(11): pages 1416--1421, November 2003. Note : Special section on `Energy minimization methods in computer vision and pattern recognition'
@ARTICLE{crouzilXDJDD,
author |
{Crouzil, A. and Descombes, X. and Durou, J.D.}, |
title |
{A Multiresolution Approach for Shape from Shading Coupling Deterministic and Stochastic Optimization}, |
year |
{2003}, |
month |
{November}, |
journal |
{IEEE Trans. Pattern Analysis ans Machine Intelligence}, |
volume |
{25}, |
number |
{11}, |
pages |
{1416--1421}, |
note |
{Special section on `Energy minimization methods in computer vision and pattern recognition'}, |
pdf |
{http://ieeexplore.ieee.org/iel5/34/27807/01240116.pdf?tp=&arnumber=1240116&isnumber=27807}, |
keyword |
top of the page
3 Conference articles |
1 - Reconstruction 3D du bâti à partir d'une seule image par naissances et morts multiples. J.D. Durou and X. Descombes and P. Lukashevish and A. Kraushonak. In Proc. GRETSI Symposium on Signal and Image Processing, Bordeaux, France, September 2011.
@INPROCEEDINGS{DurouGretsi11,
author |
{Durou, J.D. and Descombes, X. and Lukashevish, P. and Kraushonak, A.}, |
title |
{Reconstruction 3D du bâti à partir d'une seule image par naissances et morts multiples}, |
year |
{2011}, |
month |
{September}, |
booktitle |
{Proc. GRETSI Symposium on Signal and Image Processing}, |
address |
{Bordeaux, France}, |
url |
{http://hal.inria.fr/inria-00625527/fr/}, |
keyword |
Résumé :
Dans cet article, nous nous écartons de l’approche classique qui considère la reconstruction 3D comme un problème inverse et la
résout en mettant en correspondance deux images d’une paire stéréoscopique. Au contraire, nous montrons qu’il est plus simple de résoudre le
problème direct. Pour ce faire, nous proposons aléatoirement des configurations de bâtiments pour ne conserver que les plus pertinentes par un
algorithme de type naissances et morts multiples. Nous montrons notamment que cette approche ne nécessite pas un temps de calcul prohibitif,
grâce à la puissance de calcul d’OpenGL qui s’appuie sur la carte graphique. Les premiers résultats obtenus montrent la pertinence de l’approche
adoptée. En particulier, elle permet de résoudre des ambiguïtés pour lesquelles l’inversion du problème serait quasiment impossible. |
Abstract :
In this paper, contrary to the classical approach addressing the 3D reconstruction problem as an inverse problem and solving it by matching two images from a stereoscopic pair, we show that we can solve the direct problem in a simpler way. To do so, we randomly propose configurations of buildings while keeping only the most relevant ones, using a multiple births and deaths algorithm. Notably, we show that this approach does not imply a prohibitory computation time, thanks to the freeware OpenGL which exploits the graphic card. The first results show that the proposed approach is relevant. In particular, it allows solving ambiguities for which inverting the problem is almost impossible. |
2 - Reconstruction 3D du bâti par la technique des ombres chinoises. P. Lukashevish and A. Kraushonak and X. Descombes and J.D. Durou and B. Zalessky and E. Zhizhina. In GRETSI Dijon, Dijon, France, November 2009. Keywords : 3D reconstruction.
@INPROCEEDINGS{luka09,
author |
{Lukashevish, P. and Kraushonak, A. and Descombes, X. and Durou, J.D. and Zalessky, B. and Zhizhina, E.}, |
title |
{Reconstruction 3D du bâti par la technique des ombres chinoises}, |
year |
{2009}, |
month |
{November}, |
booktitle |
{GRETSI Dijon}, |
address |
{Dijon, France}, |
url |
{http://hal.inria.fr/inria-00399208/fr/}, |
keyword |
{3D reconstruction} |
3 - Recuit simulé pour le shape from shading. X. Descombes and J.D. Durou and L. Petit. In Proc. GRETSI Symposium on Signal and Image Processing, Toulouse, France, September 2001.
@INPROCEEDINGS{xd01h,
author |
{Descombes, X. and Durou, J.D. and Petit, L.}, |
title |
{Recuit simulé pour le shape from shading}, |
year |
{2001}, |
month |
{September}, |
booktitle |
address |
{Toulouse, France}, |
keyword |
top of the page
Technical and Research Report |
1 - A Multiresolution Approach for Shape from Shading Coupling Deterministic and Stochastic Optimization. A. Crouzil and X. Descombes and J.D. Durou. Research Report 5006, INRIA, France, December 2003. Keywords : Shape from shading, Simulated Annealing, Optimization, Multiresolution.
@TECHREPORT{Crouzil03,
author |
title |
year |
{2003}, |
month |
{December}, |
institution |
{INRIA}, |
type |
{Research Report}, |
number |
{5006}, |
address |
{France}, |
url |
{http://www.inria.fr/rrrt/rr-5006.html}, |
pdf |
{ftp://ftp.inria.fr/INRIA/publication/publi-pdf/RR/RR-5006.pdf}, |
ps |
{ftp://ftp.inria.fr/INRIA/publication/publi-ps-gz/RR/RR-5006.ps.gz}, |
keyword |
{Shape from shading, Simulated Annealing, Optimization, Multiresolution} |
Résumé :
Le Shape from shading est un problème inverse mal posé pour lequel aucune méthode de résolution complètement satisfaisante n'a encore été proposée. Dans ce rapport technique, nous ramenons le à un problème d'optimisation. Nous montrons d'abord que l'approche déterministe fournit des algorithmes efficaces en termes de temps de calcul, mais est d'un intérêt limité lorsque l'énergie comporte des minima locaux très profonds. Nous proposons comme alternative une approche stochastique utilisant le recuit simulé. Les résultats obtenus dépassent largement ceux de l'approche déterministe. La contrepartie est l'extrême lenteur du processus d'optimisation. Pour cette raison, nous proposons une approche hybride qui combine les approches déterministe et stochastique dans un cadre de multi-résolution. |
Abstract :
Shape from shading is an ill-posed inverse problem for which there is no completely satisfactory solution in the existing literature. In this technical report, we address shape from shading as an energy minimization problem. We first show that the deterministic approach provides efficient algorithms in terms of CPU time, but reaches its limits since the energy associated to shape from shading can contain multiple deep local minima. We derive an alternative stochastic approach using simulated annealing. The obtained results strongly outperform the results of the deterministic approach. The shortcoming is an extreme slowness of the optimization. Therefore, we propose an hybrid approach which combines the deterministic and stochastic approaches in a multiresolution framework. |
top of the page
These pages were generated by
