org/objectweb/proactive/core/component/Constants.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.component;
00032
00033
00039 public interface Constants {
00040     public final static String CONTENT_CONTROLLER = "content-controller";
00041     public final static String LIFECYCLE_CONTROLLER = "lifecycle-controller";
00042     public final static String BINDING_CONTROLLER = "binding-controller";
00043     public final static String COMPONENT_PARAMETERS_CONTROLLER = "component-parameters-controller";
00044     public final static String NAME_CONTROLLER = "name-controller";
00045     public final static String ATTRIBUTE_CONTROLLER = "attribute-controller";
00046     public final static String SUPER_CONTROLLER = "super-controller";
00047     public final static String MULTICAST_CONTROLLER = "multicast-controller";
00048     public final static String GATHERCAST_CONTROLLER = "gathercast-controller";
00049     public final static String MIGRATION_CONTROLLER = "migration-controller";
00050
00051     public final static String COMPONENT = "component";
00052     public final static String CYCLIC_NODE_SUFFIX = "-cyclicInstanceNumber-";
00053
00054     // hierarchical types of component
00055     public final static String COMPOSITE = "composite";
00056     public final static String PRIMITIVE = "primitive";
00057     public final static String PARALLEL = "parallel";
00058     public final static boolean SYNCHRONOUS = true;
00059 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
