00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.benchsocket; 00032 00033 public class ShutdownThread extends Thread { 00034 // //singleton pattern because of java bug #4533 00035 // private static ShutdownThread sh; 00036 // 00037 // static { 00038 // sh = new ShutdownThread(); 00039 // Runtime.getRuntime().addShutdownHook(sh); 00040 // } 00041 // 00042 // public static synchronized void addStream(BenchStream b) { 00043 // ShutdownThread.sh.streamList.add(b); 00044 // System.out.println("Adding current size is " + 00045 // ShutdownThread.sh.streamList.size()); 00046 // } 00047 // 00048 // public static synchronized boolean removeStream(BenchStream b) { 00049 // boolean result = ShutdownThread.sh.streamList.remove(b); 00050 // System.out.println("Removing current size is " + 00051 // ShutdownThread.sh.streamList.size()); 00052 // return result; 00053 // } 00054 // 00055 // private LinkedList streamList; 00056 // 00057 // private ShutdownThread() { 00058 // this.streamList = new LinkedList(); 00059 // } 00060 // 00061 // public void run() { 00062 // //// this.bos.displayTotal(); 00063 // synchronized (sh.streamList) { 00064 // System.out.println("Run on list with " + this.streamList.size() + 00065 // " elements"); 00066 // Iterator it = this.streamList.iterator(); 00067 // while (it.hasNext()) { 00068 // ((BenchStream) it.next()).displayTotal(); 00069 // } 00070 // } 00071 // } 00072 protected boolean fakeRun; 00073 protected BenchStream stream; 00074 00075 public ShutdownThread() { 00076 } 00077 00078 public ShutdownThread(BenchStream s) { 00079 this.stream = s; 00080 } 00081 00082 protected void fakeRun() { 00083 this.fakeRun = true; 00084 this.start(); 00085 } 00086 00087 public void run() { 00089 //System.out.println("XXXfakerun " + fakeRun); 00090 if (!this.fakeRun) { 00091 this.stream.displayTotal(); 00092 } 00093 } 00094 }
1.5.1
