org/objectweb/proactive/ext/security/crypto/SessionKeyFactory.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.security.crypto;
00032
00033 import java.io.Serializable;
00034 import java.security.Key;
00035 import java.security.SecureRandom;
00036
00037 import javax.crypto.KeyGenerator;
00038
00039
00040 public class SessionKeyFactory implements Serializable {
00041     // private SecureRandom      rand = new FixedSecureRandom();
00042     private KeyGenerator keyGen;
00043
00044     public SessionKeyFactory() {
00045         //  myProvider = new org.bouncycastle.jce.provider.BouncyCastleProvider();
00046         // Tester ici si ca n'a pas ete deja fait : cf mail...
00047         //  Security.addProvider(myProvider);
00048         try {
00049             // "BC" is the name of the BouncyCastle provider
00050             keyGen = KeyGenerator.getInstance("Rijndael", "BC");
00051             keyGen.init(128, new SecureRandom());
00052
00053             // keyGen.init(128,rand);
00054         } catch (Exception e) {
00055             System.out.println("Exception in the Session Key Generation : " +
00056                 e);
00057         }
00058     }
00059
00060     public Key generateSessionKey() {
00061         return keyGen.generateKey();
00062     }
00063 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
