00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.ext.mixedlocation;
00032
00033 import org.apache.log4j.Logger;
00034 import org.objectweb.proactive.ProActive;
00035 import org.objectweb.proactive.core.UniqueID;
00036 import org.objectweb.proactive.core.body.LocalBodyStore;
00037 import org.objectweb.proactive.core.body.UniversalBody;
00038 import org.objectweb.proactive.core.body.ft.protocols.FTManager;
00039 import org.objectweb.proactive.core.body.future.FutureProxy;
00040 import org.objectweb.proactive.core.body.request.RequestImpl;
00041 import org.objectweb.proactive.core.mop.MethodCall;
00042 import org.objectweb.proactive.core.mop.StubObject;
00043 import org.objectweb.proactive.core.util.log.Loggers;
00044 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00045 import org.objectweb.proactive.ext.locationserver.LocationServer;
00046 import org.objectweb.proactive.ext.locationserver.LocationServerFactory;
00047
00048
00049 public class RequestWithMixedLocation extends RequestImpl
00050 implements java.io.Serializable {
00051 static Logger logger = ProActiveLogger.getLogger(Loggers.MIGRATION);
00052 private static final int MAX_TRIES = 15;
00053 private static int counter = 0;
00054 private int tries;
00055 transient protected LocationServer server;
00056
00057 public RequestWithMixedLocation(MethodCall methodCall,
00058 UniversalBody sender, boolean isOneWay, long nextSequenceID,
00059 LocationServer server) {
00060 super(methodCall, sender, isOneWay, nextSequenceID);
00061 if (logger.isDebugEnabled()) {
00062 logger.debug("RequestWithMixedLocation.RequestWithMixedLocation " +
00063 ++counter);
00064 }
00065 this.server = server;
00066 }
00067
00068 protected int sendRequest(UniversalBody destinationBody)
00069 throws java.io.IOException {
00070 int ftres = FTManager.NON_FT;
00071 if (logger.isDebugEnabled()) {
00072 logger.debug("RequestWithMixedLocation: sending to universal " +
00073 counter);
00074 }
00075 try {
00076 ftres = destinationBody.receiveRequest(this);
00077 } catch (Exception e) {
00078 this.backupSolution(destinationBody);
00079 }
00080 return ftres;
00081 }
00082
00086 protected void backupSolution(UniversalBody destinationBody)
00087 throws java.io.IOException {
00088 boolean ok = false;
00089 tries = 0;
00090
00091 UniqueID bodyID = destinationBody.getID();
00092 while (!ok && (tries < MAX_TRIES)) {
00093 UniversalBody remoteBody = null;
00094 UniversalBody mobile = queryServer(bodyID);
00095
00096
00097 remoteBody = (UniversalBody) ((FutureProxy) ((StubObject) mobile).getProxy()).getResult();
00098
00099 try {
00100 remoteBody.receiveRequest(this);
00101
00102
00103
00104 if (sender != null) {
00105 sender.updateLocation(bodyID, remoteBody);
00106 } else {
00107 LocalBodyStore.getInstance().getLocalBody(getSourceBodyID())
00108 .updateLocation(bodyID, remoteBody);
00109 }
00110 ok = true;
00111 } catch (Exception e) {
00112 logger.error("FAILED = " + " for method " + methodName);
00113 tries++;
00114 }
00115 }
00116 }
00117
00118 protected UniversalBody queryServer(UniqueID bodyID) {
00119 if (server == null) {
00120 server = LocationServerFactory.getLocationServer();
00121 }
00122 UniversalBody mobile = (UniversalBody) server.searchObject(bodyID);
00123 logger.debug("backupSolution() server has sent an answer");
00124 ProActive.waitFor(mobile);
00125 return mobile;
00126 }
00127 }
