00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.process.rlogin; 00032 00033 import org.objectweb.proactive.core.process.AbstractExternalProcessDecorator; 00034 import org.objectweb.proactive.core.process.ExternalProcess; 00035 import org.objectweb.proactive.core.process.SimpleExternalProcess; 00036 import org.objectweb.proactive.core.process.UniversalProcess; 00037 import org.objectweb.proactive.core.process.lsf.LSFBSubProcess; 00038 00039 00058 public class RLoginProcess extends AbstractExternalProcessDecorator { 00059 public final static String DEFAULT_RLOGINPATH = "/usr/bin/rlogin "; 00060 private boolean exitAfterCommand; 00061 private String username; 00062 // 00063 // -- CONSTRUCTORS ----------------------------------------------- 00064 // 00065 00070 public RLoginProcess() { 00071 super(); 00072 setCompositionType(SEND_TO_OUTPUT_STREAM_COMPOSITION); 00073 this.command_path = DEFAULT_RLOGINPATH; 00074 } 00075 00081 public RLoginProcess(ExternalProcess targetProcess) { 00082 this(targetProcess, false); 00083 } 00084 00091 public RLoginProcess(ExternalProcess targetProcess, boolean exitAfterCommand) { 00092 super(targetProcess, SEND_TO_OUTPUT_STREAM_COMPOSITION); 00093 this.exitAfterCommand = exitAfterCommand; 00094 this.command_path = DEFAULT_RLOGINPATH; 00095 } 00096 00097 // 00098 // -- PUBLIC METHODS ----------------------------------------------- 00099 // 00100 00104 public String getProcessId() { 00105 return "rlogin_" + targetProcess.getProcessId(); 00106 } 00107 00111 public int getNodeNumber() { 00112 return targetProcess.getNodeNumber(); 00113 } 00114 00118 public UniversalProcess getFinalProcess() { 00119 checkStarted(); 00120 return targetProcess.getFinalProcess(); 00121 } 00122 00127 public void setExitAfterCommand(boolean b) { 00128 exitAfterCommand = b; 00129 } 00130 00136 public boolean getExitAfterCommand() { 00137 return exitAfterCommand; 00138 } 00139 00140 public static void main(String[] args) { 00141 try { 00142 LSFBSubProcess lsf = new LSFBSubProcess(new SimpleExternalProcess( 00143 "ls -lsa")); 00144 RLoginProcess p = new RLoginProcess(lsf, false); 00145 p.setHostname("galere1"); 00146 p.startProcess(); 00147 } catch (Exception e) { 00148 e.printStackTrace(); 00149 } 00150 } 00151 00152 // 00153 // -- PROTECTED METHODS ----------------------------------------------- 00154 // 00155 protected String internalBuildCommand() { 00156 return buildEnvironmentCommand() + buildRLoginCommand(); 00157 } 00158 00159 protected String buildRLoginCommand() { 00160 String command; 00161 if(this.username == null) { 00162 command = DEFAULT_RLOGINPATH + hostname + " "; 00163 }else { 00164 command = DEFAULT_RLOGINPATH + "-l " + username + " " + hostname + " "; 00165 } 00166 return command; 00167 } 00168 00169 protected void internalStartProcess(String command) 00170 throws java.io.IOException { 00171 super.internalStartProcess(command); 00172 if (exitAfterCommand) { 00173 outputMessageSink.setMessage(null); 00174 } 00175 } 00176 00177 public String getUsername() { 00178 return username; 00179 } 00180 00181 public void setUsername(String username) { 00182 this.username = username; 00183 } 00184 00185 // 00186 // -- PRIVATE METHODS ----------------------------------------------- 00187 // 00188 }
1.5.1
