00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.group;
00032
00033 import java.lang.reflect.InvocationTargetException;
00034 import java.lang.reflect.Method;
00035 import java.lang.reflect.ParameterizedType;
00036 import java.util.Map;
00037 import java.util.Vector;
00038
00039 import org.objectweb.fractal.api.Component;
00040 import org.objectweb.fractal.api.Interface;
00041 import org.objectweb.proactive.Body;
00042 import org.objectweb.proactive.ProActive;
00043 import org.objectweb.proactive.core.ProActiveRuntimeException;
00044 import org.objectweb.proactive.core.body.LocalBodyStore;
00045 import org.objectweb.proactive.core.component.collectiveitfs.MulticastHelper;
00046 import org.objectweb.proactive.core.component.exceptions.ParameterDispatchException;
00047 import org.objectweb.proactive.core.component.identity.ProActiveComponent;
00048 import org.objectweb.proactive.core.component.type.ProActiveInterfaceType;
00049 import org.objectweb.proactive.core.component.type.ProActiveInterfaceTypeImpl;
00050 import org.objectweb.proactive.core.group.ExceptionListException;
00051 import org.objectweb.proactive.core.group.ProActiveComponentGroup;
00052 import org.objectweb.proactive.core.group.ProcessForAsyncCall;
00053 import org.objectweb.proactive.core.group.ProcessForOneWayCall;
00054 import org.objectweb.proactive.core.group.ProxyForGroup;
00055 import org.objectweb.proactive.core.mop.ClassNotReifiableException;
00056 import org.objectweb.proactive.core.mop.ConstructionOfReifiedObjectFailedException;
00057 import org.objectweb.proactive.core.mop.ConstructorCall;
00058 import org.objectweb.proactive.core.mop.MOP;
00059 import org.objectweb.proactive.core.mop.MethodCall;
00060 import org.objectweb.proactive.core.mop.StubObject;
00061
00062
00069 public class ProxyForComponentInterfaceGroup extends ProxyForGroup {
00070 protected ProActiveInterfaceType interfaceType;
00071 protected Class itfSignatureClass = null;
00072 protected ProActiveComponent owner;
00073 protected ProxyForComponentInterfaceGroup delegatee = null;
00074
00075 public ProxyForComponentInterfaceGroup()
00076 throws ConstructionOfReifiedObjectFailedException {
00077 super();
00078 className = Interface.class.getName();
00079 }
00080
00081 public ProxyForComponentInterfaceGroup(ConstructorCall c, Object[] p)
00082 throws ConstructionOfReifiedObjectFailedException {
00083 super(c, p);
00084 className = Interface.class.getName();
00085 }
00086
00087 public ProxyForComponentInterfaceGroup(String nameOfClass)
00088 throws ConstructionOfReifiedObjectFailedException {
00089 this();
00090 className = Interface.class.getName();
00091 }
00092
00096 public ProActiveInterfaceType getInterfaceType() {
00097 return interfaceType;
00098 }
00099
00100
00101
00102
00103 @Override
00104 public synchronized Object reify(MethodCall mc)
00105 throws InvocationTargetException {
00106 if (delegatee != null) {
00107
00108 if (itfSignatureClass.equals(mc.getReifiedMethod()
00109 .getDeclaringClass())) {
00110
00111 } else if (mc.getReifiedMethod().getDeclaringClass()
00112 .isAssignableFrom(itfSignatureClass)) {
00113
00114 Method adaptedMethod;
00115 try {
00116
00117 adaptedMethod = itfSignatureClass.getMethod(mc.getReifiedMethod()
00118 .getName(),
00119 mc.getReifiedMethod().getParameterTypes());
00120 } catch (SecurityException e) {
00121 throw new InvocationTargetException(e,
00122 "could not adapt client interface to multicast server interface " +
00123 interfaceType.getFcItfName());
00124 } catch (NoSuchMethodException e) {
00125 throw new InvocationTargetException(e,
00126 "could not adapt client interface to multicast server interface " +
00127 interfaceType.getFcItfName());
00128 }
00129 mc = MethodCall.getComponentMethodCall(adaptedMethod,
00130 mc.getEffectiveArguments(), mc.getGenericTypesMapping(),
00131 mc.getComponentMetadata().getComponentInterfaceName(),
00132 mc.getComponentMetadata().getSenderItfID(),
00133 mc.getComponentMetadata().getPriority());
00134 } else {
00135 throw new InvocationTargetException(null,
00136 "method " + mc.getName() + " defined in " +
00137 mc.getReifiedMethod().getDeclaringClass() +
00138 " cannot be invoked on " + itfSignatureClass.getName());
00139 }
00140 }
00141
00142 return super.reify(mc);
00143 }
00144
00145
00146
00147
00148 public Object getGroupByType() {
00149 try {
00150 Interface result = ProActiveComponentGroup.newComponentInterfaceGroup(interfaceType,
00151 owner);
00152
00153 ProxyForComponentInterfaceGroup proxy = (ProxyForComponentInterfaceGroup) ((StubObject) result).getProxy();
00154 proxy.memberList = this.memberList;
00155 proxy.className = this.className;
00156 proxy.interfaceType = this.interfaceType;
00157 proxy.owner = this.owner;
00158 proxy.proxyForGroupID = this.proxyForGroupID;
00159 proxy.waited = this.waited;
00160 return result;
00161 } catch (ClassNotReifiableException e) {
00162 e.printStackTrace();
00163 return null;
00164 } catch (ClassNotFoundException e) {
00165 e.printStackTrace();
00166 return null;
00167 }
00168 }
00169
00170
00171
00172
00173 @Override
00174 protected Object asynchronousCallOnGroup(MethodCall mc)
00175 throws InvocationTargetException {
00176 if (((ProActiveInterfaceTypeImpl) interfaceType).isFcCollective()) {
00177 if (delegatee != null) {
00178 Object result;
00179 Body body = ProActive.getBodyOnThis();
00180
00181
00182 try {
00183 Object[] paramProxy = new Object[0];
00184
00185
00186 if (!(mc.getReifiedMethod().getGenericReturnType() instanceof ParameterizedType)) {
00187 throw new ProActiveRuntimeException(
00188 "all methods in multicast interfaces must return parameterized lists, " +
00189 "which is not the case for method " +
00190 mc.getReifiedMethod().toString());
00191 }
00192
00193 Class returnTypeForGroup = (Class) ((ParameterizedType) mc.getReifiedMethod()
00194 .getGenericReturnType()).getActualTypeArguments()[0];
00195 result = MOP.newInstance(returnTypeForGroup.getName(),
00196 null, null, ProxyForGroup.class.getName(), paramProxy);
00197 ((ProxyForGroup) ((StubObject) result).getProxy()).setClassName(returnTypeForGroup.getName());
00198 } catch (Exception e) {
00199 e.printStackTrace();
00200 return null;
00201 }
00202
00203 Map<MethodCall, Integer> generatedMethodCalls;
00204
00205 try {
00206 generatedMethodCalls = MulticastHelper
00207 .generateMethodCallsForMulticastDelegatee(owner, mc,
00208 delegatee);
00209 } catch (ParameterDispatchException e) {
00210 throw new InvocationTargetException(e,
00211 "cannot dispatch invocation parameters for method " +
00212 mc.getReifiedMethod().toString() +
00213 " from collective interface " +
00214 interfaceType.getFcItfName());
00215 }
00216
00217
00218 Vector memberListOfResultGroup = ((ProxyForGroup) ((StubObject) result).getProxy()).getMemberList();
00219
00220
00221 for (int i = 0; i < generatedMethodCalls.size(); i++) {
00222 memberListOfResultGroup.add(null);
00223 }
00224
00225 for (MethodCall currentMc : generatedMethodCalls.keySet()) {
00226
00227 this.threadpool.addAJob(new ProcessForAsyncCall(delegatee,
00228 delegatee.memberList, memberListOfResultGroup,
00229 generatedMethodCalls.get(currentMc), currentMc, body));
00230 }
00231
00232 LocalBodyStore.getInstance().setCurrentThreadBody(body);
00233 return result;
00234 } else {
00235 Thread.dumpStack();
00236 return null;
00237 }
00238 } else {
00239 return super.asynchronousCallOnGroup(mc);
00240 }
00241 }
00242
00243
00244
00245
00246 @Override
00247 protected void oneWayCallOnGroup(MethodCall mc,
00248 ExceptionListException exceptionList) throws InvocationTargetException {
00249 if (((ProActiveInterfaceTypeImpl) interfaceType).isFcCollective() &&
00250 (delegatee != null)) {
00251
00252
00253 Body body = ProActive.getBodyOnThis();
00254
00255 Map<MethodCall, Integer> generatedMethodCalls;
00256
00257 try {
00258 generatedMethodCalls = MulticastHelper
00259 .generateMethodCallsForMulticastDelegatee(owner, mc,
00260 delegatee);
00261 } catch (ParameterDispatchException e) {
00262 throw new InvocationTargetException(e,
00263 "cannot dispatch invocation parameters for method " +
00264 mc.getReifiedMethod().toString() +
00265 " from collective interface " +
00266 interfaceType.getFcItfName());
00267 }
00268
00269 for (MethodCall currentMc : generatedMethodCalls.keySet()) {
00270
00271 this.threadpool.addAJob(new ProcessForOneWayCall(delegatee,
00272 delegatee.memberList,
00273 generatedMethodCalls.get(currentMc), currentMc, body,
00274 exceptionList));
00275 }
00276
00277 LocalBodyStore.getInstance().setCurrentThreadBody(body);
00278 }
00279
00280
00281 super.oneWayCallOnGroup(mc, exceptionList);
00282 }
00283
00288 public void setDelegatee(ProxyForComponentInterfaceGroup delegatee) {
00289 this.delegatee = delegatee;
00290 }
00291
00296 public ProxyForComponentInterfaceGroup getDelegatee() {
00297 return delegatee;
00298 }
00299
00300
00301
00302
00303 @Override
00304 public int size() {
00305 if (getDelegatee() != null) {
00306 return getDelegatee().size();
00307 }
00308 return super.size();
00309 }
00310
00314 public Component getOwner() {
00315 return owner;
00316 }
00317
00321 public void setOwner(Component owner) {
00322 this.owner = (ProActiveComponent)owner;
00323 }
00324
00328 public void setInterfaceType(ProActiveInterfaceType interfaceType) {
00329 this.interfaceType = interfaceType;
00330 try {
00331 itfSignatureClass = Class.forName(interfaceType.getFcItfSignature());
00332 } catch (ClassNotFoundException e) {
00333 throw new ProActiveRuntimeException("cannot find Java interface " +
00334 interfaceType.getFcItfSignature() +
00335 " defined in interface named " + interfaceType.getFcItfName(), e);
00336 }
00337 }
00338 }
