00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.ext.webservices.soap;
00032
00033 import java.lang.reflect.Method;
00034 import java.net.MalformedURLException;
00035 import java.net.URL;
00036 import java.util.Enumeration;
00037 import java.util.Hashtable;
00038 import java.util.StringTokenizer;
00039 import java.util.Vector;
00040
00041 import org.apache.soap.SOAPException;
00042 import org.apache.soap.server.DeploymentDescriptor;
00043 import org.apache.soap.server.ServiceManagerClient;
00044 import org.apache.soap.server.TypeMapping;
00045 import org.apache.soap.util.xml.QName;
00046 import org.objectweb.fractal.api.Component;
00047 import org.objectweb.fractal.api.Interface;
00048 import org.objectweb.fractal.api.control.LifeCycleController;
00049 import org.objectweb.proactive.core.body.http.util.HttpMarshaller;
00050 import org.objectweb.proactive.core.component.type.ProActiveInterfaceTypeImpl;
00051 import org.objectweb.proactive.ext.webservices.WSConstants;
00052 import org.objectweb.proactive.ext.webservices.wsdl.WSDLGenerator;
00053
00054
00060 public class ProActiveDeployer extends WSConstants {
00061
00069     public static void deploy(String urn, String url, Object o, String[] methods) {
00070         deploy(urn, url, o, null, methods, false);
00071     }
00072
00081     public static void deployComponent(String componentName, String url,
00082         Component component) {
00083         Object[] interfaces = component.getFcInterfaces();
00084
00085         for (int i = 0; i < interfaces.length; i++) {
00086             Interface interface_ = ((Interface) interfaces[i]);
00087
00088
00089             if (!(interface_ instanceof LifeCycleController)) {
00090                 if (!((ProActiveInterfaceTypeImpl) interface_.getFcItfType()).isFcClientItf()) {
00091                     String name = interface_.getFcItfName();
00092
00093
00094                     Method[] methods = interface_.getClass().getMethods();
00095                     Vector meths = new Vector();
00096
00097                     for (int j = 0; j < methods.length; j++) {
00098                         String methodName = methods[j].getName();
00099
00100                         if (isAllowedMethod(methodName)) {
00101                             meths.addElement(methodName);
00102                         }
00103                     }
00104
00105                     String[] methsArray = new String[meths.size()];
00106                     meths.toArray(methsArray);
00107                     deploy(componentName + "_" + name, url, interface_,
00108                         component, methsArray, true);
00109                 }
00110             }
00111         }
00112     }
00113
00119     public static void undeploy(String urn, String url) {
00120         ServiceManagerClient serviceManagerClient = null;
00121
00122         try {
00123             serviceManagerClient = new ServiceManagerClient(new URL(url +
00124                         ROUTER));
00125             serviceManagerClient.undeploy(urn);
00126         } catch (MalformedURLException e) {
00127             e.printStackTrace();
00128         } catch (SOAPException e1) {
00129             e1.printStackTrace();
00130         }
00131     }
00132
00139     public static void undeployComponent(String componentName, String url,
00140         Component component) {
00141         Object[] interfaces = component.getFcInterfaces();
00142
00143         for (int i = 0; i < interfaces.length; i++) {
00144             Interface inter = (Interface) interfaces[i];
00145
00146             if (!(inter instanceof LifeCycleController)) {
00147                 if (!((ProActiveInterfaceTypeImpl) inter.getFcItfType()).isFcClientItf()) {
00148                     String serviceName = componentName + "_" +
00149                         inter.getFcItfName();
00150                     undeploy(serviceName, url);
00151                 }
00152             }
00153         }
00154     }
00155
00156
00157
00158
00159     private static void deploy(String urn, String url, Object o, Component c,
00160         String[] methods, boolean componentInterface) {
00161
00162
00163         String wsdl = WSDLGenerator.getWSDL(o.getClass().getSuperclass(), urn,
00164                 url + ROUTER, DOCUMENTATION, methods);
00165
00166
00167         ServiceManagerClient serviceManagerClient = null;
00168
00169         try {
00170             serviceManagerClient = new ServiceManagerClient(new URL(url +
00171                         ROUTER));
00172         } catch (MalformedURLException e) {
00173             e.printStackTrace();
00174         }
00175
00176
00177         DeploymentDescriptor dd = new DeploymentDescriptor();
00178         dd.setID(urn);
00179         dd.setProviderType(DeploymentDescriptor.PROVIDER_USER_DEFINED);
00180
00181         dd.setServiceClass(PROACTIVE_PROVIDER);
00182
00183         dd.setIsStatic(false);
00184
00185
00186         TypeMapping[] tms = getMappings(o.getClass(), methods);
00187         dd.setMappings(tms);
00188
00189         if (methods != null) {
00190             dd.setMethods(methods);
00191         } else {
00192             Method[] ms = o.getClass().getDeclaredMethods();
00193             Vector mv = new Vector();
00194             for (int i = 0; i < ms.length; i++)
00195                 if (!disallowedMethods.contains(ms[i].getName())) {
00196                     mv.addElement(ms[i].getName());
00197                 }
00198             methods = new String[mv.size()];
00199             Enumeration e = mv.elements();
00200             int j = 0;
00201             while (e.hasMoreElements())
00202                 methods[j++] = (String) e.nextElement();
00203
00204             dd.setMethods(methods);
00205         }
00206
00207         dd.setProviderClass(o.getClass().getName());
00208
00209
00210         Hashtable props = new Hashtable();
00211
00212         props.put(WSDL_FILE, wsdl);
00213
00214         if (componentInterface) {
00215             props.put(COMPONENT_INTERFACE, "true");
00216             props.put(PROACTIVE_STUB, HttpMarshaller.marshallObject(c));
00217         } else {
00218             props.put(COMPONENT_INTERFACE, "false");
00219             props.put(PROACTIVE_STUB, HttpMarshaller.marshallObject(o));
00220         }
00221
00222         dd.setProps(props);
00223
00224         try {
00225             serviceManagerClient.deploy(dd);
00226         } catch (SOAPException e1) {
00227             e1.printStackTrace();
00228         }
00229     }
00230
00231
00232
00233
00234     private static boolean isAllowedMethod(String method) {
00235         return !disallowedMethods.contains(method);
00236     }
00237
00238
00239
00240
00241
00242     private static TypeMapping[] getMappings(Class c, String[] methods) {
00243         Vector tms = new Vector();
00244         Vector sMethods = new Vector();
00245
00246         if (methods != null) {
00247             for (int i = 0; i < methods.length; i++) {
00248                 sMethods.addElement(methods[i]);
00249             }
00250
00251             Vector mMethods = new Vector();
00252             Method[] ms = c.getDeclaredMethods();
00253
00254             for (int i = 0; i < ms.length; i++) {
00255                 mMethods.addElement(ms[i]);
00256             }
00257
00258             Enumeration e = mMethods.elements();
00259
00260             while (e.hasMoreElements()) {
00261                 Method m = (Method) e.nextElement();
00262
00263                 if (sMethods.contains(m.getName())) {
00264                     Class[] parameters = m.getParameterTypes();
00265
00266                     for (int j = 0; j < parameters.length; j++) {
00267                         if (!supportedTypes.contains(parameters[j])) {
00268                             String pname = extractName(parameters[j]);
00269
00270                             TypeMapping tm = new TypeMapping("http://schemas.xmlsoap.org/soap/encoding/",
00271                                     new QName("http://" + pname,
00272                                         getSimpleName(parameters[j])),
00273                                     parameters[j].getName(),
00274                                     "org.apache.soap.encoding.soapenc.BeanSerializer",
00275                                     "org.apache.soap.encoding.soapenc.BeanSerializer");
00276
00277                             tms.addElement(tm);
00278                         }
00279                     }
00280                 }
00281             }
00282         } else {
00283             Method[] ms = c.getDeclaredMethods();
00284
00285             for (int i = 0; i < ms.length; i++) {
00286                 if (!disallowedMethods.contains(ms[i].getName())) {
00287                     Class[] parameters = ms[i].getParameterTypes();
00288                     for (int j = 0; j < parameters.length; j++) {
00289                         if (!supportedTypes.contains(parameters[j])) {
00290                             String pname = extractName(parameters[j]);
00291
00292                             TypeMapping tm = new TypeMapping("http://schemas.xmlsoap.org/soap/encoding/",
00293                                     new QName("http://" + pname,
00294                                         getSimpleName(parameters[j])),
00295                                     parameters[j].getName(),
00296                                     "org.apache.soap.encoding.soapenc.BeanSerializer",
00297                                     "org.apache.soap.encoding.soapenc.BeanSerializer");
00298
00299                             tms.addElement(tm);
00300                         }
00301                     }
00302                 }
00303             }
00304         }
00305
00306         TypeMapping[] tmsArray = new TypeMapping[tms.size()];
00307         Enumeration e = tms.elements();
00308
00309         int i = 0;
00310
00311         while (e.hasMoreElements()) {
00312             tmsArray[i++] = (TypeMapping) e.nextElement();
00313         }
00314
00315         return tmsArray;
00316     }
00317
00318     private static String getSimpleName(Class c) {
00319         String cName = c.getName();
00320         StringTokenizer st = new StringTokenizer(cName, ".");
00321         String result = "";
00322
00323         while (st.hasMoreTokens())
00324             result = st.nextToken();
00325
00326         return result;
00327     }
00328
00329
00330
00331
00332     private static String extractName(Class c) {
00333         String result = new String();
00334
00335         Package p = c.getPackage();
00336
00337         if (p != null) {
00338             String packageName = p.getName();
00339             StringTokenizer st = new StringTokenizer(packageName, ".");
00340             int nbTokens = st.countTokens();
00341             String[] tmp = new String[nbTokens];
00342             int n = 0;
00343
00344             while (st.hasMoreTokens())
00345                 tmp[n++] = st.nextToken();
00346
00347             for (int i = nbTokens - 1; i > -1; i--)
00348                 result += (tmp[i] + ".");
00349
00350             return result.substring(0, result.length() - 1);
00351         }
00352
00353         return "DefaultNamespace";
00354     }
00355 }
