00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.adl.bindings;
00032
00033 import java.util.HashMap;
00034 import java.util.List;
00035 import java.util.Map;
00036 import java.util.NoSuchElementException;
00037
00038 import org.objectweb.deployment.scheduling.component.api.InstanceProviderTask;
00039 import org.objectweb.deployment.scheduling.core.api.Task;
00040 import org.objectweb.fractal.adl.ADLException;
00041 import org.objectweb.fractal.adl.TaskMap;
00042 import org.objectweb.fractal.adl.bindings.Binding;
00043 import org.objectweb.fractal.adl.bindings.BindingBuilder;
00044 import org.objectweb.fractal.adl.bindings.BindingCompiler;
00045 import org.objectweb.fractal.adl.bindings.BindingContainer;
00046 import org.objectweb.fractal.adl.components.Component;
00047 import org.objectweb.fractal.adl.components.ComponentContainer;
00048 import org.objectweb.fractal.adl.components.ComponentPair;
00049 import org.objectweb.fractal.adl.interfaces.Interface;
00050 import org.objectweb.fractal.adl.interfaces.InterfaceContainer;
00051 import org.objectweb.fractal.adl.types.TypeInterface;
00052 import org.objectweb.proactive.core.component.adl.types.ProActiveTypeInterface;
00053
00054 public class ProActiveBindingCompiler extends BindingCompiler {
00055
00056
00057 private static Map<String, Integer> multicastItfTaskIndexer = new HashMap<String, Integer>();
00058
00059
00060
00061
00062
00063 public void compile (
00064 final List path,
00065 final ComponentContainer container,
00066 final TaskMap tasks,
00067 final Map context) throws ADLException
00068 {
00069 Map subComponents = new HashMap();
00070 subComponents.put("this", container);
00071 Component[] comps = container.getComponents();
00072 for (int i = 0; i < comps.length; i++) {
00073 subComponents.put(comps[i].getName(), comps[i]);
00074 }
00075
00076 if (container instanceof BindingContainer) {
00077 Binding[] bindings = ((BindingContainer)container).getBindings();
00078 for (int i = 0; i < bindings.length; i++) {
00079 Binding binding = bindings[i];
00080
00081 String value = binding.getFrom();
00082 int index = value.indexOf('.');
00083 Object clientComp = subComponents.get(value.substring(0, index));
00084 String clientItf = value.substring(index + 1);
00085
00086 value = binding.getTo();
00087 index = value.indexOf('.');
00088 Object serverComp = subComponents.get(value.substring(0, index));
00089 String serverItf = value.substring(index + 1);
00090
00091 InstanceProviderTask createClientTask =
00092 (InstanceProviderTask)tasks.getTask("create", clientComp);
00093 InstanceProviderTask createServerTask =
00094 (InstanceProviderTask)tasks.getTask("create", serverComp);
00095
00096 int type = BindingBuilder.NORMAL_BINDING;
00097 if (binding.getFrom().startsWith("this.")) {
00098 type = BindingBuilder.EXPORT_BINDING;
00099 }
00100 if (binding.getTo().startsWith("this.")) {
00101 type = BindingBuilder.IMPORT_BINDING;
00102 }
00103
00104 try {
00105
00106
00107 if ( (BindingBuilder.EXPORT_BINDING == type)
00108 && (container instanceof BindingContainer)
00109 && (container instanceof InterfaceContainer)) {
00110 Interface[] itfs = ((InterfaceContainer)container).getInterfaces();
00111 for (int j = 0; j < itfs.length; j++) {
00112 TypeInterface itf = (TypeInterface)itfs[j];
00113 if (clientItf.equals(itf.getName())) {
00114 if (ProActiveTypeInterface.MULTICAST_CARDINALITY.equals(itf.getCardinality())) {
00115 throw new NoSuchElementException(clientItf);
00116 }
00117 }
00118 }
00119
00120
00121 } else if ((clientComp instanceof BindingContainer)
00122 && (clientComp instanceof InterfaceContainer)) {
00123 Interface[] itfs = ((InterfaceContainer)clientComp).getInterfaces();
00124 for (int j = 0; j < itfs.length; j++) {
00125 TypeInterface itf = (TypeInterface)itfs[j];
00126 if (clientItf.equals(itf.getName())) {
00127 if (ProActiveTypeInterface.MULTICAST_CARDINALITY.equals(itf.getCardinality())) {
00128 throw new NoSuchElementException(clientItf);
00129 }
00130 }
00131 }
00132 }
00133
00134
00135
00136 tasks.getTask("bind" + clientItf, clientComp);
00137
00138 } catch (NoSuchElementException e) {
00139 BindTask bindTask = new BindTask(builder, type, clientItf, serverItf);
00140 bindTask.setInstanceProviderTask(createClientTask);
00141 bindTask.setServerInstanceProviderTask(createServerTask);
00142
00143
00144 if ( (BindingBuilder.EXPORT_BINDING == type)
00145 && (container instanceof BindingContainer)
00146 && (container instanceof InterfaceContainer)) {
00147
00148 InterfaceContainer itfContainer = ((InterfaceContainer)container);
00149 clientItf = setMulticastIndex(clientComp, clientItf, itfContainer);
00150 } else if ((clientComp instanceof BindingContainer)
00151 && (clientComp instanceof InterfaceContainer)) {
00152
00153 InterfaceContainer itfContainer = ((InterfaceContainer)clientComp);
00154 clientItf = setMulticastIndex(
00155 clientComp, clientItf, itfContainer);
00156 }
00157
00158 tasks.addTask("bind" + clientItf, clientComp, bindTask);
00159
00160 if (clientComp != container) {
00161 Task addTask = tasks.getTask("add", new ComponentPair(
00162 container, (Component)clientComp));
00163 bindTask.addPreviousTask(addTask);
00164 }
00165 if (serverComp != container) {
00166 Task addTask = tasks.getTask("add", new ComponentPair(
00167 container, (Component)serverComp));
00168 bindTask.addPreviousTask(addTask);
00169 }
00170
00171 Task startTask = tasks.getTask("start", clientComp);
00172 startTask.addPreviousTask(bindTask);
00173 }
00174 }
00175 }
00176 }
00177
00184 private String setMulticastIndex(Object clientComp, String clientItf, InterfaceContainer itfContainer) {
00185
00186 Interface[] itfs = itfContainer.getInterfaces();
00187 for (int j = 0; j < itfs.length; j++) {
00188 TypeInterface itf = (TypeInterface)itfs[j];
00189 if (clientItf.equals(itf.getName())) {
00190 if (ProActiveTypeInterface.MULTICAST_CARDINALITY.equals(itf.getCardinality())) {
00191
00192
00193 int multicastIndex = 1;
00194 if (multicastItfTaskIndexer.containsKey(clientComp+clientItf)) {
00195
00196 multicastIndex += multicastItfTaskIndexer.get(clientComp+clientItf);
00197 multicastItfTaskIndexer.put(clientComp+clientItf, multicastIndex);
00198 } else {
00199
00200 multicastItfTaskIndexer.put(clientComp+clientItf, multicastIndex);
00201 }
00202 clientItf = clientItf+"-" + multicastIndex;
00203 }
00204 }
00205 }
00206 return clientItf;
00207 }
00208
00209 }
