00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.event; 00032 00033 import org.objectweb.proactive.core.descriptor.data.VirtualNode; 00034 import org.objectweb.proactive.core.node.Node; 00035 00036 00047 public class NodeCreationEvent extends ProActiveEvent { 00048 public static final int NODE_CREATED = 10; 00049 protected Node node; 00050 protected VirtualNode vn; 00051 protected int nodeCreated; 00052 00060 public NodeCreationEvent(VirtualNode vn, int messageType, Node node, 00061 int nodeCreated) { 00062 super(vn, messageType); 00063 this.node = node; 00064 this.vn = vn; 00065 this.nodeCreated = nodeCreated; 00066 } 00067 00071 public Node getNode() { 00072 return node; 00073 } 00074 00078 public VirtualNode getVirtualNode() { 00079 return vn; 00080 } 00081 00085 public int getNodeCreated() { 00086 return nodeCreated; 00087 } 00088 }
1.5.1
