00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.util.wrapper; 00032 00033 import java.io.Serializable; 00034 00035 00044 public class IntWrapper implements Serializable { 00045 00049 private int value; 00050 00054 public IntWrapper() { 00055 // nothing to do 00056 } 00057 00062 public IntWrapper(int value) { 00063 this.value = value; 00064 } 00065 00070 public int intValue() { 00071 return this.value; 00072 } 00073 00077 public String toString() { 00078 return this.value + ""; 00079 } 00080 00081 @Override 00082 public boolean equals(Object arg0) { 00083 if (arg0 instanceof IntWrapper) { 00084 return ((IntWrapper) arg0).intValue() == this.value; 00085 } 00086 return false; 00087 } 00088 00089 @Override 00090 public int hashCode() { 00091 return new Integer(this.value).hashCode(); 00092 } 00093 00094 }
1.5.1
