org/objectweb/proactive/core/process/glite/GLiteProcess.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.process.glite;
00032
00033 import javax.naming.directory.InvalidAttributeValueException;
00034
00035 import org.glite.wms.jdlj.*; // /lib/glite/glite-wms-jdlj.jar
00036 import org.objectweb.proactive.ProActive;
00037 import org.objectweb.proactive.core.ProActiveException;
00038 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00039 import org.objectweb.proactive.core.process.AbstractExternalProcessDecorator;
00040 import org.objectweb.proactive.core.process.ExternalProcess;
00041 import org.objectweb.proactive.core.process.JVMProcess;
00042 import org.objectweb.proactive.core.process.UniversalProcess;
00043 import org.objectweb.proactive.core.process.filetransfer.FileDependant;
00044 import org.objectweb.proactive.core.process.filetransfer.FileTransferDefinition;
00045
00046 import java.util.LinkedList;
00047
00048
00060 public class GLiteProcess extends AbstractExternalProcessDecorator
00061         implements FileDependant {
00062
00066     private static final long serialVersionUID = 1L;
00067     private static final String FILE_SEPARATOR = System.getProperty(
00068             "file.separator");
00069     protected static final String DEFAULT_PROCESSOR_NUMBER = "1";
00070     protected static final String DEFAULT_COMMAND_PATH = "glite-job-submit";
00071     protected static final String DEFAULT_FILE_LOCATION = System.getProperty(
00072             "user.home") + FILE_SEPARATOR + "public" + FILE_SEPARATOR + "JDL";
00073     protected static final String DEFAULT_STDOUPUT = System.getProperty(
00074             "user.home") + FILE_SEPARATOR + "out.log";
00075     protected static final String DEFAULT_CONFIG_FILE = System.getProperty(
00076             "user.home") + FILE_SEPARATOR + "public" + FILE_SEPARATOR + "JDL" +
00077             FILE_SEPARATOR + "vo.conf";
00078     protected int jobID;
00079     protected String hostList;
00080     protected String processor = DEFAULT_PROCESSOR_NUMBER;
00081     protected String command_path = DEFAULT_COMMAND_PATH;
00082     protected String interactive = "false";
00083     protected String filePath = DEFAULT_FILE_LOCATION;
00084     protected String stdOutput = DEFAULT_STDOUPUT;
00085     protected String fileName = "job.jdl";
00086     protected String configFile = DEFAULT_CONFIG_FILE;
00087     protected String remoteFilePath = null;
00088     protected boolean confFileOption = false;
00089     protected boolean jdlRemote = false;
00090     protected String netServer;
00091     protected String logBook;
00092     /*jdl related fields*/
00093     protected GLiteJobAd jad;
00094     protected int jobNodeNumber = 2;
00095     protected String jobType;
00096     protected String jobJobType;
00097     protected String jobExecutable;
00098     protected String jobStdOutput;
00099     protected String jobStdInput;
00100     protected String jobStdError;
00101     protected String jobOutput_se;
00102     protected String jobVO;
00103     protected String jobRetryCount;
00104     protected String jobMyProxyServer;
00105     protected String jobDataAccessProtocol;
00106     protected String jobStorageIndex;
00107     protected String jobEnvironment;
00108     protected String jobRequirements;
00109     protected String jobRank;
00110     protected String jobFuzzyRank;
00111     protected String jobArgument;
00112     protected LinkedList jobInputSB;
00113     protected LinkedList jobOutputSB;
00114
00119     public GLiteProcess() {
00120         super();
00121         setCompositionType(COPY_FILE_AND_APPEND_COMMAND);
00122         this.hostname = null;
00123         command_path = DEFAULT_COMMAND_PATH;
00124         jad = new GLiteJobAd();
00125     }
00126
00133     public GLiteProcess(ExternalProcess targetProcess) {
00134         super(targetProcess);
00135         setCompositionType(COPY_FILE_AND_APPEND_COMMAND);
00136         this.hostname = null;
00137         jad = new GLiteJobAd();
00138     }
00139
00140
00141     public static void main(String[] args) {
00142         ProActiveDescriptor pad;
00143         try {
00144             pad = ProActive.getProactiveDescriptor(args[0]);
00145             pad.activateMappings();
00146         } catch (ProActiveException e) {
00147             e.printStackTrace();
00148         }
00149     }
00150
00155     public void buildJdlFile() {
00156         StringBuffer gLiteCommand = new StringBuffer();
00157         String args;
00158         gLiteCommand.append(command_path);
00159         String initial_args = ((JVMProcess) getTargetProcess()).getCommand();
00160
00164         if (this.getJobType().equals("MPICH")) {
00165             args = this.getJobExecutable() + initial_args.substring(initial_args.indexOf("/bin/java") + "/bin/java".length());
00166             /*arguments will be parsed again at script level within gLite environment*/
00167             this.setJobExecutable("gLiteStartRuntime.sh");
00168         } else {
00169             args = initial_args.substring(initial_args.indexOf("/bin/java") + "/bin/java".length());
00170         }
00171
00172         args = checkSyntax(args);
00173
00174         try {
00175             /*multiple job*/
00176             if (this.getJobType().equals("job") && this.getJobJobType().equals("mpich") ) {
00177                 this.jad.addAttribute(Jdl.TYPE,  "job");
00178                 this.jad.addAttribute(Jdl.JOBTYPE,  Jdl.JOBTYPE_MPICH);
00179                 this.jad.addAttribute(Jdl.NODENUMB, this.getJobNodeNumber());
00180
00181             /*single job, number of nodes doesn t matter (so far)*/
00182             } else if (this.getJobType() != null) {
00183                 this.jad.addAttribute(Jdl.TYPE, "job");
00184             }
00185
00186             if (this.getJobExecutable() != null)
00187                 this.jad.addAttribute(Jdl.EXECUTABLE, this.getJobExecutable());
00188
00189             if (this.getJobStdOutput() != null)
00190                 this.jad.addAttribute(Jdl.STDOUTPUT, this.getJobStdOutput());
00191
00192             if (this.getJobStdInput() != null)
00193                 this.jad.addAttribute(Jdl.STDINPUT, this.getJobStdInput());
00194
00195             if (this.getJobStdError() != null)
00196                 this.jad.addAttribute(Jdl.STDERROR, this.getJobStdError());
00197
00198             if (this.getJobOutput_se() != null)
00199                 this.jad.addAttribute(Jdl.OUTPUT_SE, this.getJobOutput_se());
00200
00201             if (this.getJobVO() != null)
00202                 this.jad.addAttribute(Jdl.VIRTUAL_ORGANISATION, this.getJobVO());
00203
00204             if (this.getJobRetryCount() != null)
00205                 this.jad.addAttribute(Jdl.RETRYCOUNT, Integer.parseInt(getJobRetryCount()));
00206
00207             if (this.getJobMyProxyServer() != null)
00208                 this.jad.addAttribute(Jdl.MYPROXY, this.getJobMyProxyServer());
00209
00210             if (this.getJobEnvironment() != null)
00211                 this.jad.addAttribute(Jdl.ENVIRONMENT, this.getJobEnvironment());
00212
00213             if (this.getJobRequirements() != null)
00214                 this.jad.setAttributeExpr(Jdl.REQUIREMENTS, this.getJobRequirements());
00215
00216             if (this.getJobRank() != null)
00217                 this.jad.setAttributeExpr(Jdl.RANK, this.getJobRank());
00218
00219             if (this.getJobDataAccessProtocol() != null)
00220                 this.jad.addAttribute(Jdl.DATA_ACCESS, this.getJobDataAccessProtocol());
00221
00222             if (this.getJobStorageIndex() != null)
00223                 this.jad.addAttribute(Jdl.OD_STORAGE_ELEMENT, this.getJobStorageIndex());
00224
00225             if (this.getJobFuzzyRank() != null)
00226                 this.jad.addAttribute(Jdl.FUZZY_RANK, this.getJobFuzzyRank());
00227
00228             if (this.jobInputSB != null && this.jobInputSB.size() > 0) {
00229                 for (int i = 0; i < this.jobInputSB.size(); i++) {
00230                     String entry = (String) jobInputSB.get(i);
00231                     this.jad.addAttribute(Jdl.INPUTSB, entry);
00232                 }
00233             }
00234             if (this.jobOutputSB != null && this.jobOutputSB.size() > 0) {
00235                 for (int i = 0; i < this.jobOutputSB.size(); i++) {
00236                     String entry = (String) jobOutputSB.get(i);
00237                     this.jad.addAttribute(Jdl.OUTPUTSB, entry);
00238                 }
00239             }
00240
00241             if (jad.hasAttribute(Jdl.ARGUMENTS)) {
00242                 jad.delAttribute(Jdl.ARGUMENTS);
00243             }
00244             jad.setAttribute(Jdl.ARGUMENTS, args);
00245             jad.toFile(filePath + "/" + fileName);
00246
00247             //examples of requirements
00248             //jad.setAttributeExpr(Jdl.REQUIREMENTS,"other.GlueCEUniqueID ==\"pps-ce.egee.cesga.es:2119/blah-pbs-picard\"");
00249             //jad.setAttributeExpr(Jdl.REQUIREMENTS, "!(RegExp(\"*lxb2039*\",other.GlueCEUniqueID))");
00250         } catch (IllegalArgumentException e) {
00251             e.printStackTrace();
00252         } catch (InvalidAttributeValueException e) {
00253             e.printStackTrace();
00254         } catch (Exception e) {
00255             e.printStackTrace();
00256         }
00257     }
00258
00259     protected String internalBuildCommand() {
00260         return buildGLiteCommand();
00261     }
00262
00270     protected String buildGLiteCommand() {
00271         String path = filePath;
00272         buildJdlFile();
00273
00274         if (jdlRemote) {
00275             path = remoteFilePath;
00276         }
00277
00278         if (!confFileOption) {
00279             return DEFAULT_COMMAND_PATH + " " + path + FILE_SEPARATOR +
00280                     fileName;
00281         }
00282
00283         return DEFAULT_COMMAND_PATH + " --config-vo " + configFile + " " +
00284                 path + FILE_SEPARATOR + fileName;
00285     }
00286
00293     private String checkSyntax(String args) {
00294         String formatted_args = "";
00295         String[] splitted_args = args.split("\\s");
00296         for (int i = 0; i < splitted_args.length; i++) {
00297             if (!(splitted_args[i].indexOf("=") < 0)) {
00298                 splitted_args[i] = "\"" + splitted_args[i] + "\"";
00299             }
00300             formatted_args = formatted_args + " " + splitted_args[i];
00301         }
00302         return formatted_args;
00303     }
00304
00311     /* (non-Javadoc)
00312      * @see org.objectweb.proactive.core.process.UniversalProcess#getProcessId()
00313      */
00314     public String getProcessId() {
00315         return "glite_" + targetProcess.getProcessId();
00316     }
00317
00321     public int getNodeNumber() {
00322         return this.getJobNodeNumber();
00323     }
00324
00328     public String getProcessorNumber() {
00329         return processor;
00330     }
00331
00332     public UniversalProcess getFinalProcess() {
00333         checkStarted();
00334         return targetProcess.getFinalProcess();
00335     }
00336
00340     public String getFileName() {
00341         return fileName;
00342     }
00343
00347     public void setFileName(String fileName) {
00348         this.fileName = fileName;
00349     }
00350
00354     public String getFilePath() {
00355         return filePath;
00356     }
00357
00361     public void setFilePath(String filePath) {
00362         this.filePath = filePath;
00363     }
00364
00368     public String getCommand_path() {
00369         return command_path;
00370     }
00371
00375     public void setCommand_path(String command_path) {
00376         this.command_path = command_path;
00377     }
00378
00382     public GLiteJobAd getJad() {
00383         return jad;
00384     }
00385
00392     public void addAtt(String attrName, Ad attrValue) throws Exception {
00393         jad.addAttribute(attrName, attrValue);
00394     }
00395
00402     public void addAtt(String attrName, int attrValue)
00403             throws Exception {
00404         jad.addAttribute(attrName, attrValue);
00405     }
00406
00413     public void addAtt(String attrName, double attrValue)
00414             throws Exception {
00415         jad.addAttribute(attrName, attrValue);
00416     }
00417
00424     public void addAtt(String attrName, String attrValue)
00425             throws Exception {
00426         jad.addAttribute(attrName, attrValue);
00427     }
00428
00435     public void addAtt(String attrName, boolean attrValue)
00436             throws Exception {
00437         jad.addAttribute(attrName, attrValue);
00438     }
00439
00443     public String getNetServer() {
00444         return netServer;
00445     }
00446
00450     public void setNetServer(String netServer) {
00451         this.netServer = netServer;
00452     }
00453
00457     public String getConfigFile() {
00458         return configFile;
00459     }
00460
00464     public void setConfigFile(String configFile) {
00465         this.configFile = configFile;
00466     }
00467
00468     public void setConfigFileOption(boolean b) {
00469         confFileOption = b;
00470     }
00471
00475     public boolean isJdlRemote() {
00476         return jdlRemote;
00477     }
00478
00482     public void setJdlRemote(boolean jdlRemote) {
00483         this.jdlRemote = jdlRemote;
00484     }
00485
00489     public String getRemoteFilePath() {
00490         return remoteFilePath;
00491     }
00492
00496     public void setRemoteFilePath(String remoteFilePath) {
00497         this.remoteFilePath = remoteFilePath;
00498     }
00499
00500     public FileTransferDefinition getFileTransfertDefiniton() {
00501         FileTransferDefinition ft = new FileTransferDefinition("gliteProcess");
00502         ft.addFile(filePath + "/" + fileName, remoteFilePath + "/" + fileName);
00503         return ft;
00504     }
00505
00510     public int getJobNodeNumber() {
00511         return jobNodeNumber;
00512     }
00513
00518     public void setJobNodeNumber(int jobNodeNumber) {
00519         this.jobNodeNumber = jobNodeNumber;
00520     }
00521
00525     public String getJobType() {
00526         return jobType;
00527     }
00528
00533     public void setJobType(String jobType) {
00534         this.jobType = jobType;
00535     }
00536
00541     public String getJobJobType() {
00542         return jobJobType;
00543     }
00544
00549     public void setJobJobType(String jobJobType) {
00550         this.jobJobType = jobJobType;
00551     }
00552
00557     public String getJobExecutable() {
00558         return jobExecutable;
00559     }
00560
00564     public void setJobExecutable(String jobExecutable) {
00565         this.jobExecutable = jobExecutable;
00566     }
00567
00571     public String getJobStdOutput() {
00572         return jobStdOutput;
00573     }
00574
00578     public void setJobStdOutput(String jobStdOutput) {
00579         this.jobStdOutput = jobStdOutput;
00580     }
00581
00585     public String getJobStdInput() {
00586         return jobStdInput;
00587     }
00588
00592     public void setJobStdInput(String jobStdInput) {
00593         this.jobStdInput = jobStdInput;
00594     }
00595
00599     public String getJobStdError() {
00600         return jobStdError;
00601     }
00602
00606     public void setJobStdError(String jobStdError) {
00607         this.jobStdError = jobStdError;
00608     }
00609
00613     public String getJobOutput_se() {
00614         return jobOutput_se;
00615     }
00616
00620     public void setJobOutput_se(String jobOutput_se) {
00621         this.jobOutput_se = jobOutput_se;
00622     }
00623
00627     public String getJobVO() {
00628         return jobVO;
00629     }
00630
00634     public void setJobVO(String jobVO) {
00635         this.jobVO = jobVO;
00636     }
00637
00641     public String getJobRetryCount() {
00642         return jobRetryCount;
00643     }
00644
00648     public void setJobRetryCount(String jobRetryCount) {
00649         this.jobRetryCount = jobRetryCount;
00650     }
00651
00656     public String getJobMyProxyServer() {
00657         return jobMyProxyServer;
00658     }
00659
00663     public void setJobMyProxyServer(String jobMyProxyServer) {
00664         this.jobMyProxyServer = jobMyProxyServer;
00665     }
00666
00670     public String getJobDataAccessProtocol() {
00671         return jobDataAccessProtocol;
00672     }
00673
00677     public void setJobDataAccessProtocol(String jobDataAccessProtocol) {
00678         this.jobDataAccessProtocol = jobDataAccessProtocol;
00679     }
00680
00681
00685     public String getJobStorageIndex() {
00686         return jobStorageIndex;
00687     }
00688
00692     public void setJobStorageIndex(String jobStorageIndex) {
00693         this.jobStorageIndex = jobStorageIndex;
00694     }
00695
00699     public String getJobEnvironment() {
00700         return jobEnvironment;
00701     }
00702
00706     public void setJobEnvironment(String jobEnvironment) {
00707         this.jobEnvironment = jobEnvironment;
00708     }
00709
00710
00714     public String getJobRequirements() {
00715         return jobRequirements;
00716     }
00717
00722     public void setJobRequirements(String jobRequirements) {
00723         this.jobRequirements = jobRequirements;
00724     }
00725
00729     public String getJobRank() {
00730         return jobRank;
00731     }
00732
00736     public void setJobRank(String jobRank) {
00737         this.jobRank = jobRank;
00738     }
00739
00743     public String getJobFuzzyRank() {
00744         return jobFuzzyRank;
00745     }
00746
00750     public void setJobFuzzyRank(String jobFuzzyRank) {
00751         this.jobFuzzyRank = jobFuzzyRank;
00752     }
00753
00758     public boolean addInputSBEntry(String entry) {
00759         if (jobInputSB == null) jobInputSB = new LinkedList();
00760         return jobInputSB.add(entry);
00761     }
00762
00767     public boolean addOutputSBEntry(String entry) {
00768         if (jobOutputSB == null) jobOutputSB = new LinkedList();
00769         return jobOutputSB.add(entry);
00770     }
00771
00772
00776     public String getJobArgument() {
00777         return jobArgument;
00778     }
00779
00783     public void setJobArgument(String jobArgument) {
00784         this.jobArgument = jobArgument;
00785     }
00786
00787     /******************************************************************************************
00788      *                                END OF GETTERS AND SETTERS                              *
00789      ******************************************************************************************/
00790 }
Generated on Mon Jan 22 15:16:08 2007 for ProActive by  doxygen 1.5.1
