org/objectweb/proactive/core/util/ClassDataCache.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.util;
00032
00033 import java.util.Hashtable;
00034 import java.util.Map;
00035
00036 import org.apache.log4j.Logger;
00037 import org.objectweb.proactive.core.runtime.ProActiveRuntimeImpl;
00038 import org.objectweb.proactive.core.util.log.Loggers;
00039 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00040
00041
00050 public class ClassDataCache {
00051     static Logger logger = ProActiveLogger.getLogger(Loggers.CLASSLOADING);
00052     private static ClassDataCache classCache = null;
00053     private static Map<String, byte[]> classStorage;
00054
00055     private ClassDataCache() {
00056         classStorage = new Hashtable<String, byte[]>();
00057     }
00058
00059     public static ClassDataCache instance() {
00060         if (classCache == null) {
00061             return classCache = new ClassDataCache();
00062         } else {
00063             return classCache;
00064         }
00065     }
00066
00072     public boolean contains(String className) {
00073         return classStorage.containsKey(className);
00074     }
00075
00081     public void addClassData(String fullname, byte[] classData) {
00082         if (logger.isDebugEnabled()) {
00083             logger.debug(ProActiveRuntimeImpl.getProActiveRuntime().getURL() +
00084                 " --> " + ("ClassDataCache caching class " + fullname));
00085         }
00086         classStorage.put(fullname, classData);
00087     }
00088
00093     public byte[] getClassData(String fullname) {
00094         if (logger.isDebugEnabled()) {
00095             logger.debug(ProActiveRuntimeImpl.getProActiveRuntime().getURL() +
00096                 " --> " + ("ClassDataCache was asked for class " + fullname));
00097         }
00098         return classStorage.get(fullname);
00099     }
00100 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
