00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.mop;
00032
00033 import java.lang.reflect.Field;
00034 import java.lang.reflect.Method;
00035 import java.lang.reflect.Modifier;
00036 import java.util.ArrayList;
00037 import java.util.List;
00038
00039
00043 public abstract class Utils extends Object {
00044
00048 public static final Class<?> JAVA_LANG_NUMBER = silentForName(
00049 "java.lang.Number");
00050 public static final Class<?> JAVA_LANG_CHARACTER = silentForName(
00051 "java.lang.Character");
00052 public static final Class<?> JAVA_LANG_BOOLEAN = silentForName(
00053 "java.lang.Boolean");
00054 public static final Class<?> JAVA_LANG_VOID = silentForName(
00055 "java.lang.Void");
00056 public static final Class<?> JAVA_LANG_RUNTIMEEXCEPTION = silentForName(
00057 "java.lang.RuntimeException");
00058 public static final Class<?> JAVA_LANG_EXCEPTION = silentForName(
00059 "java.lang.Exception");
00060 public static final Class<?> JAVA_LANG_THROWABLE = silentForName(
00061 "java.lang.Throwable");
00062
00066 public static final char STUB_ESCAPE_CHAR = '_';
00067 public static final String STUB_ESCAPE = "" + STUB_ESCAPE_CHAR +
00068 STUB_ESCAPE_CHAR;
00069
00073 public static final char STUB_PACKAGE_SEPARATOR_CHAR = 'P';
00074 public static final String STUB_PACKAGE_SEPARATOR = "" + STUB_ESCAPE_CHAR +
00075 STUB_PACKAGE_SEPARATOR_CHAR;
00076
00080 public static final char STUB_GENERICS_SEPARATOR_CHAR = 'D';
00081 public static final String STUB_GENERICS_SEPARATOR = "" + STUB_ESCAPE_CHAR +
00082 STUB_GENERICS_SEPARATOR_CHAR;
00083
00084
00085 public static final String STUB_DEFAULT_PREFIX = STUB_ESCAPE_CHAR + "Stub";
00086
00087
00088 public static final String STUB_GENERICS_SUFFIX = STUB_ESCAPE_CHAR +
00089 "Generics";
00090
00091
00092 public static final String STUB_DEFAULT_PACKAGE = "pa.stub.";
00093
00094
00095 public static final String STUB_GENERICS_PACKAGE = "parameterized.";
00096
00109 static public String getRidOfNative(String in) {
00110 String result;
00111 int leftindex;
00112 int rightindex;
00113
00114 leftindex = in.indexOf("native");
00115 if (leftindex == -1) {
00116 return in;
00117 }
00118 rightindex = leftindex + 6;
00119
00120 result = in.substring(0, leftindex) +
00121 in.substring(rightindex, in.length());
00122 return result;
00123 }
00124
00125 static public String getRidOfAbstract(String in) {
00126 String result;
00127 int leftindex;
00128 int rightindex;
00129
00130 leftindex = in.indexOf("abstract");
00131 if (leftindex == -1) {
00132 return in;
00133 }
00134 rightindex = leftindex + 8;
00135
00136 result = in.substring(0, leftindex) +
00137 in.substring(rightindex, in.length());
00138 return result;
00139 }
00140
00141 static public String getRidOfNativeAndAbstract(String in) {
00142 String s = in;
00143 s = getRidOfAbstract(s);
00144 return getRidOfNative(s);
00145 }
00146
00160 static public boolean checkMethod(Method met) {
00161 int modifiers = met.getModifiers();
00162
00163
00164
00165 if (Modifier.isFinal(modifiers)) {
00166 return false;
00167 }
00168
00169
00170 if (Modifier.isStatic(modifiers)) {
00171 return false;
00172 }
00173 if (!(Modifier.isPublic(modifiers))) {
00174 return false;
00175 }
00176
00177
00178 if ((met.getName().equals("finalize")) &&
00179 (met.getParameterTypes().length == 0)) {
00180 return false;
00181 }
00182 return true;
00183 }
00184
00197 static public String sourceLikeForm(Class cl) {
00198 if (!(cl.isArray())) {
00199
00200
00201
00202 return cl.getName().replace('$', '.');
00203 } else {
00204 int nb = 0;
00205 Class current = cl;
00206 String result = "";
00207
00208 do {
00209 current = current.getComponentType();
00210 result = "[]" + result;
00211 nb++;
00212 } while ((current.getComponentType()) != null);
00213
00214 result = current.getName() + result;
00215 return result;
00216 }
00217 }
00218
00219
00220
00221
00222
00223 static public String nameOfWrapper(Class cl) {
00224 String str = cl.getName();
00225
00226 if (cl.isPrimitive()) {
00227 if (str.equals("int")) {
00228 return "java.lang.Integer";
00229 } else if (str.equals("boolean")) {
00230 return "java.lang.Boolean";
00231 } else if (str.equals("byte")) {
00232 return "java.lang.Byte";
00233 } else if (str.equals("short")) {
00234 return "java.lang.Short";
00235 } else if (str.equals("long")) {
00236 return "java.lang.Long";
00237 } else if (str.equals("float")) {
00238 return "java.lang.Float";
00239 } else if (str.equals("double")) {
00240 return "java.lang.Double";
00241 } else if (str.equals("void")) {
00242 return "void";
00243 } else if (str.equals("char")) {
00244 return "java.lang.Character";
00245 } else {
00246 throw new InternalException("Unknown primitive type: " +
00247 cl.getName());
00248 }
00249 } else {
00250 return null;
00251 }
00252 }
00253
00254
00255
00256
00257
00258 public static String getPackageName(String fqnameofclass) {
00259 int indexoflastdot;
00260
00261 indexoflastdot = fqnameofclass.lastIndexOf('.');
00262
00263 if (indexoflastdot == -1) {
00264 return "";
00265 } else {
00266 return fqnameofclass.substring(0, indexoflastdot);
00267 }
00268 }
00269
00273 public static String getSimpleName(String fullyQualifiedNameOfClass) {
00274 int indexOfLastDot = fullyQualifiedNameOfClass.lastIndexOf('.');
00275 if (indexOfLastDot == -1)
00276 {
00277 return fullyQualifiedNameOfClass;
00278 } else {
00279
00280 if (indexOfLastDot == (fullyQualifiedNameOfClass.length() - 1)) {
00281 return "";
00282 } else {
00283 return fullyQualifiedNameOfClass.substring(indexOfLastDot + 1);
00284 }
00285 }
00286 }
00287
00292 public static Class getWrapperClass(Class cl) {
00293 if (!(cl.isPrimitive())) {
00294 return null;
00295 }
00296 String s = Utils.nameOfWrapper(cl);
00297 try {
00298 return MOP.forName(s);
00299 } catch (ClassNotFoundException e) {
00300 throw new InternalException("Cannot load wrapper class " + s);
00301 }
00302 }
00303
00307 public static Class getPrimitiveType(Class cl) {
00308 Field cst;
00309 if (Utils.isWrapperClass(cl)) {
00310
00311
00312 try {
00313 cst = cl.getField("TYPE");
00314 return (Class) cst.get(null);
00315 } catch (NoSuchFieldException e) {
00316 throw new InternalException(
00317 "Cannot locate constant TYPE in class " + cl.getName());
00318 } catch (SecurityException e) {
00319 throw new InternalException("Access to field TYPE in class " +
00320 cl.getName() + " denied");
00321 } catch (IllegalAccessException e) {
00322 throw new InternalException("Access to field TYPE in class " +
00323 cl.getName() + " denied");
00324 }
00325 } else {
00326 throw new InternalException("Not a wrapper class: " + cl.getName());
00327 }
00328 }
00329
00334 public static boolean isWrapperClass(Class<?> cl) {
00335 if (Utils.JAVA_LANG_NUMBER.isAssignableFrom(cl)) {
00336 return true;
00337 } else if (Utils.JAVA_LANG_BOOLEAN.isAssignableFrom(cl)) {
00338 return true;
00339 } else if (Utils.JAVA_LANG_CHARACTER.isAssignableFrom(cl)) {
00340 return true;
00341 } else if (Utils.JAVA_LANG_VOID.isAssignableFrom(cl)) {
00342 return true;
00343 } else {
00344 return false;
00345 }
00346 }
00347
00348 public static String getRelativePath(String className) {
00349 String packageName;
00350 String fileSeparator;
00351 String result;
00352 int indexOfDot;
00353 int indexOfLastDot;
00354
00355 fileSeparator = System.getProperty("file.separator");
00356 packageName = Utils.getPackageName(className);
00357
00358 indexOfDot = packageName.indexOf((int) '.', 0);
00359 result = "";
00360 indexOfLastDot = 0;
00361
00362 while (indexOfDot != -1) {
00363 result = result + fileSeparator +
00364 packageName.substring(indexOfLastDot, indexOfDot);
00365 indexOfLastDot = indexOfDot + 1;
00366 indexOfDot = packageName.indexOf((int) '.', indexOfDot + 1);
00367 if (indexOfDot == -1) {
00368 result = result + fileSeparator +
00369 packageName.substring(indexOfLastDot, packageName.length());
00370 }
00371 }
00372
00373 if (result.equals("")) {
00374 result = fileSeparator + packageName;
00375 }
00376
00377 return result;
00378 }
00379
00380
00381
00382
00383
00384
00385 public static boolean isNormalException(Class exc) {
00386 boolean result;
00387
00388 if (Utils.JAVA_LANG_THROWABLE.isAssignableFrom(exc)) {
00389
00390 if (Utils.JAVA_LANG_EXCEPTION.isAssignableFrom(exc)) {
00391 if (Utils.JAVA_LANG_RUNTIMEEXCEPTION.isAssignableFrom(exc)) {
00392 result = false;
00393 } else {
00394 result = true;
00395 }
00396 } else {
00397 result = false;
00398 }
00399 } else {
00400 result = false;
00401 }
00402
00403 return result;
00404 }
00405
00406 public static Class decipherPrimitiveType(String str) {
00407 if (str.equals("int")) {
00408 return java.lang.Integer.TYPE;
00409 } else if (str.equals("boolean")) {
00410 return java.lang.Boolean.TYPE;
00411 } else if (str.equals("byte")) {
00412 return java.lang.Byte.TYPE;
00413 } else if (str.equals("short")) {
00414 return java.lang.Short.TYPE;
00415 } else if (str.equals("long")) {
00416 return java.lang.Long.TYPE;
00417 } else if (str.equals("float")) {
00418 return java.lang.Float.TYPE;
00419 } else if (str.equals("double")) {
00420 return java.lang.Double.TYPE;
00421 } else if (str.equals("void")) {
00422 return java.lang.Void.TYPE;
00423 } else if (str.equals("char")) {
00424 return java.lang.Character.TYPE;
00425 }
00426
00427 return null;
00428 }
00429
00430 public static boolean isSuperTypeInArray(String className, Class[] types) {
00431 try {
00432 Class c = MOP.forName(className);
00433 return isSuperTypeInArray(c, types);
00434 } catch (ClassNotFoundException e) {
00435 throw new InternalException(e);
00436 }
00437 }
00438
00439 public static boolean isSuperTypeInArray(Class c, Class<?>[] types) {
00440 for (int i = 0; i < types.length; i++) {
00441 if (types[i].isAssignableFrom(c)) {
00442 return true;
00443 }
00444 }
00445 return false;
00446 }
00447
00448 public static Object makeDeepCopy(Object source) throws java.io.IOException {
00449 java.io.ByteArrayOutputStream baos = new java.io.ByteArrayOutputStream();
00450
00451
00452 java.io.ObjectOutputStream oos = new PAObjectOutputStream(baos);
00453 oos.writeObject(source);
00454 oos.flush();
00455 oos.close();
00456 java.io.ByteArrayInputStream bais = new java.io.ByteArrayInputStream(baos.toByteArray());
00457
00458
00459 java.io.ObjectInputStream ois = new PAObjectInputStream(bais);
00460 try {
00461 Object result = ois.readObject();
00462 ois.close();
00463 return result;
00464 } catch (ClassNotFoundException e) {
00465 throw new java.io.IOException("ClassNotFoundException e=" + e);
00466 }
00467 }
00468
00469 public static String convertClassNameToStubClassName(String classname,
00470 Class[] genericParameters) {
00471 if (classname.length() == 0) {
00472 return classname;
00473 }
00474 String packageName = getPackageName(classname);
00475 if (!packageName.equals("")) {
00476 packageName += ".";
00477 }
00478 packageName = STUB_DEFAULT_PACKAGE +
00479 (((genericParameters == null) || (genericParameters.length == 0))
00480 ? "" : STUB_GENERICS_PACKAGE) + packageName;
00481
00482 String genericsDifferentiator = "";
00483 if (genericParameters != null) {
00484 for (Class gClassName : genericParameters) {
00485 if (!genericsDifferentiator.equals("")) {
00486 genericsDifferentiator += STUB_GENERICS_SEPARATOR;
00487 }
00488 genericsDifferentiator += escapeClassName(gClassName.getName());
00489 }
00490 if (!genericsDifferentiator.equals("")) {
00491 genericsDifferentiator = STUB_GENERICS_SUFFIX +
00492 genericsDifferentiator;
00493 }
00494 }
00495
00496 return packageName + STUB_DEFAULT_PREFIX +
00497 escapeClassName(getSimpleName(classname)) + genericsDifferentiator;
00498 }
00499
00500 public static boolean isStubClassName(String classname) {
00501 if (classname.startsWith(STUB_DEFAULT_PACKAGE)) {
00502
00503 int index = classname.lastIndexOf(".");
00504 if (index != -1) {
00505 return classname.startsWith(Utils.STUB_DEFAULT_PREFIX, index +
00506 1);
00507 } else {
00508 return classname.startsWith(Utils.STUB_DEFAULT_PREFIX);
00509 }
00510 } else {
00511 return false;
00512 }
00513 }
00514
00515 public static String convertStubClassNameToClassName(String stubclassname) {
00516 return unEscapeStubClassesName(stubclassname, false).get(0).toString();
00517 }
00518
00519 public static String[] getNamesOfParameterizingTypesFromStubClassName(
00520 String stubClassName) {
00521 if (!isStubClassName(stubClassName)) {
00522 return new String[] { };
00523 }
00524 if (!stubClassName.startsWith(Utils.STUB_DEFAULT_PACKAGE +
00525 Utils.STUB_GENERICS_PACKAGE)) {
00526
00527 return new String[] { };
00528 }
00529 List<CharSequence> classesName = unEscapeStubClassesName(stubClassName,
00530 true);
00531 classesName.remove(0);
00532 String[] result = new String[classesName.size()];
00533 for (int i = 0; i < result.length; i++) {
00534 result[i] = classesName.get(i).toString();
00535 }
00536 return result;
00537 }
00538
00545 private static String escapeClassName(String className) {
00546 StringBuilder sb = new StringBuilder(className.length() * 2);
00547 for (int i = 0; i < className.length(); i++) {
00548 switch (className.charAt(i)) {
00549 case '.':
00550 sb.append(STUB_PACKAGE_SEPARATOR);
00551 break;
00552 case STUB_ESCAPE_CHAR:
00553 sb.append(STUB_ESCAPE);
00554 break;
00555 default:
00556 sb.append(className.charAt(i));
00557 break;
00558 }
00559 }
00560 return sb.toString();
00561 }
00562
00569 private static List<CharSequence> unEscapeStubClassesName(
00570 String stubClassName, boolean withParameterizingTypes)
00571 throws IllegalArgumentException {
00572 ArrayList<CharSequence> result = new ArrayList<CharSequence>();
00573 StringBuilder sb = new StringBuilder(stubClassName.length());
00574 boolean stubFlag = false;
00575 boolean genericFlag = false;
00576 boolean genericPackage = false;
00577
00578 if (isStubClassName(stubClassName)) {
00579 String temp = "";
00580 if (stubClassName.startsWith(Utils.STUB_DEFAULT_PACKAGE +
00581 Utils.STUB_GENERICS_PACKAGE)) {
00582 genericPackage = true;
00583
00584 temp = stubClassName.substring((Utils.STUB_DEFAULT_PACKAGE +
00585 Utils.STUB_GENERICS_PACKAGE).length());
00586 } else {
00587 temp = stubClassName.substring(Utils.STUB_DEFAULT_PACKAGE.length());
00588 }
00589 temp = Utils.getPackageName(temp);
00590 if (temp.length() != 0) {
00591 sb.append(temp);
00592 sb.append('.');
00593 }
00594
00595
00596 int begin = stubClassName.lastIndexOf('.');
00597 if (begin == -1) {
00598 begin = 0;
00599 }
00600 for (int i = begin + 1; i < stubClassName.length(); i++) {
00601 char c = stubClassName.charAt(i);
00602 if (c != STUB_ESCAPE_CHAR) {
00603 sb.append(c);
00604 } else {
00605 i++;
00606 switch (stubClassName.charAt(i)) {
00607
00608 case STUB_PACKAGE_SEPARATOR_CHAR:
00609 sb.append('.');
00610 break;
00611 case STUB_ESCAPE_CHAR:
00612 sb.append(STUB_ESCAPE_CHAR);
00613 ;
00614 break;
00615 case STUB_GENERICS_SEPARATOR_CHAR:
00616 result.add(sb);
00617 sb = new StringBuilder(stubClassName.length());
00618 break;
00619
00620
00621 case 'S':
00622 if (stubClassName.startsWith(STUB_DEFAULT_PREFIX, i -
00623 1)) {
00624 if (stubFlag) {
00625 throw new IllegalArgumentException(
00626 "The escapedClassesName is not a well formed escaped string at index " +
00627 i + ", the flag STUB_DEFAULT_PREFIX (" +
00628 STUB_DEFAULT_PREFIX +
00629 ") are present twice : " + stubClassName);
00630 }
00631 stubFlag = true;
00632 i += (STUB_DEFAULT_PREFIX.length() - 2);
00633 }
00634 break;
00635 case 'G':
00636 if (stubClassName.startsWith(STUB_GENERICS_SUFFIX, i -
00637 1)) {
00638 if (genericFlag || !genericPackage) {
00639 throw new IllegalArgumentException(
00640 "The escapedClassesName is not a well formed escaped string at index " +
00641 i + ", the flag STUB_GENERICS_SUFFIX (" +
00642 STUB_GENERICS_SUFFIX +
00643 ") are present twice or this class is not in the STUB_GENERICS_PACKAGE (" +
00644 STUB_DEFAULT_PACKAGE +
00645 STUB_GENERICS_PACKAGE + "): " +
00646 stubClassName);
00647 }
00648 genericFlag = true;
00649 i += (STUB_GENERICS_SUFFIX.length() - 2);
00650
00651 result.add(sb);
00652 if (!withParameterizingTypes) {
00653 return result;
00654 } else {
00655 sb = new StringBuilder(stubClassName.length());
00656 }
00657 }
00658 break;
00659 default:
00660
00661 throw new IllegalArgumentException(
00662 "The escapedClassesName is not a well formed escaped string at index " +
00663 i + " : " + stubClassName);
00664 }
00665 }
00666 }
00667 result.add(sb);
00668 return result;
00669 } else {
00670 result.add(stubClassName);
00671 return result;
00672 }
00673 }
00674
00680 public static void addSuperInterfaces(Class cl, List<Class> superItfs) {
00681 if (!cl.isInterface()) {
00682 return;
00683 }
00684 Class[] super_interfaces = cl.getInterfaces();
00685 for (int i = 0; i < super_interfaces.length; i++) {
00686 superItfs.add(super_interfaces[i]);
00687 addSuperInterfaces(super_interfaces[i], superItfs);
00688 }
00689 }
00690
00696 public static void addSuperInterfaces(List<Class> interfaces) {
00697 for (int i = 0; i < interfaces.size(); i++) {
00698 Class[] super_itfs_table = interfaces.get(i).getInterfaces();
00699 List<Class> super_itfs = new ArrayList<Class>(super_itfs_table.length);
00700 for (int j = 0; j < super_itfs_table.length; j++) {
00701 super_itfs.add(super_itfs_table[j]);
00702 }
00703 addSuperInterfaces(super_itfs);
00704 for (int j = 0; j < super_itfs.size(); j++) {
00705 if (!interfaces.contains(super_itfs.get(j))) {
00706 interfaces.add(super_itfs.get(j));
00707 }
00708 }
00709 }
00710 }
00711
00712 private static final Class silentForName(String classname) {
00713 try {
00714 return MOP.forName(classname);
00715 } catch (ClassNotFoundException e) {
00716 System.err.println(
00717 "Static initializer in class org.objectweb.proactive.core.mop.Utils: Cannot load class " +
00718 classname);
00719 return null;
00720 }
00721 }
00722 }
