org/objectweb/proactive/core/descriptor/data/VirtualNode.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.descriptor.data;
00032
00033 import java.io.IOException;
00034
00035 import org.apache.log4j.Logger;
00036 import org.objectweb.proactive.Job;
00037 import org.objectweb.proactive.core.ProActiveException;
00038 import org.objectweb.proactive.core.node.Node;
00039 import org.objectweb.proactive.core.node.NodeException;
00040 import org.objectweb.proactive.core.process.ExternalProcess;
00041 import org.objectweb.proactive.core.util.log.Loggers;
00042 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00043 import org.objectweb.proactive.filetransfer.FileVector;
00044
00045
00056 public interface VirtualNode extends java.io.Serializable, Job {
00057     public final static Logger vnLogger = ProActiveLogger.getLogger(Loggers.DEPLOYMENT);
00058
00063     public String getProperty();
00064
00069     public String getName();
00070
00075     public void addVirtualMachine(VirtualMachine virtualMachine);
00076
00082     public VirtualMachine getVirtualMachine();
00083
00088     public long getTimeout();
00089
00093     public void activate();
00094
00101     public int getNbMappedNodes();
00102
00106     public int createdNodeCount();
00107
00113     public int getNumberOfCurrentlyCreatedNodes();
00114
00119     public int getNumberOfCreatedNodesAfterDeployment();
00120
00127     public Node getNode() throws NodeException;
00128
00136     public Node getNode(int index) throws NodeException;
00137
00143     public String[] getNodesURL() throws NodeException;
00144
00150     public Node[] getNodes() throws NodeException;
00151
00158     public Node getNode(String url) throws NodeException;
00159
00165     public void createNodeOnCurrentJvm(String protocol);
00166
00176     public void killAll(boolean softly);
00177
00185     public Object getUniqueAO() throws ProActiveException;
00186
00190     public boolean isActivated();
00191
00195     public boolean isLookup();
00196
00215     public void setRuntimeInformations(String information, String value)
00216         throws ProActiveException;
00217
00224     public int getMinNumberOfNodes();
00225
00230     public boolean isMultiple();
00231
00240     public FileVector fileTransferRetrieve() throws ProActiveException, IOException;
00241
00246     public ExternalProcess getMPIProcess();
00247
00252     public boolean hasMPIProcess();
00253
00261     public void setFileTransferParams(int fileBlockSize, int overlapping);
00262 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
