| [static initializer] (defined in org.objectweb.proactive.ProActive) | org.objectweb.proactive.ProActive | [package, static] |
| addNFEListenerOnAO(Object ao, NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| addNFEListenerOnGroup(Object group, NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| addNFEListenerOnJVM(NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| addNFEListenerOnProxy(Object ao, NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| allAwaited(java.util.Vector futures) | org.objectweb.proactive.ProActive | [static] |
| createStubObject(String className, UniversalBody body) | org.objectweb.proactive.ProActive | [static] |
| disableAC(Object obj) | org.objectweb.proactive.ProActive | [static] |
| enableAC(Object obj) | org.objectweb.proactive.ProActive | [static] |
| enableExitOnEmpty() | org.objectweb.proactive.ProActive | |
| endTryWithCatch() | org.objectweb.proactive.ProActive | [static] |
| exitFailure() | org.objectweb.proactive.ProActive | [static] |
| exitSuccess() | org.objectweb.proactive.ProActive | [static] |
| exposeAsWebService(Object o, String url, String urn, String[] methods) | org.objectweb.proactive.ProActive | [static] |
| exposeComponentAsWebService(Component component, String url, String componentName) | org.objectweb.proactive.ProActive | [static] |
| getActiveObjectNodeUrl(Object activeObject) | org.objectweb.proactive.ProActive | [static] |
| getAllExceptions() | org.objectweb.proactive.ProActive | [static] |
| getBodyOnThis() | org.objectweb.proactive.ProActive | [static] |
| getFutureValue(Object future) | org.objectweb.proactive.ProActive | [static] |
| getJobId() | org.objectweb.proactive.ProActive | [static] |
| getNode() | org.objectweb.proactive.ProActive | [static] |
| getProactiveDescriptor() | org.objectweb.proactive.ProActive | [static] |
| getProactiveDescriptor(String xmlDescriptorUrl) | org.objectweb.proactive.ProActive | [static] |
| getProactiveDescriptor(String xmlDescriptorUrl, VariableContract variableContract) | org.objectweb.proactive.ProActive | [static] |
| getProActiveVersion() | org.objectweb.proactive.ProActive | [static] |
| getStubOnThis() | org.objectweb.proactive.ProActive | [static] |
| isAwaited(Object future) | org.objectweb.proactive.ProActive | [static] |
| isException(Object future) | org.objectweb.proactive.ProActive | [static] |
| listActive(String url) | org.objectweb.proactive.ProActive | [static] |
| logger | org.objectweb.proactive.ProActive | [protected, static] |
| loggerGroup | org.objectweb.proactive.ProActive | [static] |
| lookupActive(String classname, String url) | org.objectweb.proactive.ProActive | [static] |
| lookupVirtualNode(String url) | org.objectweb.proactive.ProActive | [static] |
| migrateTo(Object activeObject) | org.objectweb.proactive.ProActive | [static] |
| migrateTo(String nodeURL) | org.objectweb.proactive.ProActive | [static] |
| migrateTo(Node node) | org.objectweb.proactive.ProActive | [static] |
| migrateTo(Body bodyToMigrate, Object activeObject, boolean isNFRequest) | org.objectweb.proactive.ProActive | [static] |
| migrateTo(Body bodyToMigrate, String nodeURL, boolean isNFRequest) | org.objectweb.proactive.ProActive | [static] |
| migrateTo(Body bodyToMigrate, Node node, boolean isNFRequest) | org.objectweb.proactive.ProActive | [static] |
| migrateTo(Body bodyToMigrate, Node node, boolean isNFRequest, int priority) | org.objectweb.proactive.ProActive | [static] |
| newActive(String classname, Object[] constructorParameters) | org.objectweb.proactive.ProActive | [static] |
| newActive(String classname, Object[] constructorParameters, String nodeURL) | org.objectweb.proactive.ProActive | [static] |
| newActive(String classname, Object[] constructorParameters, Node node) | org.objectweb.proactive.ProActive | [static] |
| newActive(String classname, Class[] genericParameters, Object[] constructorParameters) | org.objectweb.proactive.ProActive | [static] |
| newActive(String classname, Class[] genericParameters, Object[] constructorParameters, String nodeURL) | org.objectweb.proactive.ProActive | [static] |
| newActive(String classname, Class[] genericParameters, Object[] constructorParameters, Node node) | org.objectweb.proactive.ProActive | [static] |
| newActive(String classname, Class[] genericParameters, Object[] constructorParameters, Node node, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| newActiveAsGroup(String classname, Object[] constructorParameters, VirtualNode virtualnode) | org.objectweb.proactive.ProActive | [static] |
| newActiveAsGroup(String className, Object[] constructorParameters, VirtualNode virtualNode, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| newActiveAsGroup(String classname, Class[] genericParameters, Object[] constructorParameters, VirtualNode virtualnode) | org.objectweb.proactive.ProActive | [static] |
| newActiveAsGroup(String classname, Class[] genericParameters, Object[] constructorParameters, VirtualNode virtualnode, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| newActiveComponent(String className, Object[] constructorParameters, Node node, Active activity, MetaObjectFactory factory, ComponentParameters componentParameters) | org.objectweb.proactive.ProActive | [static] |
| newActiveComponent(String className, Object[] constructorParameters, VirtualNode vn, ComponentParameters componentParameters) | org.objectweb.proactive.ProActive | [static] |
| newActiveComponent(String classname, Class[] genericParameters, Object[] constructorParameters, Node node, Active activity, MetaObjectFactory factory, ComponentParameters componentParameters) | org.objectweb.proactive.ProActive | [static] |
| newActiveComponent(String className, Class[] genericParameters, Object[] constructorParameters, VirtualNode vn, ComponentParameters componentParameters) | org.objectweb.proactive.ProActive | [static] |
| newActiveInParallel(String className, Object[][] constructorParameters, Node[] nodes) | org.objectweb.proactive.ProActive | [static] |
| newActiveInParallel(String className, Object[] constructorParameters, VirtualNode virtualNode) | org.objectweb.proactive.ProActive | [static] |
| newActiveInParallel(String className, Class[] genericParameters, Object[][] constructorParameters, Node[] nodes) | org.objectweb.proactive.ProActive | [static] |
| newActiveInParallel(String className, Class[] genericParameters, Object[] constructorParameters, VirtualNode virtualNode) | org.objectweb.proactive.ProActive | [static] |
| newMain(String classname, String[] mainParameters, Node node) | org.objectweb.proactive.ProActive | [static] |
| newRemote(String classname, Node node) | org.objectweb.proactive.ProActive | [static] |
| register(Object obj, String url) | org.objectweb.proactive.ProActive | [static] |
| registerVirtualNode(VirtualNode virtualNode, String registrationProtocol, boolean replacePreviousBinding) | org.objectweb.proactive.ProActive | [static] |
| removeImmediateService(Object obj, String methodName, Class[] parametersTypes) | org.objectweb.proactive.ProActive | [static] |
| removeNFEListenerOnAO(Object ao, NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| removeNFEListenerOnGroup(Object group, NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| removeNFEListenerOnJVM(NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| removeNFEListenerOnProxy(Object ao, NFEListener listener) | org.objectweb.proactive.ProActive | [static] |
| removeTryWithCatch() | org.objectweb.proactive.ProActive | [static] |
| setImmediateService(Object obj, String methodName) | org.objectweb.proactive.ProActive | [static] |
| setImmediateService(Object obj, String methodName, Class[] parametersTypes) | org.objectweb.proactive.ProActive | [static] |
| terminateActiveObject(Object ao, boolean immediate) | org.objectweb.proactive.ProActive | [static] |
| throwArrivedException() | org.objectweb.proactive.ProActive | [static] |
| tryWithCatch(Class c) | org.objectweb.proactive.ProActive | [static] |
| tryWithCatch(Class[] c) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, String nodeURL) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Node node) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Node node, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, String nameOfTargetType, Node node) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, String nameOfTargetType, Node node, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, String nameOfTargetType, Class[] genericParameters, Node node, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Class[] genericParameters) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Class[] genericParameters, String nodeURL) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Class[] genericParameters, Node node) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Class[] genericParameters, Node node, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Class[] genericParameters, String nameOfTargetType, Node node) | org.objectweb.proactive.ProActive | [static] |
| turnActive(Object target, Class[] genericParameters, String nameOfTargetType, Node node, Active activity, MetaObjectFactory factory) | org.objectweb.proactive.ProActive | [static] |
| turnActiveAsGroup(Object target, String nameOfTargetType, VirtualNode virtualnode) | org.objectweb.proactive.ProActive | [static] |
| turnActiveAsGroup(Object target, Class[] genericParameters, String nameOfTargetType, VirtualNode virtualnode) | org.objectweb.proactive.ProActive | [static] |
| unExposeAsWebService(String urn, String url) | org.objectweb.proactive.ProActive | [static] |
| unExposeComponentAsWebService(String componentName, String url, Component component) | org.objectweb.proactive.ProActive | [static] |
| unregister(String url) | org.objectweb.proactive.ProActive | [static] |
| unregisterVirtualNode(VirtualNode virtualNode) | org.objectweb.proactive.ProActive | [static] |
| waitFor(Object future) | org.objectweb.proactive.ProActive | [static] |
| waitFor(Object future, long timeout) | org.objectweb.proactive.ProActive | [static] |
| waitForAll(java.util.Vector futures) | org.objectweb.proactive.ProActive | [static] |
| waitForAll(java.util.Vector futures, long timeout) | org.objectweb.proactive.ProActive | [static] |
| waitForAny(java.util.Vector futures) | org.objectweb.proactive.ProActive | [static] |
| waitForAny(java.util.Vector futures, long timeout) | org.objectweb.proactive.ProActive | [static] |
| waitForPotentialException() | org.objectweb.proactive.ProActive | [static] |
| waitForTheNth(java.util.Vector futures, int n) | org.objectweb.proactive.ProActive | [static] |
| waitForTheNth(java.util.Vector futures, int n, long timeout) | org.objectweb.proactive.ProActive | [static] |
