00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.benchmarks.timit.util;
00032
00033 import java.io.File;
00034 import java.io.FileOutputStream;
00035 import java.io.IOException;
00036 import java.util.Arrays;
00037 import java.util.HashMap;
00038 import java.util.Iterator;
00039 import java.util.List;
00040 import java.util.regex.Matcher;
00041 import java.util.regex.Pattern;
00042
00043 import org.jdom.Attribute;
00044 import org.jdom.Document;
00045 import org.jdom.Element;
00046 import org.jdom.input.SAXBuilder;
00047 import org.jdom.output.Format;
00048 import org.jdom.output.XMLOutputter;
00049
00055 public class XMLHelper {
00056
00064     public static Document readFile(String filename) {
00065         try {
00066             return new SAXBuilder().build(new File(filename));
00067
00068         } catch (Exception e) {
00069             e.printStackTrace();
00070             return null;
00071         }
00072     }
00073
00082     public static void writeFile(Document document, String filename) {
00083         try {
00084             XMLOutputter out = new XMLOutputter(Format.getPrettyFormat());
00085             File file = new File(filename);
00086
00087             String path = file.getParent();
00088             if (path != null) {
00089                 new File(path).mkdirs();
00090             }
00091             FileOutputStream fos = new FileOutputStream(file);
00092             out.output(document, fos);
00093
00094         } catch (Exception e) {
00095             System.err.println("Unable to write file: " + filename);
00096             e.printStackTrace();
00097         }
00098     }
00099
00108     public static void errorLog(String filename, String message) {
00109         try {
00110             File file = new File(filename);
00111             String path = file.getParent();
00112             if (path != null) {
00113                 new File(path).mkdirs();
00114             }
00115             FileOutputStream fos = new FileOutputStream(file, true);
00116             String time = ""
00117                     + (new java.sql.Timestamp(System.currentTimeMillis()));
00118             message = time + "  " + message + "\n";
00119             fos.write(message.getBytes());
00120             fos.close();
00121
00122         } catch (Exception e) {
00123             System.err.println("Unable to write file: " + filename);
00124             e.printStackTrace();
00125         }
00126     }
00127
00142     public static void generateDescriptor(String inFilename,
00143             HashMap<String, String> gvars, HashMap<String, String> lvars,
00144             String outFilename) {
00145
00146
00147         Document doc = XMLHelper.readFile(inFilename);
00148         Element eVariables = doc.getRootElement().getChild("variables");
00149         Iterator it = eVariables.getChildren().iterator();
00150         while (it.hasNext()) {
00151             Element var = (Element) it.next();
00152             String name = var.getAttributeValue("name");
00153             if (lvars.containsKey(name)) {
00154                 var.setAttribute("value", lvars.get(name));
00155             } else if (gvars.containsKey(name)) {
00156                 var.setAttribute("value", gvars.get(name));
00157             }
00158         }
00159
00160
00161         XMLHelper.writeFile(doc, outFilename);
00162     }
00163
00174     public static void replaceAll(Element elt, String old, String value) {
00175         Iterator itAttr = elt.getAttributes().iterator();
00176         while (itAttr.hasNext()) {
00177             Attribute attr = (Attribute) itAttr.next();
00178             attr.setValue(attr.getValue().replaceAll(old, value));
00179         }
00180     }
00181
00190     public static void replaceVariables(List serieList,
00191             HashMap<String, String> vars) {
00192
00193
00194         Pattern p = Pattern.compile("[^\\x24\\x7B\\x7D]*\\x24\\x7B" +
00195                 "([^\\x7D]*)" +
00196                 "\\x7D[^\\x7D\\x24\\x7B]*");
00197         Iterator it = serieList.iterator();
00198         while (it.hasNext()) {
00199             Element serie = (Element) it.next();
00200
00201             replaceVariablesAttributes(serie, p, vars);
00202
00203
00204             Iterator itSerie = serie.getDescendants();
00205             while (itSerie.hasNext()) {
00206                 Object elt = itSerie.next();
00207                 if (elt instanceof Element) {
00208                     replaceVariablesAttributes((Element) elt, p, vars);
00209                 }
00210             }
00211         }
00212     }
00213
00225     private static void replaceVariablesAttributes(Element elt, Pattern p,
00226             HashMap<String, String> vars) {
00227         Iterator itAttr = elt.getAttributes().iterator();
00228         while (itAttr.hasNext()) {
00229             Attribute attr = (Attribute) itAttr.next();
00230             String values = attr.getValue();
00231             Matcher m = p.matcher(values);
00232             while (m.find()) {
00233                 String var = m.group(1);
00234                 String resolve = vars.get(var);
00235                 values = values.replaceAll("\\x24\\x7B" + var + "\\x7D",
00236                         resolve.split(",").length == 1 ? resolve : "#{"
00237                                 + resolve + "}");
00238                 attr.setValue(values);
00239             }
00240         }
00241     }
00242
00253     public static void tagFiltering(Element eTag, String[] values) {
00254         Arrays.sort(values);
00255         List<Element> children = eTag.getChildren();
00256         int i = 0;
00257
00258         while( i<children.size() ) {
00259             Element elt = children.get(i);
00260             Element parent = elt.getParentElement();
00261
00262             while( ! filter( elt, values ) ) {
00263                 if( ! elt.getName().equals(parent.getName()) ) {
00264                     children = eTag.getChildren();
00265                     i--;
00266                     break;
00267                 }
00268                 elt = parent;
00269             }
00270             i++;
00271         }
00272     }
00273
00274     private static boolean filter( Element eTag, String[] values ) {
00275         if (values.length == 0) {
00276             return true;
00277         }
00278         if (Arrays.binarySearch(values, eTag.getAttributeValue("name")) < 0) {
00279
00280             eTag.detach();
00281             return false;
00282         } else {
00283             List children = eTag.getChildren();
00284             for (int i = 0; i < children.size(); i++) {
00285                 Element child = (Element) children.get(i);
00286                 Element parent = child.getParentElement();
00287                 while( ! filter(child, values) ) {
00288                     child = parent;
00289                 }
00290             }
00291             return true;
00292         }
00293     }
00294
00300     public static void printOut(Document doc) {
00301         XMLOutputter xmlOutputter = new XMLOutputter(Format.getPrettyFormat());
00302         try {
00303             xmlOutputter.output(doc, System.out);
00304         } catch (IOException ex) {
00305             ex.printStackTrace();
00306         }
00307     }
00308 }
