org/objectweb/proactive/ext/webservices/wsdl/WSDLGenerator.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.webservices.wsdl;
00032
00033 import java.io.IOException;
00034 import java.io.StringWriter;
00035 import java.util.Vector;
00036
00037 import javax.wsdl.WSDLException;
00038 import javax.xml.parsers.ParserConfigurationException;
00039
00040 import org.apache.axis.wsdl.fromJava.Emitter;
00041 import org.objectweb.proactive.ext.webservices.WSConstants;
00042 import org.xml.sax.SAXException;
00043
00044
00048 public class WSDLGenerator extends WSConstants {
00049
00059     public static String getWSDL(Class c, String serviceName, String urlRouter,
00060         String documentation, String[] methods) {
00061         StringWriter sw = new StringWriter();
00062         String namespace = serviceName;
00063
00064         try {
00065             Emitter emitter = new Emitter();
00066
00067             emitter.setDisallowedMethods(disallowedMethods);
00068
00069             if (methods != null) {
00070                 Vector allowedMethods = new Vector(methods.length);
00071                 for (int i = 0; i < methods.length; i++) {
00072                     allowedMethods.addElement(methods[i]);
00073                 }
00074                 emitter.setAllowedMethods(allowedMethods);
00075             }
00076
00077             //            TypeMappingRegistryImpl tmr = new TypeMappin gRegistryImpl();
00078             //            emitter.setTypeMappingRegistry(tmr);
00079             emitter.setLocationUrl(urlRouter);
00080             emitter.setIntfNamespace(namespace);
00081             emitter.setImplNamespace(namespace);
00082             emitter.setCls(c);
00083             emitter.setServiceElementName(serviceName);
00084
00085             String wsdl = emitter.emitToString(Emitter.MODE_ALL);
00086             System.out.println(wsdl);
00087             return wsdl;
00088         } catch (WSDLException e) {
00089             e.printStackTrace();
00090         } catch (IOException e) {
00091             //e.printStackTrace();
00092         } catch (SAXException e) {
00093             e.printStackTrace();
00094         } catch (ParserConfigurationException e) {
00095             e.printStackTrace();
00096         }
00097
00098         return null;
00099     }
00100 }
Generated on Mon Jan 22 15:16:11 2007 for ProActive by  doxygen 1.5.1
