00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.webservices; 00032 00033 import java.lang.reflect.Array; 00034 import java.math.BigDecimal; 00035 import java.util.Date; 00036 import java.util.Enumeration; 00037 import java.util.GregorianCalendar; 00038 import java.util.Hashtable; 00039 import java.util.Map; 00040 import java.util.Vector; 00041 00042 import org.apache.soap.util.xml.QName; 00043 00044 00049 public class WSConstants { 00050 public static final String PROACTIVE_PROVIDER = "org.objectweb.proactive.ext.webservices.soap.ProActiveProvider"; 00051 public static final String PROACTIVE_STUB = "Stub"; 00052 public static final String WSDL_FILE = "Wsdl"; 00053 public static final String ROUTER = "/soap/servlet/rpcrouter"; 00054 public static final String DOCUMENTATION = "ProActive Active Object"; 00055 public static final String COMPONENT_INTERFACE = "Compoment Interface"; 00056 public static final String URL_PUBLICATION = "URL"; 00057 public static final Vector<String> disallowedMethods = new Vector<String>(); 00058 00059 static { 00060 disallowedMethods.addElement("equals"); 00061 disallowedMethods.addElement("toString"); 00062 disallowedMethods.addElement("runActivity"); 00063 disallowedMethods.addElement("setProxy"); 00064 disallowedMethods.addElement("getProxy"); 00065 disallowedMethods.addElement("setFcItfName"); 00066 disallowedMethods.addElement("isFcInternalItf"); 00067 disallowedMethods.addElement("setFcOwner"); 00068 disallowedMethods.addElement("setFcIsInternal"); 00069 disallowedMethods.addElement("getFcItfName"); 00070 disallowedMethods.addElement("getFcItfType"); 00071 disallowedMethods.addElement("getFcItfOwner"); 00072 disallowedMethods.addElement("isFcInternalItf"); 00073 disallowedMethods.addElement("setFcItfImpl"); 00074 disallowedMethods.addElement("getFcItfImpl"); 00075 disallowedMethods.addElement("setFcType"); 00076 disallowedMethods.addElement("getFcItfImpl"); 00077 disallowedMethods.addElement("getFcItfImpl"); 00078 disallowedMethods.addElement("wait"); 00079 disallowedMethods.addElement("notify"); 00080 disallowedMethods.addElement("notifyAll"); 00081 disallowedMethods.addElement("getClass"); 00082 disallowedMethods.addElement("hashCode"); 00083 } 00084 00085 /* A vector containing all supported types by Apache Soap */ 00086 protected static Vector<Class> supportedTypes = new Vector<Class>(); 00087 00088 static { 00089 supportedTypes.addElement(String.class); 00090 supportedTypes.addElement(Boolean.class); 00091 supportedTypes.addElement(Boolean.TYPE); 00092 supportedTypes.addElement(Double.class); 00093 supportedTypes.addElement(Double.TYPE); 00094 supportedTypes.addElement(Long.class); 00095 supportedTypes.addElement(Long.TYPE); 00096 supportedTypes.addElement(Float.class); 00097 supportedTypes.addElement(Float.TYPE); 00098 supportedTypes.addElement(Integer.class); 00099 supportedTypes.addElement(Integer.TYPE); 00100 supportedTypes.addElement(Short.class); 00101 supportedTypes.addElement(Byte.class); 00102 supportedTypes.addElement(Byte.TYPE); 00103 supportedTypes.addElement(BigDecimal.class); 00104 supportedTypes.addElement(GregorianCalendar.class); 00105 supportedTypes.addElement(Date.class); 00106 supportedTypes.addElement(QName.class); 00107 supportedTypes.addElement(Array.newInstance(Byte.TYPE, 0).getClass()); 00108 supportedTypes.addElement(Array.newInstance(Boolean.TYPE, 0).getClass()); 00109 supportedTypes.addElement(Array.newInstance(Double.TYPE, 0).getClass()); 00110 supportedTypes.addElement(Array.newInstance(Long.TYPE, 0).getClass()); 00111 supportedTypes.addElement(Array.newInstance(Float.TYPE, 0).getClass()); 00112 supportedTypes.addElement(Array.newInstance(Integer.TYPE, 0).getClass()); 00113 supportedTypes.addElement(Array.newInstance(Object.class, 0).getClass()); 00114 supportedTypes.addElement(Vector.class); 00115 supportedTypes.addElement(Hashtable.class); 00116 supportedTypes.addElement(Map.class); 00117 supportedTypes.addElement(Enumeration.class); 00118 } 00119 }
1.5.1
